Date: 02/25/2017 08:45 pm
Date: 10/02/2017 02:16 pm
Date: 02/21/2017 06:29 am
NOS Sedan decklid
Date: 10/23/2019 11:51 am
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
Seeking parts
Date: 10/18/2020 10:35 am
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 02/21/2022 11:11 pm
  • Online today: 553
  • Guests: 433
  • Total: 433
Taking the turbo plunge!
Started by 76hotrodpinto, January 27, 2015, 11:59:24 PM
Rebolting73
I have often pondered the hood clearance issue.  What if you just popped in the whole running turbo and cut a hillbilly hatch in the  hood and covered it with a scoop?  If you had a donor hood, you could play the turbo game before getting in too deep.  Going turbo is like the children's' song about the old woman that swallowed a fly...  Running a fuel injected 2.3 and T5 is such a huge upgrade that it really raises questions about running a turbo.  I wanted a turbo Pinto and was 100% in from the start, but it really took a ton of extra work to stuff it under the hood.  I had to do all the stuff that 65Shelby just said and plumb my intercooler down and around the front.  If you decided the turbo was not worth all the extra headache to get under a hood, you still have EEC IV, fuel injection and an overdrive transmission.
You're going to have hood clearance problems regardless of how you change the intercooler location or plumbing because it's the intake manifold/TB/TB linkage that hits the hood. The only way around that is to use a "rotated" short upper intake that faces forward and change the plumbing. The rotated upper will also require either eliminating the EGR tube or fabricating a new one.
76hotrodpinto
Me too. I haven't done something so out of my realm, in a long time, as far as motors go.
dianne
Pinto_one has some great advise. I'm glad I'm doing the EFI to be honest, but kind of wish I was doing the turbo. I am looking forward to your project to be honest!
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
76hotrodpinto
So rather than start butchering my factory turbo setup, that goes over the head and will cause hood clearance problems, I'm looking in to other options I've seen in pics that route the pluming forward through the core support, through an intercooler, and back through the other side of the core support. I feel this design is just cleaner looking and less of a pain in the posterior.
Now this all makes me a little nervous as I'm new to the turbo world. I went with this motor because it was touted as a good way to get one going without having to blow through a few blocks learning. Can I do this type of setup, and still not get in over my head with new tuning issues? I feel I have a good grasp on this factory efi/turbo, but it's pretty basic. Does this change everything tuning-wise? Or just some extra plumbing to get around the motor,with maybe some minor tuning changes. Not trying to go bigger... yet... just clean and simple.
76hotrodpinto
Hmmm... never tried that stuff. And it's at auto parts stores?
go get a can of aircraft aluminum  stripper at the local parts store..10 bucks
76hotrodpinto
I had decided to polish up the cast valve cover and put it on a motor that is actually fuel injected and turbo. I thought I'd just blast the paint off and get polishing. I was wrong, What the hell is that paint made of?! I started with soda... not even a chip. So I prepped for some hard media... nothing. I've blasted through powder coating and plastic coating, but damn! It won't run right if the valve cover isn't shiny!
76hotrodpinto
Perfect, thanks. I think I'll set the turbo motor on to the trans that's in the car to get it settled in, then swap out the old trans for the t5 afterwards. Less to guess that way.
If a picture is worth a thousand words hopefully this will help. Thought I had a picture of the opening, but I don't.  Anyway, the tunnel just needs to be cut forward about 3".  The cover I used is from the Turbo Coupe, just hammered to fit. It covered the whole opening.
  I shortened  the shifter (it is too high) by cutting and welding it and then made the plate to move it rearward (it is too far forward). I'm 6ft. and prefer the seat back and leaned.   Getting the shifter right is tricky. The angles need to be just right otherwise the motion becomes awkward. I could still use it back 2"-3" ideally. But, where it is..., is the compromise one must accept.  I tried angling it by pivoting on the lower bolt, but that is when the awkwardness started.
It was about 6 years ago and I don't recall the install method. But, I'm not an engine/Trans as one piece kind of guy.  So I know it wasn't that. Which went first engine or trans I don't exactly recall.  With the tight fitting I'm guessing I put the trans to the (dangling) motor before I welded the motor mount in.
76hotrodpinto
I guess I can count myself lucky to have the 76. Even though I lust for an early model! On the subject of the t5 install, is the shifter offset consistent enough that someone could have a template or just just a few measurements they can share with me? Or is it a try and see type scenario? And which way is going to be easier, given I don't have spiffy car lift, dropping the motor/tranny married, or individually?
Quote from: Wittsend on January 29, 2015, 12:54:48 PM
Dianne,
Putting a 2.3 (Turbo) in a '71-'73 car is like driving a bus through a narrow ally. The problems that the '71-73 cars have are:
1. The existing motor mounts need to be cut out and the 2.3 mount need to be welded in.  The tricky part is the pan clearance at the rack and intake plumbing at the top with the hood (on turbo and I assume NA injected cars).  There is about 3/16" clearance at the top and bottom. I have the lowered center section valve cover/intake system and I still filed the top of the throttle body as much as I dare to get the 3/16" clearance. SO..., before the motor mounts get welded in you have to be dead sure about their placement.  I had my engine in/out 7 times before I was willing to commit.  I see you have a '73 like I have. This car has a one year only steering rack where the pinion housing is rather bulbous.  I both hammered the oil pan and filed the pinion housing for clearance (do at your own risk).
2. Ideally you will run a larger than the stock 17" radiator.  To get the Pinto 20" radiator to fit you need to widen the opening. There are likely other options, but you should enlarge the opening for full air flow, not just put in a larger radiator with restricted air flow. Related is the fact that the '71-'73 cars have a shorter engine bay and clearance between the water pump nose and the radiator is about 3/8". I opted to run a "pusher" fan from the front.
Otherwise the other alterations mentioned are needed for all Pinto's.
Hmm, all reasons why I want to stay with a 2.0L EAO or Cossie YBG . I had installed a 4 core radiator, and a Pusher fan in front of the Rad, my competition accused me of turning on the fan to increase my speed and lower my times while racing ;D  Never overheated in Sacto Summers at autocross with fixed fan on W/ Pump removed..
If you buy the goodies From Burton in UK, you can install a 2.3L Duratec from a Focus and have easy 150Hp with little mods and great Open hood Penache'
Lots of options, all it takes is money and sweat! 8)
Dianne,
dianne
Ummm, so mine is going to have issues?
Vehicles:
76hotrodpinto
Quote from: Wittsend on January 28, 2015, 02:53:51 PM
The 74 and up cars, which you obviously have are a lot easier. Rack clearances, motor mounts and radiator size options are not problems you will encounter.
  There is the battery tray issue. My 73 was badly rusted so I just put in a new panel that was advantageous to a turbo. Options are the trunk or the drivers front (move the washer tank). Be aware of the alternator or other accessories on that side if you use the battery in the front.
There is a bolt (stud) issue on the outer exhaust where it turns 90 degrees downward. Shorten the stud as much as reasonable and possibly drill a hole to facilitate tightening. From there I used the stock T/C downpipe and had some clearance issues with the frame rail. Slightly flattening the out edge fixed that.
I have the 87-88 intercooler in my '73 and other than the scoop to feed the intercooler the hood closes without issue - BARELY and I do mean BARELY.  Your engine has the taller center section of the valve cover and that might raise the air plumbing..
I used the fan motor from an MG (reverse the polarity) and have sufficient exhaust clearance. Some opt for the A/C model that puts the motor in the interior.
The T-5 has clearance issues (if you use the bell crank) with the cable and the crossmember. A small offsetting plate fixes that. The drive shaft is dependent upon the rearend used.  I went from a /C-4/6.75" rear to a T-5/ 8" rear and the shaft swapped right over.
Mounting the fuel pump, return lines, harness etc. you just sort as you go.
I did a two part write-up on my '73 wagon swap using a stock '88 T/C engine - T-5.  You might glean something from it.
http://www.fordpinto.com/index.php?topic=11908.msg76893#msg76893  http://www.fordpinto.com/index.php?topic=11909.msg76894#msg76894
That's just the type of stuff I'm looking for. Thank you!
76hotrodpinto
Quote from: dianne on January 28, 2015, 07:19:38 AM
I think you should rip that turbo stuff off and send it to me so you can have a nice EFI ;-)  LOL
Pictures also as you do it!!! :D
I'm so bad about the picture thing. I'm lucky to get a before and after. I just don't think to stop and take pics. I'll try though. Without the turbo, I wouldn't even want the efi.
dianne
Vehicles:
76hotrodpinto
I'm shining up this motor...
And stuffing it in here!
I've done a ton of motor swaps, but this will be the first turbo. The motor has been put in a courier truck, and run, before pulled. Married to a t5. I have questions about some clearances. Will my hood close? How about heater motor and battery? I'm familiar with most trans. issues I will encounter, I think. And of course I will be looking to max out the hp on this setup, but let's get her in there first. How about some often overlooked issues? I understand this is a good motor to learn the art of the turbo, without to much financial hardship. Please and thank you!
