72 Pinto parts
Date: 12/04/2018 09:56 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
Electrical
Date: 03/29/2017 11:37 am
Date: 01/23/2017 07:41 am
convert to stick
Date: 05/19/2018 09:26 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
  • Online today: 586
  • Guests: 520
  • Total: 520
New project... 1980 Runabout
Yup it is. Especially since the brake issue isn't on the right rear that hasn't been touched but the left rear that was already fixed with a new wheel cylinder and newer shoes. Gotta buy a new pair for the right rear so the left rear shoes will be replaced as well. More than likely new drums as well since I'm guessing the old ones will be cooked thanks to the left rear issue.
Sometimes it's good to walk away and do something different, you have a better frame of mind when you come back to it later..
No not giving up. Just parking the thing for a while.
Quote from: r4pinto on November 10, 2016, 06:37:09 PM
Unfortunately I don't know that. Brakes are this cars sore spot. I'm having issues with all my cars and am at a breaking point where I've had enough
Yeah, I know... but you've come way too far to give up now!
Bum deal on missing the car show, but at least you'll know you're safe once it's all done!
Parked again. Left rear locked up again. Yesterday I almost hit someone when I had to stop quick off the freeway due to the left rear locking up. I am going to cut the brake cable so it doesn't seize again and will replace it when I have the cash. When I got to work I could smell burning brakes at the left rear. I am going to put on new shoes all around and will more than likely need a new drum. It will probably be burned up after the excessive heat. Feeling pretty fed up currently. I am missing a car show Saturday because of the latest brake problems. Can't spend the money on parts since I have to fix my impala so it stops leaking oil.
I did. No luck other than her DOB and address
Google that name. You will probably get tons of possibilities, but you may find her.
Hahaha I do that all the time at work. Last week I mentioned Cher and someone didn't know the song "if I could turn back time"
Quote from: r4pinto on November 07, 2016, 07:35:51 AM
I had to look her up.
LOL  -  I should have known I was dating myself with that remark!  I keep forgetting how much younger than me you are. ;D
Quote from: dga57 on November 06, 2016, 11:46:01 PM
It's a shame it wasn't Linda Lovelace... then you'd have a really good story to go with your Pinto!!!
Dwayne ;D
I had to look her up. If that was the case I'd exploit it and probably be able to get a decent buck out of the car. Well maybe not but I'd try . I did find out she was born in 1984 which would make her about 16 in 2001. Trying to locate the previous owner and dob is only thing I could locate. Oh well woulda been cool to talk to a previous owner that took the car to a car show before pintos were considered cool.
Quote from: Reeves1 on November 07, 2016, 06:37:31 AM
Even new vehicles have brake troubles.
My 2007 F-350 had the rear calipers locked twice, before selling it with 165,000 KM on it.
My 2012 has done it twice, before it had 100,000 KM on it.
That goes for a lot lot things these days, just because it's new don't always mean it's good.
Dwayne ;D
That would have made it a REAL classic then, lol..
Dwayne ;D
makes me wonder what I will find next.
So I did forget to mention... I installed the new passenger seat buckle. Like the driver seat buckle they are a little shorter but in much better shape than the original seat belt buckles. The originals were all faded and the plastic cover was all broke and nasty. When I did that I found something hiding under the seat. A pay stub for the person that owned it prior to the idiot I bought the car off of, as well as a windshield card. To be exact it is a card that you stick in the window for a car show. I am guessing it was from 2001 since the pay stub from Kroger was also with it. I tried to look up the person on facebook but they aren't on there. I figured if I could locate them I could get some info on the car since they owned it. Like find out why holes were drilled in to the dash and what not.
It's pretty cool to see someone else had taken this car to car shows in 2001, and has got me thinking. May be a bit crazy but I am going to find out the date of that same car show for 2017 and take it there.
Yeah, I know you're right about it. Had it inspected ok I would have installed it. But since I saw minimal seepage I won't chance it. In the mean time the car does stop fine. The brakes on the car are ok, just older on the right rear. Good solid pedal and fresh fluid is hopefully a good combination
I think, in the long run, you won't regret buying new.  I know prices can be somewhat daunting at times, but you can't really put a price tag on safety.
Pulled the wheel off the 77 expecting to be able to grab the brake shoes and wheel cylinder. NOPE!!! Brake shoes coated in greasy grime. Wheel cylinder didn't even have bolts in the back so it wasn't secured to the backing plate. Cylinder looked ok on the outside but peeled back the boot & slight signs of leakage. Removed the piston & it had some rust as well. I will be buying a new wheel cylinder and set of new shoes. Hopefully I can find them at a lower price than I am seeing. At least I was able to save the hardware since it was replaced when I bought the 77.
Yup I know what you mean. First thing I am going to do is inspect it for signs of leakage to be sure. Don't want or need a repeat. The one on the car is good but old and won't bleed which is why I am replacing it. Very solid pedal so no air but rather be sure it's good.
Well, like I said just be careful, after all it's 4 years old already so who knows??..
Quote from: 74 PintoWagon on November 03, 2016, 09:49:56 PM
Just be careful driving, personally I would freshen up the whole system with new parts for peace of mind..
Both front calipers have been replaced, as have the hoses. Fresh fluid had been put in the master cylinder and the car had a good solid pedal. It should be ok until Saturday when I swap wheel cylinders on the right rear. If I didn't know for sure the age of the right rear cylinder from the 77 I wouldn't use it but know it was replaced in June 2012 when dad and I had a bad brake line and thought it was the wheel cylinder.
Well, once again the car is stopping. I installed a brand new wheel cylinder on the left rear and readjusted the shoes. Took her for a test drive and at first they did grab but there may have been some residual brake clean on the shoes and drum. Only locked up twice and was very little the second time. The car no longer pulls when stopping and has a good solid pedal. This weekend I am going to get the right rear addressed with the newer wheel cylinder from the 77 and those new shoes. They were last installed in 2012 so should be good... in theory. I thought the left rear wheel cylinder was good and it lasted all of two weeks before failing. Driving the car to work tomorrow so we'll see what happens.
The car is a trainwreck. I replaced the bad left front caliper only to have the left rear lock up. Shoes wouldn't back off the drum and found the leading shoe was in place of the trailing shoe. Took them off to find a leaky wheel cylinder. I just installed it two weeks ago from the 77. This car hates moving.
Quote from: r4pinto on October 30, 2016, 12:22:25 PM
Drove her to a car show. Hit 65 and not a shake at all
Awesome..
Caliper replaced so it's not locking up but another issue. This with the left rear. It is locking up which is causing the rear to kick out. Think it's just over adjusted causing the shoes to grab too quickly. We will see if an adjustment helps.
So I ran into another problem. The left front caliper is locking up. Gotta replace it before I drive the car any more. Another car show Saturday and will also be pulling the sending unit to check it out. I put in $5 and it jumped up to over half tank but was below 1/4 tank close to empty.
