Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
V8 rear end
Date: 04/12/2018 10:57 am
Date: 12/13/2016 10:25 am
Date: 03/06/2017 01:24 am
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Date: 08/09/2018 11:09 am
Date: 10/02/2017 02:16 pm
  • Online today: 295
  • Guests: 203
  • Total: 203
Project Europa Killer
Started by Snow Wolf, June 14, 2012, 12:56:21 AM
jackal9
Do you happen to know what the lincoln engine is off hand? I have searched and searched to no avail, thanks!
Jack
Grumpy
This is the Lincoln LS/Thunderbird 3.9 V8(290 hp stock)
And this is the 400 hp 4.2 supercharged Jaguar AJ V8...
Notice the similarity? (hint, Ford owned Jaguar at the time). And if you look at the oil pan it seems designed to drop right in to a Pinto.
Grumpy 8)
79 Pinto Hatch, Yellow w/White Pony stripes, Pony wheels, 6650 miles
Grumpy
Here's an aluminum V8 that isn't cast of pure money...
Ford owned Rover when the 4.0 and 4.6 motor was in them. I don't know where everybody is getting their engine weights at, but this motor in stock 200 hp(about 280 ft lbs)4.6 form weights almost exactly the same as the 2.3. Accessories add weight to both, but without accessories both weight about 315 pounds(the 2.3 is actually about 10 pounds heavier). The Rover can be stroked to 5.0 and built to 350 or so for NA, but it is a bit limited in RPM(6000 max without injections of pure gold). I'm thinking a low compression torque motor with a smallish turbo(instant boost, about 15 lbs), near stock cam and forged pistons. Methanol/water injection instead of intercoolers and hide the turbo where the right rear seat used to be, boxed in and isolated from the interior, the seat back makes an excellent lid. It dresses up kind of nice, too...
Notice the Boss 302ish valve covers(stock on 3.9, like this, and all 4.0 and 4.6 models, though they have no distributors at all)and the distributor more or less in the right place? Even the exhausts are spaced nearly correctly. Technically, it's a Ford, visually it looks like a Ford(if you squint) and you won't even have to change the front springs. and they are torque monsters! Given a choice of huge low end torque and modest top end power or weak low end torque and high horsepower up high, take the torque every time(why do you think muscle cars came with truck engines?). Torque moves the car while horsepower is waiting on rpm, add a turbo to boost the top end and you have Ecoboost, the best of both worlds.
Grumpy 8)
PintoMaverick
If your still thinking about this, have you considered using a 3.7 engine and trans from a new Mustang? That's 305 hp stock. Adding a turbo would get you in the hp range your looking for. You can get those complete takeout's with trans for 2-3 grand.
I like your avatar by the way!
vonkysmeed
there is an aluminum windsor to save weight, but that is cubic dollars
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
Quote from: Snow Wolf on June 20, 2012, 01:52:04 PM
well i'm sure it'll hellishly fast....
It remains to be seen. On paper it should handle like a roadracer, top out near 190 mph & run low 9's with a drag suspension installed. I'll settle for street drivability & a tolerable ride that doesn't jar my teeth loose.
Snow Wolf
Cars I own:
*87 Ford Ranger. 2.3 was EFI now carb and loving it. <-- my baby
*75 Chevy Nova 250 I6. nice cruiser.
Past cars i've owned:
*65 Ford mustang 200 I6.
*68 Ford Ranchero 302.
*78 Ford F350 Camper Special Ranger XLT with a 460.
*74 Dodge Charger HT with a 318.
and that's all of them.
I bought it new for 28K & dropped another 15K on paint & body mods less than a year later. Engine/trans. set me back nearly 15K so far & over 7K on wheels/tires/brakes/suspension plus so much other stuff I'm forgetting & I'm still not through yet. It's amazing how fast it adds up.....
Snow Wolf
70 wow 70K that's alot...
the build i had in mind would of been way under 20k.
but i think i could do the fenders with fiberglass.
as for the suspension i was thinking of robbing a foxbody mustang of its.
Cars I own:
Quote from: Snow Wolf on June 18, 2012, 11:29:18 PM
something like this?
how would you go about doing that?
Thats exactly what I'm referring to. I was planning to do just that to my '80 Runabout before I sank over 70K into my "07 Mustang to install an adjustable corner carving suspension & over 800 RWHP to push me close tp 200 MPH top speeds.
I was going to use 2 pairs of '79-'80 Pinto fenders to form my widebody panels from. It really isn't that difficult to visualize how to cut & form the fender skins to the perfect shape if you make cardboard templates & tape them to the body to get the shape right. My build was going to use the Jag IRS that I picked up for $200. It's 63" wide & comes with 10" disc brakes & parking brakes already. My front suspension was just going to be the crossmember & adjustabe A-arms out of a wrecked late model stock car that was 62" wide & had 11" disc brakes already on it.  Stock Pinto is 57" width front & rear roughly. The rest of the width I wanted was coming via wheel offsets.
i don't mean any disrespect, but it means CUBIC MONEY.  if you want a race car then build one. you will not get what you say you desire by cutting ANY corners
Snow Wolf
Quotewith custom wide body panels to cover the tires.
Cars I own:
A Pinto suspension isn't the hot suspension for corner carving PERIOD! It's respectable but if I were putting a corner carver together under a Pinto body I'd fab a wider front suspension out of NASCAR take-offs & a wider axle out back with trailing arms & a watts link. A built 2.3  EFI turbo/5 speed set back 10 inches, 9 inch wide front & 10 inch rear wheels with custom wide body panels to cover the tires.
Basically I'd want to add a foot to the width, increase braking, stiffen it up with roll cage & put some fat sway bars under it.
Not even doable.. Without real Bucks See attached Photo
Snow Wolf
it's not the engine that would make it a track car.... but to race in a SCCA class that will fit this kind of build i would need a cage. plus the car would be gutted.... basically i was looking at something like this but with a v8 in it ...
i don't know a lot of road race tracks around where i live. and on top of that i'm sure the entry fees are more then your entry fees at a local nhra/ihra tracks.
i can race in ETK/Trophy class at 75-80 dragway at Monrovia MD for like 30-40 dollars. but i heard SCCA is a bit more or i should say a lot more money. <--- but i could be wrong. and if i am let me know.
Cars I own:
ive got less than your initial investment in just the motor in a 2.3turbo pinto(car and all) and am over your target hp level and can drive it anywhere and all the while whooping up on v8s and getting near 30mpg... do that with your351..... :D
Snow Wolf
ok... more i dive into this, more i have to ask "is it worth it"...
yes it would be nice to have a crazy fast car. but for this project it would end up being a strait up race car. and i'm not a fan of the hatchback (sorry). and you got the money that it will take, and the time it will take... all for a car that i could only use at a road race course.
think i should abandon this project before a wast a ton of money in something that i might not like.... and go ahead and build some that i would like. like an old school tuner but do it with a pinto cruiser wagon....
but i do like the idea of this kick@ss road racing monster. so what i might do is continue this build on paper only.
what do you all think.....
Cars I own:
Snow Wolf
well... i'm still looking into it. i got to look a the price too. i can get a windsor small block that will put out my target HP (350-400) for about $7000. and that's carb to oil pan. all new, done, just need to put into car and break in.
but i got to look in and price out a carb-ed turbo 2.3 build. and see how much it will cost, and if it's worth it.
Quote from: Srt on June 16, 2012, 04:26:04 AM
this what you're looking to 'kill'?
yes... not that one, but yes that car. what i'm really aiming for are the few d!cks on the Europa forum (a yahoo group). how they treated me was uncalled for.
here was one of the last messages i got.
QuoteI wasn't addressing Kris, I was addressing Mike about a timeline pertinent tp the development of the AC/Cobra automobile , nothing more.
I have no interest in Kris' street racing/ dick wagging agenda, whether alone, or backed by a "team" of fellow dick-waggers.
Kris, please, stick a fork in this mess; it's done!
and i never talked about street racing and i did not brag or boast. all i did was try to see if i could do a budget/junkyard build. starting with a low hp 289. (210 - 250 hp). and all i got was defecated on, over and over. i have never been treated like that on any other forums. never.
so to get even with them, i'm going to build a pinto (maybe) to out do my original plans for the Europa.
but before i start to throw money around, i want to do research and find out as much info as i can for this build.
thank you... looking into it now...
Cars I own:
Quote from: Snow Wolf on June 15, 2012, 10:43:28 PM
still looking but going through price shock... god d@mn!!! a little warring to this hillbilly would of been nice.... CSU 750BT. a 750cfm blow through carb... new from CSU is $925.00 just wow.
Yah those carbs are expensive But they are nice there are write ups on the net on how to convert holleys to blow thru by yourself.http://web.archive.org/web/20031025025448/http://www.hangar18fabrication.com/blowthru.html
Another route other then blow thru Is a fully enclosed carb box then you just need "mechanical secondaries, .120 needle and seat plus nitrophyll float set". http://www.allfordmustangs.com/forums/attachments/drag-racing/146900d1326343350-will-my-turbo-plans-work-help-paxton.jpg thats a pic of a paxton carb box.
Oh and as for you havent seen a fast carbed 2.3 turbo yet I got one person for you to look up. Joe laramee his street car and drag pinto are both blow thru carbed 2.3s. Heres his drag car right before it got wrecked but this aint even turned up all the way yet.
Also his "Street car" has went 9s.
http://www.youtube.com/watch?v=3e-kxluQL78
Snow Wolf
Cars I own:
racer99
CSU or C&S for a blow thru,I have one from each and both work well.
The turbo wagon is going draw thru but if I cant get it to run right
it will be blow thru in a week.
Go to the turboforums.com and lurk in the carb section.
Snow Wolf
ok i don't know alot about turbos. a supercharger (an old school blower style) you can put the carb right on top. but the a turbo you need to do or have a blow through carb. i think that's what they call them. carbureted turbos i just know a little bit about them. but i think i can rap my head around that. just need to know how it works. being under boost and not vacuum.
and can i get enough hp out of it. i never seen a high power carbureted 2.3 turbo. all the fast 2.3 turbos i have ever seen was EFI...
but i do like your idea. but i will need more info to see if it can be done.
Cars I own:
Quote from: Snow Wolf on June 15, 2012, 04:43:37 PM
  if i knew how to play with fuel injection i would just do a bad@ss 2.3 turbo.
Im all for you spanking a lotus Europa with a pinto cause I think those europa are butt ugly personally. lol
That being said why not build a Carbed 2.3 turbo?
Snow Wolf
thanks for the idea. there's nothing wrong with it. BUT, BUT i'm sure it's EFI. i can build it. but if i do can you tune it for FREE....
the requirements for this build.
first: a light weight car: i'm thinking the pinto
2nd: a decent amount of power: with a car that weighs around what the pinto weighs, it would need to be around 350 to 400 hp
3rd: being true: a ford engine goes in a ford, a chevy engine goes into a chevy. sorry that's just me...
4th: it has to be cheap and reliable: and i know a v8 windsor can do that.
5th: i need to be able to work on it, get parts for it, and be able to tune it: so i think a carb-ed 347 or 331 windsor would be the best bet. since i don't know how to tune fuel injection. not a d@mn clue. i was so happy when i got that junk off my ranger and went to carbs.  if i knew how to play with fuel injection i would just do a bad@ss 2.3 turbo. just look at my sig and that well tell you alot about how much i know about EFI. 0.00%...  :-[ sorry i'm so stupid when it comes to that. i can put them in and fix then all day long but i don't know how to tune them.
Cars I own:
82expghost
the duracrap 3.0 can do it for you, its light and i can guarantee you can get 600+ out of it, the company noble sports cars did it and put it in their car, or you could build the cossie engine like cossiepinto, 1:5 ratio shouldnt be hard to hit
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
Snow Wolf
Well first, the Windsor is a light motor. Lighter than Chevy or Dodge small blocks. (except the LS's, but that's aluminum)...
QuoteOh and as for them saying the V8 will make a pinto nose heavy It will no matter what you do cause they just dont sit back in the engine bay like a 4 banger
But that is true. If I can't punch the firewall back a bit, this build is no good... So i'm looking at different classes that will allow that. If any of you know of one let me know about it...
Well I'll say it again. This build is for one thing and one thing only. To blow the doors off of the Europa. Not everyone who owns a Europa is a dick, but there are about 7 of them that I really badly what to shove their words right back into their mouths.  To show them i can build a car that has a horsepower to weight ratio of 1:5 (1 hp for every 5 lbs), in a car that handles, using an old school V8, and being on some kind of a budget.
The Lotus Europa only weighs 1600 lbs and they can be lightened to about 1200 lbs, but most of them build motors that only put out 200 hp, at most. So that's like 1:6 horsepower to weight ratio.
But this build may be pointless; if I can't find a road racing class/bracket/day/ whatever-you-want-to-call-it, like they have in drag racing. In drag racing they have what they call "grudge matches". You just need to come in there on a street night, race what you brung.
Quote from: racer99 on June 15, 2012, 11:23:59 AM
There are catch-all classes in SCCA.
They are regional classes though.
SPU production based under 2.0l
SPO production based over 2.0l
I have ran both as well as A/S ,GT3 and Spec Miata.
thank you for that info.
Cars I own:
racer99
thecustommuffler
Quote from: Reeves1 on June 14, 2012, 05:53:27 AM
V8 will make it nose heavy....not a corner carver.
I`ll second that. My v8 (350 dynoed at 437 on 92) `80 Monza coupe would damn near wanna come around just from straight line braking. The car became dangerous with a posi. I had a 400 trani in it then switched to a TH350 and that helped.
I`m going the route of big block in my Pinto, but cruising the streets to be "the man" and a front wheel pull at the red light is all I`m looking for.
pinto21
How is your 77 project going, get the turbo put in yet? We had a great time at all the tracks we were able to visit, but I really enjoyed the road course track at Summit Point,W.Va. could really get into that type of racing. Check out the stampede on U-tube. Take care.
