Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
Oddsnends
Date: 12/20/2016 10:52 am
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 03/06/2019 06:40 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 02/08/2018 02:26 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
  • Online today: 452
  • Guests: 378
  • Total: 378
Project Europa Killer
Started by Snow Wolf, June 14, 2012, 12:56:21 AM
82expghost
holy crap bigtimmay, remind me not to mess with you, i dont even bother trying to mess with my dressed 2.3 cause i cant move it, while its out thoe i will weigh it so every one knows, i mentioned the 3.0 24v duracrap because of the all alumanim cunstruction and its mabe alittle lighter than 200 not dressed but with intake and exhaust, winds high and puts out quite a bit of power, ls1 is a good choice too thoe, we are guna be putting one in my friends bimmer, those are cheap and so easy and light, just make sure you get the right one, the trucks have diferent cranks and are usualy the cast iron blocks, so get one out tof the 1998 or newer cars, and some of the trucks came supercharged and that will bolt on too, and if you have money to blow, here where i live the company my friend works for made the first 500 ci ls motor and they build them any way you want them.
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
Snow Wolf
got the weight off of http://www.gomog.com/allmorgan/engineweights2.html
Quoteif your in a certain racing class some rules wont allow it.
now see you all are real ppl. i didn't know that, thank you. but is there a class where it's run what you brung? i know in dragracing IHRA & NHRA has them classes but does any of the road racing sanctioning bodies have a class like that?
QuoteV8s are great but I wouldnt touch anything with an Iron block thats a V8 anymore LS1 are super cheap and will flat out spank any mild older smallblock.
no no i can't.... chevy goes with chevy and ford goes with ford .
and hooking up EFI is no biggie. it's tuning it that is the pain in the @ss. i don't know how to remap an ECM. but give me a carb, flathead screwdriver, 3/8 socket, and i can tune that carb for 10 different  motor and 10 different set ups. and each time it will only that 5 minutes.
to me EFI is only good for 2 things. daily drive, or your highest most outer reaches of performance. (more then 2 horsepower per cubic inch without going forced induction)
anyway i like the sound of a high winding 289 over a ls1... <--- a joke but true....
Cars I own:
*87 Ford Ranger. 2.3 was EFI now carb and loving it. <-- my baby
*75 Chevy Nova 250 I6. nice cruiser.
Past cars i've owned:
*65 Ford mustang 200 I6.
*68 Ford Ranchero 302.
*78 Ford F350 Camper Special Ranger XLT with a 460.
*74 Dodge Charger HT with a 318.
and that's all of them.
Quote from: Snow Wolf on June 14, 2012, 01:01:46 PM
but as for a v8 making it noes heavy.... not really the stock 2.0 is HEAVY.
all cast iron to all cast iron. the lima comes in at about 418 lbs and the Windsor (221, 255, 260, 289, 302, stroker's 331 & 347) comes in at about 460 lbs.
I dont know where those qoutes come from cause I have 4-5 2.3s and I can carry them around the garage fully dressed and I have a 351w and a 302 and I can move them around my shop but I can tell you this they are alot heavier then 42 pounts more then the 2.3 oh and the small blocks arent fully dressed like the 2.3.
Oh and as for them saying the V8 will make a pinto nose heavy It will no matter what you do cause they just dont sit back in the engine bay like a 4 banger does only way to get around that is push your firewall back and if your in a certain racing class some rules wont allow it.
V8s are great but I wouldnt touch anything with an Iron block thats a V8 anymore LS1 are super cheap and will flat out spank any mild older smallblock. Oh and yah can run them carb but why would yah want to when a swap harness is only like 7 wires and your done.
Snow Wolf
trust me i've looked into fixing up a 2.3 lima. but it seem to become high dollar after you get above 250 hp. Jon Huber is one of my heroes. runs 8.7's @ 150 with a turbo-ed lima 4-cyl Mustang.
aluminum heads and intake should make up most of the extra 42 lbs, if not more.
oh and i want to KEEP IT OLD SCHOOL. no EFI... carbs only
Cars I own:
82expghost
the duracrap 3.0 with the svt parts on it, its v6 24v dohc over 200hp, lighter than the 2.3 by almost 100 pounds, and hits 8000 rpms no problem, im working on the stuff to make that possible right now in a pinto, had a taurtus with performance parts on it, guy hit me hard enough to total it, silly insurance, your not getting the whole car
id consider (and i am) a turboed duratech,,,,,,, 2.0 or 2.3-2.5 any of them are capable of 400 horse and 9000 rpm......and its aluminum......
V8 will make it nose heavy....not a corner carver.
Snow Wolf
ok i always like the 1980 pinto cruising wagon. i would love to do something like a old school tuner build. you know lowered with Enkei 92's Black with Machined Lip the old school tuner look.
BUT that's not the Europa killer.
The Europa killer is going to be pretty much a road-race car. i would like to keep away from tube chassis. if i can. but going to be gutted, mini tubbed, caged and so on and so on.... looking to put a 350 to 400+ hp Small block ford in it. would like to put a 6 speed richmond trans behind that. but at least the 5 speed. but really would like the 6 speed. then cut down a 9" rear.... well anyway you get the point. i'm thinking about putting all of this in a hatchback. looking at about 5 lbs per horsepower.
but right now the build is only in the planning stage.
you may say "Why build a car like that..." why not. but here the story behind this crazy build. i already posted this in the "FordPinto.com Welcomes YOU!" page... but i'll repeat it here for you all... about 2 months ago i got really interested in the Lotus Europa. i always did like that car. when i was 16, there was one running around Westminster. i thought it was mean looking in an elegant way, but i always thought it would be an expensive car. but not too long ago i found one on Ebay. it only went for $9000. i seen this so i went to look up the value of the Europa. i found out you can pick a good one up for $8000 to $15000. not bad, the first gen mustangs go for more. well anyway, i joined one of the biggest Europa club to find out more info. i got this grate idea to make a budget build V8 Europa. but it was doomed form the start. as soon as i put the words V8 and Europa in the same sentence they started to hound on me. saying i was stupid and didn't know what i was talking about. and that just p!ssed me off. so i am going to build a car that will whoop up on the Europa. I was thinking about using a Ford Fairmant. since it uses almost everything from the Foxbody mustang. and mustang has a sh!t ton of roadracing parts. and the Fairmant was a bit lighter then the mustang. but it is still too heavy. weighing in at 2800 lbs. yes that's too heavy. but the pinto hatchback weighs in at around 2000 to 2100 lbs. and i know you can put a V8 in one relatively easily. and i know there are some road racing parts out there, and ppl who use to race then. so now i'm thinking the pinto is the best car for this build.
so i'm here to learn everything i can about the pinto and what can and can't be done....
Cars I own:
