2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Date: 08/05/2018 01:58 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Date: 01/18/2017 05:35 pm
Date: 07/17/2019 05:23 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
  • Online today: 529
  • Guests: 366
  • Total: 366
72 pangra v8 swap questions
Started by Fehrion_sit, November 03, 2011, 10:03:41 PM
QuoteI hope you an find a complete setup, makes it nice to get everything at once.
:D
built 302w & T-5 going to be pulled (replacing with a B2).
I have motor mounts (71-73) I'd toss in.
Shoot me a PM if interested. Price keeps dropping as Dec storms in on me !
RSM
Sorry Fehrion, I sold the pedal assembly about 3 months ago. An automatic is the way to go when your drag racing...keeps your times consistent. The problem with manual transmissions is that if you miss a gear or have a hard time shifting then your done. Also for street driving just stick in gear and go. Manual transmissions are kool to have and all and a T5 has a nice od 5th gear but I'm all about the 1/4 mile and car shows. I'll keep an eye out for a bell housing for ya...I hope you an find a complete setup, makes it nice to get everything at once.
Quote from: RSM on November 09, 2011, 10:19:55 PM
Push or pull means the way the clutch fork is actuated. A pull type uses a cable and the push type is pushed to engauge/disengauge the clutch. For the pull (cable) type the pivot ball (inside the bell)is on the passenger side and push type has the pivot ball on the drivers side of the bell. If your looking at a bell housing and it has no clutch fork in it...that is how you tell which one it is. I hope that wasn't confusing lol
Mine is cable & on the left.
Fehrion_sit
RSM, you went from manual to automatic, do you still have the clutch pedal assembly? i am going from auto the manual.
about the bellhousing, i should be looking for a t-5 with a cable operated clutch, hopefully i can buy it all as one, they should all bolt to the 289 because it is the same block as a 302.
correct?
RSM
I checked this bell housing...it's not a cable pull.
RSM
In order to use a push type clutch you would have to have either mechanical linkage or a hydraulic clutch setup...cable is the easiest since it's already setup. Even easier is an automatic  ;D
Fehrion_sit
well i just learned something new. im gonna go out on a limb and say a push is probably best for a pinto because it is the path of least resistance?
on a side note, attached is a picture of 1975 mustang II frame mounts i found on craigslist, any thoughts, i think those are what im looking for.
RSM
Fehrion_sit
if parcel post is an option, im all for it!
what is a push or pull type? im assuming the way the clutch is engaged/disengaged?
RSM
I'll have to take a look at it...I'm not sure if it's a push or pull type bell....glad you said something.
Send it Parcel Post for 12 or 13 bucks. I bought an '89 Mustang T5 off Craigslist for $300 & it came with the pull type bell which is the correct one. I think up to '93 will work.
RSM
If its something would actually use you can have it...didn't cost me anything and I'd just wind up selling it for scrap anyways.
Fehrion_sit
so what you have is a small block to t-5 bellhousing, could you get me the part # so i have a good idea of what to look for, id buy it but shipping from AZ would probably be out of this world.
RSM
I'm in Az. It's a small block bell so it will fit anything Windsor. I'll have to take a good look at it since I just pulled the tranny off and set it aside. I'll get a look at it and let you know.
Fehrion_sit
will it bolt up to my 289? ... hydro  clutch or cable,
we are running cable clutch.
how far away are you from PA?
RSM
Do you need a V8 T5 bell housing? I have one I don't need since I'm running an automatic. It came with a tranny I bought for my wifes Mustang we had several years ago.
Fehrion_sit
good good, than i think that is going to become the new plan, according to the web, c5ta-6394-a is a 351 bellhousing to a 4spd toploader (pinto trans will obviously not bolt up to that) and to my understanding neither will a t-5 ... in my opinion ... this is overly complicated haha ... suggestions? i got it all off craigslist, ill just turn around and sell it again.
i am still looking for the clutch pedal/brake pedal assembly. is it true i absolutely need a non power brakes assembly because the fulcrum is different? any thoughts? im really hoping i dont have to modify the headlight lever when i install the new pedals.
Quote from: Cookieboystoys on November 04, 2011, 02:44:30 PM
I have a call into the previous owner to see if they had to modify the firewall or tunnel for the t5.
in the case of my Pangra V8 setup with 302 and t5 - firewall and tunnel did not need to be modified. His words were.... slid right in
Quote from: Fehrion_sit on November 04, 2011, 02:47:06 PM
thankyou cookieboy, another question, does the blower motor coil stick into the fire wall? on the left side, if you are facing the firewall, does that hit the head on the motor?
here is a picture of my motor/blower motor
Fehrion_sit
i can post a picture if needed
Quote from: Fehrion_sit on November 04, 2011, 01:38:20 PM
he used a t-5 and had to do extensive work to the fire wall ... is there any way i can avoid that .... i kind of suspect thats the bellhousing i have x_x
the 302 and t5 in my pangra use a front mount engine plate vs. motor mounts in the standard location... I have a call into the previous owner to see if they had to modify the firewall or tunnel for the t5. I know he didn't build it, had professionals do the work, but he may know. I don't recall anything on the firewall looking out of place, never looked at the tunnel... waiting for a call back from him and will let you know...
send me an email and I will send you a bigger picture. Brian was right, you will need sub frame connectors and I can give you some feedback on how to work this street legal and driveable.  it is easy to make these tough to handle if you go too big.  Your set up should produce somewhere between 220-280 horsepowerd depending on how you build it. More if you put a supercharger, turbo or really port everything and go big with intake and exhaust.  Room wil be your enemy on that sida though. bosspinto@pintostampede.com
Here is a picture of my motor mounts.  They are MustangII.  I saw this car on craigslist, I was going to buy this with a freind and you snatched it up, nice purchase, good luck with the build and I hope to see this car at Carlisle or on a Stampede down the road.
Fehrion_sit
I think you should take a look at this thread, it may help...
here ~>http://www.fordpinto.com/your-project/71-v8-swap-let-the-fun-begin!!/
one thing to keep in mind is that you have a 1972... the 71-73 have a smaller engine bay than the 74 and up Pintos so fitting the V8 in an early Pinto has special considerations . 71pintoracer's build may help you quite a bit and answer a few questions for you.
fast64ranchero
By the looks of the mounts, someone has installed later (74 and up) 2.3 mounts, I'd suggest removing those mounts and installing Mustang II or making your own mount,
72 old V-8 parts Pinto
73 pinto, the nice one...
Fehrion_sit
im not expressing my question in the right way, the motor mounting system has two parts. an engine side, and the corresponding frame side, i do not understand how the frame side is made/modified/bought .... the stock pinto frame mounts are far to narrow to hold a v8...
it's my understanding that if you do not want to twist the car with lots of HP... it's rear frame connectors you should be looking into... not motor mounts
Fehrion_sit
im anticipating close to 300hp, that may be over estimating but id rather be safe than sorry
so... are you thinking 200hp? more? I don't know enough about enging building and parts to know based on your description how much HP to expect out of that build.
