Date: 07/30/2020 11:45 am
Date: 11/12/2020 08:28 pm
80 pinto original
Date: 08/04/2019 10:45 am
Date: 06/25/2021 12:59 am
Date: 07/10/2016 10:17 am
Built 2.0
Date: 10/07/2018 05:27 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 11/23/2017 05:44 pm
  • Online today: 525
  • Guests: 188
  • Total: 188
72 pangra v8 swap questions
Started by Fehrion_sit, November 03, 2011, 10:03:41 PM
RSM
Good deal on the pedals. I saw the other post on the tank after I responded lol.
Fehrion_sit
RSM, i asked the question on a similar fuel tank thread, so now it got bumped to the top, if they dont respond, ill start a new thread. i got my pedals, found a guy on ebay with both brake and clutch (matching out of the same car) so im that much closer!! time to get a lock on a trans
RSM
I have no idea on the Ranger stuff. As far as gas tanks, I know that subject has been brought up before and I know don't remember if Mustang tanks are the same or not. You might want to start a new thread and ask if anyone knows.
Fehrion_sit
i havent had the drums off the 8" but when i get to the 5 lug axle ill be using the ranger drums, do you happen to know what year ranger drum is used for that? i wish the brake hardware from the small axle (stock one) was interchangable because it looks like it is all brand new.
have any experience with fuel tanks, we found a replacement one on amazon for a reasonable price, shape wise it matchs up exactly, but the listing does have a year listed.
http://www.amazon.com/Spectra-Premium-F80A-Mustang-Pinto/dp/B0049QQ49W/ref=au_pf_pfg_s?ie=UTF8&Model=Pinto%7C693&n=15684181&s=automotive&Make=Ford%7C54&Year=1972%7C1972&vehicleType=automotive&newCar=1&carId=001
thats the tank ^^^^
RSM
Other than replacing the axle bearings & seals and giving the axles a good once over, not much else to do other than figure what gear ratio you want if your thinking about changing it. If your sticking with what gears you have then probably the best thing to do is take the center section to a gear shop and have it inspected unless you have all the tools to check everything unless you know the axle is in good shape. Give it a good cleaning and check for any cracks then a fresh coat of paint if it everything checks out ok. How do the brakes look?
Fehrion_sit
RSM, any tips or tricks for refreshing the rear axle? mines at 8" ?
im leaning hard toward those heads so i can spend more in other places, ive done multiple equations (combustion ratio) to make sure i get my 10:1 which is my main concern, im looking hard into transmissions right now, trying to find the right t-5 and parts
RSM
I've never heard of the heads before. I tried reading the article but the second page was missing altogether but it sounds like they got good results. Looks like the company has been around since 2007 so if they are still in business they must be doing something right. At that price I'd be tempted to buy a pair and try them on my 347.
Fehrion_sit
why hello guys, well im now the proud owner of several parts
-one 8" rear axle, drums and all + drive shaft from a 75 wagon
- mII oil pan, a little rough but hopefully repairable
-mII exhaust manifolds
- pinto v8 swap mounts came in the mail too!!!
all from one yard run! hahha
ill post pics soon, but if i wanted to unload the mustangII manifolds, whats my asking price, they are untouched, no rust no damage?
George Davis
it was a LONG time ago, but when i put the 289, 4speed (top loader) in the Gold Bee Pangra Race car i used a Herbert and Meek kit, it came with all the mounts including the trans mount and was a total bolt in, the headers were weird but fit. I did have to use a sledge to dimple the firewall at the bellhousing but nothing else. I used a clutch cable but forgot where i got it from and it was reverse mounted and never worked correctly as the fulcrum and ratio made the pedal so stiff a bodybuilder whould have trouble with it. the bellhousing was from a '65 Mustang and Shelby flywheel and clutch. the floor was notched to fit the hurst vertigal gate shifter. I finally ended up putting a built C-4 with 2800 stall converter in it and had lots of fun. Pic's of the car is in my galley pictures. I also had to notch the front radiator support to get a Mustang II V-8 Radiator in it, also switched to electric fans due to clearance problems. That's as about as much as i remember on it now, this was in 74 so the memory fades, i'm sure others on here have more recent experience than I do. Good luck. Oh, sub frame connectors, slapper bars and a 6 point cage helped stiffen my Pangra.
If you have a drive shaft that fits with your current axle it should be fine to use with the 8". The only real difference is the yoke which changes from manual to automatic transmissions. As a side note, the C4 and C3 automatic transmissions use different yokes as well.
I have a stock 2.3 in my 78 with the stock 4spd Ford FOG transmission behind it. I did the 8" axle swap and am still using the same drive-shaft.
My understanding is that all Pinto's have the same wheel base.  Therefore the difference maker becomes the transmission and rearend. Also, in your case the location of the transmission might be different (meaning moved) for the V-8 installation.
But as a reference point I went from a:
2.0 / C-4 / 6.75 rearend
to a
2.3 / T-5 / 8" rearend
And the original '73 wagon driveshaft fit perfectly.  :-)
Tom
RSM
I believe the wagon drivelines are longer but I couldn't tell you by how much. If you get it cheap enough i'd take it anyways.
Fehrion_sit
yahoo! and because its coming out of a pinto , it will be the right length to fit under our rear end! ... should i take the driveshaft too? the car is a wagon.
RSM
Fehrion_sit
The late spindle is about 7/8" taller (between the ball joints) than the early spindle.  I suspect this would affect the geometry but I do not understand such topics.  However I seem to remember somebody here installing the late spindle in a 73.  Another problem is that the hole for the tie rod end is larger in the late spindle than the 71-72 spindle.  The 73 has a unique rack which uses the larger tie rod end.
Fehrion_sit
i have seen that link, is switching to the newer spindle even possible?
In case you have not seen the great thread below, it shows what is involved in adapting the Granada disc to the early Pinto.  I am not aware of anybody making after market brakes for the early spindles anymore.  Would like to hear if someone is.
http://www.fordpinto.com/pinto-faq/front-disc-brakes-(4-5-lug)/msg6498/#msg6498
Fehrion_sit
on a side note, for my early pinto, is a granada brake swap overly difficult, would i be better off with aftermarket brakes?
Look in the parts for sale section. Guy has a brand new set of headers you are looking for & the price is good as well.
Seems to me, he may have mounts as well ?
Edit: his listing has expired.
shoot a PM to 79prostreet: http://www.fordpinto.com/profile/?u=8303
Fehrion_sit
Reeves, i was planning on getting a set of used super comps, but i need to mount the motor first which wont happen till i have all the parts to do so(probally in the spring) ... recommendations ?
I didn't re-read the topic, but have you decided on what headers you will be going with ? May make a difference on which way you mount the engine....
I do have frame mounts, but I'm holding them till I know what will happen to the 302w & T-5, as I would like to sell as a complete unit/swap .
Fehrion_sit
i was under that impression, but i was unsure, i know the pedals i need also have to be non power brakes because they are not interchangable ...? i read that on another post
Reeves, are those mounts you have for a v8 swap? id buy just them .. Fehrionsit@gmail.com
RSM, i emailed the guy in California about the swap mounts .. he responded but has not emailed me back yet with a defiant answer.
Ricpinto, i believe it is a six bolt bellhousing, i will double check when i hone the block tomorrow.
289Wagon
 Not all 289 blocks are the same as a 302. The early blocks used a smaller bell housing and only a 5 bolt mounting ( like a 260) the later ones used the same 6 bolt pattern as the 302.
You may want to count the threaded holes on the rear of your block. Two holes are for the dowel pins, so it should be either 7 or 8 holes total.
Keep in mind you will need a clutch pedal assembly from a 71-74.  75 and up pedals are different in the way they mount.
Fehrion_sit
ive been talking to Norm and he said those look alot like his, and i cant seem to find a picture of those mounts in there original condition. ive been reading alot and it seems like everyone has something different.
RSM
I'm not sure if those Mustang II mounts will work. I saw a pair of Hooker swap mounts in the classified section...I think those are what you need. As far as the headers...I don't remember which ones worked on the early Pinto...need to do some homework before you buy anything.
Fehrion_sit
that sounds like one mean drivetrain reeves, but ive already got a built 289 thats almost done!! im building it myself in my engine machining class at school.
RSM, your right, automatics are easier and more consistent, but i love driving stick, there is nothing else like it, okay maybe winning too, but this is a street car for my dad and i to take out on the weekends and to local shows.
any thoughts on those mustang mounts i posted a picture of? im supposed to go pick them up tomorrow, i just dont want to buy the wrong thing again. http://philadelphia.craigslist.org/pts/2679652559.html
there is the link of stuff the guy has.
New Hooker Super Comp Headers 1 5/8" x 31"x 3" Part # 6102
^^^ those arent the super comps that work with pinto swap is it?
