Date: 02/04/2018 08:26 am
Date: 01/19/2020 09:06 am
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Date: 02/28/2018 09:37 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Date: 12/15/2018 02:21 am
Custom Pinto Project
Date: 06/12/2016 07:37 pm
  • Online today: 447
  • Guests: 392
  • Total: 392
72 pangra v8 swap questions
Started by Fehrion_sit, November 03, 2011, 10:03:41 PM
Fehrion_sit
its a 67 289 .030 over, with hypereutectic pistons, flat tappot with a holley intake/carb with 302 heads ... nothing crazy for a v8
cookieboy, i think my dad was emailing you about ours
Quote from: Fehrion_sit on November 04, 2011, 11:21:45 AM
i want to get the frame mounts correct because im not looking to twist it. i had a long conversation with a man who raced dirt track pintos and he was very concerned with my plans because the frame reinforcement ends about an inch forward of the original 4cyl frame mounts. this car is going to be a street car, not a DD but more of a weekend toy.
how much horse power are you planning for this V8 you want to install????
Fehrion_sit
i was under the impression that it was common the run the small block ford with the pinto 4spd?
Thankyou reeves1 for that link, ive been reading several threads similar to that one, and i want to get the frame mounts correct because im not looking to twist it. i had a long conversation with a man who raced dirt track pintos and he was very concerned with my plans because the frame reinforcement ends about an inch forward of the original 4cyl frame mounts. this car is going to be a street car, not a DD but more of a weekend toy. ive been talking to Cookieboy and Fred morgan trying to get a handle on mounting my v8 into the car (a great thanks to them for being so open!)
i have many pictures of the car and of our tear down process turbopinto72, what do your frame mounts look like in your 289 pinto? what trans are you running?
Can you post a picture of the car ? I would like to see it.
Thanks
302 will likely rip the stock Pinto trans to pieces.
Motor mounts: http://www.fordpinto.com/your-project/302-motor-mounting/
Five pages in that topic alone......
Not to sure about the frame mounts, I can't tell if those are the original ones for the 2.0 or not either, someone else may know though.
As for the engine sitting as far back as possible, be prepared to modify the firewall. Regardless of the bell you decide to use, you will need to cut out or hammer in the firewall at the entrance to the transmission tunnel for clearance.
Fehrion_sit
i have the pinto v8 book off ebay which suggest engine plates, that is not an option for me. i also have no problem running a notched oil pan and (or) front sump, the engine needs to remain as far back as possible for the best weight distribution.
i do not reccommend that book to anyone, it is very vague.
i know mustang II motor mounts will work, im just concerned with the corresponding frame mounts.
I would use an engine plate or build some brackets that go from the frame to the heads. The only issue with that, though, is the lack of motor mount and it would vibrate like crazy! I have heard of people using Mustang II mounts (two passenger side mounts with minor relocation of the frame mounts), but others have also said it does not work.
I am assuming you are using a front sump pan on that motor, which will help, but you may need to push the motor forwards to clear the cross member (without notching it) due to the pan sump "slant/drain" being angled to much. This is why the Mustang II pan is so desired for this swap.
For my 78 Sedan, I plan to use Mustang II donor parts. Looking for a Mustang II oil pan, pump pickup, mounts and headers which should make things a breeze when it comes time.
Fehrion_sit
let me start off with what i have, My father and I have a 72 pinto Pangra, automatic (non turbo). the car has atleast the stage 2 (suspension and body effects). the drivetrain has all been removed, we are planning for a manaul swap with a 67 289 with 302 heads using a Ranger rear end. i am having problems with the frame mounts, how do i get the small block mounts to work? i also have the wrong smll block bellhousing(c5ta-6394-a).  i would like to use the four speed out of a pinto.
- attached is a picture of the best frame mounts i have found (attached pic) ... thoughts on them?
- which bellhousing do i need?
- i am in need of a clutch pedal/brake pedal assembly, no power brakes, any for sale?
- i know hedmen has a set of headers that would work, so does hooker, which will work best for a 72?
suggestions?
