Looking for front seats
Date: 08/10/2021 09:54 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
77 pinto
Date: 08/22/2017 06:31 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
1980 Ford AM radio
Date: 12/22/2019 11:57 am
71-73 Hood
Date: 12/07/2018 06:22 pm
  • Online today: 481
  • Guests: 167
  • Total: 167
302 motor mounting
Started by WTR 70, September 12, 2011, 03:39:21 PM
WTR 70
i just bolted the actual trans to my motor, didnt put the clutch in or anything yet, i set it in with the mustang 2 pan and it like wedged in between the rack and the sway bar, so i pulled the factory pan back out of the scrap pile, lifted the motor back up, and while still in the car swapped the pans (not an easy task) and then measured how far i could modify the pan for clearence and still have room on the pickup tube. i used the mustang 2 pickup, its a bit shorter than a factory one, gained another half inch there. im not sure if i have the short pump or not, but i threw a fan on it and actually set the original radiator back in, and i have clearence for everything. i ended up moving the motor back about 4 inches. ended up having the shifter line up perfectly with the factory hole.
I did a sort of opps.....while the engine was out of my car I meant to take pictures of the frame mounts. Never seen ones like these.
I'll take pictures next time I pull the B2 for the re-build.
Go with the short water pump & pulleys. Gives you an extra 1.5" at the front.
Rad support doesn't need to be cut. Install the flywheel & water pump, dampner etc after the motor is in & you will have planty of room to drop the engine in.
If you have some help, the flywheel , trans etc can be installed at the same time. (I do all my work alone)
WTR 70
finally got the swap started! doing lots of modifications, cut the firewall up and modifying the pan, set the motor back to where i can run a manual fan and radiator without cutting the core support or removing the sway bar. also removing th mounts, got a set of mounts from a 73 mustang, just gotta fab up some mounts and then build the firewall.
Turns out they will not work on BOSS 302 heads. Not even close !
WTR 70
cant afford now, and im getting everything gathered up finally, doing mine over christmas break, school is interferring lol
Same as a 302w except for headers. No one makes them & I will be going custom.
But you have a ton of info here now : you need to start yours.
There is no try, only do, or do not (Yoda)
I'll be going to Sweetgrass MT to pick my B2 up. I could bring my 302w & T-5 down for you to the same place, ship from there. Just lowered the price by 1k.
PM for info if you are serious.
WTR 70
how much of a project is putting one of those in? i think that looks sweet!
If the bolt pattern is different, I will just change it.
Not much choice, as there are not a lot of things made for B2s.
289Wagon
 Oh, now I understand - a 289/ 271 Hi-Po with crooked valves.
  *** JUST KIDDING ***
That is a great find !   I hope the bolt pattern on the front of the heads are the same.
Hope all goes well for you - it surely will s**t & get when it's done !
BOSS 302.
This is the engine going in (my car had a B2 before, but 2 owners ago took it out)
In the picture it is sitting in a 67 Cougar. It's out now & crated up ready to ship to me. Will look better when cleaned up....
289Wagon
@ Reeves1
At the risk of showing how old & behind the times I am, would you please tell me what a B2 is.
Looking good !
I had forgotten to order the frame mounts ! Opps ! Done now though.
The two head bolts looks like it may be too light for my B2 swap. I will/may/try  and do a mod or two to them....
289Wagon
 Cookieboy -- Thanks for posting the pics for me !
A note, if anyone is interested in using these -
The frame brackets will be up higher on a 'normal' V-8 conversion. I lowered my R&P and modified my oil pan to get my carbs down low enough to meet PA overkill inspection rules.
And BTW that is not the engine I will be using.   :)
Quote from: Ricpinto on October 17, 2011, 07:49:50 PM
And I'm way to computer stuipd to ever figure out how to post a pic on here. Sorry about that.
Don't worry Ricpinto, I got your back and will post them for all to see, thanks for sharing  ;D
@ cookieboy, yes i have found some pics I took with a 'film' camera & scanned for you,but I can't find anway on here to contact you.
email is cookieboystoys @ yahoo.com
if you click on any members name at the beginning of a post it brings you to their profile and... most will have an email listed  ;)
Ricpinto - you can email him, or me. I'd be happy to post them for you.
(or just load them into Photo Bucket & copy/paste the bottom link in your post here. Just make sure not to post a link side by each. Leave a line or two between each one)
Send me a PM with your e-mail....
289Wagon
 @ cookieboy, yes i have found some pics I took with a 'film' camera & scanned for you,but I can't find anway on here to contact you. And I'm way to computer stuipd to ever figure out how to post a pic on here. Sorry about that.
WTR 70
hmm looks interesting, that'd be sweet if it did work
Another sleepless night, so rooting around the net looking at Pinto stuff.
Found a site claiming Pinto headers: http://www.pronto.com/user/search.do?displayQuery=ford%20engine%20headers&SEM=true&query=ford%20engine%20headers&adid=1211339975-7046279d-0_gs&ref=ford%20engine%20headers&creativeid=3791455004&site=
So, went to the Headman site & they say they are for a Ranger.  http://www.hedman.com/site/?d=119&dt=108&Keyword=89500
Wonder if they would work ?
Ric... you have any pictures available?
289Wagon
 I will be using the 2 items already mentioned + I bought the frame adapters # 1353274.
They will work out, but if I had to do it again I would make my own since there is so much stuff inbetween the 'frame rails' (support tubes for the impact bumper bolts etc ) that it difficult to drill holes where you need them,+ sway bar mounting bkt. & so on.
One person who placed a review for the 1353274 bkt. said he cut them off at the weld & built from there. At first glance that seems a waste of $ but when you think about the time & material to make something with an adjustable slot etc. it may not be such a bad idea.
I would "guess" they mount similar to the way the motor plate does, just a bit farther back
QuoteVery Interesting! thanks for the info - has anybody used these? offer more info?
I might be able to ? Since I like that better than the plate style. May have to order them today ? LOL !
Edit: Done !  Hey, it's only money ! LOL !
Didn't see any frame mounts that would work for me though. Easy enough to make them though.
289Wagon
 You may want to look at Speedway Motors part #s
1353764  and  7209314
They may seem pricey, but they are well made with heavy gauge metal.
WTR 70
or does someone have a pattern for the front style plates that bolt to the heads
WTR 70
does anyone have a set of mustang 2 motor mounts they'd sell?
WTR 70
I just checked all my pictures & none show them completely. I'll be in the shop today, so will try & get better pictures.
