Date: 08/22/2018 09:23 am
1976 Pinto
Date: 10/24/2017 02:00 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 02/14/2019 06:27 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
Date: 01/10/2022 03:41 pm
Date: 09/01/2017 11:58 am
  • Online today: 2,457
  • Guests: 559
  • Total: 559
Found some motivation (finally)
Started by discolives78, October 10, 2008, 09:15:30 PM
I forgot I had these. Pics of documents I scored on e-bay
The owners manual (very nice condition) and 1978 warranty tri-fold pamphlet
and the bag it came in
A dealer sales brochure, from canada, notice the wording under 1978 ford pinto is different from the american ones, don't believe me? theres another one on ebay that's different than mine
If it all goes through, you had better be sure to let us all know so we can see a fellow PCCA member's car in theaters! ;)
That is freaking Awesome i hope you get to do that man.
So I got the pinion nut seal and the rear cover gasket replaced. Everything went ok. No leaks so far. Sorry no pics. I've been busy at work, just got done putting two 1979 Trans Ams back together for a movie. I'll bet alot of you don't know the film business is booming in New Mexico. When the guy came to get the second car, he asked about the Pinto, and offered to rent it for a film, so I exchanged info from him. I think it would be cool to have my car in a movie!
That looks much better than what you started out with.  Good Job!
Awesome work on the dash! I sure wish I had a spare dash to try this on!
Let us know how it holds up to the weather changes and what not.
Keep up the great work!
They dash looks fantastic, Chuck!  Keep up the good work.
Beauty, Chuck. I am restoring these pads the "old, hard fashioned" way with foam, filler, and a lot of sanding (just like doing bodywork). I had a local upholstery shop recover my original pad, I brought it home, the vinyl lifted in 2 days. They tried to fix it and ruined it.
Great job for a first time attempt.
The gauge lens are the original. looks good from here but there are a few scratches if you get close enough. Thanks for the compliments.
That looks awesome!  I will send you my dashes, yes more then one, and let you practice some more!!!!  :D
I wanna know where you get the nice looking instrument panel? All 4 of mine have a smokey clear plastic. Yours looks brand new!!!
I will have to say though on the dash pad part of it. I will probably just buy the aftermarket cover. I am not one for alot of patients, and it looks like it took some to do that nice of a job!!!!
I just wanted to add that this is one of those things that's not as easy as it looks. I can't stress that enough!
Some pics of the new dash pad taken today
Keep in mind this was my first attempt. hopefully I can get it a little tighter next time. Just need a little more practice. This actually took about 6 hours from start thru prep and then drying time and trimming.
Congrats - VERY much looking forward to seeing the pictures. I may have some to send you to wrap  ;D
The dash is done. The batteries in the camera are dead, hopefully tomorrow or tuesday I'll post a pic (it's back in the car) Doing this project is like painting, prep is everything. First the dash pad was removed and the high spots and loose vinyl were ground off with a "nitty gritty" pad ( a plastic pad on the drill that looks like really coarse sandpaper). Then the rest of the vinyl was sanded with about 80 grit paper. I covered the dash with 1/4 inch high density foam, using upholstery adhesive shot from a spray gun. applied adhesive to both dash pad and foam. new foam extends from underside of bottom to top edge of the top, but not around the sides. the vinyl has to be stretched in places to avoid the need for seams and avoid wrinkles. The application of the vinyl started at the right edge of the gauge opening and some stretching was required to get the contour. then the passenger side, about the last 8 inches and around the corner were glued in place, much stretching and heat gun needed to wrap the vinyl around the edge. Driver side edge next, same process. Then the entire lower edge was glued and stretched to remove wrinkles. Finally the section between the gauges and the passenger side was glued and stretched into place. The adhesive needs about 10 minutes to tack up before fitting the vinyl. The vinyl was left about 6 inches longer than needed on all sides and trimmed after installation. It was so long in places that we used the factory bolts to hold the stretched vinyl in place while the adhesive set. After everything was glued down, I used a staple gun and 3/8 in staples to secure the new vinyl to the old pad.
Reed
Hey guys:
  As you know, Matt Gunter is driving to build the kickoff of the first Pinto Magazine in late Winter 2009. Having had some experience in dash cap restoration (and, in the middle of another right now), I am writing a lengthy article on dash cap restoration, including materials, photos, and procedure. This will be my first submission for the magazine, and I hope to do others. I hope this article is a good adjunct to what Chuck has to say about it.
Stay tuned!!
Reed
Sounds good!   Please post lots of pics of your dash.   A write-up of how to recover a dash would be much appreciated!
Sounds like you are on a good and steady road of the restoration of your Pony!
That is really cool that your boss wants to show you how to recover your dash, even better that he likes you! :D
I'll be checking up to see what documents you won off ebay. I know I have pretty much everything that came with mine, even the car's first third party battery replacement warranty from Sears!
That's great about your boss. Sounds like things are really going good at your job. Those seals are pretty easy to replace on the rear end. Been there, done that. Looking forward to the pics of the recovered dash.
My boss likes me. Yesterday he had me pull the dashpad out of my car so he can show me how to recover it! Look for pics in a couple days. I got my package from Rock Auto today, new pinion seal, rear cover seal and leaf spring bushings, and new spark plug wires, and I got my winnings from E-bay, a very good owners manual with other docs, including car and tire warranty booklets, I'll post pics of them soon. I'm going to have to live with the 6 3/4 rear for a while due to budget.
before, the old dash pad:
Chuck,
Your car really is an inspiration.  It looks great!  Glad to hear you like the new job.  I'm sure there are lots of us here who could loan you seats to practice on once they let you at that sewing machine!  LOL.   Take care!
Chuck,
first off good luck with your health & hope all turns out well for you. As for the car, great job with it. Your 78 is looking really good & makes me want to do some more work on my 77. Her condition is not nearly as good as yours is, but it's mine, none the less.
Looking forward to the next update & pics of yours.
Chuck:
  You are killing me - you have done more work on your car in the last few weeks than I have done since June!! Good grief, it warms my heart to see you take a break. Glad the new job is working out and that it seems promising. Have fun and keep us "slow guys" up to date on progress.
...who MUST MUST MUST get his brakes done and change the windshield gasket and repaint the dash while the windshield is out and pull the gask tank to fix the leaks and recarpet the floor and etc etc etc etc etc  :o
I haven't done anything to the car in a few days except add a quart of oil and put gas in it. It seems to be handling the 8 mile commute to the upholstery shop just fine.  I've been working every day so far this week. I like my new job, I stripped 3 living room chairs down to the frame and yesterday I started putting a 70 VW Squareback back together. I'm just getting the hang of things, so they put me on simple tasks, like re-installing seatbelts, sunvisors, door handles (stuff I already know how to do). Hopefully soon I'll get to play with the sewing machine!
I agree! You did a fantastic job on the covers.  When this little beastie is finished it will be that much more special to you because of the blood, sweat and tears that went into her to restore her your way. I miss the days where I could cruise to the junkyard (Ecology is the big one here in San Diego county, with three or four locations) to get stuff to improve my blue baby.  As for the Pinto script on the piece of wood, it is beautiful what you did with them. The red-white-blue in the P looked brand-new. The upholstery job is a great idea- especially since you're eager to do that. Things are looking up, it seems. Thumbs up to you!
I have my original battery tray from my car in my storage unit if you cannot clean yours up or find one in good shape in a yard. I am hoping to go back to JJ tomorrow to pull the one from the 77 Bobcat, since I start working grave yard tomorrow. PM me if you are interested!
I really wish I could do an 8" swap right now. I have a fellow Pinto member holding one for me, but he is in washington and I will have to wait until next spring to pick it up during a northwest meet that apintonut is organizing.
Your car is coming along great and it almost makes me jealous in great in shape yours is compared to mine. Maybe it is just me nit picking at my own Pinto's defects, but then again, I would notice them more since I drive it every day. :P
You have me modivated enough to pull my valve cover and belt covers off and repaint them! Thank you chuck. :)
The career path was chosen based on interest! I like to look at upholstery, and sit on upholstery, and nice upholstery makes me smile! I have thought about persueing it for years, I happened to get a 'silver lining' in my dark cloud! I start tomorrow and I'm pretty excited! Once I learn a little bit, I want to redo my interior (including the headliner, it's starting to come apart) and help other guys and gals with their cars.
I've decided to swap in a 8" rear out of a 76 Pinto with a v-6 instead of fixing the leak on mine. I'm hopefully getting it from the u-pull next weekend. Here are some shots of the battery tray issue I need to address, the tray isn't rusted through (that I can see) but its pitted pretty bad, I'm gonna check out the ones in the yard while I'm getting the diff. I think I need to take the exhaust off to get the bolts out.
I lucked out and found one of these on my last trip to the boneyard
my old one is on the right, it has a crack in it next to the bolt hole on the inside.
found this under the carpet
and this on the radiator support
and while the carpet was out I installed the original shift boot
Hopefully this week I'll get pics up with the tire/wheel combinations I have in mind.
As always, nice work Chuck! Glad to see your motivation is paying off. Your floors were far better than mine, and that's a blessing in itself! Had I thought otherwise, I would have far rather owned a car that did not require as much work as mine does - it's definitely dragging me down, and actually motivates me less. With the money I have in it by now, I could have bought a nicer, road ready vehicle. Yours is a great example of a car you can enjoy and tinker with as you go!!
Regardless, you are doing some great work - and best wishes on your new career path. Hope it works out well for you!!
I got the piece of wood from home depot, it's unpainted base molding for the house, with two coats of polyurethane. The emblem is from my  75 Pinto, painted with testors model car paint. There was a matching strip of moulding between the heater control and the vent with a 'blue oval' emblem, that's also been removed. I have since removed that console and it was donated to Joe aka 'thewhitebeast' to make it easier for him to install a cd player, since I moved my radio to the stock hole. I used permatex grey to attach the wood to an extra console and the install kit was for a 87-93 Mustang.
check out the console in joe's car
http://www.fordpinto.com/smf/index.php/topic,10734.0.html
