free transmissions
Date: 11/28/2019 10:21 am
Great Cruise wagon
Date: 12/17/2016 03:39 pm
Date: 08/06/2021 02:23 pm
Date: 10/24/2018 07:41 am
Date: 03/05/2017 03:27 pm
Date: 02/08/2018 02:26 pm
Date: 07/21/2017 11:49 am
Pinto hubcap
Date: 01/07/2017 08:40 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
  • Online today: 531
  • Guests: 430
  • Total: 430
Found some motivation (finally)
Started by discolives78, October 10, 2008, 09:15:30 PM
I second that the USPS post office is the best for shipping rates!
Your headlight surrounds/extensions look just like mine, all cracked and what not. Mine is due to the incorrect primer used which caused the paint to crack and lightly flake.
Your project car is coming along very well! I'm thrilled to see another 78 Sedan being restored with such vibe and excitement! I feel like I've found a twin! ;) :P :D
I ship all my parts at the post office. About $1.20 a pound if the box is small. I,ve shipped cylinder heads / sway bars / headers / etc-etc with very good service. And their only 1/2 block away from work.
Its raining off and on today, I got off work at noon and drove home in a downpour (yes, in the Pinto) I boxed up some parts and sent them off, one to oregon, another to missouri.  UPS is expensive! $11.78 for one package 4.25 pounds, 10x12x10 and $10.82 for the other 2 lbs. 2x10x12!  Anyone know a cheaper way to ship parts?  I'm installing the blue console, between bouts of rain, and I took out my gauges, the plastic oil line that came with the gauges contributed to the oil all over the engine, and the temperature gauge never worked right (old fashioned gauges), so on the list of improvements is electronic gauges, and a volt meter instead of amps. I liked the wood trim 5 years ago when I did it, but I think I outgrew it, so it's coming off the dash too ( I used Permatex to fasten it, no holes!)
Heres a couple of pics with a question attached:
can these be chemically stripped or do I need to sand them?  The paint is very dried out and cracked.
these are the cracks in my hood, they're about 4 inches long.
More later, gotta get some work done.
I spent most of the afternoon at u-pull-it, so I didn't get too much work done, but here are some pics from yesterday:
before
after, at least 'that' is clean!
the stickers weren't perfect, but I masked them off anyway.
The new washer bottle on the left, the old one on the right. Improvement, right? I got it installed and the pump actually works! So now I have windshield washers  :surprised:
More things on the list:
a hood and trunk lid! they crushed two wagons that were there two weeks ago, and today there were 2 new pintos!  a blue 78 sedan and a green 75 hatchback that I used to own(!) I sold that car for $100 in 2000, it didn't run, so someone must have fixed it or tried and stashed it.
I also got a hood cable, a blue console (mine is black), extra door sills, and some wiring odds and ends.
I checked all the cars for the guage cluster holder ( the white part), but none were salvageable. I grabbed everything I could afford, because I was there saturday and found a mustang II with a console, today the entire interior was gone from that car!
Next couple weeks,new plug wires, new heater hoses, radiator hoses, and a new timing belt (it's been 5 years, and I had an oil leak from the front of the cam cover) not to mention I need to paint the timing belt cover too. much easier when its off the car!
My doctor told me today I can go back to work (finally, going CRAZY!) So I have to be at work at 6:00 am,  More soon!
so the seats went back to the planning phase.  I opened the hood today to check the oil and decided I need to replace the cam cover gasket.  I found a rubber Fel-Pro gasket at Pep-Boys for $18.99.  I got the plug wires and air cleaner off, pulled the cam cover, and thought "That's really greasy, I should clean it" so 6 rounds with the "super clean" and an an old scrub brush, I decided it was missing a little too much paint.  2 hours of 80 grit sandpaper later, I washed it in the bathtub with plenty of dishsoap and a green scotchbrite pad, hand dried it, wiped it with a tack cloth and applied two coats of Ford blue from a spray can.  Then I read the instructions on the can and it dries "to the touch" in one hour, but can be handled in 3 hours.  So here I am waiting for the paint to dry so I can put my car back together.  I have a doctors appointment at 10 in the morning tomorrow, and after that I want to go back to the u-pull-it yard.  I misplaced my memory card reader, so no pics today.  I'll post some tomorrow, thanks for stopping in!
Quote from: 75bobcatv6 on October 12, 2008, 04:46:15 AM
60 Dollars new at Autozone. I just replaced mine
Ok, thanks.
Did not mean to hikack the thread. Keep us posted on your progress. I have some blue parts if you need them
Quote from: 78squirewagon on October 11, 2008, 05:24:53 PM
Jumping off just a little bit but if you go back to that junk yard, see if they have a water pump for a V6. My white wagon needs one BAD.
Their aluminum is easier to drill, bend, and jack saw.
Reed
Quote from: discolives78 on October 11, 2008, 05:36:25 PMAgreed, I'd rather not drill holes in the car!  There's no metal on the escort seats where I would need to drill holes, the seats aren't too wide though.  Maybe a flat piece of metal attached to the original holes in the new seats and drill holes in that?
Yah.  Try some flat iron from Home Despot.
Sorry, I mentioned earlier the wagons are gone.  There are a few mustang II's. one has a v-8(!)  I didn't look under the hoods of the other two, but I can, give me a few days.  The 2.8 is the same between the Pinto and Mustang II, just like the 2.3, right?
but you car is looking good. I found a little trick to repairing window felts if yours are cracked and coming apart. A little rummer cement to put them back together and a product called plasti dip. It's the stuff you can dip the handles of your tools in to put a plastic/rubber coating on them. it works great when you cant afford new window felts
Reed
Is there enough room on the frame of the new seats to just drill new holes?  Personally, I prefer to drill holes in the floor of my cars as little as possible.
So I got to u-pull it this morning, and got my seats
it was very windy today!  That's my neice trying to get comfortable.  I cleaned the seats with "Tuff Stuff" and they look pretty good.  They are from an 87 EXP.  Then I took the tracks off the new seats, pulled out my driver seat, took the tracks off of it, and then I realized I have to drill out the knock-outs on the new seats, and the width of the holes is different.  The pinto's holes are about 12 1/2 inches apart and the escort holes are about 13 3/4 inches apart, so I either have to improvise some brackets or drill holes in the floor of the car.  Bummer.
And more bad news, they crushed the two wagons with v-6's so I didn't get a hood because the one on the 74 had a big dent where bondo used to be and the 78 wagon had been wrecked in the front.  The bumper is gone, the extensions are trash and the hood has a huge crease in it.
I came inside because while I was messing with the seats some pretty good storm clouds moved in.
Anyone know where I can get some door lock grommets?  I checked the Help! section at Pep Boys, Autozone, and Checker and no luck.
I got excited and clicked "post", sorry,
Back to the story, I also found a very good set of light blue door panels, my passenger side one was a little rough, so this was a blessing!
So while I was working on the car I swapped out the passenger door panel, and the window cranks(also from u-pull-it, $1.00 each) from an 80 Mustang, now it has black knobs instead of the faded yellow clear jobbies. :)
There's a bit of body work I need to get to:
that's the only cancer on the whole car, and I think it was caused by a plugged drain hole and dried out weatherstripping.  I have another door (had it for a while) but I'm not ready to paint the car yet, so I was thinking I'd grind the hell out of it and patch it up with some screen and bondo for now, the hole is the size of my pinkie and the outer area is smaller than my palm.  After that I was thinking I'd paint the bottom of the car the aforementioned mettalic blue that I'm going to paint the wheel well trim.  That should hold it for a year or two.
I seem to remember somebody mentioning that they were looking for a salvageable 78 grille, when I was cleaning the trunk I found this :
I can't remember who you are or where I saw it, I'll try looking again.  If you see it and you want it before I find you, send me a PM,  I don't want anything for it, it needs to be stripped (cheap black spraypaint) and there are a couple tabs are held in with what I think is silicone, but its in one peice!  If you pay the shipping I'll send it to you!
Well enough about me, I'll put more here in a couple days, I'm off to see what you all have been doing! :afro:
I am so in awe of everyone's cars!  I look at the work and admire what you do.  I have spent hours here reading countless threads, looking thru galleries, watching vids and looking at everyone elses projects.  I dig the turbo pintos!  That project is a little more than I could handle right now, so lets work on getting her cleaned up real good first!  First thing today was another trip to u-pull-it.  Here are some of my treasures
a set of wheel well trim, its a little beat up but it was free!(because it was a little beat up)  I spent two hours tapping the dents out with a spoon dolly and a pick hammer, when I was done I realized the  memory card on the camera was full.  You can still see some of the little dings but they are fairly smooth and have been test fitted on the car.  My plan is to rough them up real good with some 40 grit, use a skim coat of Bondo, wet sand them and paint them mettalic blue.
a very nice (after I cleaned it up)  original shift boot and knob!
I also got a very nice pair of blue kick panels, none of the tabs are broken. these are keepers in case I want to take the 6 1/2s out and go back to original.
I found a dome light in light blue! mine's black.
So when I got home, I cleaned out my trunk:
and found the floor!
I went to Pep Boys for some "Super Clean" in the purple bottle, good stuff!  While I was there I found these:
They're plastic peel'n'stick, but hey, they're $1.99 each and it took less than five minutes to install.  I've seen a lot of pictures of other Pintos and I think mine's supposed to have lettering spaced out across the front of the hood but mine has no holes for letters or letters, so I improvised.  I saw a 74 at the junkyard and on it the letters are clustered in the corner, I liked that look, so thats what I was going for.
Bad news.  upon closer inspection of the hood the 4 "scratches" I saw are not scratches at all, there is a patch of bondo and its cracking!  Tomorrow I'm going back to u-pull it for a hood and a nice set of blue cloth seats I saw in an 86 escort.  so look for pics of those in a few days.  This time I'm going in a truck, not the Pinto!
Here's some before pics of what my interior looks like right now:
