McLeod Clutch
Date: 04/12/2017 12:08 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Date: 05/22/2018 02:27 pm
parting out 1975 & 80 pintos
Date: 10/31/2018 12:00 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
Date: 02/21/2022 11:11 pm
Date: 11/29/2018 10:26 am
Date: 05/22/2018 01:54 pm
  • Online today: 2,737
  • Guests: 2562
  • Total: 2562
New car !
Started by Reeves1, June 30, 2011, 07:47:57 AM
Quote from: Reeves1 on April 23, 2015, 07:10:14 AM
The Bud Moore intakes have been going as high as (for NOS) $4500.00 +
CROSS BOSS now : http://www.ebay.com/itm/131487913847?item=131487913847&viewitem=&vxp=mtr
First B2 engine I bought back in the 70s for $200.00. All parts on boxes. 6 of the 8 pistons had cracked skirts. Common for them to do that.
I replaced all rotating parts. Seem to remember it cost about $1300.00 ?
Huge difference now ! Most people would have a stroke if they knew how much $ I now have in my engine !
That one is going for $10,500 on the link. I amazed at what I put into my cars to be honest, or even my truck. You've built one heck of an engine there Reeves. It not only looks awesome, it looks like an amazing runner.
All of use restoring a Pinto, or something else, end up putting way more than we expect in one.
Pintocrazed
OH IF I HAD THAT TRUCKLOAD IT BE ON ITS WAY TO LOUISIANA
Its been years since I have seen one, back in the very early 70s,  we had a small group of ford guys and one of them worked at the local ford dealer in the parts department, he had one with the manifold on his 70 boss 302 mustang , later he brought a spare engine shortblock for it, first thing you noticed it had four bolt mains and screw in core plugs,  later found out the rods were the special 3/8 bolt 289 long rods , the boss Pistons only would fit with that combination,  that is what made made me notice yours because of the top that comes off, did not know it was a bud more,  on the pluss side it makes porting the intake to match the heads a dream,  thank for reviving old memories from the past 😸
Quote from: Pintocrazed on April 22, 2015, 08:20:00 AM
THIS PINTO IS HIGH ON MY LIST OF CARS I WANT
All it would take is a truck load of cash  ;D
Pintocrazed
Cross BOSS is a different intake.
This is the Bud Moore Mini Plenum.
I have a picture of a Cross BOSS - in a Pinto....
While the smaller in lines are street able, the bigger ones work best WFO. ie: Trans AM
Looking at the intake manifold noticed you have the rare cross boss one, would have been very nice if you had the inline autolite four barrel carb, the only thing about them they had no choke and are super rare and expensive $$$$$
Too much info 🐵🙈🙉🙊
Quote from: 76hotrodpinto on April 21, 2015, 10:02:51 AM
SEXXY!!! Mmmm, I think I need a few minutes alone now.
ahahahahahahaha tisk tisk tisk ahahahahaha
76hotrodpinto
Looks just awesome!
Slow progress is still progress.....
Plugs wire made.
New copper oil line to gage & more small stuff.
This week I'll have the valve covers soda blasted.
May also have an alignment done & the new windshield put in......
Tonycando
Coming along and looking good..
Tony
I looked on Photobucket! WOW!
Had a couple hours , so started to add parts.....
This is the Bud Moore intake I'm using, with the thermostat housing set up I do not like.
Pictures are not of the newest re-built engine.
I (finally) found inline thermostats. New style, not like the old Ford 8-N tractor ones.
http://www.summitracing.com/int/parts/mez-wn0072
http://www.jegs.com/i/JEGS-Performance-Products/555/53260/10002/-1
I like the second design best.
I now know how the new system will be built.
There will be two 90 degree stainless bends. Cope one onto the other, turning to the right side.
Bosses will be welded on for the 4 other things that need to connect.
Should have pictures after the Header build.....
Didn't take any.
The water neck on a Mini Plenum has two.
I do not like the thermostat housing that came with it. Going to have another one made. May end up using an inline (in hose) stat.
With the last engine / different intake, I cut the Lokar throttle cable to length - which is too short now for the taller Mini.
Like I've said.....change one thing & you'll have to change 10 other things !
Pictures can be seen by looking back in this topic.
BTW.....the car's VIN is stamped onto the block in the normal location now  ;D
Quote from: Reeves1 on March 21, 2015, 04:43:11 PM
Engine / trans in.
Mounting not bolted. Tons of small stuff to do , next days off.
Took about 2 - 3 hours to drop it in.
Had the back plate & flywheel bolted on. Tight fit to drop in.
Clutch, bell etc has to be bolted on after it is in place.
Shifter bolted on.
Next days off will be getting it ready for the Header build.
Several other custom parts need to be built as well.
Couldn't do them before the engine was in......
Pictures?  :P
Engine / trans in.
Shifter bolted on.
Quote from: Reeves1 on March 21, 2015, 07:51:18 AM
Not yet - maybe today ?
Got caught un-prepared for days off. Was home for what was supposed to be one day. Then the foreman calls late in the day to inform me he is "resetting" us, so we can work a full 24 days.
So 1st day little got done. Yesterday lost 1/2 a day going to town for stuff. Will lose 1/2 day today getting all my stuff ready for work, so I can leave 4-5 AM.
Didn't get the scheduled time off - couldn't make appointments for my truck & other stuff - that will now have to wait a month.
Good luck and hope you get it in! I'm still waiting on my car and the engine is ready. But did get the engine in the Cobra!
Looking forward to seeing yours!
Quote from: dianne on March 21, 2015, 06:39:25 AM
Did you get it in?
Quote from: Reeves1 on March 20, 2015, 08:42:02 AM
As long as nothing goes wrong....dropping engine , trans ect into the car today.
Did you get it in?
As long as nothing goes wrong....dropp ing engine , trans ect into the car today.
Good luck, Derrick!
Tonycando
Quote from: Reeves1 on March 07, 2015, 06:53:44 PM
Engine home. Finally !
Will be in touch re: specs.
FYI - B2s were capable (Trans AM) of handling over 1200 cfm : depends on build.
I have dyno data on the difference between 750 & 850. With my build it should easily handle 850 + with no problems, and still have [some] street manners  ;D
I am familiar with the Boss 302's. Lol enjoy your build.
I will not have all the specs till I pick the engine up. Should be in a few more days. Work eating up time....
Will let you know.
Tonycando
Quote from: Reeves1 on February 04, 2015, 08:45:36 AM
BOSS 302 stuff is hard to find and rare....
Engine builder could not find any 2" headers. Had to use ones with 1 3/4" tubes - which chokes this engine big time.
He also did the dyno with a 750 DP Holley. Way under carbed.
I do not have the TQ numbers (yet).
But the engine "quit" building power at 6500 RPM -header/carb issues.
Came in at 510 HP - so far.
(hope it's not the custom cam)
After I get new headers built (April or May) and get an 850 DP (min) on it, it should be well over 550 HP.
Unless something (more) goes wrong, picking it up this morning.......
Those are good numbers for a 302,lots more power can be made with a 750 carb and you might not make any more with a 850 but you will or might lose some street-ability unless you are just wanting the most and are willing to put up with it.
What are your cam Specs  Dur @.050 intake and exh and Lift intake and exhaust.
Tony
