Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Date: 09/17/2024 12:35 pm
Date: 02/14/2018 01:34 am
Date: 02/27/2017 10:10 pm
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
Date: 01/19/2021 03:56 pm
Date: 12/13/2016 10:25 am
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
Date: 04/04/2020 09:38 am
  • Total Topics: 16,268
  • Online today: 239
  • Guests: 182
  • Total: 182
New car !
Started by Reeves1, June 30, 2011, 07:47:57 AM
Called the engine builder yesterday. Said the pistons etc are due to arrive any day.....two months late. So far. >:(
I've got the wiring done as far as I can go , without the engine in place.
Outside of inner fenders has a new coat of "tar".
Frame rails painted.
I need to take the swing arms in to press out the old bushings & push the new ones in.
Then blast them & paint......
New brake lines to the back done.
Need to run new fronts next.
Quote from: Reeves1 on June 09, 2014, 11:45:25 AMTalk about a simple engine & trans swap gone wild......it's turning out to be a complete "freshen up" !
Define simple LOL.... My wagon driver is a parts car that will get stripped & scrapped in a couple more years.
I can't get the NOS carb sorted & the resulting 14 mpg has led to a freshened 2.3 sitting in the garage, new clutch/flywheel/T5 trans to replace the automatic, pedals/ clutch cable, new Weber 38, NOS distributor, NOS Duraspark box, new header, new Dynomax muffler, freshly bushed control arms with new ball joints & a freshened manual rack to get rid of the worn power rack. I've probably spent $1500 so far.
All this to keep my beater running another couple years until I get the new body whipped into shape & all because 2 different carbs & 50 hours of fiddling under the hood leaves my engine running rough & getting 14 mpg just like it did "BEFORE" I laid a finger on it.
Yeah, "SIMPLE" !!
Got a special touch for the seats this summer....
Before pictures.....
Those seats look awesome!
Dwayne :)
Interior back in. Couple paint chips to fix. I have to make a bolt in tube to attach the shoulder harnesses. For now they are attached to the top bar.
Quote from: dick1172762 on May 27, 2014, 12:26:50 PM
What did you use for the 90 deg bends on the heater hoses? I like that idea very much. Much cleaner all the way around.
NAPA
3/4 elbow connector 9925
5/8 elbow connector 9924
Behind the catch tank for the rad I reduced the 3/4 hose to 5/8 with reducer connector 9911
Used banded clamps. Looks much nicer when no rubber/silicone is sticking through the slots.
Got a start on re-installing the carpet. Pictures keep turning out dark - so pictures later.
Got most of the engine compartment wiring done. More to do after the engine is back.
New rack mounted. Passenger side bracket has been sand blasted - will install after paint has dried.
Lucked out on the rubber being in mint shape.
Note the 90 degree fittings on the heater hoses. Wanted a "clean" install, and ran them down the inner fenders.
Nice blue silicone hoses !
All bolts, nuts, washers, screws  etc have been replaced with new.
All hose clamps have been replaced with banded clamps.
I think you are looking at the brown towel I have on the windshield cowl, to protect it from setting tools on it ?
Looks like a pink rug to me.
Dash color strange ?
It's semi gloss black.
Same as my parts car - factory.
Dash pad was recovered at some past time. Whoever did it, did a nice job.
The dust on everything is my personal touch  ;D
COOL DASH TOO!  Color is a little strange but hay, its your car.  Guys at the drag strip will love it too.
If you look back at/near the start, you'll see the battery mount .
Also the Tach was mounted near my right knee. Bad location.
I made a new mount & now it's in my sight line, where I wanted it.
Scott Hamilton
Nice!!!
Originally the battery had a couple brackets & was sitting on the tank. Only 4 spots of some kind of epoxy was (not) holding it to the tank.
Didn't like the way it was in there.
Made a shelf/bracket & also installed a kill switch. Shutting it off will kill the car.
Original builder had 2 hot wires and a ground (all size 4 welding cable) going all the way to the front. I pulled all that out. One hot cable & the ground had welding type joiners.
I now have one hot cable.
Grounded to the sub frame at the back.
Likely cut 5+ lbs of copper out of the equation !
There was some rust on the inside floor pan on both sides where your feet rest.
Cleaned up & put POR 15 on the rust areas.
Then painted the whole inside floor pan.
Then installed a sound proofing material.
The original stuff used was falling apart.
Nasty stuff to install !
Self adhesive.
Couldn't find any type of paint, even from a body shop, to match the grey with black splatter paint that was originally in the engine bay.
So I sand blasted it. Prime, sand, prime, sand....
It is now semi gloss black.
3 NOS lower ball joints (have 4 now)
4 rolls of sound proofing/heat shield
New rack
2 - 3/4" smooth x 3/4" smooth u-joints
assorted blue zip ties
2 packs various rev limit chips
12-700 inline fuel pump
5 point harness
Black cap for my MSD (don't like red)
2 kill switches
Need to get back to work  :o
Quote from: Pinto5.0 on May 05, 2014, 09:26:22 AM
I sure wish I could find the time to work on mine
Ain't that the truth.. ::) >:(
I sure wish I could find the time to work on mine  :'(  I'm jealous  ;)
Sand blast & paint under dash parts.
Went shopping yesterday. A few steering parts are for Ugly Yellow.
Still need to find lower ball joints.
Shifter hole done.
Next up is to clean up the floors & apply POR 15.
Got the four engine mounts done.
Sand blasted & at least 4 coats of primer.
Mid mounts are 1/4" plate & 2" angle as well.
I was going to gusset the mid plate angle iron, but think it's plenty strong enough as is. Stronger than the frame.
Frame rails are flat black right now. I'll be changing this and the mounts to semi gloss black, after the header build.
Note how I made the left side so it pulls up - right side pushes down.
Anyone that has looked under a dash knows Ford didn't paint lots of things.
Since the car is apart I'm re-building the heater.
New core. Sand blast, prime & paint all metal parts.
All new screws & clips etc
Quote from: derekrichmond15@yahoo.com on March 30, 2014, 08:50:56 PM
I would definitely be giving them the worst review EVER!!!! THIS IS Y U BUILD YOUR OWN ENGINE!! The only thing I let good old Napa do is the .030 cylinder bore so no messing around with assholes!!!!!!Just me and my 75 year old father that worked for Ford for 35 years. What are you going to do about all the BS and BAD workmanship from that company?? I would give them HELL!!!!
Talked with two different Lawyers. Both said the same.....cost more to go after him than to build another engine.
But..... he has lost business from word of mouth.....for as long as I am alive.
1977 408W stroked pinto
79prostreet
Smiles per gallon! that's what the B2 is built for. If I know right NASCAR runs e85 in their cars now.  Reeves1 looks like your engine mounting should be good and stable, good luck with that new engine.
79prostreet
Not sure if I've ever seen of e85.
Don't recall reading about it.
Don't mind using race fuel.
Tank is 11 gallons.
B2 engine is built without fuel mileage in mind  ;D
beaner
dont know if you can get e85 up in canada but try this guy out so you dont need to run race gas  ;)
http://www.horsepowerinnovations.com/concrete/index.php?cID=1
brad :)
