Date: 06/24/2020 06:12 am
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Date: 03/18/2020 01:30 am
Date: 04/13/2018 11:30 am
Date: 02/18/2017 04:47 pm
Date: 03/27/2017 10:07 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
  • Online today: 826
1977 Pinto- project in the works
Started by r4pinto, April 07, 2008, 07:54:57 PM
0 Members and 4 Guests are viewing this topic.
I tested the light repair I made & it's holding perfectly. JB WELD IS AWESOME!!!!
Today I got the oil pump in the mail. Thanks Bill!!! Anyways, looked at the pump and noticed it seemed somewhat different from the original 1977 Ford oil pump when Isaw the tag with a part number. That pump is a  Melling oil pump, and looks reasonably new. It must have been replaced at one time in the engine Bill got it out of.
I got the car pulled up the driveway with the help of a 94 Taurus and a piece of chain. My dad's Taurus may be falling apart and near death but the engine & transaxle still have some guts to them. Without even giving the car gas she pulled the Pinto up the driveway with minimal damage to her plastic bumper.
With that I can go ahead and install the brake clips, thanks to Tigger for sending them a while back, and also bleed the brakes to make sure all is good.
Got some more pics of the parts I worked on while it's raining. Including the visor reglue. The top visor in the pic has the JB welded pin. You can see where I had to use JB weld on the map light. If it doesn't stay glued this time then I will keep an eye out for a replacement. I repainted the grille while I had it off & posted a pic of it. Lastly, the sport mirrors I bought long, long ago when I had my 78 hatchback. Black is a neutral color so I went ahead and painted them gloss black so they won't look as bad.
Another update. It's been raining so I'm unable to work on the engine or busy, so I've been working on intierior pieces. The maplight setup I have had a broken mounting screw hole so I'm in the process of fixing it. Previously I used plastic epoxy but it didn't hold, so I decided to retry it with gobs of JB weld. Also this time I've secured the broken piece to the light with a clamp.
Also I had the typical broken sunvisor peg, and used JB weld on it to secure the peg to the visor. I'm gonna start reassembling the interior in the next couple days as well as restitching a torn part of the headliner. Pics to come soon.
Lastly, a shot of the dashboard after I repainted it in semi-gloss black paint. I plan on taking the glovebox door off & painting the backside of the door semi-gloss.
That's all for now, more to come later
Interior work. I redid the trim using the silver sharpie, like Cookieboy suggested. Thanks for the great idea! I went a little further & used a black sharpie on the little spots where black was coming off of the instrument cluster
heater control redone
steering wheel installed
RF fender repair. There were lots of small chips & dents in the fender
closeup of the area that had a big dent
RR quarter panel scratch filled & fixed.
Pics of the passender door repair. Lots of rust, so it's temporary
I have bumps on the a pillar, and am trying to fix it.
Finally, I got some pics of the work that I've got done to the car so far. It's the shots of the bodywork I've gotten done so far.
I wish I could, but my dad's taurus wagon won't make it too well, if at all. It barely gets him to work so if I get the Pinto running he can drive it while I work on the Taurus. Thanks again, you're a stand up guy Bill.
Got it, will ship Monday.
I still have a good running engine you can have if you can come get it.
I just pulled apart a 2.3 for the pan and pick-up. It was a running engine with good oil pressure. PM me your address and I will send you the pump for free (I will pay shipping too).
It just keeps getting worse... As I originally planned I couldn't get the cam pulled form the head yesturday since it rained onn & off all day. I did do a good soaking of the oil pump so I could inspect it better.
Today I finished cleaning the pump and saw more rotten news. While the pumps clearances are within specs there are some grooves worn in the side of the pump housing. At this point I now have to find a pump as I don't want to chance losing the engine over a $20 oil pump. I don't really have the money for a replacement pump but if I put the oil pump back in the engine it will fail with the way my luck has been going.
I took some pictures of the car as she sits and will get them posted soon.
Ground down quite a bit of the rust on the passender side door, and also finished filling and sanding the RF fender. I just have to do some finish work to the fender so I can get it primed and painted to match the other fender. On the A pillars there is a bulge on the top of each and I'm working to get that fixed. To be honest I can't believe how much I've gotten done on the body. The door may be temporarily fixed since it's rusted through but atleast it'll look better for Carlisle.
Tomorrow if all goes according to plan I'm going to remove the cam from the head so I can clean it up really good to make sure there's no metal shavings.
Well, at about 9 pm I was bored so I took the 1977 cars Motor repair book to the garage and checked the specs for the oil pump. It shocked me to see it's in specs by about .003". With that in mind I have the oil pump soaking in cleaner overnight- parts soaking out of the housing that is-  so tomorrow I can reassemble the pump and get it all lubed up and ready to reinstall in the engine. Figured while I had it apart to clean the crud out of it after flushing the engine I might as well be safe & check the clearances. The pickup tube will get cleaned out then bolted back on the pump. I tell ya, this car will probably run almost as good as it did when new.
While I've got the cooling system drained I'm gonna remove the valve cover and make sure there's nothing wrong under there. If I have any bad lifters I have some known good lifters ready to be installed.
More to come later.
Update.....
Today I took out the radiator, removed the timing belt, and the rear timing cover. I am going to wait until after I have the transmission pulled to remove the front seal holder. As long as it doesn't rain I'll be able to get the transmission out of the car.
Aside teardown of the front of the engine I also got some minor body work done to the fender and a couple rust spots on the door. Two spots down, about 20 to go. This is just temporary until I can afford to get a replacement door, and that'll be after Carlisle.
Pics to come soon.
I probably shoulda mentioned I'm swapping out the crank since there is some noticeable wear from what I could see on the main cap I took off. I wish I had a micrometer so I could check the journals to make sure they are within specs. Might just go & get one.
It looks to be easy enough, and difficult at the same time. I'm going to pull the transmission anyways, so changing the crank won't be too hard.
I have replaced the rear main seal on more than one Pinto engine with the engine still in the car. If that can be done I can't see why you could not change out the crankshaft. It would not be the best way, or easy, but I am sure it could be done.
BTW: I never said that the engine did not have to be lifted.
Depending on how the crank looked I would just slide in the bearings.
77 Turbo Pinto.
I too would like to know just how this is possible in the Pinto without lifting the engine. There's that dang cross member right in the way! BTW, I have a 1984 Rabbit GTI and it is possible in that and many other Front wheel drive cars. Apples & Oranges  ???
Quote from: crazyhorse on April 08, 2008, 03:59:04 PM
Ok, NOW I'm intrigued!
How ya gonna get the crank out with the engine in the car?
No, wait, better yet, beg, borrow or steal a camera, & post a how-to!
Teach me young one. ;D
I did that job on my Rabbit GTI racecar, no big deal. I did not have an engine hoist at the time.
Thanks for your support guys. Fortunately I got the crankshaft from the engine I was rebuilding and it's in great shape. It came out of an engine with only 80k miles so I'll use that one & get some bearings for it. It'll be a pain to do in the car but better to do it now than end up dead on the side of the road.
Sorry to hear that Matt. If we were closer I would bring over one of my spare running engines and help you put it in.
DANG Matt, that sux. Sounds like a rebuild is in order. I wish I were closer, I'd gladly lend a hand with it.
The picture gets grimmer.... I just pulled a main bearing cap since I already knew I was gonna have to drop the crank, and I saw the main bearings are shot. Worn down to the bronze, or brass or whatever it is, I don't care right now.... At the moment I've found I gotta get new rod & main bearings, and am deciding whether or not to pull the head & rering it while the crank is out. s for the flexplate, now I don't know if I will replace it or not. We'll see.
 >:( DAMMIT!!!!!!!!!!!!!!! THAT"S WHAT I WAS AFRAID OF!!!
OK, 'nuff yelling. I pulled the pan, lots of sludge on the bottom from the engine flush, no big deal. What is though is the fact that the rods do have play down there, not much but enough to concern me.
BTW, I didn't notice anything out of the ordinary with the flexplate aside from some ground teeth. When The tranny gets pulled I'll be replacing the flexplate. I just have a bad feeling about it.
As for the rest of the car, the floor is beyond trashed so it's gonna need major floor repair. Gotta figure out how to get a donor pan for it since it's pretty bad. The actual body of the car is is pretty good shape for a 30 year old car. The passenger front fender was replaced  cuz it had a dent in it & I had a spare. Both front doors were rotted at the corner.  As for the back half of the car, it's suprizingly good. It's got a few places that'll need patched, but overall they are in great shape. Wish I coulda gotten the patch panel for the quarter panel that was on ebay. It went for cheap on there but I had ZERO cash then.
If there's any play in the rods, it'll be apparent at any part of the stroke. Grab 'em & give a firm shake.
I looked at my post & it didn't make much sense to me. What I meant was do the rods need to be at the bottom or top of the crank journals?
Gotcha. Thanks for the tips. Do the rods need to be on any certain stroke, and how much play is acceptable?
