Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
Date: 03/16/2017 10:00 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
Date: 03/21/2017 07:47 pm
Date: 03/18/2020 01:30 am
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Date: 02/05/2017 09:45 am
Date: 09/15/2019 08:30 pm
  • Online today: 826
  • Guests: 644
  • Total: 644
1977 Pinto- project in the works
Started by r4pinto, April 07, 2008, 07:54:57 PM
I GOT THE RACE OUT!!! After soaking & soaking the pilot bearing race in PB Blaster I was able to keep chiseling until it came loose. I got it out in two pieces but it came out in about 15 minutes after I drained the blaster out of the end of the crankshaft. Blaster... The miracle cure for what is frozen.
If all goes according to plan I will be reinstalling the bottom end and get this thing back on to the road to recovery.
NExt step, tranny install.
Well, the remaing part of the pilot bearing seems froze in the end of the crankshaft. The cage & needle bearings are long gone, but the race is still stuck in there. I might have to take the crank to a machine shop to have them take care of it, or have the old crank turned since it was grooved.
More to come soon
Yes...been there, done that, on the seat thing.   Good luck, you'll find just the right ones, I'm sure.
Larry :police:
Well, the project has taken yet another turn. Instead of all black interior with an unknown exterior color I have decided to go with a blue exterior & a combo blue and black interior.
My reasoning for this is because my seats are junk & can't find any I like in black. I also have blue door panels for the car already that I was going to paint black but will now stay blue. The Tempos & Topaz's have a nice comfortable seat so I am going to go with that. I hope to get a power seat from a Topaz as those are really nice. Pretty much the seats, rear side panels, door panels, arm rests, headliner, and carpet will be blue, and the console, dashboard, and rear deck will be black. I got the image in my mind and I like what I see. It will be unique and at the same time I won't have to worry about finding black seats.
I'm thinking I might give it another go today after I get off work. Worse case I'll have to pay to get what is left out.
One thing I am trying is letting it soak in blaster for a few hours. I went ahead and filled the end up with the stuff and am letting it soak while I am working today. It couldn't hurt.
I've been there too!  I had a hell of a time pulling the pilot bearing when I put the motor in my CW.  I tried everything but the correct tool to get that stupid thing out.  I finally took a sharp cold chissel to it and a couple hours later it was out.  Needless to say I was not happy as it was about 20 degree's outside and that task took the majority of the day.  Before I replaced the clutch in my 79 wagon, I went to harbor freight and bought their pilot bearing tool.  3 minutes and the bearing was out.  It was the best $30 I spent that year!  Try the cold chissel and see if that will loosen it.  You can do it Matt!
Well, I am now a bit calmer & in the process of tracking down a radiator for the car. Tomorrow I plan on calling around to see where I can take the crankshaft to so I can get the pilot bushing, or what is left of it out of the crank. If I can't get it out I will have to get another crank. This one had only 80k miles on it so I'll end up looking for another low milage crank or just breaking down & buying a remanned crank.
The car might not last much longer. If it could go wrong after the door it did. I am one step away from saying the hell with the car and calling a tow truck to have the piece of junk towed away  >:( At one point I got mad enough that I threw my jack handle into the garage & it bounced off the radiator. I now need a new radiator. Got the crank out of the engine to find that the pilot bearing race is stuck in the end of the crankshaft. I have about had it with this car & if I quit I will junk it & never mess with another pinto again.
The only way from losing your mind on these long term projects is to just take it one job at a time.  You have already proven that you can do it.  is it furstrating??? oh hell yes and i like the part where you feel you have been working on a part for a year and it still needs work.  have faith as all of a sudden you will see positive results.  when you finish this car you are going to be proud of the car and yourself for seeing it through.
I got the front of the engine torn back apart. After I take a break I'm gonna get the car up the driveway & pull the crank so I can get the pilot bushing out of the end. While it's out I'm gonna rechange the rear main seal just to make sure it's good.
Things are really turning around for this car.
Got the lower door hinge replaced and the door opens & closes perfectly. I am happy about that. Now I am going to get the front of the engine taken back apart so I can get the crank pulled back out of the engine.
Well,
today I planned on getting quite a bit done to my car. Fix the door hinge, pull the front of the engine & crank off. Knock out the pilot bushing, get the crank back in & also install the flexplate.
Well, nothing went to plan. I spent all day messing with the stupid door hinges. I bought two kits that both went to the upper hinge after I messed up the first pin on a bent hinge. Tomorrow I hope to get another hinge pin kit so I can rebuild the bottom hinge Gerhard sold me last year. Then I can get the door to close properly & get to work on the bottom end of the engine. Hopefully I can get all that done tomorrow.
Quote from: r4pinto on April 02, 2009, 09:51:20 PM
I know Gerhard.. It's just frustrating. I try to fix one thing for something else to go wrong. I so hope I don't need to pull the dash. I hear it is virtually impossible
Back in high school I was where you were at with my 67 Mustang.  I was in a wreck that took out the majority of the perfect original parts of the car.  Next week my parents started their divorce.  I decided to focus on the car to keep my mind off my parents divorce.  The car however, decided to fall apart.  I would take one step forward and the next day the car would take me 3 steps back.  I was so frustrated after the third or fourth time that I almost sold it out of frustration.  Eventually the car started comply and things turned around.  I am so glad I didn't sell the car.  I have since gone thru this with a couple other cars.  A couple years ago, I spent what felt like a year under our explorer, trying to keep in on the road.  It seemed like every month I was doing a major repair on it.  Lately my crusing wagon has been nickel and diming me but I am slowing fixing all the little qwerks.  Unfortunately I think this is the nature of our hobby.  We are going to get into these ruts from time to time.  We just need to stick to it and fix one thing at a time.  Eventually you will get over the hump and be able to enjoy your car.  At that point you will be motivated to finish her.
Great. That is not what I needed to hear. I might be having to replace the windshield rubber and headliner sooner than I wanted to. Both need done but I don't want to do it now. If I gotta do that I might just go ahead and get her running & driving and see if I can borrow part of the garage of a guy my Dad works with.
Not really too impossible, it's just A LOT of work. I pulled the dash from a 77 Bobcat at the junkyard to keep as a spare. The windshield had to be removed for access to the screws along the firewall at the base of the windshield. Then I dropped the steering column, removed the glove box insert, radio bezel, switches, gauges, vents and ducts, heater control panel, wiring harness clips, fuse panel, dash struts on each side, then removed the rest of the mounting hardware for the dash.
It took about 45 minutes to do, but I really didn't give any concern to the well being of the other parts that I didn't want. I will admit though, I did cut the harness in some places.
That is what seemed to happen to me with the Ghost!! If it wasn't one thing, then it was another, but not to that extreme!
If I am correct in my assumption, you will need to pull the windshield to get to top dash bolts/screws.  The shield was already broken out of the parts pinto I stripped so I can't say for sure if it needs to be pulled, but I think it does?? Other then that, the rest was fairly easy. I did it myself with out hubby being around to help me.
If you do have to pull the windshield, I would defenitly buy a new rubber, and just cut the old one to get the shield out!!!! I broke my shield when I tried to pull it back out when I still had a leak. Course, I think the new rubber runs about 89 bucks, and a new shield cost me 100! LOL Not much of a difference! LOL I did lose my original shield though, but then again, I got rid of the scratches from the PO not having good wiperblades!! LOL
Good luck, and I hope you can get that part with maybe a combo of string and magnet!!!!
Don't give up on it Matt.  You can do it.  Just take one thing at a time.
Funny thing, is the problems today started to occur after I decided that I was going to get the car ready to go to Carlisle this year. I am really starting to think the car does not want to go to Pennsylvania, let alone Carlisle.
Something like that. I removed the bottom one to see what was causing my problem and that's what it basically was. A bent over piece of metal to hold it so you can adjust the hinge. The bottom one is easily gotten to but not the top one so much.
Hmm. I wonder what DOES hold that in place. I'm guessing it is just a little shelf that it sits on that is folded on the other side, cradling the metal piece.
Well, I had a wire run to pull it back up, but ran into a small problem. I couldn't get the part to stay in place. Whatever holds that piece in place was getting in the way, so I couldn't position the place. That's why I think I might just have to remove the dash.
Hmm, perhaps you can gain access to a high power magnet to put against that panel and "guide" the plate back to where you need it. Would need to be a mighty powerful magnet though, as the panel between the magnet and the plate that fell is metal itself. :\
It's been a while since I posted on my car, but that is because it didn't make it to Carlisle last year. I had one problem after the other so I couldn't get it done. The last nail in the coffin was the pilot bushing stuck in the crankshaft.
Well, I have started to work on her again this year, with a little hope of going to Carlisle. The little hope is VERY LITTLE at this point but we'll see.
Anyways, I am in the process of replacing the driver door hinges since they got mangled last year, when disaster struck again.. I couldn't get the door lined up. No problem, I figure I'm going to have to remove the fender for easier access. Well, I got it off then found out the bolts on the door were not wanting to thread, so I took the hinges & door back off the car. I got the threads fixed & pushed the door on the striker bolt  and tried to line up the bolts. Well, the adjustable plate the bolts go into fell down into the side panel. I am now trying to figure out how to get it back up there without removing the door. I went ahead and put the lower hinge on & got the door on the car since it is going to rain, but I have to fix that one problem tomorrow after work. I hope I don't have to remove the dash to get the plate back in but if I do then I do.
Lol.. Yeah, I am but it's not because I want to. I am trying to get Harrold II back to Carlisle for the first time since 2006. The trip wasn't technically completed since the car died on the way home and I want to get the car done so I she can redeem herself. The flexplate arrived today, and had a rear brakehose rushed so I could get it installed before Carlisle. It arrived today after having it overnighted. The original one I ordered April 20 through another website was apparently out of stock and I found out when the money reappeared in the account. Not happy that I had to pay $40 to have the hose overnighted but I couldn't chance it.
The car is far from done being restored as the underside is a major disaster area. She needs a lot of work under there. It has more rust under there than my 85 Omni turbo did. I might just have to help you with your car. lol
ADaughen
Man, you're flying on that rebuild.
You should stop by and get mine done.
I bet two weekends you could have it up and running.   ;D
'78 Cruisin' Wagon
I got the crankshaft & bearings swapped out today as well as the oil pump installed. It rotates nice & freely, and now I'm getting the rest of the engine reinstalled. I'm waiting for the flexplate to arrive then I can get the rest of the work done. If all goes according to plan the car will run wednesday night. If not then I WILL have her ready for Carlisle Thursday night. The only thing that will keep the car from Carlisle is another problem, but hopefully I'm done finding problems with the car.
Got the tranny out of the carand it turned out to be quite easy to be honest. I removed the flexplate since I'm going to be replacing the crankshaft & bearings & found out the ring gear teeth on the flexplate are more worn than I originally thought. I have a replacement on order, but it won't be in until tuesday. Since I have school on Tuesday that gives me wednesday & thrusday to get the transmission back in the car.
Looking forward to meeting you, as well as anyone else that goes to Carlisle this year. I got the car's back end painted silver to match the rest of the car. It doesn't look perfect but is better than nothing. The tranny is just about out of the car. All I have left is to remove the bolts to the rear transmission mount then the transmission will be out of the car. I had to take a break since it's wuite warm out & I have not drank much water today.
Hey Matt!
After following your recent progress, I can't wait to meet you and see Harold II up close and in person!  Can't bring my Pinto this time, but am planning to make a day trip to Carlisle next Saturday.  Hoping to meet all the PCCA guys and the Lincoln guys I converse with regularly online... kind of put faces with the names.  See you there!
