1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Date: 09/01/2017 07:52 am
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Date: 01/06/2017 11:42 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
2.3 carb intake
Date: 07/15/2020 09:25 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
Date: 03/27/2017 10:07 pm
  • Online today: 224
  • Guests: 188
  • Total: 188
Getting back to the Pinto after time off from it
Started by r4pinto, July 15, 2007, 09:52:40 PM
Well, today I fired up the engine for the first time in about a month. I noticed it was spewing oil out the side of the engine so I looked for a leak. I found out I forgot to replace the oil switch that broke as I was pulling off the head. After I get some more parts I need for her I'll be getting more work done to her. At this point it's ready for an oil change, fresh coolant, check the timing & finally replace the bad tranny. I'll get some shots of the engine all painted up, looking shiney.
It's been a while since I updated the progress on the car. I got the seals changed & just about have the engine back together. I think I need to seat the dipstick tube a little more, and have to do a little touching up on the water pump. It is really looking great. I plan on getting the Timing belt on the car, reinstall the old exhaust manifold so I can start the car and see how it runs. Then I will finish installation of the required parts.
Pics to come soon.
Well, today I unbolted to intermediate sprocket & the crank pulley & found the intermediate shaft seal is also leaking. While I have both pulleys off I'm gonna go ahead & replace the seals. At this point the only seals & gaskets that haven't been pulled off the engine are the crank & intermediate shaft seals & the seal holder mounting gaskets. All that will be left in the engine are the bearings & rings, and I've checked them. All are well with that.
I pulled the water pump off the engine so I could paint it since it's all nasty, & found out it was starting to show its age. I had another one bolted to the engine I'm building for the car so I went ahead & unbolted it, & painted it up. I was gonna leave it cast iron colored when I got it about 2 years ago, but decided to paint it to match the block. I started soaking the block yesturday & hope to be able to degrease the block tomorrow after work, as well as get it ready for paint. Once I get all the paintwork done I plan on starting reassembly.  More pics to come soon.
There is a number on the decal. I think it's the number for the bottle. E2PJ-6B315-CA
Also, I have been wanting to install a coolant recovery tank on my car, & while I was at a Ford Ranger found one that will work almost perfect & look original. It's a combo washer bottle/ coolant bottle & seems to be able to fit right in there after I move down the voltage regulator about an inch. Pic is of the bottle
Well, I ended up having to get a new valve cover for the car since the old one was bent beyond repair. The gasket surface was all bumped up & also bent too much. Got some pics of the replacement cover after I degreased it & then painted it.
Before
After
One more of my intake manifold painted up
Thanks, I sure am. Getting everything nice & shiney. I'm gonna degrease the bottom end tomorrow& paint the block. Once I do tht I'm gonna start reassembling it.
Scott Hamilton
Thermostat Housing & bolts repainted
Intake manifold drying after cleaning. The blue paint is what's left of the original paint.
Dipstick tube repainted
Dipstick handle repainted.
That's all for now, more to come as I get the work done.
As promised, here are some pics of the progress of the head work.
The head after cleanup & roller cam installed
Cylinder head painted
Intake manifold, No that isn't black paint, but lots of grease
Distributor hold down, intake end piece, and engine bracket
Timing cover
Intake mainfold soaking in cleaner
Got the head cleaned up a bit today. I used a brass wheel & cleaned off the exhaust & intake gaskets surfaces so it'll be ready for paint tomorrow. I also took a wire brush to the combustion chamber & removed all the grime. After letting the valves soak for about a day or so I also cleaned the valves with a wire wheel to get rid of the deposits. Two of the valves were badly carboned up so I'm letting them soak over night to get all the carbon & sludge off. The valve seals were so worn out the engine was burning quite a bit of oil at startup. Tomorrow I'm gonna get the engine degreased, and also mask off the inside of the head so I can paint it back to the original Ford Blue. I was just gonna clean up the head, slap in the new cam & reinstall everything, but I figure since it's off I might as well make it all look nicer. Pics to come soon.
Well, I got the valve springs removed & found out the valve stems were gone. They wouldn't even hold the valve in place to remove the keepers. They were cracking as I removed them from the head. As for the valves there were actually a few that were stuck when I was removing the valve springs. I'm soaking the springs overnight to get them clean of any crud that is on them. Got them in butter bowels separated by cylinder so they go back where they came from.
More to come later
Well, I got the head off the engine & found out the head gasket was starting to go. 30 years with lack of maintenence & old age was catching up to it. The followers also showed quite a bit of wear, so it was definitely time for some repairs. The engine is probably due for a rebuild since there is no crosshatch pattern, but I'm not going to rebuild this engine. I have an engine in the garage I'm in the process of rebuilding so I should be fine until then. I'm just gonna make sure the engine is all clean before I put the head back on the engine.
Just came inside from removing the intake manifold & it was filthy. Covered in all the oil from the leaking valve cover. Anyways, Found a few more issues. The intake gasket was original & looked like it was starting to go in a few places. I noticed a small hose that goes from the intake to the metal line for coolant that is getting replaced since it's the original hose. It has Ford stamped right on it! That'll be getting replaced before I put the manifold back on. Everything is covered in oil & grease so I'll be cleaning off all the parts, as well as the block before I bolt it all back together.
That's all for now, pics to come tomorrow.
Well, I have decided to go a little further in the engine. Instead of just jacking up the engine& removing the cam with the engine in the car I'm going to remove the head & change out the head gasket. I already have most the gaskets & want to change the valve seals while I have the cam out of the head so I figure whay the hey.
Anyways, I soaked the exhaust manifild bolts over night since they were badly rusted & got them out today to find no manifold gasket. I proceded to pull the distributor so I can get to the bottom intake bolts, when I found some problems with the distributor. I have a piece missing out of my distributor cap, something was sitting in the distributor cap (a long piece of hard plastic), the distributor electrical connector was broken & the wires to the distributor were actually melted. Also the drive gear is worn. I'm gonna see if I can check out the auxillary shaft without pulling it to make sure the gear on it isn't badly worn. If need be I'll pull the shaft. The PCV is clogged big time which has me concerned since I replaced it when I got the car & have only logged about 3000 miles on it since.
I have most the parts I need except for the carb mounting gasket & will get new manifold hardware since the old bolts are just about gone. I have a distributor I previously rebuilt for an engine I've been rebuilding over the years so I'll just use that.
That's all for now, more to come later.
Thanks again Bill. Found a roller cam & followers in a 93 Ranger & the cost for all that was around $30 out the door. Good thing I got there today since it was the only post 86 ranger in the yard that had a 2.3 in it.The rest were the 3.0 Vulcan v6
not a problem on that one. Gotta take backa  bad switch to pick N pull tomorrow so I'm gonna look for any of the years ranger you mentioned. might get lucky & get the parts cheap. lol
I gotcha. Thanks for the info again Bill. This'll be another time you've helped me big time.
Also, for what you pay for a good used cam and followers you are much better off spending just a little more on the roller. Keep in mind that if the person that removed it did not keep the followers in order (they will TELL you they did reguardless), it can eat the cam VERY FAST.
Thanks Bill, I'll keep that in mind. What year ranger used that? A ford Ranger was the only thing I didn't look for when at the junkyard today & I gotta go back tomorrow.
Well, I got in the car today to work on installing a wiper delay I found on a Ford truck in the junkyard & went ahead & started it so I wouldn't drain the battery. Started it up & it was running very rough. It smoothed out a little bit but was chugging really bad, & putting bad at the exhaust. Decided to pull the valve cover to see what I'd find. Just as I suspected, the cam lobes are shot. Each & every one is scratched to hell & most are worn down to where I can feel a nice grove where it rides the rocker arm. There were no cams at Pick N Pull, actually no 2.3's come to think of it. so I posted on here for a cam. Hopefully I can get this thing running better so I can get it driving again. I'm jsut glad I found this before I changed the oil. No harm in removing the valve cover gasket since it was leaking anyways. The previous owner replaced it, but overtightened it & spit the gasket so now it leaked everywhere.
Quote from: r4pinto on November 10, 2007, 09:30:30 AM
lol, you sure did & I never put it in. I got so involved with the GLH that I ignored the Pinto needing the tranny installed. Gonna be installing it within the next week or so with the help of my dad. Then I just need to bleed the brakes, change the oil, check the fluids, & it'll be ready to drive, after I drop the gas tank & get that boiled & sealed... not to mention rebuilding the carb. I know there has got to be some rust in there that gave me some starting problems.
Good idea bill, I'll do that. Prolly will make it shift better anyways.
Quote from: Pintony on November 10, 2007, 09:18:29 AM
Hey R4,
I thought I brought an c3 transmission to your house last year???
Oh well, sorry.
BTW: I put half a bottle in Connie's car (C3) just in case. You might want to put some in the new tranny, might help it last longer.
There's actually a bottle of Lucas in there right now. I was still working at Advance Auto at the time & everyone including the customers told me to try it. I did, no use. It didn't help. Yeah, you're right. It was worth a try so I did. Woulda saved me from having to pull the tranny. Oh well $hit happens.
