Date: 09/20/2018 11:01 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
1974 Ford Pinto
Date: 10/16/2017 10:45 am
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
  • Online today: 587
  • Guests: 235
  • Total: 235
Getting back to the Pinto after time off from it
Started by r4pinto, July 15, 2007, 09:52:40 PM
Hey R4,
I thought I brought an c3 transmission to your house last year???
I have never been one to belive the claims of some products as being "a rebuild in a bottle," or the like, however:
I had gotten an 80 Chevy P-U 4X4 with a bad engine (for free) and I wanted to use it for a 'yard truck' at my place. I had the snow plow for a while before I got the truck. Anyway, I found a running engine (for free, my favorite...) and dropped it in. The truck would BARLY move, and the tranny made a hideous whine when in gear. I was not looking forward to swapping the tranny in it at all, not to mention trying to find one at a 'good' price, but I did need the truck. A good friend, and auto service shop owner told me to try Lucas Tranny Treatment; I put in a bottle. Then, every day for a few days I would drive the truck a little, and it got better fairly quickly. It has been about 5 years and the truck drives fine, and makes almost no tranny noise. Keep in mind that it never leaves my yard, I just use it to haul wood and snowplow, but it will pull out a tree stump now. A couple of years ago I bought an 89 S-10 Blazer 4X4 that had a tranny that was slipping a little. I put a bottle in that and it stopped the slip. That truck is at another friends place in NH and it will go up any hill or over any rock if the tires have traction.
I don't know if it would help your tranny, but for under 10 bucks.....
The fluid level is perfect & the filter has only about 1500 miles on it. Last year when going to Carlisle it started to slip when I was at a toll booth & it's just shot. I bought the car with no fluid in the tranny, filled it up & drove it but the damage apparently was already done before I bought it. Thanks for the tip on the driveshaft. I'll hold off on the rear end for a while so I can get a driveshaft.
Thanks for the info regarding the rag joint for the power steering. I would have never thought of that. That's later on down the road, but is something I will do before taking the car on any long drives.
I know you checked it, but I will ask anyway: how is the fluid level and filter in the "bad" tranny?
If you plan to swap the rear, you SHOULD get a driveshaft from a 4spd car with a 6.75" rear, or one from a C3 and an 8" rear. The 8" rear will push the yoke further into your tranny; might never be an issue, but....
Also, if you are going to power steering, you will need the lower half of the "rag joint" assembly, they are different.
If you are pulling the engine/tranny out as one, remove the driveshaft yoke and zip-tie it into the tranny, or get another to do the same; can get messy. Plug the speedo-cable hole too.
I reccamend doing one swap at a time. Get the bugs worked out, then do the next.
Well, this time I'm getting back into my car for real. The turbocharger on my 85 Omni GLH Turbo went out & I don't feel like tearing into it right now, so I'm gonna work on getting the Pinto mobile again. Last night I got some gas for it & went to park the GLH. Got in the Pinto after putting the gas in it & it barely cranked. The battery was dead & I had no jumper cables!! I drove the GLH home, smoking all the way & got the cables out of my Corolla. Got the Pinto jumpstarted only for it to keep dying. I thought the carb was plugged up with rust again. After spraying ether in the carb repeatedly for 15 minutes the car finally started & stayed running. I drove it home, barely making it with the badly slipping tranny. This weekend I'm gonna clean out the car & wash it up a bit. The tranny swap will begin shortly after. I'm thinking while I have the car on jackstands I might go ahead & install the 8" rear end I got off ebay a while back. Dunno yet. might, might not. I also have decided to put power steering on the car. The thing was a pain in the butt to steer so it's gotta get power steering.
I'll keep posted on what goes on guys.
yeah, me too. I was bored & read the posts I had on it. That thing was a piece. rust everywhere, blown engine, missing sunroof glass... POS.. It lives on through the 77 sedan though. The green Pinto front brakes are on the 77. It's been a year & I still have to fix the missing brake anti rattle spring.
It's not even registered right now since it's sat for so long. Gotta get that taken care of. It's been sitting on asphalt so it's got no more rust on it though. Funny thing though, I bought the green 78 in Alliance and this month I got a Shelby Dodge Auto Club Buckeye Chapter meeting in Alliance. Be even wierder if it were on the same street as where I bought the green 78.
losin sux
Glad to see you gettin back into it Matt!  I still miss your mean green machine.
Steve
77 HB 2.3 C3 3.40
Hey all,
I've been away for a while if you hadn't noticed. lol Anyways, I'm gonna be getting back into the Pinto thing since I got my Omni GLH-T on the road. Did the whole Carlisle Chrysler Nationals with it & had fun, but I want to get back into the Pinto. She hasn't seen the road for almost a year & I want to start the tranny replacement on it, as well as the 8" rear end installation. I last drove it to a couple local car shows last fall then parked it with a failing tranny & junk in the gas tank & it still sits in storage. I could go out to it & start it right up after spraying some ether in the carb so it's still good. I might go ahead & pull the head & change the valve seals since it smoked a bit at startup, but that head is awfully heavy so I dunno.
Gonna be getting some replacement partssoon, so the car will be all good. Gonna rebleed the brakes, change the oil & get it registered to drive again.
