Date: 12/04/2018 07:40 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Date: 10/25/2019 03:30 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 08/01/2018 01:17 pm
Seeking parts
Date: 10/18/2020 10:35 am
74 pinto
Date: 09/11/2016 06:32 pm
Date: 08/20/2017 01:34 pm
  • Online today: 2,399
  • Guests: 1614
  • Total: 1614
Restoring my 78 Sedan
Started by dave1987, May 25, 2007, 01:09:26 AM
I have an order on Rockauto.com prepared. Going to be getting a new flywheel ring gear for the flywheel I have sitting here in the house. Hopefully I can get the clutch rebuilt in February! :D
Well so far it's sealed up damn well! Not a drop of water on my floor, carpet or under the dash! :D Keeping my fingers crossed that it stays this way for awhile. George at the glass shop said it should last me about another 20 years before the butyl dries out again.
Hey, YOU gave me the idea! :D I just couldn't remember where/why I thought to use it while I was posting.
Thanks again! :D :D
Dave, that is basically what I used on the wiper posts on my crusing wagon.  I am pretty sure you will have no more problems with leaking posts ;)
Last week we had a down pour while I was at work. While on break I went out to the car to get away from all of the timers and sounds of the HVAC hoods. While sitting in the car watching the rain fall I had water dripped onto my feet and a puddle on the passenger side floor mat.  :'(
I'm thinking it started leaking because I reused the original wiper post cowl gaskets which are pretty darn SHOT. So today while I waited for Les Schwab to check the sealing lips on the studded snow tires, I pulled the wiper linkage to reseal them.
While I did not find a true full replacement gasket for the originals, I came up with this (pictures).
I used the 1/4" butyl rubber cord I was originally planning to use to seal around the windshield gasket (it didn't work for that task). I have a lot of the cord left, some of it in clumps and a a few feet left still in cord form. I took about five inches of the cord and mashed it between my fingers to make it semi-flat and pressed it down around the wiper posts completing two circles.
After reassembly, from outside and inside, it appears to have sealed well...at least visually! It has pushed through to the inside of the cowl and mashed out around the inside.
I also used some "Ultra Black" RTV silicone gasket sealer on the bolt threads before installing them. Hopefully this works! I won't know until the next down pour though.
Just as a reference post, this is a 4spd Pinto vibration dampener. It came off a 73 Station Wagon, but perhaps it will go onto the car if I ever feel like I want to find out if it makes a difference.
1) Vibration Dampener & Hardware
2) Dirt/Crud from it after scraping with a putty knife
3) Big mess from cleaning it up with some old gasoline from Brownie's tank
Quote from: dave1987 on November 08, 2010, 09:59:49 AM
Thank you! I changed out the flasher after dropping my step daughter off at school and it works great now!
Only thing irritating now is that the replacement flasher's body is nothing like the original and has no mounting tab on it, so it just hangs behind the fuse block. Any ideas where to get one that does have the tab?
None of the aftermarket replacements have the tab that I have seen.  You will have to get one from Ford or the wrecking yards to find one with the tab.
check the relay under the dash, that could be bad Flasher relays are fairly easy to replace IIRC.
Sounds like I'm all turned around then! lol
The 78 is giving me headaches again! :(
So today it was raining like crazy and I found out that my wiper post seals are leaking like crazy! Puddles on the floor mats, lucky for me those are rubber, but that doesn't change the fact that they NEED TO BE REPLACED! What should I use to replace them with? Not sure what the original material is either.
On the way home the right turn signal wouldn't work. The light on the instrument cluster is staying on, as in solid, and the tail light and the parking light doesn't flash either. Turning on the left signal works fine though. I changed the brake lamp bulb which was burned out and looks like it has a small crack in it, but it still isn't flashing.
Previously this issue has been related to my turn signal switch getting messed up and I have to pull the steering wheel to get to it. Before I delve into that, what else should I check for? I know a bad ground could cause it, think all this rain has caused issues with the wiring?
Quote from: dave1987 on September 30, 2010, 12:23:29 PM
There are other great project logs like mine here as well. Dwayne (dga57) and Matt (r4pinto) both have great logs going that are full of info and details.
Gee, Dave... thanks for the plug and I sincerely wish I could claim that distinction, but you've got the wrong guy, my friend.  I haven't written anything about my Pinto because nothing is happening with it.  You've mentioned Matt - I would also recommend 71pintoracer's (if you're considering a V-8 swap) or larjohnson's (if stock is your thing) logs, as well as any number of others that are available here.  There is a ton of good information here but unfortunately I can't take credit for any of it!
lateniteauto, I'm so happy to hear that the information I've supplied over time has and will help you with your own project!
That is actually a big part of the reason why I post everything about my 78's progress here, in hopes that someone will find something they couldn't find else where. I also like having a project log here that I can look back onto and retrieve information I may have forgotten.
There are other great project logs like mine here as well. Dwayne (dga57) and Matt (r4pinto) both have great logs going that are full of info and details. I highly recommend looking around in the Project Logs section and reading through a few.
Feel free to contact me if you have any questions, concerns or would like some input on something. I'm almost always online! :)
lateniteauto
Dave,
  I want to personally thank you.  I have started a project of my own.  I have been reading and reading your thread here.  So much info, great detail, and a refreshing outlook on the slow day to day that is "restoring".  Your car is wonderful looking, and I can tell you have put a lot of time and thought into every detail. There have been many things I have learned from just this one thread.  If everyone was as detailed as you are about their projects, I think we would already have all the answers to little questions.  I love the way your console turned out, and I think I will use your idea. as well as a few of the others.  For someone like me, who is new to the pinto scene, it is great to find so many answers in one place.  I will contact you if I have questions about my resto/mod that aren't already answered in the forum.   Thank you again.
Went down to Transtar today and had them order the gasket kit for the transmission. It's a Ford FOG (4spd) that we Pinto owners have, so if you are looking for parts for your stock 4spd that's what to call it. The only difference over the years was the gear ratios. Although they cannot obtain synchronizer assemblies, they can get the rings and bearings. The gasket kit, Scott said, should only be about $4.80 or so, just a few gaskets in the kit. I'll have to call back some time and see about the rebuild kit with the bearings and rings.
RSM
I work on school buses and every transit bus has those. They don't last long upside down....some of those doors are heavy. With something light it will prolly last forever.
Thank you RSM! I still have them on upside down but my hood is closed 99.9% of the time. About a year after install now and still working great though!
RSM
I don't know if anyone answered the question about the gas hood struts or not but the cylinder part goes on top so the seals stay oiled. One reason they fail is because they are upside down.
Larry,
the razor blade trick works really good, as does the turtle wax rubbing compound. I used the razor blade since I had lots of overspray on the windshield, then I finished it off with the rubbing compound. What a difference that made!
Dave:  The windshield on the 1971 Pinto I bought off of Reed in Washington State needs some help too.  I thought Turtle Wax rubbing compound would do the trick.  Think I'll try the razor blade thing first.  Hope it works.  Glad to see you got your little windshield problem taken care of so easily.  Have a great day!!!!! Larry :police:
Hmm, thought I updated this from my phone. Guess it didn't finish uploading the reply.
The glass shop used a fresh razor blade and the film of hard water peeled right off! Nice and clean windshield again! :D
Since it seems I've got a nack for tig welding, I'm thinking of fixing the clutch pedal on the car. I'm using a Mustang II cable with adjuster tube on the car , but the way the cable connects to the pedal is off. The Mustang II cable doesn't have a ball at the end of it like the Pinto cable does, instead it has an eyelet. So instead of using the clip on the cable and using the stud through the pedal to hold the cable to it, I am using a bolt through the hole of the pedal, as well as the cable eyelet, then two nuts tightened against each other. Even then, the cable is off to the driver's side about 3/8" and twists the pedal. I now have a wobbly pedal because of it.
I recall someone telling me that cutting the pedal towards the top and welding it to one side of the bottom half of the pedal would probably correct this. I'm thinking it will work, and very tempted to cut the pedal and weld as said. I really am getting tired of the wobbly pedal that is really squeaky in cold weather because of it's angle and twist pressure against the pivot bushings.
I scheduled an appointment with. The glass shop, that installed my new windshield, is going to try a compound they use frequently on the windshield. If that doesn't work they have a couple other meathods they can try. I will keep you all updated.
Quote from: r4pinto on July 26, 2010, 05:03:41 PM
what do you use to polish the windshield? Just regular rubbing compound? The windshield on my car definitely needs that done.
Eastwood company used to sell a glass polising kit that worked fantastic. It was like 20 bucks or so. It would remove scratches & water & acid rain spots.
Parked the car in a bad spot at work a few days ago and the sprinklers got it.
Not sure if it's just hard water or a chemical in the city water system, but there are white circular spots all over the car. Where it hit the windshield I can't seem to get it clean just by using glass cleaner or washer fluid.
I now need to polish the windshield so I see through it clearly again! :(
Matt,
At least your car HAS a headliner! When I bought mine all that was left was a little bit back by the hatch.
But at least I didn't have to worry about ripping it to take it out. :-)
I am seriously thinking about using the stuff they sell at JoAnne's ( a craft store my wife likes as much as I like Summit Racing). It is a headliner material, for newer cars. More of a foamy felt sort of thing. Gets glued on. But that is a long way away at this point.
Mine's the same way, looks better in pictures than it does in person! Then again, it might just be us nit picking at little things that we have to deal with EVERY DAY that others never get the chance to see/experience!
Thanks Dave,
I know normally people say the pics don't do the car justice but in my case the pics make the car look better than she is. I can safely say that she has been falling apart, evident by the fact the headliner stitching ripped out over the past year, along with the flaking rear panels & everything else. I just need to get my butt in gear & fix it.
Thanks guys, I appreciate the kudos!
I'm sure your car is making progress r4. I just try to keep in mind that it takes time, more often more time than I expect, and it takes patience, A LOT of patience. I just think about what I have to do weeks before I do it so that I can get it all done the way I want it and with pleasing results. Nothing has to be absolutly perfect since it is my daily driver, but it does have to be presentable and not half assed. I do enjoy driving a car that is well maintained and visually appears that way to.
Keep at it and take your time, your ride is looking good still!
Lookin good Dave,
If you want you can work on my car  ;D You are so much better at it than I am lol.
Excellent work Dave, keep it up!! TOO stinking hot here to do ANYTHING right now.
When it's 90 degrees at 10 PM.....I think that says it all....
