Front sway bar frame brackets
Date: 07/13/2017 01:05 am
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 11/05/2020 06:32 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 09/05/2018 06:30 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
  • Online today: 2,399
  • Guests: 1533
  • Total: 1533
Restoring my 78 Sedan
Started by dave1987, May 25, 2007, 01:09:26 AM
Next set of pictures....The first photos shows the bottom of the sleeve/mount. The two black dots on the upper corners are just sheet rock screws that help to hold the unit together. The center hole is the important one. A good size sheet metal screw with a hex head is screwed in from under the dash and into the sleeve/mount, this is all that is used to hold the entire assembly to the dash. Once the deck is installed straight and where it should be, the mounting screw is tightened to secure it.
Second picture shows the radio with the cage on it. In this photo you can see the triangular tabs that push through the holes cut into the top of the sleeve/mount (as shown above). I use at least six of the tabs to be sure it stays put.
Third picture shows the "filler bezel". This goes behind two tabs on the left and right sides of the front of the cage. The hole cut in the actual PINTO radio bezel was to large, showing more not just the face of the deck, but also some of the mount behind the Pinto bezel. This filler bezel covers up that gap and gives the final install a nice clean appearance. I used 1/8" thick lexan and spent about two hours getting it to fit perfectly as I wanted. Since the Pinto radio bezel I am using is plastic and slightly warped, it took a lot of trimming to make it match up right.
The fourth photo shows the Pinto radio bezel with the hole enlarged for the deck.
Not positive about the emblems on the fenders quite yet, but at least I know how to go about adding them!
I got the radio bezel finished finally. Two years after installing the new radio and I FINALLY finalized it! :D
Here's some pictures and a little bit of what I did....
These first four pictures are of the wood "sleeve/mount" I put together. It holds the cage for the Pioneer deck, which the deck slides in and locks to. I added wood to the base of it so it can rest on the bottom inside of the dash, keeping it level and tight when secured. The holes cut in the top of it are for the metal tabs that push outwards on the cage, the tabs hold the cage to the sleeve/mount and keep everything secure and together.
1) Side view of sleeve/mount
2) Front view of sleeve/mount
3) Back view of sleeve/mount
4) Top view of sleeve/mount
Put the barrel clips on the emblem first then push them in the holes
Need to get work done on Mr. Tadakichi....Fix the radio bezel, touch up some paint here and there to make it decent, add the front mud flaps, I may change the bumpers out for the spare I have and polish the trim, but we'll see. Just over a month to go till the big show here, need to hurry!
Thanks 78_starsky, I'll see if I can track down some barrel clips at a body shop here!
Finding parts for the cars hasn't been easy here either, a lot of my stuff is either stock piled, or I get a hold of people around here. Since I drive one of the three well known pinto's here in the valley of Idaho (the only three that people ever see), I do my best to build LASTING relationships with other pinto owners and hot rodders here. Lots of people here are doing hot rods and buy Pintos for the front ends, then want to junk the rest or they sell them on craigslist for zilch! I buy up as much as I can afford without killing myself and then store it until I use up what I want to then sell the rest.
I've been stock piling parts for the past three years. Parted out/off a 77 Bobcat Wagon at the junk yard, and salvaged parts from a 78 Pinto Wagon in a near by town, the rest of my parts mostly come off other 70's era Ford cars, or I drive distances to find the parts I need, but only go that far if I absolutely cannot find what I need locally, and if I'm feeling up to a road trip! :)
78_starsky
Hi,  arrrhg  you guys make it sound soooo easy to find parts for your cars down south....  up here where I live you don't see any of these old pintos on the road let alone parts for them "pop up on CL"  lol   I do/will keep searching thou.  I did get an emblem mailed out from Seattle CL last week.  This one is one that I placed onto the valve cover,  if you are wanting to place emblems on your fenders, all I can suggest is you carefully measure out where you want to palce them,  drill the holes and be precise and then (from what I learnt taking the FORD ones off the hood) is you will need to get barrle clips/clamps and place the works into the holes.
hope this helps,  as I said  I haven't placed them into fenders (yet) but it is mainly in the measurements.
How hard would it be to add pinto emblems to the fenders, seeing as I cannot find a reasonably priced source for PONY decals?
dave I get that on both wagons now. the one I bought from fred, or my wagon that Ive had for years. youll get used to it lol
I bought it from carlharris here on the pinto forums, but I met him locally. He had it advertised on Craigslist last year, didn't know he was part of the car club until I met him and his car at a park here in Idaho. I still talk to him now and then, busy guy though.
I got it from him for $15 and a tube header for a 2.3 for $5. He was just clearing out stuff he didn't need/want anymore.
Craigslist digging helps a lot here in Idaho, no more Pintos in the junk yards with anything worth paying for anymore.
Going to a Craigslist ad early tomorrow morning to pick up the rear tail gate from a 78 wagon that I bought a couple weeks ago, and a pair of aluminum bumpers for the 78 for $20 for the pair! Keep searching, you'll get what you're after sooner or later. Patience has helped a lot with this car, more than I can say.
I had another offer on the car today, $1500, a customer at work made it. Of coarse I said no! lol Last month I had three other offers to buy the car, $5000, $2000, and $3500, in that order. This little guy hasn't got a price tag on it, why does everyone keep asking me if it's for sale!?!?!!
78_starsky
hey  back on page 10 or so  you said you added a front valance,  how much did that set you back?  and where did you order it from?
thanks
rctinker
Awsome! Thanks Dave I apperciate you taking the time to grab those pics for me. They really helped me visualize what was needed to be done. Thanks again.
Tink
1977 Crusin Wagon when I was 16
It isn't perfect, but it looks great and I like it. The space between the cubby and were the console was cut is REQUIRED. If the console isn't cut back that far, it's impossible to squeeze the cubby into it's place, which already requires some effort.
I have cut two small "blocks" out of the extra material removed from the console to fill in those spots. I originally hot glued them in place but the glue separated and they have fallen off. Need to get that all fixed before the big show here in July.
I hope this helps, Robert!
Here are some pictures of where my Mustang II console is installed under the stock cubby.
I haven't driven the car in about four days now, had some rain here and there, never bothered to check the car since it seemed to have been sealed up after my last visit to the glass shop.
Nope, still leaking somewhere. I opened the door to get in and take some pictures for Robert's Mustang II console install and found a little puddle on the driver's side floor mat, passenger's side is nice and dry though.
I'll have to hit the windshield with the hose to really watch where it's coming from, but I suspect the bottom of the windshield between the body and the gasket, it's the only place they didn't put sealant in. Between the glass and gasket all around and gasket and body all around the sides and top are sealed though.
Got the video I made of my 78 Sedan finished and uploaded to Facebook! The video is split into two parts, for upload purposes. Those of you who would like a copy of the video in it's full resolution and quality, let me know so I can send you a copy of the DVD video. Check it out!
(Copy the links below to your address bar to view)
http://www.facebook.com/profile.php?id=1062308253&v=app_2392950137&ref=profile#!/video/video.php?v=1386536377752
http://www.facebook.com/profile.php?id=1062308253&v=app_2392950137&ref=profile#!/video/video.php?v=1387497161771
Finally picked out a name for my 78 Sedan...
Mr. Tadakichi
Those of you who watch anime, Auzumanga Daioh will recognize the name. Mr. Tadakichi is the name of the main character's dog, a Great Pyrenees. In the anime TV series, the dog is a cherished family member of Chiyo-chan's family. Chiyo-chan is so small she can ride on the back of Mr. Tadakichi, and Mr. Tadakichi loves his owner(s) as much as they love him, not minding the attention he gets from outsiders. He is obedient and loved by all.
Seems to fit my 78 Sedan well! :)
The original axle is going to be rebuilt then reinstalled. Two reasons behind this. 1) I'm just way to used to driving around with the gear ratio (2.73) of the original axle, and 2) the replacement axle ratio (3.40) just doesn't work to well for driving around town in fourth gear. :(
The windshield gasket leaked today while I washed the car! :(
Lucky for me it's an easy fix. The water is coming in right above where they stopped sealing between the glass and gasket up the pillars. They only sealed 1-2 inches up along the pillars between the gasket and glass, so I have an appointment on Monday at 10AM to bring the car by and they will seal all around the glass for it! Gotta love a good glass shop with a lifetime warranty on their work!
I posted in your other thread before I read this one, you need to get the perches with a round hole to match the rear end perch. Fred prob has a couple!
Two views of a Pinto that you just don't see everyday! :P
One of the bigger problems with this axle swap is pictured below. The large bolt to hold down the hydraulic brake hose on a 73 axle is larger in diameter than the 78's breather port/hose junction bolt. Because I cannot obtain a rear hydraulic brake hose for a 73 Pinto locally, I was forced to thread a bolt into the axle tube hole to seal it over, and use plastic zip ties to hold the existing hose/junction block to the new axle until a new one arrives from RockAuto.
Another problem I ran into with using a 73 axle on the 78 was the plates that are welded to the axle tubes, letting the axle sit flat on the leaf springs. On 73's, they have round holes in them for the leaf spring/axle bushing to come through slightly. On a 78, the same hole is rectangular. Because these are not ea silly interchangeable, I kept everything as it was, and just set the round hole plates on top of the rectangular bushings, letting the axle sit about 1/8" higher than it probably should.
The next problem was the backing plates. The 78 backing plates and axle tube flanges have a difference bolt offset than the 73 does. The 73 has a smaller distance between bolts than the 78 does, so I was forced to use the 73 backing plates. I continued to use my 78 brake drums though. They do have slightly smaller stud holes, but they DO work fine without any issues!
The last problem is that the 73 axle points upwards about 1/2" more than the 78 axle did. I was greatly concerned about this when bolting the axle down, due to the change in pinion angle. Fortunately it did not make a big difference and no real problems, but it is something to be aware of!
While driving the car I notice a slight thud, most likely from a combination of the higher pinion angle and the extra 1/8" of axle height from the swap. The differential is probably being torqued upwards causing it to bounce against the rubber bumper at the end of the drive line tunnel at the back of the car.
The good news! I ended up using a 21 tooth (Red gear, P/N CODD-17271-B) speedometer gear in the transmission, it leaves me 1-2 mph slower on the speedometer than the actual speed, but I can live with that! The car has SO MUCH MORE get up and go now! First time going forwards from a complete stop and I easily squealed the tires!
5) Hydraulic brake hose bolt on 73 axle
6) Hydraulic brake hose bolt AND breather port screw on 78 axle
Well, here are some photos of the axle swap, er differences, that I took today while installing the 73 Wagon axle on my 78 Sedan!
1) 73 Axle on LEFT, 78 axle on RIGHT
2) Differential casting differences
3) Breather port on the 73 differential
4) No ports on the 78 differential
I used the Permatex RTV Copper gasket maker. in the tube.
How long does the spray can stuff take to cure?
I have had issues with this thermostat housing sealing correctly since the motor rebuild. My dad bought a NOS one from a dealership in texas a few years ago that I still have in storage. I think it might be time to starting using it now.
What kind of sealant are you using? I use the red spray can gasket sealer, put it together and go. When you work on flat rate you don't have time to wait!  :lol: I never use silicone on a gasket.
Found a little problem today while changing out the spark plugs.... :(
The it appears that the water pump and the thermostat might be leaking between the gaskets. I think I might have added coolant to early after reassembly. I will be double checking the bolts on them on Sunday while I am at my parents swapping out the rear axle.
I also noticed a drip from under exhaust port #1.  :'( :'( I don't know if it is just flowing from the upper thermostat bolt or if it's leaking from the head gasket, I hope it's just the bolt!
Sunday I will redo the gaskets on the pump and thermostat, let it sit until Wednesday, then add coolant and try again.
Once I refilled the system and let it run until it hit 190 degrees according to my temperature gauge in the car, the thermostat popped open and engine temp went down to 160 degrees, and while holding the motor at a constant 2500 RPM, it only ever got up to about 175-ish, that's with the radiator cap off.
Once I put the cap on and drove the car home, it stayed at about 180, occasionally getting up to 190 but then dropping back down. I think it's all good to go now. No leaks in the system and temperature has yet to go any higher than 190! :D
On a side note, I don't really think the PUMP was the problem, I think it was more a combination of the thermostat going out and there being air in the system. It had been awhile since I properly bled all the air out of the system and I had topped off the antifreeze a couple times in the past year. The pump doesn't spin rough or have any sticky spots when I spin it by hand, slow or fast!
The clicking sound was there when I started the car and let it idle in front of my parents before I left, but went away quickly. I'm still thinking that it is my smog pump making that sound.
I now have a new pump, thermostat and radiator cap on the car, and a spare water pump for later in case I have to special order a replacement under warranty!
13) New water pump and thermostat housing installed
14) Motor reassembled and ready to go!
I figured that while I had the thermostat housing off this time, that I would paint it since I didn't do that the last four times it was off. lol
9) Front of motor cleaned off and ready for the new thermostat and pump to be installed!
10) Thermostat housing wire wheeled clean with the aid of the pheumatic grinder!
11) Base of thermostat housing clean
12) thermostat housing painted and readying for installation!
Since I had the whole the cooling system empty and most of the front of the motor taken apart, I decided to change the thermostat while I was there. Bought a new 192 degree thermostat, the old one was a 185 I believe, I can't remember for sure.
5) Old thermostat vs. New thermostat (I'm sure you can tell which is which! ;))
6) Old thermostat vs. New thermostat (again)
7) Thermostat housing after removed from motor
8 ) Base of thermostat housing after removed from motor
Yeah, I put one on. The MasterPro new water pump came with one. I also used some high temp RTV copper gasket sealer on both sides of it just to make sure it wouldn't leak. Me and my dad had a hell of a time trying to seal up the thermostat after the first drive after the engine rebuild, turns out we didn't have the thermostat seated in the housing all the way because there was some old buildup in the thermostat seat/groove!
The New pump is a MasterPro unit, not a reman, brand spakin new! Came with a lifetime warrenty to! :D
The Old pump was a Carter, from what I can tell. It looks like it was a reman pump, as it has Ford casting numbers on it, D42E-AB. It was purchased in 1988 by my dad at a Kragen's Auto Parts store, which became a Schucks in the 90s, and is now an Oreilly's/Schucks. It only had a 2 year warrenty, but has lasted this long, 22 years later!
Now on to some pictures!
1) Difference in impellers between a "Carter" and a "MasterPro"
2) Difference in shaft mount assembly
3) Carter Pump Casting Number
4) MasterPro Pump Casting Number
Dave, you put the water pump gasket in, right? When I bought mine last year the gasket was separate. Anyway, good job!  ;D
