Date: 09/26/2019 05:31 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
72 pinto drag car
Date: 07/08/2017 08:25 pm
Date: 07/20/2018 03:00 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 06/30/2018 09:48 am
72 pinto drag car
Date: 06/22/2017 07:19 am
2.3 carb intake
Date: 07/15/2020 09:25 pm
  • Online today: 403
  • Guests: 185
  • Total: 185
UPDATE: On my winter (and now summer) project. Pics inside
Started by Glassman, March 18, 2004, 07:02:17 PM
Hey Brien.
Sorry the reply is late. Ive been pretty much working all the time, commuting to and from work, looking for a house and being sick. Ive been bed riden for the last 3 days. :(  Things will be busy for a few more months.
Turns out the tire rubbing (drivers side only) is from the axle being off center by 3/8". This pic is of the passenger side.
This is the drivers side. The photo needs to be flipped.
I took the rear suspension apart and checked the leaf springs for bows. They were fine. When I bolted everything up, the axle was still not centered. :-\
I then loosened the shackle mounting brackets and moved them over as far as I could. About 1/8". I found some washers and put them between the shackle and the leaf spring bushings. This helped a little but Im not trusting it.
BTW  The backspacing is 5 1/2". Im using a 1/2" worth of spacers on each wheel.
wagonmaster
Hey Pete!! Glad to see you haven't fallen off the face of the earth!!
What size tires are you using on the rear? What size Draglites are you using and what is the back spacing?
How are things working out in Florida? Being a "glassman" in Florida with the hurricanes must have been a pretty lucrative proposition!
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
Quote from: 78pinto on November 27, 2004, 01:04:07 AM
hey Pete, long time no talk! Hope to catch you on here soon!
Hi Jeff, all work and no Pinto makes Pete coo coo.
Thanks for the Email about your set-up SVO.
Ive been working on the VAF mount and still trying to replace rusted spots with terrible bodywork. Im still waiting for new shackles and lowering blocks. ::) They say the blocks havent left the machine shop.
Thats about it. I will be devoting about a week of 8 to 12 hour days to working on the Pinto. Hopefully Ill be able to put it on the tow-dolly under its own power.
I quit working on the wire harness and started fixing some of the rusted parts of the passenger side rear. I need to install the battery box and run the cables to the engine bay. Im also learning metal working and welding.
I just might have to get a Merk. harness. I started to install the TC harness and got mad at all the wires and connectors I didnt need. So, took the harness out and removed all the tubing and tape. I cut all the wires I could tell that I didnt need ( I hope :-\) and removed them. It was about half the wires. The harness is loosely taped and about half installed.
SVO, It looks like you mounted the VAF in the fender. If so how how did it work out? Im thinking about mounting mine there.
SVOwagon
Album looks really good. If you haven't started on the harness yet, I would go with one from a Merkur. They are much easier to work with and a lot less wires.
80 2.3 EFI Turbo Pinto Squire Wagon
91 Mustang LX 5.0 (93 Cobra clone project)
82 Mustang GT (built 460)
89 Mustang LX coupe (built 302)
83 Ranger
http://www.cardomain.com/ride/2167062
Poison Pinto
Your album's lookin' good.
I still say my wagon has more rust than your wagon.  ;D
I left my Pinto in front of my house last night. This morning there were two more left with it.
SVOwagon
I smashed and cut holes in the wheelwell area. Good thing the metal is thin. Ive decided Im not going to keep this body. It is rusted too much for me to feel safe in it. Im fixing all the major parts but am going to leave a lot of things the way they are so I can get it on the road. This car is for practice now and learning.
Right now Im installing the wire harness.  ;D Ive been closely looking at the photos on your page for ideas. Im using a TC harness though.
Ive added about 20 more pictures to the album. The descriptions are slowly coming. If anyone has a question about any of the pics just ask.
Now onto the pics.
Ready for the road. Except so far it looks like the tires might rub the fenders.
I had to cut the last bolt (of course  ::)) off the passenger side front bushing. I used a cut off disk and the garage stunk like tire smoke. I should be able to use one of the bolts from the TC.
Heres the album http://imageevent.com/pandbz/1979fordpintowagon
SVOwagon
Looks good Glassman. Did you have fun smashing down the passenger side wheelwell?  Ya, I know all about that.  I found out later, that when I switched from the IHI to a T3 that there is a lot more room. But not much. The T3 seems to sit higher. One more thing, is there anything on your ride that isn't going to be new? Just kidding  ;D   If you're going to do it, do it right...I wish I would have! ::)
83 Ranger
Ok that is right, now I remember reading about the bellhousing changing in 87-88.  I've been collecting parts for the past couple years to do my own swap.  I have an 86 setup minus the fuel pump stuff.  I forgot to snag that stuff before I sold what was left of the car :(   Keep up the good work!
I picked up an 8" rear end Monday. Its not an traction lok but it does have 3.55 gears. Its complete with all brake hardware. Unfortunately everything may need to be replaced.  ::) I should be able to swap some of the good brake parts from the Pinto onto it. A pair of new leaf springs came Saturday. I should have enough POR-15 to do the whole axle.
I have 1/4 wheel spacers coming on Friday.
A brushed alum. battery box came yesterday along with a battery wire kit complete with an 18"+1 1/2" ground strap.
A VDO 8000 rpm Tach. came too.
All I need is more  time............ :-\
Quote from: TIGGER on May 19, 2004, 01:18:58 PM
Looking good!
Did the transmission shifter line up properly with the exisiting opening or did you have to trim it to make it work properly?  I take it you are using the T-bird bellhousing?
Thanks Tigger
I did have to cut the opening about 2 inches bigger toward the dash.
The 88 T-bird bellhousing is for a hydraulic clutch set-up. Ive read and been told that its a lot easier to use a mechcanical clutch set-up. So, I bought a bell, fork and cable used from an earlier T- bird. I also had to use the throttle cable from the 88 T-bird because the Pinto cable is too short.
Looking good!
Thanks Jeff.
Ive been working overtime and doing other things so my fun time has been down. I daubt she'll be running by June 1st.  ::)
thats an awesome photo documentary! My god that sure looks clean on the front Pete, great job!
Ive added about 20 new pics taken last month to the album. Heres a few samples.
Heres the Gallery http://imageevent.com/pandbz/1979fordpintowagon
Crazy
I already have the wheels. They are Weld drag lites.
I just havent put them on the car yet.
Jeff
Im hoping for the end of the month. I havent been able to work on it as much as I had planned.
A couple of shiney wheels & you'll be "in there" Glassman. I've been SLOWLY working on the Interior of mine. It's tough to work on a car you've gotta drive every day  :(
Quote from: 78pinto on April 11, 2004, 10:37:54 PM
Are you rebuilding Pete, or did it run fine before? Mileage?
I think the mileage on the car is 155,000  :o which might be a lot for some people . Here in the Northeast everything is "out of town" so cars have a lot of miles on them. My Ranger has 177,000 and runs well. The previos owner said he had done some engine work. The cam and followers and a few other things I cant remember.
The engine ran OK before so, my plan is to get it in and get it running. I have another turbo engine that Im going to rebuild and mod a little. When thats done Ill swao it in. By then Ill probably have another wagon to swap all the new suspension parts into.
I washed the engine and trans. yesterday and they are in the garage. I should be able to drop them in this week end.  ;)
The engine and trans came out of the T-bird today.  I ended up breaking the top part of the nose of the car, by resting the engine and trans. on it.  ::) :D The car going to the yard in a while anyway. Otherwise things are moving along. I removed the accessories and motor mounts from the engine.
The engine and transmission are still connected and are in back of the Ranger. Im taking them to a car wash tomorrow to degrease them after work.
