Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
SVO SWAP
Date: 03/15/2018 03:12 am
78 fender and hood
Date: 03/23/2021 01:07 pm
Date: 03/14/2020 01:52 pm
Date: 12/10/2017 01:14 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
  • Online today: 452
30+ MPG w/ modification
Started by joecool85, August 01, 2006, 08:08:31 AM
earthquake
An easy way to raise compresson is to mill the head.You can take 60 thou off a 2.0 and still use a cam with a 470 lift without problems,This raises the  comp ratio 1 full point.However the motor is not a no interference motor any more so don't break a timing belt.The same applys to the 2.3 but the cam has a lower max lift than the 2.0.I have 90 thou milled from my 2.3 with a 60 thou increase in the piston eyebrows.
joecool85
The wagon also weighs considerably more.  I wouldn't expect to, easily, get better than 25-26mpg.  There are a lot of good things listed in this thread for mpg gains though.  First, like already stated, check your tire pressure.  Do an oil change, new air filter, tune your carb, new fuel filter (do this before tuning the carb), and use an electric fan for the rad instead of the mechanical one that comes on it.
Life is what you make it.
http://www.thatraymond.com
I meant '79 wagon.
The '80 Pony that I had way back when got MPG in the high twenties. Even got 31 or 32 MPG on the interstate to St. Louis and back. I know the wagon has a bit of a disadvantage with an automatic.
Anyway, the distributer was advanced at seven degrees before a dialed it up to 20. The previous carburetor was running a bit rich too.
I'm thinking about doing the old time thing of setting the timing by ear where you advance it until the engine runs the best and then retard it slightly until it starts to bog.
goodolboydws
A 70 Pinto wagon? Must be a typo.
I'd do a compression test first, both wet and dry.
There isn't much you can do without tearing down the engine, if the compression is low across all cylinders on a high mileage engine, for example.
I and some people that I personally know have used RESTORE (look in auto parts stores and WalMart s/b under $8 for a 4, or under $10 for 6 cyl engine) with some fairly decent results to improve compression somewhat and to reduce oil usage, but I've not personally seen a big increase in fuel mileage. (But then again none of my engines on which i've used it have been down much on all or most cylinders either.)
If you're barely getting 20 now, don't expect miracles from the engine, but changing HOW you drive and doing a lot of little things like emptying the car of extra weight, keeping the tires highly but properly inflated, checking for dragging brakes, changing the air filter, doing a decent tune up and running a more fuel efficient engine oil can together have a significant effect on your mileage.
Bumping the timing a few degrees isn't going to make much of a change in terms of fuel ecomomy, UNLESS it is considerably off from where it is SUPPOSED to be, for whatever reason. If the engine timing is now running where it should be, it WILL DEFINITELY increase the combustion chamber temperature, so if you decide to do that, you will be increasing the odds of getting a burnt exhaust valve if the engine is already using too much oil through the valve guides.
My old '70 wagon is barely getting over 20 mpg. I'd just like to bump it up to 25 or so. I'll probably move the timing up 3 or 4 degrees. Anything else?
I'm not going to screw around with it tooooo much because I'm going to drop a turbo 2.3 in it this winter.
73pintogeek
 :text_yb_lol:
Hmmmm...Glad to see I`m not the only one....guess I could take the 2.0 out of my `74 and put it in my `71 Van...I dunno...maybe shave the head`s first...and then Dyno it...no...no...put the 302 out of the van in the `73 ...I`m sooooo confused....
A bad day workin` on my Pinto is better than a good day at work!
pintoguy76
joecool85
The fuel injected ranger has 9.5:1 and runs fine on 87 octane.  My sister has an escort with 9.4:1 that runs fine on 87, again, fuel injected.  As far as I know, carbs/fuel injection doesn't matter when figuring out what you want for compression, but I could be wrong.  I do however know that you can run up to 10:1 on 87 octane as long as you keep your car tuned well (timing etc).  Also, to get 9.5 you could probably just grab some newer 2.3 internals from a junkyard for cheap.
pintoguy76
Yeah id like to have about 9.5:1 Compression. Wonder what it would take to make that. Might take some pricey pistons and they might not be exactly 9.5......which would probably require higher octane. with 9.5 you could get by with 87 or 89 octane, barly, but you could. Beyond that who knows. This kind of makes me worry that the 74 wagon im about to buy may not make the best milage in the world. Maybe i should consider putting a new head on my 76 engine and dropping it in my 74. And putting the 74 engine in the 76. Since it wont get driven too much i dont think.
joecool85
8.4 to 8.6 might not make a huge difference, but going to 9.0 does.  For one, its the lowest compression you can run E85 effectively, and for two it is one of the better mpg CRs as well as an ok performance CR.
pintoguy76
Its really hard to say what the actual compression is.....its possible it could be none of the above. All depends on pistons, heads (chambers) etc. one or two tenths of a point i dont think matters too much anyways.
joecool85
So 76 is 9:1 compression, good to know.  Now...according to http://pintopage.fordpinto.com/ the compression on the 74-75 was 8.6, not 8.4  I guess it doesn't matter too much as I'm more interested in the 77-78, maybe a 76.
pintoguy76
Quote from: lugnut on August 09, 2006, 05:05:15 PM
Thats good to know.  I can also add that I had a 1974 Wagon w/ 2.3 and 4 speed that could barely reach 20 mpg. It was my first car after school, and it was 2 years old and had around 15k miles when I got it. When I got tired of the loan  payments, I sold it and got a 65 Mustang  289 Auto that managed to get 16 mpg!
According to chiltons, the 74  2.3 made the most horsepower (102@5200) on 8.4 compression, while 75 was behind it at 97@4400 also with 8.4:1 compression. The 76-77 was 92@5000 with 9.0:1 Compression, and the 78-80 was dragging butt with 88hp@4800 and 9.0:1 Compression.
pintoguy76
Quote from: Original74 on August 09, 2006, 07:24:01 AM
If Pintoguy got 27 at 80 MPH, I am sure he could get something in the range of 32 or better at 65 MPH. Wow, 80 MPH in a Pinto...never had 3.00 gears, but man, you had to be way into the secondaries at that speed! LOL
Dave
Nope that was after a fresh tune up, on my way to kansas city a year ago. I drove 272 miles and put 10 gallons in the car to fill it up. It had awesome power, it ran like a striped butt ape. Too bad that only lasted about a week then it was back to its old self again. I dont know what was up with that but i only got into the secondarys twice that trip. Bear in mind 3.00s with a small tire like that is really equal to a lower ratio in comparison to a truck or something. I was turning some 3400 RPM. Now then that the newness has worn off the tuneup i recently made 25 at speeds varying between 65 and 75, and several stops along the trip and many hills. Not as much power either.
lugnut
Quote from: joecool85 on August 06, 2006, 07:10:19 AM
I think I know why you have better mpg than some of the other 2.3 guys.  From 77-80 the 2.3 had 9:1 compression, before that it was 8.6:1    :o
Original74
Dave
1976 Runabout, project.
joecool85
Really?  34...wow.  If I could do mid 30s, like 34-35 on the interstate, I would be totally ecstatic!
pintoguy76
Ive made a maximum of 27.2 MPG out my stock 76 pinto at 80 MPH. it has a 2.3 with a rebuilt carb (rebuilt by me and i really dont know what im doing) with the EGR wiped out, a 4 speed (no overdrive) 3.00 Gears and 185-75-13 tires. The engine has a burnt valve in cylinder number three due to an intake leak it had right there. I assume that was the problem anyways, it makes sence to me. 30 mpg should be easily acheivable. i beleive the sales ads for a pinto said they were rated at 34 miles per gallon.
joecool85
Well, I've decided that I'm going to hold out on getting a pinto till I can find a 77-78 that I like, since those are my fav years.  I think with this list:
5spd mustang tranny
4.10 gears
header and freeflowing exhaust system
K&N air filter
rebuilt or new carb
roller cam out of ranger
upgraded ignition (high output coil, silicone wires etc)
Electric radiator fan
I should be looking at about 110hp/130tq and 32mpg highway, 28mpg regular driving (for me that is 45mph backroads and stuff.)
joecool85
Quote from: lugnut on August 04, 2006, 04:55:06 PM
I bet that the 5 speed alone will get you there;  I had a 78 cruising wagon 4 speed that got 28-30 mpg.
joecool85
Thanks for the suggestions.  Good to know that 30 mpg should be pretty easy.  I'd really like to keep it carb'd.  I know EFI should get 30mpg with no mods, probably mid to high 30s with some work, but I like carbs, there is a certain magic to it.  It looks like the 2.3 might be around 9:1 stock so I wouldn't need to change the compression ratio.
lugnut
I bet that the 5 speed alone will get you there;  I had a 78 cruising wagon 4 speed that got 28-30 mpg.  It had a 2.3 with the feedback carb (Calif. Emissions)  Had an electronic/vacuum unit that would lean the mixture according to an oxygen sensor at cruising speed. However, that mpg was before they changed us over to oxygenated fuel. Probably would be 5-10% less now... How about one of those Holley EFI units- do they still make them?
I don't think the fancy ignition will help much.  At highway speed the stock Duraspark works fine- I mean, if you light the charge reliably, you are good- can't ignite it again.
  Also might help a bit to see if you can get some weight out of the car somehow.
Just some thoughts...
mike
joecool85
I was pretty sure that was from a 2.3, but I'm not 100% sure.  Someone feel free to correct me if I'm wrong.
Quote from: joecool85 on August 04, 2006, 01:03:35 PM
...a 5spd mustang tranny, they have a 0.69 5th gear.
Would that be one from a 2.3, 3.8 (?) or a 5.0 car? You do know that they are not a direct interchange, right? (the t-5 bells will interchange, but the trannys are different)
joecool85
Did some calculations and if the 4spd manual tranny is a 1:1 in 4th gear, then 3.08 gears would have the same overall ratio on the interstate.  Anyone know the gearing in the manual trannies?
joecool85
You can get 4.56 in an 8" rear.  And 4.10 would be great for a 5spd mustang tranny, they have a 0.69 5th gear.
robw
are you sure you want 4:10's in the rear end? they are awfully low considering you most likley won't run any tire over 28" tall. I got 4:11's in my 1976 chevy K-10 spinning 35's and it'll rip most cars out of the hole and still do 65-70mph fairly easily down the highway.I just think you might want something a little tamer in the rear end and are you sure you can even get 4:10's for pinto carrier. you might have to upgrade to a 8.8 or an early bronco 9 inch.just my two cents
joecool85
The more I'm thinking, the more I think that maybe something between 8.7 and 9.2 would be a better compression if I'm keeping it carb'd.
joecool85
I'm thinking raising the compression ratio to 9.5 (like the later 2.3s have) might be a good idea as well.  Maybe give a tick more hp, a little better mpg, and also be able to run E85.
joecool85
So, this seems to be the list I'm looking at:
5spd mustang tranny
4.10 gears
K&N air filter
rebuilt or new carb
upgraded ignition (no points/condensors, high output coil, silicone wires etc)
This should bring the car up to around 30-32 on the highway by my estimates, as well as 105-110hp.
