Date: 08/01/2018 01:17 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 01/24/2021 07:54 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
  • Online today: 628
  • Guests: 434
  • Total: 434
My Cruiser Wagon Project.....
Started by TIGGER, July 31, 2006, 12:23:06 AM
0 Members and 3 Guests are viewing this topic.
I finally got some time to work on the car today.  I finished my lowering block install.  I wire wheeled the drivers side floor board and painted it.  I also seam sealed the underside of the patch I welded on the drivers side.  Tomorrow I will under coat the area and drop the car down on the ground.  Here are some pics....
Thanks Pintony.  Yes, they are old Racer Walsh blocks.  I feel they are the best blocks for the Pinto.  I am not a big fan of using the the rubber isolators and normal lowering blocks.
Hey Tigger,
Those look like the old Racer Walsh lowering blocks???\
Again nice work!!!!!
I spent some time working on the car today.  I sealed the passenger side wiper arm.  I also seam sealed the underside welds and seams.  I also undercoated the passenger side floor board once the seam sealer dried.  Here are some pics of the painted floor board as well as the drivers side floor board.  I had to weld a small patch where the punctures were as I was not able to weld them up without blowing holes thru the floor.  I seam sealed the patch as well as some other areas.  I still have to wire wheel some areas before I paint it.  While I was waiting for the seam sealer to dry, I decided to install my lowering blocks.  I finished one side but did not finish the other side.  Not sure if I will have time to finish the other....
Quote from: TIGGER on September 17, 2007, 02:58:27 AM
Saw these on Ebay.  What do you guys think?
Hey Tigger,
If the side bulge will clear the door I say... Y-NOT try them????
P.S I hope U find the leak and can get it sealed...
I took the time and effort to make custom mounts for a pair of Saturn seats. I installed them both as low as I could get the right side one, because the floor has the bulge for the cat. converter. Had them installed, level, perfectly even, with the same seat height as the stock ones; they LOOKED great and everything went smooth UNTIL I sat in the car (head hitting the roof). The Pinto seats are thick and soft where the Saturn seats are thin and firm. If it were not for that bulge, they might have worked.
I plan to get a pair of my stock hi-backs re-covered. It cost us less than $200. per seat in labor to have Connie's re-done, and the place said it would be about that inluding black vinyl to have mine done because they are much simpler.
look just like a set I bought and then gave away... hard and unconfortable, I didn't like the way I sat in the seat but did get used to it after awhile. No seat release for people to get in the back seat... had a manual seat adjustment that you could turn to move the seat back forward but you had to turn, turn and turn the manual adjustment and was still a tight fit to get in the rear. The shoulder pads that stick out.... get in the way when looking over the shoulder. And finally they were Large... looked to big in the pinto.
Since we had a good rain this evening, I took a peak in the wagon and noticed a small puddle.  Now that the floor board is not all nasty I can lay on it and peek under the dash.  It looks like the passenger side wiper post is causing the puddle.  l can see where it is dripping from.  The weather lady said we should be getting some good rains on Tuesday so I will keep a watch on the car and see if any more pop up.
I hear ya Tony.  I think there are a few of us that would pay dearly for the parts we need.   There are a few items that I have been looking for for years now and I am almost to the point that I would pay just get them.  For me, I would want the NOS Mustang parts to have in case something happens to my car.  In your case I imagine you have spares of certain things that you will not sell for the very same reason.  I bought all NOS trim when I restored my Mustang in the early 90's.  At the time, it was not much more than repro stuff.  Now some items are 10X to what the repro stuff is.  NOS rocker panel moldings are $750 a pair, I paid around $150.  It's crazy.....  I really need to get my car appraised.  If anything were to happen to it, there is no way the insurance will give me money to fix the car using NOS parts :(
Anyway, back to the wagon....  I got the passeger side floor board painted and most of the underside welds cleaned up before the rain started.  I wanted to get some seam sealer on the outside welds but it just got too wet.  It looks like the rain will be here for most of the week so it will be a good time to find some leaks!  I didn't take any pictures today.
Hey Tigger,
Keep UP the GREAT work and keep sending the photos of your progress.
Your Mustang story is Y I am reluctant to sell my NOS Pinto parts now...
I have a BIG investment in these parts and I'd like to se a return on my investment.
I sell used Pinto parts cheep.. I just do not have the time to send them out much.
Thanks Tony, I am trying to do it right  ;D  For now, I plan on leaving the car orange on orange and black.  The interior is not too bad of shape.  I replaced the trashed door panels and armrests.  I have a mint dash pad for it.  I just need to do something with the front seats and paint the cargo panels and the interior should look pretty sharp.
Your door sills came out nice.  I have yet to dig thru my collection to find a nice set for the CW.  The original ones were corroded so in the garbage they went.
Years ago I bought some NOS door sills for my 67 Mustang because my original ones were all dull.  Instead of using them, I buffed out my original ones and to my amazement they came out almost perfect.  To this day the NOS ones are put away and worth 3X what I paid for them.  I only wish I would have bought more Ford trim and stashed it away as the prices for some of that stuff have gone thru the roof.
Hey Tigger,
Looks like you R doing it right!
Will be a NICE ride when U R finished.
What R your plans for paint? Interior color???
Here is part of what I did today
Today I finished welding the front floor pan.  I ground down all the welds and seam sealed both panels.   I still have to clean up the bottom and undercoat them.  I did not feel like doing it today so I removed the passenger side fender and seam sealed the cowl.  I got it back on and quit for the day.  I will paint the floor tomorrow.  Here are some pics.
I got this one out of a 73 Pinto Wagon a couple years back.
turbowagonman
Hey Tigger, what kind of Wagon is that Spare Tire cover out of?
turbowagonman
Here is what it looks like put together.  I am hoping to get some more time on the car this week.  Hopefully I can get the floors done this week.
I then replaced the dry hatch seal with a nice used one I had put away.  Then came the cleaning of the spare tire.  It looks to be the original one ;D  I also got a jack and lug wrench for it since they were both missing.  The fiber board spare tire cover was in pretty bad shape so it was tossed in the garbage.  I came across this plastic spare tire cover from an early wagon a few years ago that I decided to install to keep the cargo area flat.
Once I was done with the carpet, I started to clean the cargo area and spare tire well.  The cargo panels are in fair shape but once I am done with the floors I plan on removing them and painting them so that are all one color.
I have had the floor trimmed for some time now but have not had a chance to weld it till today.  I did not get far as I ran out of shielding gas for my welder ???  Since I was SOL on that, I decided to clean out the cargo area a little and straighten up some of the parts that I had in the back.  I vacuumed up the carpet. Someone replaced the carpet at some point as it is in real good shape.  The cargo mat cleaned up quite well also.  I had to sew the vinyl back on along one half of it.  The only thing that is in bad shape is the piece of carpet that goes behind the seat back.  It is disintegrated.  I will have to find one somewhere.
Well, the last couple months I have not done much to the crusing wagon.  I have been working on my jet boat mainly rebuilding the pump.  I trimmed the rear floor board and tack welded it in a couple months ago but that has been about it till lately.  Last weekend I ran into a snag on the boat so I decided to weld in the rear panel.  It is not best weld job but it will do.  I think I will overlap the front section instead of doing butt welds as I think it will be easier for me to weld.
One of the things that has been keeping me from getting the car smogged was the exhaust.  The wagon had the original exhaust on it when I bought it. Ford muffler and all.  It was all rotted out so, yesterday I swapped out the cat back for another used one I had from a past parts car.  The used one was in decent shape so I decided to use it instead of spending the $200-$300 for a new exhaust system.  The car is so quite now, and does not pop when you let off the gas ;D
Today, I pulled out the patch floor pan and drilled out all the spot welds from the old bracing and frame rail.  It was not too bad of a job.  I think it took me a couple hours to get everything off.  Then I cut out all the rust from the front floor of the crusing wagon.  The next job is to trim the patch.  Not sure if I will have time tomorrow, this may be a next weekend project.  Here are some pics.....
Once I get the front floor welded in and everything sealed and painted, the plan is to go get the car smogged and licensed.  At that point, I will start to drive it  ;D
I got home for work tonight kind of late.  I just went out and took a look in the car.  There is hardly anything on the passenger side floor board, maybe a trickle.  Infact it is hard to tell because I think it is frozen.  However the drivers side is different story, there was more water there than I expected.  There is a trail of water coming from the pinch weld under the fender, near the windshield.  I am not sure if that is the only one or not yet.  The same thing that I found on my 67 Mustang.  Looks like I will be pulling the fender in the near future if I cannot get to it from below.
I am sticking by my windshield gasket guess.
Quote from: bigh4th on February 26, 2007, 07:16:34 AM
Sounds to me like your cowl area is leaking.  I hope its not as there's no easy way to fix that, as I'm sure you know.
I'll never understand why ford didn't use some kind of rust-proofing in their cowls.  Mustangs, maverics, and pintos all suffer from this and its a major PITA to fix.
-Harry
All my Pintos and early Mustangs that I did paint work to, or had paint issues near the cowl, had galvanized cowls.
bigh4th
-Harry
Not much new to report.  I noticed today I had a couple coolant leaks and one oil leak.  Amazingly the rack did not leave a puddle?  I tightened the hose clamps so I think I am good with the coolant leaks.  Not sure where the oil leak is coming from yet.  I was having trouble with the clutch on my 79 earlier this week so I decided to put 79 in the garage and move the crusing wagon out in the rain.  I pulled the glove box insert but I am not sure if that is going to help.  I may have to pull the heater box too ???  We should have some good rain this week so I the plan this week is to track the water leak down.  Here is a picture of the crusing wagon on the street.  I like how it sits but there is some weight in back now.  I think once everything is put back and cleaned out, it will sit higher.  I may need to block the rear to keep it somewhat level.
I looked online some but did not find one under $100.  I did see one on Ebay but it was the Ford rack and I have the TRW one.  Not sure if it will interchange easy?  I looked thru the factory manual and it take some special tools to R&R the seals.  I will call around locally and price one out.
Tigger,
    Why do't you just replace the entire rack. They are probably still under 100 bucks. I replaced mine about 6 years ago, got it from O reillys with lifetime warrenty. They honor that warrenty too...believe me. It was 65 with tax then.
I pulled the car out today and took it for a drive around the block.  Everything seems to be ok however the steering rack is leaking pretty good now :(  I left the car out all afternoon since it is raining today and found a small puddle inside.  I could not see where it was coming from, I will have to remove the glove box liner and move the car out to see if I can find it.  I cleaned the garage floor while the car was out.  Hopefully the only leak I find is from the power steering.
This afternoon I put the drivers side suspension back together.  I installed new shocks and dropped the car on the ground.  It looks much better lowered.  I installed the hood and grille.  I topped off the radiator and started the car.  I let it warm up and set the timing.  The motor runs real nice, a heck of a lot better than the other engine.  It purrs like a kitten ;D  Once warm I topped off the transmission and moved the car back and forward under its own power.  The transmission seems to work.  The rack is still leaking though, not sure what I am going to do with it.  I don't really want to replace it.  I have a factory manual that I will skim to see what it will take to replace the seals.  I think I only need to seal the tierods.  Here is a picture of the car on the ground.
