1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 02/28/2024 02:07 pm
Date: 02/21/2022 11:11 pm
Date: 11/14/2019 04:02 am
Date: 11/05/2020 06:32 pm
Date: 09/02/2021 08:21 am
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Date: 12/09/2018 11:35 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
  • Online today: 624
  • Guests: 577
  • Total: 577
My Cruiser Wagon Project.....
Started by TIGGER, July 31, 2006, 12:23:06 AM
I swapped the horn again and it is working again.  Hopefully this one lasts as this is my last spare.
I think it is ok.  I restored the center a few years back so I know that is good.  I took a meter to wire and it seems to get power when the button is pushed.  I did not have to play with it tonight but I hope to get some time tomorrow.
Could the wiring for the horn be bad?
Unfortunately my horn quit working again >:(  I have a third spare that I will try.
Hey Tigger!
I'm glad to hear you've been driving your Pinto! Projects take time and I guess we all have setbacks from time to time. I just drove, and didn't work on my car for 3 years, and then started changing things, and haven't stopped yet. My horn doesn't work. It's the button in that aftermarket wheel, or the mounting kit, or something. It worked when I got the car. If I replace the fuse and hold the horn button in my hand, it works. Put the button in the wheel and the fuse blows. Wrap the horn button in electrical tape, fuse holds. Turn a corner, fuse blows. That's the only thing that doesn't work on my car, and I'm hoping going back to an original steering wheel will help. Also, the aftermarket wheel blocks the gauges, cuz it's smaller than the factory. Good luck with all your projects, and keep the wife happy!
75BobcatV6, I have some spares if you need one.
hmm anyone know where i could get that Steering grommet? mine is missing.... Tigger the car looks great and am glad you have it back on the road.
Thanks Dave, I will check that tomorrow.  The horn on the car has never worked since I have owned it.  This morning I pulled the horn off and tested it.  I was no good.  While I was at my mom's I pulled the horn off my parts car.  It works so now the crusing wagon has a working horn ;D  The last thing on this car that does not work is the rear window defogger.  I think it is due to the contact being detached from the window.  This is a common thing with these cars as age seems to weaken the bond.  My 79 has the same issue.  I have an NOS piece of glass for that car as the window that is currently in it has a lot of broken traces.
Has anyone had any luck bonding the contact back on the glass?  I tried some stuff we use at work for repairing traces on boards but it did not work well.
TIGGER, for the water leak, I would double check the "seal" (looks like the end of a small toilet plunger) were the steering shaft exits through the floor. I have had instances where this pops out after I have worked under the dash and I haven't pushed it into place well enough.
I hate water leaks >:(  I thought I was done with them but aparently I sprung a leak on the drivers side somewhere.  The underlayment has been damp.  I have been checking the carpets regularly since I have been driving the car and the drivers side is getting wetter.  The car sat for a few weeks at my mom's house thru some heavy down pours and was dry as a bone inside.  I am wondering if the car leaks when driving in the rain.  When I bought the car, I removed the plastic fender liners in order to clean out all the pine needles from the cowl.  I installed the pass side before I started driving the car but never got around to installing the drivers.  I removed the fender today to re-seam seal the pinch welds underneath.  It looked so so but I wanted to be sure the pinch welds were sealed up tight to prevent any leaks.  I suggest everyone doing that while they have the fenders off.  When I put the fender back, I installed the plastic fenderliner.  The inside is dry now.  I will keep my eye on it to see if it is still leaking.  While I had the car in the garage I decided to remove the heater box to clean the inside and to swap out the heater core.  There were a lot of pine needles inside the heater box.  It will be nice to know that there will be no more pine needles coming out of the vents when the fan is blowing.  I removed the seat to make it easier to work under the dash.  Before I put the seat back in I installed the door sill. Before with the seat installed, there was not enough carpet to cover properly.  The person that installed this aftermarket carpet originally didn't get everything to fit properly before he started trimming the excess.
Gerhard I need to check my Rachero since it reads way low. I have my wife follow me down the road, we use 2 way radio or mobile phones. Hey anybody got gears.  Fred   :)
Thanks Guys.  I tell you it has taken me quite a lot of time and some money to get this car to this point.  At one point I thought I bit off more than I could chew.  I thought the same with my 67 Mustang years ago but I stuck with it and am glad I did.  You just need to get over the hump and then things usually tend to fall into place.  I am not done with the CW as there still are some things I need to take care of but at least it is driveable and the wife is off my case about it sitting around.  Now I need to focus on the blue Pinto in my avitar.  That is the car that the car I originally wanted to fix up before the Crusing Wagon came into my life.
On a side note, I took the car to the swapmeet this morning.  The speedo gear made a difference but I cannot tell how far it is off now.  I wish I had a GPS unit that I could check against.  I will have to figure something out.  Also, the new used door seals did the trick.  The door frames no longer rattle on rough roads and the wind does not whistle on the Highway. It is much nicer to drive now.  The next thing on the list is the alignment and and then the heater core.
Glad to hear, Tigger. My progress has been slow - but sure - I don't imagine I will be on the road realistically until 2010, though that would be a nice 50th birthday present.
Happy trails!!
That's great to hear Gerhard. I tell ya, it's success stories like this that make me want to work on my car again. If it weren't for the friggin cold & snow I would be able to.  >:(
Update, I have been driving the car almost every day for the past 2 months.  I have got quite a few comments on it.  I flushed the heater core and got a little more heat out of it but I still think it is going to require a replacement.  Either that or it will be the water pump.  Today I changed the speedo gear to a different one to get the speedo a little closer to being correct.  I also installed some mint door seals I saved from a few years back.  I hope this keeps some of the wind out on the freeway.  The last major thing needed is an alignment.  I plan on making an appointment this coming week.
Quote from: TIGGER on September 01, 2008, 10:49:45 PM
No, I used regular Krylon.  It was quite transparent and needed a lot of coats to cover the faded plastic.  I am not too happy with the way it covered as I feel I have a lot of paint on them.
They look good, but I understand your feeling about the plastic condition. Mine (wagon) rear plastic panels are pretty nasty - dry and crumbling - I am actually considering covering them in vinyl that matches the vinyl used on the doors. I realize it's non-original, but I think it would look pretty good.
Thos crumbling plastic panels are a real problem,. and I doubt they would EVER be remanufactured!!
Update, I drove the car for about a week and a half and had to park it at my Mom's house due to other projects (not car releated) that I needed my truck for.  It has sat there for a little over a month till today.  I was happy to find the interior nice and dry inside 8)  We have had quite a bit of rain in the last two weeks and I was beginning to wonder if the interior was still water tight or if I was going to have a soggy carpet.  Anyway, it is looking like I will need a new heater core as there is not much heat coming from the vents.  It is a good thing that it is plugged as it will get me to clean out all the leaves from the inside of the heater box.  I am getting tired of having crap blow out all the time, making a mess inside.   I hope to get back to this car soon......
Today I took the car and got it smogged.  It passed ;D  I then went to the DMV and renewed the plates.  I noticed today the speedo is way off, like 15-20MPH.  I do not remember it being off when I drove the car home.  I did not change the rear end or the speedo cable.  All I did was swap out the C3's and the 13" modular wheel to 13" slots. I guess I will have to do some homework and see what tooth gear I have in it now.
All in all, the car drove good today for its official maden voyage.
So this weekend I got the AM radio working again as well as hooking up the heater cables and fan.  Lots of crap came out of the vents when I turned on the fan.  I had to vaccuum the whole car again >:(  I got insurance on the car today so if all goes well, I will go smog it on my way to work.  I went and put some fresh gas in it this evening.  The car seems like it needs an alignment but that will have to wait till next month.
Did you use any kind of specialty paint to stick to the plastic?
Today,. I painted the cargo panels.  The drivers side turned out good but the pass side came out ok.  I was not too happy with it.  They are in bad shape but look better painted.  I put the back seat in.  All I have left to install are the door sills but I have to make some of those cardboard pieces that go over the rocker channel.  After that I will have to fix the radio and the horn and the car will be done (I hope)
Tigger,
So sorry to hear of your family's loss.  Our dog, Jake, is nearly 12 years old and even though he looks healthy as a horse, I know with every passing day we're inching closer and closer toward the end.
Looks like you're coming right along with that project... keep up the good work!
We got home late tonight so I did not have much time before it got dark.  I got the kick panels in and I got the heater motor working again.  Tomorrow I plan on working on the cargo panels and rear seat..
Thanks 75bobcatv6
Here is a pic of where I left off last night.  I want to work on it today but the boss made other plans so the car will have to wait till this evening.
Sorry to hear that tigger. my buddies dog passed away last weekend, She too was fine all day was out playing and Just suddenly was Sick and throwing up. I'm sure like cleo shes in good hands where ever she might be
Today started out pretty crappy as our Pit died early this morning :( As near as we can tell, she must have had a heart attack or siezure or something as she was fine earlier when she was playing with the wiener.  She was a very good dog and will be missed dearly by all of my family.  Needless to say my family and I were all a little messed up this morning so we canceled our plans and did our own thing today.  I went out and played with the crusing wagon.  I picked up some carpet underlayment on my way home yesterday to put under the carpet as the burlap stuff was removed from the replacement carpet by one of the previous owners.  I got the underlayment down and the carpet put back.  I got the new seats installed as well as the shifter bezel and ebrake cover.  By that time I finished it was about dark so I checked the shifter to see if it sill lit up.  It did but there were a few dash lights out  ??? It took me about a half an hour to replace the bulbs.  Now they all work again.  Here are a few pics.  I will get some with the seats installed tomorrow.  After all that is done, the next order of business will be to finish painting the rear cargo panels.  I started that project last fall and never finished it.
 No need to run the sprinker on it today as it has been raining most of the afternoon ???  I just checked on it and there is no water from under the dash 8)  The pass door is leaking though, coming from under the door panel into the rocker channed.  It is a good thing the door sills are out or the carpet would be getting soaked now.  When I put the door panels back on, I siliconed some thick plastic in place of the deteriorated original tar paper stuff.  I do not understand why it is leaking.  I guess I will have to pull the panel off and run the water to see where it is coming from.
Bill, I will see if the button's on the original front seats to the car are any good.  If so you can have them.
Yesterday was a nice day so I decided to fool with the wiper assembly.  It looks like I got it fixed now.  I parked the car in the front lawn and ran a sprinker over it for a couple hours and had no water leaks from under the dash.  I had one small one from my pass door seal that I will have to fix.  I will run the sprinkler and hose on it again today to make sure I got them all.  If all goes well, the interior will go back into the car this week ;D
Glad you did not get out-bid! I still want the buttons LOL.
(that was back in the day where you could see who you were bidding against)
