72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 08/02/2019 04:18 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 08/13/2017 02:01 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 02/21/2017 06:29 am
  • Online today: 624
  • Guests: 534
  • Total: 534
My Cruiser Wagon Project.....
Started by TIGGER, July 31, 2006, 12:23:06 AM
Here are a couple pictures of the 79 Bobcat that I picked up a couple weeks ago.  I wanted to buy this car a couple years ago but the gentleman that owned it did not want to part with it.  It is a 2.3L 4spd car, deluxe interior, ralley wheels, factory tach and gauges.  He had wrecked it pretty good and had it towed to his sisters house.  It was there that I found it.  I ended up selling him the fender and some misc parts to get it legal but he never did anything with it.  He passed away earlier this year and I bought it from his estate.  The straightest panel is the fender I hung on it.  All the rest have dents.  The radiator core support is all bent as well.  I had to beat it out with a sledge hammer to get the radiator back in it without the fan hitting it.  I will eventually part it out but for now it will help me fix the wiring as all the idiot lights and gauges are working.
Here are a couple more pictures of the engine compartment.
I had some time today so I pulled the motor and transmission.  I also cleaned up the engine compartment as best I could before the rain started.  I am not sure what I am going to do with the engine compartment.  I have not found a shade of orange in rattle can that I like.  I also seam sealed the seam where the cowl and firewall meet.  Hopefully this solves my water leak problem.  I have some wiring to fix.  The idiot lights and temp gauge did not work.  After pulling the motor I found out why.  I hope to have some more time to work on it over this weekend.  Here are some pictures.
Thanks High_Horse I hope it turns out like I want it.
Tigger,
      Your doing good and you a working with a very nice speciman of a Crusing wagon.
Disclaimer......I am not just saying that cause I am a wagon owner.
ThunderPinto and I are looking forward with riding with you one day as we are with all the Pintos on this sight.
Here is the doner panel.  It will have to be trimmed as it is a little bigger than the piece I cut out.
Here is a picture of the hole and the panel I cut out.
Another picture of the engine and what is left of the engine that is still in the car.  I have not decided if I will paint the engine compartment or not.  I can't seem to find a bright orange in rattle can :(  It may end up being black ::)  I have not decided yet.
I pretty much finished the engine last night.  There is not much else to put on.  I am using all the factory clips and fasteners that I can find.  I will use my 79 wagon to route the vacuum lines when the time comes.  Tonight I was going to start pulling the transmission but I am short two jackstands.  My 67 Mustang is currently using my other pair.  I will need to pick up another pair.  I ended up pulling some things like the exhaust and shifter but it was a little tight for me.  I also fixed the parking brake.  The car was missing the adjusting rod and cable bracket when I bought it.  I have had the parts for a year now but never got around to installing it.  Once I was done with that, I started fooling with the floorboard rust.  I ended up cutting out the rear section.  It went fairly quick.  The longest part was the spot welds around the leaf spring bracket.  Here are a couple pictures of the engine.
More pics
I put the wagon in the garage over the weekend.  I started pulling off stuff off tonight.  The alternator and power steering pump was being held on by three bolts.  All were very loose and came out by hand, not good.  In addition to the loose bolts, I found some broken wires.  This is the reason why the temperature gauge does not work and who know what else.  I also think I found part of the source of my water leak.  The seam sealer is missing on the pinch seam along the firewall.  I had a similar problem on my 67 Mustang between the cowl and kickpanel.  I will pick up some seam sealer tomorrow and take care of it.
BTW, this is Tigger
Last night I pulled the oil pan and replaced the rear main seal as well as the oil pan gasket.  Today I installed a new timing belt and put all the sheetmetal back on the engine.  I then did a final cleaning and painted it.  Here are a couple pics of the finished product.  The engine out of the wagon will donate the rest of the parts as the exhaust manifold off this motor had a crack.  Sometime in the next couple weeks I will kick Tigger outside and pull the wagon into the garage for the motor and transmission swap.
Here are a couple pictures after stripping it and washing it down with 4 cans of Gunk.
I pulled the motor from my parts car a couple weekends ago.  Here are a couple pictures of what it looked like when it came out.
I found a bunch of receipts behind the glove box of my parts car when I removed the dash.  It is looking like this engine had 86K on it when the timing belt jumped a tooth.  My parts car spent the first 14 years of its life as a campus security car for a local Hi-tech company here in Beaverton.  From the receipts it looks like the car had about 26K in the mid 90's.
I installed my slots today and washed it real quick.  It looks shiny ;D because it is still wet.
Thanks, Orange is my favorite color.  The car is very similar to the one on the cover, it is just missing the aluminum slots, which I have.  I have one left to polish and then I will install them.  They already have tires so it should be quick and easy.  Maybe I will throw them on tonight.
I like the color!
BTW, did I ever thell you that my Grandpa was the Allis Chalmers dealer in Moorhead, Iowa? ;D
Yours also looks like a ringer for the CW on the cover of the '77 edition of Petersen's Complete Book of Pinto.
Here is a picture of the seat without the cheesy seat cover.  I also include a picture of my parts car that will donate its floor board and the engine;D  I hope to get some more time with the car tomorrow.
Here is the drivers side.  A little time with a wire wheel and some primer should clean things up nicely.
Now the ugly.....  It looks like it will need a full pass side floor pan.  The drivers side is solid.  It just has a puncture wound from something.  I can see the scrape marks from below.  Here is the rear and front of the pass side floor board.
While doing the brakes I noticed that the passenger side floor board had some holes in it.  I have not found the source of the leak but I decided to pull the carpet and see how bad the floor really is. The replacement carpet was glued on top of the original carpet.  Aparently the drivers side window was broken at one time.
I rebuilt the entire brake system shortly after I brought it home.  Other than collecting parts for it I have not done much to it lately.  Today I decided to install some of the part I have aquired over the last year.  I installed the door panels and arm rests.  They are not perfect but are in much better condition than the original ones were.
A couple more of when I bought it.
Here are some pics of my wagon project.  I bought it about a year and a half ago from a towing auction.  It ran and drove but the brakes were almost non existant which made for an interesting drive home.  The body is decent.  About the only rust I noticed off the bat was in the hatch.  The car had the rear slats at one time but they were removed and the holes were never filled.  Here are some pictures when I brought it home.
