1978 hatch back
Date: 11/29/2019 03:18 pm
Date: 11/02/2019 10:25 am
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 08/03/2018 09:19 am
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Date: 07/01/2019 12:23 pm
  • Online today: 628
  • Guests: 441
  • Total: 441
My Cruiser Wagon Project.....
Started by TIGGER, July 31, 2006, 12:23:06 AM
0 Members and 4 Guests are viewing this topic.
I lied, the license plate bulb was missing.  A new bulb and it is working.  Now all my exterior lights work.  I started lowering the car this afternoon.  I have the passenger side done and back together.  I am half way done with the drivers side.  I noticed that the rack is leaking out of the boots on both sides.  That is a major bummer as I just sold my spare power steering rack last week  :'(  Has anyone rebuilt or resealed them?  I think I will start another post on the rack.
Tonight, I changed out the parking light socket with another NOS unit that I had.  The light and turn signal work properly.  Now all my exterior lights work ;D  I hope to get some more time with the car this weekend.
Thanks High_Horse, it looks better than it really is but it is much nicer than before.  I have not had much time this past week to fool with the car as my dad is in town for a visit.  I have been spending most of my free time with him.  For some reason the battery on Tigger was dead this week so while it was charging today, I decided to fool with the wagon some.  I decided to get the reverse lights working.  I pulled the tail lights and one of the sockets just crumbled.  I spliced in a good used one and changed the bulbs and now they are both working.  While I was at it, I swapped out the marker light bulbs that were burned.  I also swapped the tail lights and bezels for some nice used ones.  These are not pitted and have perfect paint.  However the front turn signal is still giving me problems.  I think I will have to switch out the socket as this NOS one has a bad ground wire :(  I found the caution fan cover today  ;D
Wow!!!!   Looks like new....hope mine looks that good.
Last night I worked on the shifter light as it was not working.  I had to replace the wiring harness to get it to work.  While I was at it, I cleaned up the shfter from all the goop and dirt that accumilated thru the years.  I had a little more time so I started to restore the shifter bezel.  I repainted the trim and cleaned up the lens.  Tonight I replaced the seal.  I bought a repro seal from a 65 Mustang and modified it to fit.  Not bad for $3.00.  Here is a picture of the finished bezel.
cromcru
if you do lower your car. nice job on it. the two ways to go are. either a drop spindle or a coil over shock conversion. this way you dont have to play with ball joints or lower mounting points on the I arm
Since the car is still up in the air, I think my next project will be to lower the front.  If I don't do it now, I don't think I will.  I lowered my 79 and really like the look.  I am thinking of lossening the lower control arm from the frame and dropping the spring that way.  I don't want to mess with the ball joints.  Here is what my 79 looks like compared to the cruising wagon.
Thanks Cookieboy
I spent the better part of the afternoon cleaning up the garage and picking up tools.  I am far from done but it is better.  The clutter that was in front of the car is gone now.  My bench is some what better as well.  After dinner I installed the turn signal housing I broke.  I had to change the socket again as well because the wiring was all messed up too.  I put a NOS socket on but it still had problems with the ground wire ???  I think I got it fixed now.  After I finished that, I cleaned up the aircleaner.  I polished it up a bit but it could use more.  For now, I am considering the engine done.  Here is a picture of the engine with the aircleaner on as well as one before I started.
Aaaaa... I see, mistook Nov for Dec...
my mistake but in my defence it was almost 1:30 am when I left that post, my nights seem to be getting later and later...
Still Excellent Work and Good Job  ;D
It runs!!!!!  I had it running for a couple minutes, I had to shut it down when the garage filled up with smoke from the paint heating up.  As soon as I did, everyone was going what's that smell ::)  I wish I could be out :fastcar: it but there are a few things more I want to do since it is still up in the air.  For one I need to replace the turn signal housing I broke.  Slowly but surely it is getting done ;D
Thanks Cookieboy, but it has been almost two months ;D
Tigger, 2 more days and it will be a month since you pulled the motor... excellet work/job.
I went and picked up my 79 wagon today from my mom's house.  I brought it home and swapped the carb out.  After dinking around with that car I moved to the crusing wagon.  I pretty much finished the engine today.  I ran all the vacuum lines, using the 79 as a guide.  It is as close to factory as I can get it.  I had to dig into my parts pile to get all the correct tee's and 90 degree elbows.  I found all but one.  All I need is to add some coolant .  I tried to start the car but the battery was weak and did not last long.  I poured some gas down the carb and the engine caught but did not run right.  I know the timing is off as the distributor is loose so I will have to play with it once it starts.  The car did not have much gas left in it when I pulled the motor.  I will get some fresh gas tomorrow and try again.  Here are a couple of pictures.  The only things left to install are the hood and the caution fan thing that I can't find.  It was missing when I bought the car but I have one for it.  I can't find it at the moment ???The air cleaner is on but it is dirty.  I will eventually clean it and the lid.
Tonight, I changed the transmission filter.  This transmission looks to be in great shape.  There was no band residue in the pan.  It was pretty darn clean inside.  I also installed the radiator but I broke one of the clamps.  I will have to get one in the morning.  I plan on going to get my dad's 79 wagon tomorrow.  I need to swap the carb out.  While I am at it, I will use the car to connect the vacuum lines.  I will post some pics tomorrow.
Thanks Farmboy, it was in the 20's yesterday.  I had my propane heater going for a couple hours in the morning before I started in the garage.  It was nice and toasty when I started.
Farmboy
  Tigger, how cold is it in Portland, man it's cold up here in Wa. You must have a good woodstove in your shop to work on you project in this kind of weather.
  She is lookin great
74 Pinto Wagon
71 Runabout (parts car)
I worked on the car some more this afternoon.  I pulled the transmission back to make sure I had the torque converter in all the way.  For some reason it would not spin so I could not line up the torque converter to the flywheel.  Once it was back in everything lined up properly.  Pretty much, everything is in now, starter, driveline, exhaust.  I installed the battery and turned the motor over but it was pretty weak so I did not crank it much.  All that is left is the hood, radiator, and vacuum lines.  I also need to change the tranny filter and pan gasket before I start it.  No new pictures today as everything pretty much looks the same.
DragonWagon
Looking good Tigger! Glad someone is making headway on their project. It's hard to get motivated when it's raining or cold or snowing outside! Well, come to think about it, I did do some work on my CW... got the title transfered! Does that count?  :D
Now if I could get the ol lady to buy me a shop, I could get some of these cars out of the yard...
1976 mpg Wagon. The start of it all.
1977 Cruising Wagon, to be turboed.
1979 glass hatchback. No motor atm.
1980 wagon parts car.
Thanks guys... Tonight I worked on the car some.  I replaced the lower rubber fuel lines.  I also swapped out the transmission wiring harness for a better one.  THen I installed the transmission (C3).  Man that sucker is heavy.  All the bellhousing bolts are in.  The ground cable is connected as well as the transmission dip stick and starter wire holder.  I ended the evening with replacing the rubber line for the vaccuum module thing with the correct metal line which I still had from the parts car this transmission came from.  However I do not really remember how it goes since it has been 5 years since I parted the car that particular car out.  I think I have it correct on the transmission but I am having problems getting it to look right up top.  I think I will post something in the general help section.  I have the cross member in but it is just holding it in for the time being.  Hopefully tomorrow, if it isn't too cold, I will work on it some more.  I would like to get the transmission finished, speedo, shifter, tranny lines, torque converter, driveline, etc
wagonmaster
Hey Tigger!
Looking good! I just hope mine ends up looking as good when I get to that point!
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
Hey Tigger,
Looks GREAT!
The pilot bearings are a PAIN!!!!
R U going to clean up the hood latch?
That would finish the job!!!
Here is one more picture of the engine compartment without the engine.  It was still early when I finished so I decided to drop the motor in.  I ran into a snag with the stupid pilot bearing.  Since the cruising wagon is an automatic and my parts car was a 4spd, the pilot bearing had to come out.  It took me three hours to get the stupid thing out.  The hook on my slide hammer was too big to fit thru the hole.  I packed it full of grease but that did not work.  I ended up chiseling the thing out.  What a pain in the  :showback:  Once it was out, I installed the dust shield and flex plate.  Here is a picture with the motor in the car.  Hopefully I will have time on Monday to work on the car.
I had some time to work on the car today.  I painted the engine compartment over Thanksgiving weekend.  The color is a little off.  I had a hard time finding a decent shade of orange.  Last weekend, I put the majority of the engine compartment together.  Today, I fixed the wiring harnesses that was broken as well as the wiring for the voltage regulator.  Here are some pictures of the engine compartment ready for the engine.  It is not perfect by any means.  I left the firewall alone as well as the upper half of the driver side as the original paint was not too bad.
wagonmaster
Hi Tigger,
I concur about the windshield weatherstrip. It leaked in such a way that it appeared as though it was the heater core, so knowing the top quality of the Ford heater cores, I bypassed the heater core and, low and behold, I STILL HAD THE LEAK!! After practically drowing my car, I found the leak in the lower passenger side windshield weatherstrip. Once I sealed it up, no more problems! I have a new weatherstrip that will get installed eventually.
Brien - wagonmaster
'85 LTD LX
Thanks for the tip, I will keep that in mind when I start hunting down the leak or leaks.
Hey tigger, you might want to check the gasket and sealing surface around the windshield.  My old 78 sedan had that problem, though decidedly less so than yours, as mine didn't rust through.  My gasket had cracked right above the heater core (oh the time I spent troubleshooting THAT for nothing) allowing water to get in anytime the car got wet.  I took it to one of those DIY car washes and had a buddy spray the car while I sat inside.  Found it in less than ten minutes.
Bring quarters!
Another way to go would solve your engine bay goo too.  Get yourself a power sprayer.  Then you can try to find your leak, and degrease the engine bay, all from the comfort of your own driveway.  Just a thought.  Very nice work by the way.  I have always liked the leaned back look of those 77-78 cars.
Thanks, it was not as nice as I originally thought.  I was a little blindsided by the floor board.  I am not disapointed, as the price was very fair since all the cruising wagon stuff is present and in great shape;D  I think once I am done it will be a decent car.  I will be positing an update soon, I just need some time to clean a few things up.
78PintoProject
very nice 78 cruiser wagon :hypno:
Thanks, my wife has been getting after me for the past year to get working on it or get rid of it.  I dinked around off and on but finally got working on it this fall.  I hope to get the motor and transmission swap done and running before Christmas.  I want to get my Mustang back in the garage as soon as possible.  I would like to get the floor board done as well but I think that will be a while still since my other Mustang on the other side is in the middle of a disc brake conversion.  I don't want to be welding with it in the garage.
There were a bunch of pine needles in the cowl when I bought it.  I promtly pulled the hood hinges and the inner fender liners and cleaned them all out.  I ran a ton of water down there and did not see any leaks.  However the leak has got worse since I got it.  Last winter the water started to puddle where as the year before the carpets were hardly wet.  THere was just a lot of moisture inside the car.  I will see when I get the car back outside.
You get a lot more done than I do, great progress.
If the sealant on the cowl to fire wall seam does not fix the leak, check the stand pipe inside the cowl that feeds fresh air to the heater box (about 8" diameter).  Leaves collect around the pipe keeping the area moist and Ford's painting in there was not the best.  On about half the Pinto's I had, this area rusted through allowing water to puddle on the passenger floor.  Of course I live in Florida where it rains every day in the summer.
A couple more pictures
