  • Online today: 531
  • Guests: 166
  • Total: 166
73 Pangra Project
Started by turbopinto72, May 05, 2003, 06:42:14 PM
I extended the clutch cable bracket to add more length to the cable for the 5 speed bell.
For the breather tank I shortened up a standard Summit breather
This is the throttle cable/bell crank. I use a portion of the stock unit attached to a bell crank and a Lokar 24 inch cable to the carb
The front shot. I have some detail shots that will show some of the different fab parts.
Here are a few of the most recent pics of the motor.
oh your sneaky!  I like that!
 This is where the NOS solenoids are mounted. This is the bottom of the carb plenum. Cant see them from up top.
front view. I still need to weld up the 2 seams.
 Here is the shroud I just made to cover the top of the radiator.
 Thanks, I think It will do well on the street ;D
streethorse
seriously wicked lil horse. hope my lil horse comes out that nice.
86 5.0L conv. Stang
85 4x4 F-150
78 Pinto Runabout
98 Ranger
Custom Chopper
 I dont know if any one else does this but this was my idea of how it should work.
Nice work Brad!  Did you come up with that, or is it a common 2.0 trick?
 Here is another view
 There were a few guys asking how I adapted the T5 to the 2L block. Here is a pic of the adaption. I used studs in the bell and notched it low for a bolt into the block.
 Jeff, I agree this T4 would not be my first choice of turbo's from the selection "today" to choose from. One of the nice things about the T4 exhaust housing is that its a center flange housing and allows the whole turbo to hang lower off the manifold than a T3 exhaust housing would ( which is an offset and raises the whole turbo "up", off the manifold). The T3/T4 stage III is what I use on my 2.5 Aluminum head motor in the Green Pinto, However, If I was doing it again I would opt for a T66 ballberring turbo which has a better compressor map for my motor than the T3/T4.
the  hot side A/R sounds good....but it really depends on what the compressor side is ;D   A full T4 is a fairly large turbo for a 2.0 liter engine....but obviously Miller knew what he was doing! I was going to do a full boggie 2.3 in mine, Essliger head, stainless header and a T3T4 hybred with a stage III .63 hot side and a T04 "E" 50 trim compressor......a set up good for over 400 hp   But i changed my mind, then i was going to twin turbo my 351, bought two T3's rebuilt them and changed my mind again.....decided a N/A 351 with EFI would be easiest and best. Here is a pic of the turbos
 The turbo is a T4 with a .69 AR and an "N" turbine wheel. Its probably not the " best" turbo for this combo but it works well.
Hey Brad, what turbo is that?  T3 or T4 .....or maybe even T3T4 hybred?  What are the A/R numbers on it do you know? I'm kinda into turbos a bit.
TurboPintoDude
Just an idea Brad, but throw a lil color between the spokes... Might look nice... I can tell ya got more money and time to spend on yer car than I do mine, I thank I did good if it runs and none of the wires smoke... LMAO!
Ok guys I think I found the perfect wheel for this Pangra. what do you think
This just showes the oil cooler lines and remote mounted oil filter.
New Picture of the Radiator and oil cooler as of 7/5/03. I will be building a shroud for the top in polished Aluminum
Here is a look at the oil cooler and fuel filter\regulator. I dont have the bracketry as I like it yet but its a start.
Here is the side view
Here are 2 new pics of the Turbo and carb set up.
ChrisMiddleton
Paul, The bellhousing is a 1984 SVO bell with the cable type pull for the throughout. As for the 10 spline  you will need a 10 spline clutch disc thats fits you flywheel and pressure plate and thats it. The T5 is a 10 spline. I dont know if this pic helps but here is the drivers side.
pintoautocrosser
Hey Brad, what bell housing are you using for the T-5?  Is it the later hydraulic clutch ones or the earlier cable or even the T-4 bellhousing that Bugsturbo has mentioned?  I'm doing this swap soon as my T-5  came out of an 87 T-coupe(have hydraulic clutch bell housing).  A picture of the other side would do wonders for me.  How did you switch to the 10 spline?  Was it just a disk swap or did you have to change the pressure plate as well?
