'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Date: 03/06/2017 01:24 am
Date: 09/22/2020 11:33 pm
Date: 04/27/2018 10:28 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
  • Online today: 452
73 Pangra Project
Started by turbopinto72, May 05, 2003, 06:42:14 PM
Cool
That bushing doesnt look too shiney after you deglazed it on the sander. ::) :P
 The bushing installed.
 you will need to put a slite chamfer on the end also. A before and after look.
 the final product.
 And then ran it at a 90 deg on my sanding center.
 here is how I did it. I chucked the bushing up in my cordless like so.
 size difference, The kit comes with a 1.390 and you will need to turn it down to a 1.02 ish size.
 The Big end.
 Next was the spring/shackle kit. I ordered a kit for a 67/68 mustang from summit part # PTP-6-1051. This is a Prothane urethane kit. The dimentions were correct except the OD on the small side ( shackle end). I did a quick mod on that and it all works. Here are some pic's ( some not verry good) of the install.
 Here is a closer pic of the extra spring and clamp.
 Here is the spring package together ( dont worry Jeff I will be painting the clamps shiney black) I left the clamps un-painted so you can see them. This is how the spring looks with the extra leaf.
 Here is the cool part. I made them. YES ITS HARD TO CUT A SPRING.....However It can be done with about 4 sawsall blades and a can of WD40 per cut. I used the second leaf from a spair leaf package I had and was able to get both pieces out of it.
where did you get them from brad? How much $$
 This Pic shows the order the springs will go in.
More info to come as I get them together.
 Here Is a pic of the spring package. As you can see the spring size gets smaller from the main leaf down to the smallest that sits on the perch. The leaf in the foreground is the extra leaf I am adding. As you can see by lineing up the center hole of them all, the 1/2 Leaf is forward of center and on top of the main leaf.
GO BRAD GO............GO BRAD GO!
 Today I was working on the rear suspension. Got the leaf springs all apart and cleaning them up. Im going to add one leaf ( 1/2 leaf) to the front side of the spring and clamp it up for an anti spring wrap deal. I ordered my shackle kit ( rear shackle and front eye) from Prothane ( kit # 6-1051), my rear sway bar brackets and end link ( also Prothane). I also bought from Ebay ( I hope this guy does not flake cuz I payed with Paypal) a PowerTrax No-Slip posi unit. I say that becouse I payed on Thursday and still have not heard from the guy ??? After I get the suspension installed and the rearend in, I can build my fuel cell/NOS/battery box unit that will be recessed into the floor of the trunk ( leaving enough space for the 3" exhaust, I hope :o
no updates lately bro......still working on it?
pinto_351
 I will keep my eye out of one.
pinto_351
brad # 1 i need a hatch like the one you have in the pic on your green car.  know where i can find one?  Do you have one?
Thanks
Brad #2
Here Is Tony, the guy who is writing a book on ford cars. He spent about 3 hrs at my house taking pictures for the book. Mainly he took pictures of the Red Pangra but he also took a bunch of pics of all my other ( stuff)
SIGH i guess now that tennessee FINALLY has a lottery I MIGHT be able to do that to my '74
Till then i'll just begreen with envy  :'(
looks great Brad......LOVE the shiney! ;)
pintojoe
Looks good to see a 2000cc live on with some boost. Here's a picture of my old 72 that I turboed back in 1985. As often said, wish I still had that car!
1973 Pinto runabout, 2000cc,4spd.
a shot of the fans
I routed the heater hose down so it would not crowed the top of the motor and built a heat shield for it, ( the 3" exhaust down pipe im sure will get a little hot)
Here is the crossover tube that I will later paint the color of the motor.
