need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
free transmissions
Date: 11/28/2019 10:21 am
79 pinto steering column
Date: 08/18/2018 02:00 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 05/15/2022 11:36 am
Date: 09/12/2018 12:33 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
  • Online today: 376
  • Guests: 380
  • Total: 380
73 Pangra Project
Started by turbopinto72, May 05, 2003, 06:42:14 PM
May have to post links.
I just tried to Google it & all that would show up are Pantera cars.
This car will be up for sale on Ebay starting 11-4-14
I just posted a bunch of pictures in my Ad in the classified section
This car is now for sale. Please see the classifieds . You can also use this thread to ask questions etc.
tinkerman73
So, how is the hot pants kit coming? This is something I would certainly want to get in the uture. Also, how much different would it be for the 77 wagon. From clip from a later model car. Thanks.
Jody Michielsen
I hated to drill a hole in an Ak Miller manifold, but some things cant be helped........ :o
OK, so this Winter I will be installing the Waste gate mounted on an Ak Mller Ex manifold. Below are some pictures of it.
Another thing I did was install a blowoff valve. Hard to see under all the lines.
I used an Offenhouser manifold ( because I already had it )But I did a little work on the inside of it. Those you you that know what the inside of one of these looks like can appreciate the work... The second pic is one I lifted from ebay. Look at the center section of the plenum.
There is a few things I did to this carb to prep it for boost.One of the things I had to do was cut the choke horn off. It was in the way of the air flow through the Hat.
OK, So after I ran and tuned this combo I discovered, via a wide band O2 that There really is no way to tune this the way I need to. The Holly 500 can be tuned for idle and off idle OR for when the boost comes in. ITs Either to lean OR to Fat Soooo, I solved the problem by installing a Holley 650 double pumper. See below.
The car sounded great. I did have the muffler on it though. Probably wont get it on the street untill next weekend. I still need to adjust the clutch and my oil pressure guage is not working for some reason ( Its not a probblem with the oil pressure but its at the guage ).
Quote from: turbopinto72 on February 23, 2009, 07:43:23 PM
I got the car started today. Fired right up ( I hope that is a good sign ).
did it sound 'right'?  with or without a muffler?  did you get it onto the street?
map351
Yep,the 685 Mallory. Started having tuning issues power degrades then up in smoke..
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
Thanks for the comments guys.  ;D
I've put some time in this motor and appreciate the thumbs up.
MAP351.... Do you mean the 685 Mallory Hy Fire ignition? So far its been preforming well. What is it about the ignition that goes bad ?
Thanks
map351
If you happen to have a tuning issue go for the 685 first, We lost 3 685s last year..
73 2.3Turbo Pinto
Pinto FiberGlass
WOW!
I bet you get a a lot of gratification knowing that you've done it all by YOUR hands, and that such a beautiful work of art resides in your garage. :D
Agreed, a work of art.
And the front end of the car.
The intake side of the car.
Another picture of the exhaust side of the car.
Here is the wee-lil beast basically put together. I still need to put the shine on the car.
A work of art of the highest order :drunk:
redmustangman3
Brad: That looks awesome!!! Will we get to see it up close at Knott's? Hope so.....Joe
1971- 289 V8; B&M C4; 9" with 4:11 posi. Several suspension upgrades and body modifications.
1974- 2.3L wagon,4-spd,totally stock. Medium lime yellow, avacado interior, 99k miles.
1972- 1984 Mustang SVO turbo; 5-speed tremec; 9" rear w/positraction; fiberglass front & doors; upgraded suspension.
Here is a picture of how it looks from the top.
This Picture shows the large pipe where the filter will mount and the connection ( still need the 90* ) to the innercooler.
This is the Hot side of the plumbing.
