72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
Date: 05/22/2018 01:54 pm
Date: 06/18/2018 03:47 pm
Date: 08/02/2019 04:18 pm
oldskool787
Date: 02/12/2017 12:42 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
Date: 03/23/2018 09:23 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 11/11/2019 04:49 pm
  • Online today: 445
  • Guests: 378
  • Total: 378
73 Pangra Project
Started by turbopinto72, May 05, 2003, 06:42:14 PM
 Here is the fuel pumps completed with wireing etc.
 Here is one more. ( I know, it looks like there are two pair of wires and two stainless lines but its just the reflection of the mirrior polish on the aluminum)  ;D
 I thought I would post a few pic's of my trunk now that is done. Please do not pay attention to the finger prints on the Aluminum. I was having a hard time with the glare and the flash would bounce all over If I cleaned it up. Note the power cut off switch on the side wall.
wagonmaster
Brad, they are a direct swap into '65-'70 Mustangs. Very common swap.
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
 If you look at the FAQ section in the Front disc brakes you will see what im doing with the 5 lug Granada rotors. BTW I went to the junk yard yesterday 9/8/04, and ALL the granada's had the front spindle, rotors etc pulled off. Hmm, I wonder what thats all about.
Im just finishing up the trunk this week and am going to start the 5 lug Granada rotor swap. Should be a hoot  :P
My eyes! 8)
Looking great.
Jeff.
How about  a chrome headliner?  ;D
I cant stand seeing my little red wagon just sitting in the parking lot. :'( In about half a year Ill have a garage though. :)
bricker4864
That is by far the shiniest trunk I have ever see. I don't know if you should polish it; you won't be able to see anything. Get out the welding helmet!
Jeff- I think you are going to have to buy multiple parts to equal the shiney factor here.
i'm searching through my parts cataloge right now, looking for something new and shiney......so i can keep up with the you!
Oh I forgot to say that is not polished up yet........ :P
Here are a few of the latest pic's of the trunk area. I hope Jeff thinks it's shiney enough. BTW, yes the battery is under that Billit lid.
Yes, thanks for reminding to post. The tank Is a Summit 15 Gal tank with foam and a sender.
Quote from: bricker4864 on August 17, 2004, 09:37:36 PM
Did you do all the welding on the aluminum? They sure look like some damn fine welds if I don't say so myself! :o
How thick is it?
Im pretty sure Brad bought the cell from Summit.
Thanks for the pics they are helping out a lot. At first I didnt realize you had a "floor" in in the frame. I think Ill do the same. I was planning a removeable frame also. Im still planning on swapping everything into a better body in the future.
Dont tell my wife, but, Ive been looking in the classifieds for another Pinto. Im really using a lot of will power to keep from buying one. Im going to keep with a wagon and thats making it a little easier to handle.
 A little closer look.
Here is a pic of the fuel pumps and lines. The left pump is for the Engine and the right pump is for the NOS.
Pete, here is a picture of the cage out of the car and painted. It is 5 3/4 deep which puts the dropped area of the tank just at bottom of rear vallance level.
I ended up cutting the wheel well right out of mine and bought some 1"x1" steel to make a frame like yours. Too bad I didnt have enough time to start welding it up.
The pics are going to help me. Thanks.
bricker4864
How thick is it?
And the view from the bottom. I will post next with the fuel system installed and Al. skin installed.
Another view.
I've been working on my fuel cell area of the trunk. Here are a few pictures of the lowered cage I bult to house the fuel sump, battery and NOS. Its not shiney yet but it will be soon.
1repuwannabe
pinto joe where?how did you make or get youro turbo setup???   i didn't know that i could turbo my 2.0... any pointers???
 Yes It is a shiney Aluminum Driveshaft.
losin sux
Is that one of those nice light weight aluminium drive shafts I see in one of the pics?   It is something SHINEY whatever it is!
77 HB 2.3 C3 3.40
 here is the shackle installed with the new urethane bushings.
 Here is the mounting section. as you can see, there is a lot of stuff on there. I have the 1 inch lowering block, pinion angle wedge and extra spring added to the mix.
The 8 inch is installed. Here are a few pictures of the install. I have not painted everything ( shiney) yet becouse I wanted you to see the different parts. By the way, the pinion angle  is NOT yet set correctly. I will have that corrected next and show you what I did.
well yea.....its a Canadian car....eh..
 Yeah, but I dont feel too bad becouse I saw pic's of the under side of Jeffs car and it has ( shh, rust) :o
