1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 09/21/2018 11:35 am
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
Date: 06/05/2018 09:13 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
Date: 02/28/2018 09:37 am
Date: 10/01/2020 02:00 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Date: 12/09/2018 11:35 pm
  • Online today: 484
  • Guests: 509
  • Total: 509
Borg Warner T-5 speed install
Started by Pintony, October 18, 2005, 08:06:36 PM
This thread has most of the info I'm after but it doesn't reference the stepped dowel pins. Does anyone have a source for them? I remember someone on here was making them.
What is the part number & manufacturer of the 10 spline disc that fits the 2.0 pressure plate?
I've seen how Turbopinto72 got the upper holes to work but has anyone tried welding some material to the bellhousing to bolt to the 2.0 upper holes?
Here is the post I made on the D5 & D9 bellhousings. They aren't too hard to dig up but they aren't cheap. I haven't decided which one will go in which car yet.
http://www.fordpinto.com/pinto-faq/comparison-between-d5-d9-direct-pull-bellhousings/
For a clutch I picked up an '87 TurboCoupe flywheel part#50-703 through Advance Auto Parts & I got the TurboCoupe clutch kit part #MU47827-1 since you need a 10 spline clutch disc to use with the T-5. I also Have the complete clutch/flywheel assembly that's in my '87 Mustang parts car. This should be virtually the same as the new one.
None of my T-5's are from turbo cars but they are all 4 cylinder versions that take a speedo cable.
I think any 2.3 starter works. I have never heard anything to the contrary.
Hello,
  Welcome to the world of Pinto's.  I see that you are commenting off a post that is nearly 6 years old.  A number of years ago "Pintony" was barred from posting to this forum. I will leave it to someone higher up in the PCCA to explain why.   Additionally, Pintony was not a fan of converting a '71-'73 Pinto from stock (in most cases).  That said, I have a '73 wagon that I have converted to 2.3 Turbo and a T-5.  I'll do my best to answer your questions:
1 & 2 . The T-5 had only one ratio set with the 2.3 motor. Mine is a '88 ('87 is the same) T-5 and I converted to an '86 bellcrank. The '87-'88 hydraulic (at least as used in the Turbo Coupe) is NOT the way to go. I'd recommend the bellcrank because of availability and the fact that the arm needs to be bent slightly to align (when moving the cable upward to clear the suspension crossmember).
3. I assume you are talking about the transmission crossmember. Reverse it and slot the bolt holes. I slotted ALL the holes to give a little flexibility. If your talking about the suspension crossmember I cleared the cable over it by using a small metal plate (with two holes) that bolted to the original cable hole and then the cable. It moved the cable upwards and slightly outwards.
4. I believe all the 2.3 clutches are basically the same.  The clutch and pressure plate from the '86 I got the bellhousing from looked great and I used them on my '88 flywheel.
5. I have no experience with the D-4, D-9 bellhousings.
6. I think the Turbo trans was rated to the engine output. Not sure if non-turbos were rated differently The input shaft for sure is a different length than the V-8 transmissions.
7. I swapped over from a C-4 automatic and I just reused that mount.  The '87-'88 Turbo Coupes has a round mount that if it even would work needs fabrication to use.
8. Yes, the transmission crossmember bolt holes (as stated above) will need to be slotted.
9. Shift mods will depend on your size and preferred driving position.  I made a plate to move the shifter back about 2" as well as shortened it by cutting and welding. It is my opinion that the shifter is too far forward. I also feel the shifter is too long. But, I'm 6' tall, long waist-ed and prefer my legs out straight.
10. I'll make a guess on the starter motor and say no, it shouldn't be an issue but can't confirm for sure.
If you search my posts "Wittsend" you can see write-ups and pictures of the swap.  Hope this helps.
Tom
earthwizard
Hello Pintony. I'm want to install a t-5 trans into my 2.3L 1973 Pinto sation wagon. I have read everything I can. I still have some questions if you could help me out that would be cool. I'm looking for WC T-5 trans with the bell crank type of bellhousing, if I'm not mistaken. I found A 1987 T-Bird turbo trans, complete from flywheel to shifter.
Q. Is the 1985-1986 Thunderbird 2.3 Turbo trans a better set up than the 1987 2.3 Turbo, for this mod?
     a. Are they the same? Besides the gear ratio's?
Q. To use a cable type clutch vs hydraulic. What is going to be the best bell housing to use?
     a. The Original one from the 1987 T-Bird?
     b. A D4 or D9 has been mentioned?
Q. What mods will need to be done to the crossmember with my future set up?
     a. Flip the crossmember 180*?
     b. Notch the crossmember?
     c. Build a custom bracket off the bellhousing to accommodate cable hookup?
Q.  If I was to use a D4 or D9 bellhousing can I still use the T-Bird factory clutch?
Q. Will I need to modify my bellhousing, when using the 2.3L engine?
Q. Is a T-5 Thunderbird 2.3L Turbo trans better than a non turbo trans?
Q. Will I need to use a different trans mount?
Q. Will I need to notch the trans mount?
Q. Will the stock shifter from the T-Bird need mods?
Q. Does any of these mods with the Flywheel/clutch assembly effect the starter motor?
I'm sure I have more questions. Let's see how this works out first. Thanks' for any and all help! :-\
gearhead440
Thanks Pintony!  You are the man :male: !
Hello gearhead440,
I used the stock Pinto clutch cable. I did have to take the mounting tab loos from the inner fender but I'm not sure how the later Pinto cable runs.
Some have said that the cross member is in the way on the 74 up Pintos when using the "bell-crank type bellhouse".
You may not have this problem as you are using the V8 bellAgain my T-5 install was for a 2.0 I4 install your V8 conversion may vary from what I did.
gearhead440
Pintony,
When you installed your T-5, did you use the cable operated clutch like the 4 speed pinto used or did you have to get creative to make everything work properly?  I'll be doing a 302 / T-5 install soon and would like to use the existing 4 speed clutch cable system if possible, or I have hydraulic slave / master cylinder on the shelf if need be.  Thanks!
Hello Pinto_Girl,
  Yes My T5 is working great!
The re-build and install is an outstanding improvement over the 4 speed Hummer tranny.
Actually I have had my T5 in my P.P. since 1995.
Do you have any idea what rear axel ratio you have??
I'm running a 4.11  so I really need the overdrive.
My last Turbo Pinto had 4.62 gears W/ no overdrive.
But I was young then and it did not bother me. ;D
Gas was only 65-75 cents too!
I will help anyway I can.
The most important piece is the modified Bell house for the 2.0
Lucky, WE having the early Pinto do not have the cable issues like the late model Pinto does.
Pinto_Girl
All hail, Pintony!!
I was just thinking to myself the other day, as I was watching traffic passing me in my (badly vibrating) rear view mirror, how nice it would be if my '73 had one more gear.
The engine's freshly rebuilt but the gearbox is a little tired and cranky.
This older guy I know suggested a Columbia two speed rear end(!?!) which, aside from actually finding/refurbishing/adapting/installing such a thing, still doesn't address rebuilding the stock 4-speed.
I'm still trying to catch up with y'all---Pintony, sounds like you'd already fit a T5 into your 2.0L...? Have you published a 'how to' or ever thought about it? I'd *definitely* be willing to pay/make a donation/volunteer in exchange for reasonably complete documentation of the swap.
--Pinto Girl
DragonWagon
Ok thanks for the info guys. I'll do some more junkyard scrounging when I have time... and it stops raining. I need to find an 8" rearend and a driveline anyway. Is there a cheat sheet of 8" numbers out there? Like the T5 one. A lot of this is new to me, so the more info the better.
1976 mpg Wagon. The start of it all.
1977 Cruising Wagon, to be turboed.
1979 glass hatchback. No motor atm.
1980 wagon parts car.
The D9 bell (4spd.) will bolt to a t-5 and will keep you from having to notch the crossmember.
Hello DragonWagon,
You really need a T5 bell.
Yes Hanlon was the best kit. Not the cheepest though.
DragonWagon
So Pintony, are you still happy with the Hanlan T5 kit? I just picked up a tranny and will be rebuilding it with the help of this thread and also this excellent pdf as a reference guide.
http://www.ttcautomotive.com/English/media/pdfs_autogen/T-5_Service_Manual.pdf
Unfortunately, my T5 didn't come with the bell housing. Can I use my stock 4sp BH on the T5?
jamnjm
I'm converting my 1.3 mile oval track Capri 2 with a 2.3 to try road racing and I found this site to help on trans selection:
http://ddperformance.com/Trans%20ID%20chart.htm
What I'm looking for is a 2.3 T5 from a '91-'93 which has the closest ratios...anyone In So. Calif. area have one?
Rob, I would lean more towards the Turbo Coupe 5spd if it is in good shape.  My 86-1/2 Turbo Coupe came with a Hurst short throw shifter from the factory.  I am running a Steeda Tri-ax in my Mustang and I love it.  It has been one of the most enjoyable mods I have made to date, IMO.
osiyo59
Tony, I have located several t5's in a local wrecker. One is in a 2.3 turbo coupe and the others are in n/a 2.3 mustangs. Which would be the better gearbox? Also, I checked with my local transmission shop and they said about 700 to rebuild it (bench job, no install) How difficult are they to go through (the right way)? I really don't want to fork out the bucks if I could do it my self. I do have access to the presses to take care of the bearing races.Thanks...Rob
DragonWagon
Cool, thanks. It's always nice to have confirmation that I might have some idea what I'm doing!
Hello DragonWagon,
Your 1352 209 spces. out just like my 162. Same gears and input shaft length.
You just want to stay away from the 1351 tranny.
DragonWagon
Just have to say THANKS Pintony, and to the rest of you out there who so freely share your Pinto wisedom. This site and all it's resources is invaluble! I raise a toast to you all!  :drunk:
Ok, back to business. I've located a T5 and from what I'm seeing in the ID chart, I'm guessing that it is a WC tranny. It is a 1352-209. It has the same spec's as your 162. Am correct in this assumption? WC T5 2.3.
You have to mike the shims to find the correct one.
Then re-install the front bearing retainer and check the end play again.
I actually ended up using a .025 shim to get 0 end-play.
Hello Group,
I have my T-5 back in my P.P. tonight.
Here is a shot me checking and setting the end play.
The end play should be 0 so I need a .022 thick shim.
Still tring to decide what to do about a clutch for my T-5 install.
I can not seen to find a suitable solution that is NOT 300+ BUCKS.
Quote from: Pintony on November 13, 2005, 01:10:31 PM
I FOUND THE NOISE!
Yeah....Tony.Um I dont think there is supose to be a screwdriver between the clutch disc and the flywheel............ ::) :o. Im sure that caused a bunch of noise................... :police: ;D ;)
When I removed the 2 rear U-bolts they were not real tight? But NOT LOOSE.
There is no marks on the u-joint caps and the yoke is NEW and in perfect condition.
I replaced the tailshaft bushing to match up with the new yoke before installing the first time.
Hello Group,
Here I have my old T-5 Transmission out of my Purple Pinto.
I already took the input shaft out and did not find "ANY" reason for the noise I was experiencing.
The input shaft has some small wear on the spline where the clutch disc rides.
The end-play is non-existant! It rotates good W/O any "UNUSUAL" noise???
I am puzzeled again as to what was causing the noise I'm hearing???
ETPinto
Thank You  ;D  I am collecting information from the many and sundry sources for this conversion....Maybe I'll build an instruction manual with photos, Hmmmmm.
Thanks again.
Quote from: ETPinto on November 10, 2005, 09:34:09 PM
  So Pintony,
How much $$$.$$ total in parts for the WC rebuild.....and will there be more coming on the mods for the install.  Lots of photos will make sure all your Pintos go to heaven with you...lol.
I wont be converting untill summer 06, but when I do it will be a WC/2.0 car.
  Forgive my lack of research,  please let me throw a few ?s  out to you.
Do 2.0/2.3 motors from pintos use different bellhousing with same 4spd ?
If so
Will a 2.3 4spd BH bolt to a WC t-5, and is it the proper depth for input shaft ?
Does 2.0 flywheel accept proper clutch/pressure plate for the t-5
Is end of input shaft proper diameter for 2.0 pilot bearing
Thanks  ;D
Wow!
Those are great questions!
I have many more photos to share with this group.
The rebuild kit I used came from Hanlon. 169.00 + shipping and I also purchased the 1st gear roller bearing +36.00.
This kit comes complete with all the goodies.
I will be showing the diference between 2 kits that I bought from different supplyers.
BIG Difference! In the amount of parts small difference in the Price.
To answer your direct questions
1.Q, Do 2.0/2.3 motors from pintos use different bellhousing with same 4spd ?
   A, The Ford Pinto used the EXACT same bell bolt pattern for the 2.0 and 2.3 "4SPD"
       To use the T5 bell on a 2.0 you will have to modify to use all 6 bolts.
2. Q, Will a 2.3 4spd BH bolt to a WC t-5, and is it the proper depth for input shaft ?
   A, I do not think the borg warner T-5 will bolt to the Hummer 4spd tranny????????
3. Q, Does 2.0 flywheel accept proper clutch/pressure plate for the t-5?
    A, The stock Pinto clutch can be used BUT you have to use the 10 spline disc
          The bigger clutch assy. from a Turbo T-bird will bolt directly to the 2.3 crank.
.4. Q, Is end of input shaft proper diameter for 2.0 pilot bearing/
     A, Yes
ETPinto
  So Pintony,
If so
Thanks  ;D
