Crane Cam
Date: 02/26/2018 07:50 am
Date: 11/11/2019 04:49 pm
Date: 12/09/2018 11:35 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
windshield
Date: 04/14/2018 08:53 pm
Date: 04/21/2017 02:03 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
Date: 06/28/2019 09:14 pm
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
  • Online today: 2,535
  • Guests: 2506
  • Total: 2506
Borg Warner T-5 speed install
Started by Pintony, October 18, 2005, 08:06:36 PM
"Effective" gearing is something I touched on in my build thread in the turbo forum.
With 23.9" tires and 3.55 gears, my car has gearing equivalent to 3.94 gears in the Thunderbird my trans came from. 3.94 is pretty steep for that driveline. I can take off in second gear like it's first. To functionally match the gearing that the donor Thunderbird had, I would only need a 3.12 rear end ratio.
Jerry merrill
I have a 2.3 in my 71 with the t-5 and 355 gears and the 5 speed works great. I only have a ranger header and stock roller cam. Some times I run in 5th in town over 45 mph. Yes if you come to a steep hill you will have to downshift but it works great. Might be different if you have less rear gear than 355
Hi Jerry,
  Remember that my friend is building racing engines. A stock engine leaves a lot on the table.  So, he is basically stating after everything else has been exhausted you hit a ceiling of the torque you get out of a specific displacement.  This is also related to currently available equipment and build concepts at any given point in time. Obviously future development has the potential for increase.
Since HP is factored around torque and RPM to get the HP number higher (at the torque ceiling) the torque has to be shifted to the higher RPM.
He is not some "want to be" engine builder. He did development work for Shelby, built the engine for a record holding Bonneville car and has been in magazine engine building shoot outs.  http://www.mitechengines.com/history.htm
My main point to 1oldtimer is that his search for total HP to overcome the 2.0 deficiency with a T-5 was not the solution.  The solution was to get maximum torque (or at least an acceptable amount) in the "driving" range that the T-5 would typically be used in.  My apology if I caused any confusion.
I also don't mean to contest Pintony who has obviously tried the T-5 with a 2.0. But, in his case we do not know the tire size, the rear ratio, the final ratio in 5th gear (could be anywhere from .78 to .85).  If (and I do mean IF because we don't know) he had 15"-16" tires, 3.00 rear gears, the .78 trans and a motor modified that had the torque curve moved higher that might account for the issues. On the other hand if he had 13" tires, 3.55 gears, .85 trans and a basically stock motor  (decent torque in the driving range) - and then the car still couldn't handle the overdrive then for sure I would not advise the T-5 either.
Wittsend, I do not understand it but the torque can be changed without changing bore or stroke.  The 71 2000cc had 120 ft-lbs while the 72 2000cc had 103 ft-lbs.   The compression was lowered from the 71's 9:1(8.6:1 per Ford manual) to 8.2:1 in 72.   Per the Ford manuals, the cams have the same specs but I suspect some tuning changes were made too.  Click on the "detailed specs" link in the links below to see the compression ratio numbers.
http://www.automobile-catalog.com/make/ford_usa/pinto/pinto_2-door_sedan/1971.html
http://www.automobile-catalog.com/make/ford_usa/pinto/pinto_2-door_sedan/1972.html
1oldtimer, as far increasing the NA output of the 2000cc, there are some old magazine build articles linked on the PCCA page here.  Go to "Community" at top and then to "Extended Community".    The article links will be on the lower left side.  For more complete builds, David Vizard wrote a good book on the 2000cc engine, see link below.  For some reason clicking on the link below does not work but copying and pasting the entire link seems to work.
http://www.bookfinder.com/search/?author=&title=&lang=en&isbn=0-89586-365-0&new_used=*&destination=us&currency=USD&mode=basic&st=sr&ac=qr
The issue isn't horsepower, it's torque.  You need enough of it in a "driving" RPM range (Idle to about 3,000 RPM) for everyday general driving. Horsepower is just a result of the torque at a given RPM.
You can build a 200 HP 2.0 but it will likely have to wind it up towards 8,000 RPM to get those numbers. And if you did that the torque in the "driving" RPM's would be worse than stock.  I have a friend who builds race engines and he has stated that, "You can only get so much torque out of a given bore/stroke combination. The only way to increase HP is to increase the RPM."  And note that when you shift the torque upwards you lose it on the lower end.
I only briefly had a 2.0 / Auto. I installed 225-60-16" tire which would have been similar to running with an overdrive trans ratio. The car was "pedestrian" to start with 13" tire and the 16" put it in the "walker" catagory.
You could effectively run the 5 speed with the right tire/rearend ratios. And you might actually set it up for a very mild overdrive (compared to what you have now). BUT, 1st  gear would probably be negated as it would hit "granny" status.
I also notice that the '87 Mustang T-5 was listed as a .85 (vs the .78-.81 listed for other years).  Frankly though it is a mote point without considering the trans ratios, the rear ratio and the tire circumference.
Run your current trans, rearend and tires through a calculator.  See what the RPM @ driving speeds are.  Then do the same with the desired components. Observe the RPM drop. If it is minor then the 5 speed will not offer much advantage. If it is a lot you likely lack the torque to pull the load.
In any case you would need to be building the 2.0 for torque in the stated idle to 3,000 RPM range. I doubt any power increase equipment available is slanted in that direction.  In fact the stock engine is likely doing that in its natural state now.
1oldtimer
Quote from: Pinto5.0 on July 03, 2013, 09:12:57 PM
I called Pintony today & found out the clutch disc is for a non-turbo '87 Mustang with a 2.3L engine.
He also said that anyone thinking of putting a T-5 behind a bone stock 2.0L was making a huge mistake. The stock engine won't pull 5th gear. I was planning to use it behind my built 2.0 but even at 115-120 HP its not gonna pull hard in 5th. I'm just warning anyone before they waste the time, effort & money trying to run it behind a 70 HP stocker.
What mods have you done to get to the 115-120hp. I'm trying to get an idea of what will a target hp, is 150-175 or even 200 way out of line for a N/A street driven car. I see the GM 3.0 (181 boat motor, derived from the 153 Nova motor) getting 140hp out of the box.......and the 153 getting 120 hp.
'72 2.0 in a '28 Ford.
Henrius
Quote from: Pintony on October 18, 2005, 08:06:36 PM
Hello Group,
I got my NEW Borg warner T-5 tonight. I will be showing how I rebuild and install this tranny in the coming weeks. I have hurt my old T-5 and will be replacing it with this newly aquired unit.
This is the "World Class" T-5
My install will be behind a 2.0 Turbo BUT should help othersW 2.3 in their quest for overdrive tranny.
I am drooling. The one thing I would like for my hopped-up 2.0L is a 5 speed to get a higher top gear and bring the engine RPM on the highway. But how much modification does it take?
1. Does the driveshaft have to be shortened?
2. Does the gearshift position need to be changed?
3. How do you adapt to the back of the 2.0 engine.
I know little to nothing about tranny interchanges. Where can I get info?
Thanks!
1973 Pinto Runabout with upgraded 2.0 liter & 4 speed, and factory sunroof. My first car, now restored, and better than it was when it rolled off the assembly line!
Absolutely, that's why God created the shifter.....................
Jerry merrill
I have a 71 with a mildly modified 2.3 and t-5 with 3.55 rear gears and fairly tall tires on 15 inch rims and the overdrive works pretty good even in town at speeds above 45. Yes if I am going slow and climb a hill I have to downshift but if your car has 3.40 and higher gears it should work fine, I would never go back to a 4 speed.
If you run into a lugging situation making 5th gear unusable, a recent thread on TurboFord.org suggests that the T5 5th gears can be mixed and matched to get a desired ratio.  In addition to engine out put and 5th gear ratio, I believe lugging also depends on tire size, rear gear ratio, car weight, aero drag, etc.
http://forum.turboford.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=057441;p=0
http://www.aicmctexas.com/main/showthread.php?826-Fifth-Gear-upgrades-for-Ford-T5-s&s=7076cf061ebbd37a5b6fdbcc1abe47ae
Both my cable and hydraulic bells have the tilt.  Maybe it is to get the shifter closer to the driver, don't know.
'He also said that anyone thinking of putting a T-5 behind a bone stock 2.0L was making a huge mistake. The stock engine won't pull 5th gear. I was planning to use it behind my built 2.0 but even at 115-120 HP its not gonna pull hard in 5th. I'm just warning anyone before they waste the time, effort & money trying to run it behind a 70 HP stocker.'
I would not doubt that one little bit. The zetec engines that Ford used around '95-'05 are rated around 130 HP and once they get well used to let power drop off to around 100 HP or lower an ATX PCM will routinely kick them into 4th at the slightest hint of too much load. The engine otherwise is lugging and not enough power to pull the gear and the PCM has that designed into the software. It can tell by how far you are into throttle (TPS output) to decide the issue one way or the other. Once the engines cross around 150K miles they routinely drop into 4th and stay there at any uphill incline at all. It can get kinda crazy in hilly country and using cruise, lots of upshift/downshift going on there.
1oldtimer
I wanted to post a small update. I was having some other aluminum stuff welded so I added the T5 bell to the pile. Fits good, used the '87 clutch set-up, but noticed the that the 2.3 mustang setup isn't level and has the trans at a slight twist to the drivers side.
Just for reference, below is the link to the nice build thread where those 2.0 to T5 photos are shown.
http://www.fordpinto.com/your-project/73-pangra-project/
Apparently he tapped the upper 2 holes in the 2.3 bell & threaded in some all thread. Notching the sides of the bell to use the lower bolt holes is a 10 minute job with a carbide cutter. I like this method because it can be done at home in an afternoon.
1oldtimer
Quote from: Pinto5.0 on July 14, 2013, 05:39:03 PM
I like this idea myself. Actually quite simple to do. I trust Pintony on 2.0 advice so be prepared to run around in 4th gear until you have the power to use 5th. I'm going to use the stock 4 speed & only swap to the T-5 if my engine can run the 4 speed to it's rev limit with ease. If I can't go over 4K RPM in 4th at half throttle there's no point adding a gear.
I haven't held the bells together yet.......I didn't think the holes where that close to the 2.3 bell. I see I don't need to cut the two bells apart, that's good. I was kinda planning on using it as a 4spd if all else failed, I just wanted to decide on a trans before I start making a crossmember and modifying the frame.
1oldtimer
It's stock right now, but before it goes back in it's going to get some head mods and a cam (plus the dual carbs and header).  Now the question is do I modify the 2.3 bell (looks like I can cut out the upper bolt section on the 2.0 bell and weld it into the 2.3 bell) or modify the tailshaft/shifter on the 4spd. either way there's cutting and welding of aluminum, but with the T5 I have a chance of using 5th and maybe a turbo in the future  ;D.
Quote from: 1oldtimer on July 14, 2013, 03:16:20 AM
Ok, found some parts after 3 junkyard visits. A 1988 Mustang 2.3 T5 with bell (I think I need to use the 2.0 motor plate?), S10 tail housing and shift rod.
Your 2.0 isn't stock is it? And yeah, I'd run the 2.0 block plate.
1oldtimer
1oldtimer
Thanks guys, I guess I'll look for both and see which shows up first. I'm going to use old pedals so it will be linkage for the clutch. I was already looking at shortening the shift tube/shaft and moving the housing forward so the shifter will be in a usable area. I've seen the AK Miller set-ups come up for sale once and awhile, right now I just have the edelbrock dual carbs and a header on it.........I drove it home in stock form with a C4 so some more power was needed.
Quote from: 1oldtimer on July 04, 2013, 11:43:03 AM
What bellhousing was Pintony talking about ?. I have a '72 2.0 with a 4spd now, looking into the future for a 5 speed and need to start collecting parts. The motor/trans are in a Model A with 4.11 gears and I want to stay away from a hyd clutch.
The 4 banger Fox Mustangs have the bell you are looking for. They are all cable operated.
I believe Pintony is referring to a non-hydraulic 2.3 bell housing. They can be bolted to a 2.0L using 4 of the 6 bolt holes using step down dowels (in two of the holes for proper alignment). My son has been using one for years behind a 2.0 turbo with no issues. The T-5 trans is a common upgrade if you want a 5 speed. If you are using 4.11s and can use a model A old school (long) stick shift then you should be good. The T-5 is about 1.5 inches forward in the shift tunnel over the Pinto 4-speed (and the T-9 5 speed). I know you're are looking for a T-9 but they are really hard to find in any condition and really expensive to rebuild. The input shaft needs to be modified (it's too long) for a 2.0L. I have extensive mods and big $$$ in mine. The Pinto I'm currently building has the T-5. It's a 2.0L with an A.K. Miller turbo and 3.18 gears (may go with 3.40s). The T-5s are cheap, plentiful, and stronger than the T-9s. I have about $900 in my race mod T-9 and $70 in my Pick-Your-Parts T-5/with bell that does not need a rebuild.
OhSix9
don't even bother with the d4 and d9 bellhousings as a total waste of time, effort as well as money. The cable actuated bellcrank housings are cheap and so plentiful you can't chuck a rock at a wrecking yard and not hit one.. relocating the clutch cable is a matter of a two inch long piece of flatbar with 2 holes drilled in it. bolt it to the original  cable mounting hole and raise the cable mounting point an inch. problem solved.
Virgil to Sid
1oldtimer
heres pauls contact info...
Send me a PM or an e-mail to turboford@charter.net or call me at 860-642-4429
Thanks,
Paul
I'm going to see what my machinist wants to turn me a set or 2 of dowels. I'm also going to look into welding some extensions on one of my bellhousings to bolt it to the 2.0L. I think this is the way to go.
Of course none of this matters if I can't source the 10 spline disc for the clutch.
bbobcat75
off this topic, kinda  that website is a pain in tha @ss to become a member on!! i have tried atleast 5 times with some type of issue every time!!!
1975 mercury bobcat 2.8 auto
