Date: 07/30/2018 04:32 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Date: 07/04/2017 03:26 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 03/13/2021 12:57 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
  • Online today: 531
  • Guests: 163
  • Total: 163
Borg Warner T-5 speed install
Started by Pintony, October 18, 2005, 08:06:36 PM
Thanks for the info, I have all but the bearing tool and press :(  I passed on a couple V8 T-5's for my future Mustang project due to them needing a rebuild.  I was always curious to know what was needed to rebuild them.  I will keep my eyes open for a press and then I will attempt one ;)
Quote from: TIGGER on November 04, 2005, 12:18:54 PM
Darn, your fast ;D  About how long did it take you?  Was this your first T5 you rebuild?  What special tools did it require?
When you set the end-play on the counter shaft and the main shaft you will need a dial caliper and magnetic base.
Being as the case is aluminum... I had to drill some STEEL brackets to bolt the steel to the case so my magnetic base had a place to attach.
Quote from: UltimatePinto on November 05, 2005, 12:02:16 AM
Am wondering what throw out bearings are out there so that you could use the V-8 retainer? ???
The size,( OD ),of the surface that contacts the fingers on the pressure plate,(plus overall length), is this what you are looking for?
What do you figure would be the difference between V-8/4 CYL thrust bearings, (besides the bearing retainer diameter) other than general size? Have never bothered to look at V-8 ones. I guess that you might have to change the fork as well.
Al
Hey Al,
I'm afraid I am stuck with the factory aluminum unit. I'm sure that I will not really NEED the steel bearing retainer. Especially that I won't be utting that many miles on it.
The problem is that the STEEL retainer is beter and stronger and MOST of all cheaper.
I have found the Steel retainer for 29.00 BUT the factrory aluminum unit is 50 bucks ! :'(
Hey TIGGER,
My rebuild took about 8 hrs. BUT that is including the soak time in the parts cleaner to soften the old silicone adhiesive. All the parts I.E. gears and counter-shaft were cleaned and reused.
All bearings and seals were replaced. + all the syncros and blocker rings.
List of tools.
Torque wrench, 3/16 punch snap ring pliers "2 kinds" brass mallet, rubber-plastic mallet, Bearing cup holder. 50 BUCKS! Ouch... I also needed a #40 torx bit that would allow me to tighten the countershaft bolts.
BIG damn Bearing press. My little press was good for somethings BUT I had to go to a local shop for some of the pressing. A nice parts washer is good too!
UltimatePinto
Al
Quote from: Pintony on November 04, 2005, 01:35:34 AM
Here is my T-5 fully re-assembled.
I still have to set the end play. But I'm still trying to find a way to use the V8 Steel bearing retainer.
Notice how this bearing retainer has large amount of wear.
Yeah, thats what happens when your flywheel/clutch/pressure plate assy comes off the end of the crank shaft and spins wildly around on that shaft in the bellhousing................. ::) ::) :o :o :'( ( It happend to me to ).... :'(
Here I have the output shaft re-installed in the case.
Nearly complete T-5 output shaft.
Quote from: Pintony on November 03, 2005, 09:29:28 AM
Quote from: turbopinto72 on November 03, 2005, 09:23:04 AM
Hey Tony, If you really want to impress the group, polish the case..................... ;D ;D :o :o ;) :police:
Hey Brad,
Who is going to see the my shiney transmission at 130 MPH???? ;D
I will " know" its shiny and therefore asume your car is going faster than it is........... ;D ;D :o
Hey Brad,
Here is the main shaft with the rear 1st gear and 5th gear re-installed.
Notice the BLACK 6-tooth speedo gear I have installed.
The 7-tooth yellow is the gear I'm replacing. This gear is only placed just to show the difference.
Here is The case in the bearing press ready to have the front cluster bearing race installed.
Notice the old race already pressed out.
Hello Group,
Here is my T-5 case cleaned and ready to start re-assembly.
A BIG funnel with a 3 to 4 foot piece of 3/8 fuel hose works too.
But it takes patience to allow the slow mooooving fluid to go down the small tubing.
"Something I lack"
I'm with Brad though I use the pump that connects to the bottle too.
Quote from: Pintony on October 29, 2005, 11:08:54 AM
Hello Group,
I agree with Bipper!
The T-5 uses about 3 Qt. ATF Not gear oil.
A good rule of thumb is... If yur tranny has a Cast-iron case it uses 70wt. gear oil if the case is aluminum it uses ATF.
CHECK with your local Ford dealer if you have doubt.
Yeah, and its really fun to fill the trans up with ATF when its in the car. I use a hand pump and it works real good.
Hello Group,
Bipper
UltimatePinto,
Don't use gear oil in the trans. WC T-5 with fiber syncos use ATF.
I can't remember exactly but gear oil will either ruin them or prevent
the trans from shifting properly.
Bob
71 Sedan, stock
72 Pangra
73 Runabout, 2L turbo propane
UltimatePinto
Hey Pintony,
Looking at your research I have to say I'm flabbergasted! :o
Had no idea of all the variations. I picked up my first one, (it has the plug in the top cover), but after the install I found I couldn't downshift from 4th to 3rd gears. I got another one like it, (both were discarded from local ministock racers who can't use them on a 1/3rd mile circle track), and had it rebuilt from a friend who does drivetrain stuff for these guys. Where the boxes came from I don't know, Mustangs I think as that's what they race.
By bearing retainer, are you talking the front input shaft one?  You know, the one the thrust bearing rides on?  I guess it's a bearing retainer.
Anyway, I tried to use a replacement from Jeg's that was touted as being better for the thrust bearing to ride on. When I tried to put the thrust shaft bearing on it - twas too big a shaft. Had to send it back. Afterwards, I had to use a different thrust shaft bearing, one that was longer from stem to Stearn as well for my application.
There are two different sizes available from Walsh and Esslinger, forgot which one I used but it worked with the original 4 cyl retainer.
Also, (and this is a first for me), my first T-5 had ATF for lube. I've heard of it in air compressor pumps, but never in manual transmissions, just me I guess.
Is gear oil better, like 70 weight, or is the ATF the yellow brick road?
What do you run in yours? Are seals affected by either one, I wouldn't think so.
What do you figure?
Al
Hello Group,
I got my WC T-5 transmission rebuild kit today.
It came from gearstogo.com
I have to say... I'm not happy.
I can not recomend this company.
There are many service items missing from this kit.
For what I payed... I got burned BIG time!
This kit will be going back.
I have already ordered a T-5 kit from Hanlon. Be here mon. or tues.
I'll be posting the photos and the shipping reciepts with prices later.
I have had NO luck in finding a way to use the Steel bearing retainer from the V8 tranny to use on the 4 cylinder tranny.
It seems FORD in their infinate wizdom decided to play god again and actually put a BIGGER bearing in the Turbo 4 tranny.
I guess I'm stuck with the aluminum bearing retainer for now.
Hello Gearhead440,
That is a great question!
Depending on year of your transmission??? The WC will have an electrical plug in the top cover.
See the list of WC trannysthat Brad posted above for your part number. If you have the tag.
gearhead440
I purchased a T-5 out of a 2.3 turbo T-bird.  Is there a way to know by looking externally if the trans is WC or NWC ???.  Thanks!
Hello Group,
Here is a photo of the WC Borg Warner T-5.
Notice the fiber lined steel syncros and the taperd needle bearings.
The WC T-5 gear clusters ride on needle bearings too.
Unlike the NWC that ride directly on the shaft.
Remember this ALL kits are NOT created equal!
The price varies as much as the pieces included in each sellers kit.
Hello Group,
Here is a photo of a rebuild kit for the NWC Borg Warner T-5.
Notice the Brass syncros and the caged roller bearings this is why the NWC is less desireable.
The brass syncros make for clunky shifting and the caged roller bearings do not provide good side lateral support for the stresses of masive torq.
Hello Group,
I ordered my T-5 rebuild kit today.
I also ordered a 6 tooth drive gear for my speedometer.
Should be here in a few days.
Anxious to see what I get.
There are companys that list some basic parts kit and some that offer Master parts kits.
I got my kit from http://www.gearstogo.com/
I dealt with the company owner Brent.
He called me back 3 times to help answer my questions and get me the 6 tooth gear I wanted.
Thats Service!!!!!
I know there are more companys with BIGGER names out there BUT Brent helped me out and really seemed like he wanted to provide the service I needed for my 4cylinder T-5 rebuild.
Other companys I called acted like if I was not doing a V8 tranny they did not have time to deal with me.
We will see if the shipping is as good as the service. ;D
Hey Brad,
As I understand it...., the tranny I have "IS" the WC style
My NEW tranny is the 8th one down on your list. 162
Everything I read is that the 4 cylinder T-5 is also WC.
The difference as I understand it is the WC has fiber syncros Except 5th gear and the NWC has brass on all 5 gears. Also the WC has tapered roller bearings all around The NWC has needle bearings.
Please let us know if you have a different view.
To see the differences of these trans. Please click on the PDF file below and rotate it correctly. You might want to print it out for future use. This file shows the input shaft length and OD size differences for the different T5 applications.
Quote from: Pintony on October 18, 2005, 08:38:28 PM
Hey Brad,
Do you know the difference between the WC and NWC?
Tony, Im not quite sure what you mean. Was it a question that you needed an answer to or a statement?
