Wheels and Parts
Date: 07/06/2018 04:50 pm
Date: 09/02/2021 08:21 am
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 01/19/2020 09:06 am
Date: 03/23/2018 09:23 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
Date: 07/20/2018 03:00 pm
  • Online today: 802
  • Guests: 141
  • Total: 141
"New" Pinto No Spark
Started by rob289c, June 07, 2020, 07:49:48 PM
rob289c
I didn't see any external leaks so it is a good possibility that the vacuum modulator diaphragm is bad.  I'll check that when I get under to either tighten the exh manifold or take apart for a new gasket.  The new distributor came in yesterday but I'm not messing with it until the weekend.  70 hour work weeks and 95 degree temps make me stay out of the garage. The weekend will be cooler rainy.  Good shop weather.
rob289c
Good news and bet your happy it runs , now you just have to chase out the grimlims out the car and look and see any future problems that may be hiding , you put in 2 qts of trans flude so did you see any leaks , it had to go somewhere , so check the vac line to the transmission for oil , if there is the modulator has a hole in it and will zoop the fluld out the trans , soon you will be driving it , have a good one
rob289c
Today I removed the supply and return lines from the fuel pump, extended the lines and dropped them into a 1-gallon gas can under the car and used that as a fuel cell.  It's on 4 jackstands so there is plenty of room under the car.  I got it to start and stay running.  I adjusted the idle up a little and played with the timing a bit and it will sit and idle without having to feather the throttle.  No knocking or other troubling noises.  When I put it in Drive and Reverse, nothing.  After adding 2 qts of Type F, it goes in both forward and reverse.  There is a terrible exhaust leak where the upper converter bolts to the exh manifold so it is loud and lots of fumes while under hood.  I'll have to get that tightened up to eliminate or minimize the leak.  I tried from above with 9/16, 5/8, 14 an 15  box ends, but none seemed to be the right size.  Can someone tell me what size it should be?  I'll try again another day from underneath with ratchet, socket, extension.
I made good progress this weekend; thanks again for all help provided.
rob289c
rob289c
It runs!  :) Not well, or for any length of time but it fires and has some throttle response but I have no fuel system hooked up.  The gas tank is barely hanging by one strap and I don't want to put any gas in it.  Probably full of crud.  I don't know if the fuel pump is any good.  I may try to rig a one gallon gas can as a makeshift tank to see if I can get it to stay running for any length of time.  There are vacuum lines unplugged/uncapped so now that I know it will fire I'll see what I can do to make it run longer/better.
The timing marks on the crank pulley were rusted over and invisible.  I wire-wheeled all the way around until I could barely make them out.  I checked the orientation of crank and cam pulleys and they were right on but the distributor was off.  I pulled it out and re-positioned it and it fired up!  Still waiting for the new distributor to arrive.  Hopefully on Monday.
Thanks to all that offered advice and replies.  I will continue to update and ask questions as I move forward with my project.
rob289c
For whatever reason all shippers have been really screwy for the last couple weeks. I had something "guaranteed" to be here today and it's not. Earlier in the week I had five orders come in on the same day by different carriers that were early, late and on-time. Another was lost last week by Amazon and never arrived.
rob289c
New distributor didn't show up today.  Local PO says the package still sits in the Rochester NY PO.  I won't see it till Monday.  I'm going to prep for the swap and I may pop the old one in for the heck of it and give it another whirl.
rob289c
rob289c
In a few minutes I will be out removing the old distributor and getting timing marks lined up to be ready to drop in the new distributor as soon as the mailman arrives.  Tracking shows it will be delivered today.  I will have a followup report later in the day.  Hopefully that it is running!
rob289c
It's been a while since l timed a 2.3 but l remember that they won't run at TDC. Seems like you have to move the distributor quite a bit to get it to run. Like set it so the vacuum advance is as far forward as possible, drop it in at TDC then move it around towards the rear. That could be why it's backfiring through the carb, the timing is that slow.
rob289c
Ah...got it.  I'm chomping at the bit to get this thing going!
rob289c
you do not have to remove the timing cover to check the marks , one the pointer for the crank is on the timing cover there is another mark on the lower sproket but hard to see if you do not know what to look for , just setit on TDC and there is a rubber plug on the timing cover near the thrmostsat housing , remove the plug and look inside you will see a pointer and also the mark that should be there , if not you may have to turn the engine one turn and check again , hope this helps
rob289c
I just checked the tracking on my distributor...it has arrived in the Rochester NY USPS Distribution Center at 5:00 last evening and I live in a Rochester suburb.  I'm hoping it arrives in today's mail so I can get on it first thing tomorrow AM, but I may not see it until tomorrow afternoon with Friday's mail delivery.  Regardless, I will get the engine set to #1 TDC, get the timing cover off to check alignment of timing marks and get ready to drop the new dizzy in and hear it run.  I will keep everyone posted...
rob289c
Quote from: rob289c on June 28, 2020, 05:12:36 AM
Question:  What is the correct orientation for the vacuum advance...fron t or rear of engine?
Doesn't matter; put it wherever there is the most space to rotate it without hitting things.
That would be the first thing I would check and replace in the begining , brought a few over the years and thats all it was , broken belt or just striped at the crank , even when I had a new pinto the belt would let go around 40 to 50 K , later as I did more highway driving it would max to 60 to 70K , but now that you brought the car from someone that got it in a not running condition could be so simple , a quick look and see can rule a yes or no , set the crank on TDC , remove the top rubber plug at the top and look at the pointer , should see it line up with a mark (dot ) on sprocket , let us all know ,
rob289c
Good advice.  If getting to TDC and installing the new distributor doesn't get it to fire, I will certainly get the timing cover off to check valve timing.  I keep checking the tracking on distributor shipment but no updates.  It says it should arrive by Thursday so I'll have to be patient.  No work on Friday due to the holiday other than emergency calls so I'll be out in the garage bright and early to get it ready to roar!  As for the previous owner, I have tried to contact the last owner that had it registered in 2007 with no success.  I think that's where the no start/no run condition started and he dumped it.  The person I bought it from never ran it.  He had a lot of junk or he might call them projects, and never quite figured out why it wouldn't start but made a mess of the wiring. The good news is he bought a NOS carb for it.  Now that I have spark it I'm in the home stretch.  I'll get to hear if it knocks, smokes, and if the tranny works.
rob289c
enzo
The previous owner was unable to trouble shoot the no start problem with all the work you've described. Take a look
at the camshaft to make sure it is timed correctly, the belt may have slipped some cogs.
rob289c
New distributor has shipped and scheduled to arrive on Thursday, July 2.  Good news for me...I should be able to hear this thing run on Friday!
rob289c
rob289c
Thanks for the advice...all is appreciated.  I think what I am dealing with is a no start condition that the previous owner tried to troubleshoot with no luck.  I found wire insulation stripped away on a variety of wires.  I followed the factory Duraspark troubleshooting guide and figured out the no spark condition.  I have a feeling the distributor had been removed by the previous owner and not reinstalled correctly.  I marked the rotor position on the distributor and also to the power steering pump bracket before removing.  I put it in exactly the way it was before removing.  The oil pump drive was lined up and it fell into place without having to bump the engine.  With no spark before I wasn't getting the backfire through the carb.  When the new distributor gets here I'll start from scratch with #1 at TDC on the compression stroke and I am certain it will fire and run.  I hope it isn't delayed with the July 4th holiday...no mail on Friday.  I don't want to mess with the old distributor.  The harness is a mess, the cap hold down screws were broken off and I have to use rubber bands and zip ties to hold it in place the best I can.  Once I hear it run I can pull the motor and rebuild if necessary, or degrease and detail if it runs without knocking.
rob289c
Not sure what the factory intended position is but the distributor can be removed, the rotor rotated a reasonable amount to give more adjustment and then the housing is re-inserted. The housing is rotated (in essence "chasing") to realign itself to the rotor and move the vacuum advance away from whatever it might have been hitting. The timing should then be re-set.
A number of precautions:
Take pictures of the original orientation and mark the position of the rotor on the distributor housing with a Sharpie BEFORE you move anything. Should all things fail you can then get back to "square one."
DO NOT rotate the engine with the distributor out. It is not essential but it is advisable to set the #1 cylinder to top dead center on the compression stroke as a reference point. But, again do this BEFORE you ever remove the distributor.
There is a hex shaft that drives the oil pump that inserts into the bottom of the distributor. It can be a hassle to get the hex lined up and the distributor gear to mesh with the auxiliary shaft gear.
So, with all that if you can get proper timing even if things are close to hitting it may well be better to just leave it alone.
rob289c
Question:  What is the correct orientation for the vacuum advance...front or rear of engine?  Mine was (is) toward the rear.  That's what gets hung up on the fuel line, dipstick tube, and every other piece of vacuum line that is in the vicinity when removing and installing.
rob289c
rob289c
I just ordered a distributor.  For what I would have spent on a pickup coil and reluctor, I got a whole distributor and since the core is only $15, I will keep my old one for spare parts.  I should have it by next weekend so in the meantime I will get #1 at TDC and be ready to swap distributors when the order arrives.
rob289c
rob289c
Rotating the distributor while attempting to start didn't result in a start or attempt to start.  It still backfires through the carb.  Back to the drawing board...remove the alternator, pull the distributor, set # 1 to TDC, reinstall distributor, and try again.  At least I have spark!   :)
rob289c
rob289c
***Update***Today I used the Mapp torch on the upper alternator bolt and was able to get the alternator removed and out of the way.  It still took some finagling to get the distributor out.  Once out and a spray down with brake clean, I found my problem.  About 1 1/2" from where the connector used to be, the orange wire was compromised.  It wasn't visible when the distributor was still installed.  I had to cut it shorter and temporarily crimped a male blade terminal on.  Then I read 628 ohms between orange and purple, which is in the required 400-1000 ohms range.  The two distributor cap hold down screws had been broken off by a previous owner.  I sprayed and heated in an attempt to grab what was left without success.  I drilled through them but not without ruining the threads.  I reinstalled the distributor, which was a bigger PITA than removing it, hooked up the orange, purple, and black/green wires individually, used a zip tie and a machine screw/nut to hole the cap on and now I have spark!  I hooked up a piece of fuel hose to the fuel filter, kept the end high and squeezed gas to the carb.  I couple of squirts of starting fluid made the engine backfire through the carb but did not start.  I didn't have a helper to turn the key while I rotated the distributor but will try again when I have a helper.  I may have to go through the process again, remove the distributor, get #1 to TDC on the compression stroke, then reinstall the distributor.  It seems like it's not in the right position, although it is right where it was before I removed it.  Anyway, I now have spark but still no start.  I'm sure I can get it to run but may have to play with timing a bit.  Thank you for all replies and advice.  I will keep everyone posted on progress.
rob289c
rob289c
Thank you for the info!  I will call and see what he has.
rob289c
JoeBob
If you still want a junkyard part call this number 7209384055 this is a junkyard near Denver he has 20 pintos. Will pull and ship.
77 yellow Bobcat hatchback
Deuteronomy 7:9
rob289c
From memory I think I should read 400-700 ohms between orange and purple and I read nothing.  The connector coming out of the alternator crumbled in my hand when I removed it so the new pickup coil is needed, if for no other reason, I will get the new connector.  I will be buying the Painless Wiring Duraspark kit that is really made to convert points to Duraspark, but I will use it to replace all the bad wiring and connectors that fell apart.  I can use pretty much all of it except I won't need the Chrysler style ballast resister that comes in the kit.  The end result will be a factory looking ignition wiring harness.  Getting everything out of the way to get at the distributor will be my biggest chore.  Once I have access it should be smooth sailing unless it wants to be stubborn after sitting in its spot for the last 40 years!  I haven't heard a Pinto run since my last one in 1989!
rob289c
Thats kind of odd on the open pickup going bad , but easy to remove , first you bump the engine until the rotor button points to the block , take a photo of the positon of the distribtor , Makes is easyer to set the timeing later , or just line up number 1 on comprssion stroke and and line up the rotor on the #1 on the cap , it take a 17mm socket on a 12 inch 3/8 extenion and remove bolt , should slide out easy , its short and will clear everything , soon you will have it running in no time
rob289c
Update:  I made little to no progress last weekend.  This weekend I made some.  I rewired the 4-pin connector into a home made harness down to the distributor.  I think my problem is a bad pickup coil in the distributor.  I tried to get an ohms reading between the orange and purple wires and I get nothing.  The connections are good but I get no reading.  I am going to order a pickup coil and reluctor and see if that gets me spark.  Getting the distributor out is going to be a chore.  The alternator is on top, the power steering pump is below the alternator, and there is a bunch of wiring and vacuum lines in the vicinity.  The top alternator bolt is pretty much frozen in the housing but with heat and penetrating oil, I'll persuade it out.  Once out of the way I'll tackle the power steering pump.  I'm sure the distributor won't just pull out but I'll work at it.  Distributor cap bolts are broken off so I'll have to try to drill them out.  And I though it would be a piece of cake getting this thing running!
rob289c
rob289c
I hope I'm on the right track.  Today I went to Napa and ordered two 4-pin "modern style" weather proof connectors to eliminate the big white connector in the pic.  There is corrosion and lots of missing insulation so cleaning that up will help.  I found the 3-wire connector that includes the thick wire from the alternator is broken. I'll have to do something about that too.  I don't know if that is contributing to my no spark condition but I'm sure it isn't helping!  One more work day and I can get back on it.  I hope to hear this thing run by Saturday afternoon.  If it will stay running I can see if the tranny will spin the wheels.  It's on jackstands...no brakes.
rob289c
Sounds like you're on the right track! Sometimes you have to undo 40 years of wiring repairs and start over lol
rob289c
I found that there are vendors that sell a points to Duraspark conversion kit.  It looks fairly complete and wiring is color-coded rather than all black like the pug assy I received yesterday.  I think I will use what I have for now and some piece-meal wiring repair to get it running, then while the engine is out of the car and on the engine stand I will have more room to re-wire everything correctly.  The kit price ranges between $85 - $115 depending on the vendor. might be worth it when I get to that point.  In the meantime I will continue trying to track down my junkyard man to see what he has for harnesses.
rob289c
