Date: 12/31/2017 11:14 pm
Date: 08/01/2018 01:17 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Date: 08/08/2018 12:26 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 02/05/2020 11:06 am
  • Online today: 802
  • Guests: 135
  • Total: 135
"New" Pinto No Spark
Started by rob289c, June 07, 2020, 07:49:48 PM
rob289c
There is a junkyard nearby that has a lot of older vehicles.  The owner is tough to get ahold of and it's not really an active yard.  I'll track him down and see what he has.  There are a couple of older Pintos there that are probably pre-Duraspark II but there is a '77 that probably has (had?) what I need.  Otherwise, I'll take it from any Ford product from the era with the correct harnesses.  In the meantime, yesterday my 4-slot female repair harness that the Ign Module plugs into arrived, as did the coil wire assy.  The square connector needs some work.  I'll have to try to push the pins and receptacles out and see if I can re-use or get new.  I sprayed the harnesses with brake clean last night so not so oily to work with.  I'l going to try to get the distributor harness unplugged but there is very little room to work.  This car has power steering an the pump and plumbing are in the way.  Very difficult getting my hands down near the distributor.  That will be this weekend's project.  No time during the week.  I work too much!  I'll keep everyone posted on progress.
rob289c
as for the ign harness the next best thing is a early ford ranger with the 2.0 or 2.3 , only up to 1985 . after they went to EFI ,  but your more likly to find a old ranger now than a pinto , but the ign harness should be just about the right lengh and have the same plugs , when your done and do a test run , after do not use butt splices , sorder them and use heat shrink tubing ,
Trust me the likelihood of finding a Pinto even in a Southern California wrecking yard (especially a self serve) is rather nil too. We have Pick Your Part's here and their "Classic" section is two small rows with 80's Mercedes and early Miata's and the like. A lot of people have used the Turbo Coupe as a donor car but the newest of those is 32 years old ('88). Likewise the newest Pinto (80) is 40 years old!
rob289c
Thanks again...I will see what our local Pick N Pull has for vintage Ford products.  Most cars of that era rotted away years ago in this snow/salt mess of Upstate NY.  It would be nice to find some factory harnesses.  I haven't had a Pinto to play with since 1989 so I'm looking forward to making this one run...
rob289c
The tabs by the starter relay may look like resistor but is a fuseable link , yellow goes inside , the orange is the alternator , also the plugs on the harness could also be bad from people trying to pull them apart with knowing how to seporate them , as for voltage you should have it at the red wire at the coil , and at the red wire at the ign module , you will see a red and white wire next to each other , the white wire is to bypass the inside ballist when your cranking the car to make up fr the low voltage when you use the starter , you may have to replace the plugs or make up some new ones , most all ford of the time line have the same plugs and ign , Lincons , LTD,s and trucks
rob289c
Thank you for the reply and the advice.  Originally I didn't have spark, then I did, so it has been intermittent, so you are correct, it's probably a bad connection, corrosion, or other wiring issue.  A previous owner must have been searching for a problem as there is a lot of cut-away insulation, including what appears to be the three resister wires that run to the starter relay along the cowl area.  What are they for?
It's not very visible in the pic but I have some very ratty wiring with a lot of missing insulation, corrosion, etc.  My plan for the upcoming weekend is to rectify as much of that as possible using the new connector and coil wire connector that I ordered.  When you said, "If you're getting voltage when you turn on the ign, the ballast is good", where would I be reading the voltage?  I ran so many tests already, I want to be sure I am looking where you say I should find it.  Would it be at the hot (red) side of the coil, and should it be 9v or 12v?
rob289c
if you had spark before that kind of points to a conection problem ,  first is to unplug all the plug conections and look at the inside of them corrosion , the dielectric grease they used to seal them up has dried out over the forty years and you may find some of them green , the plug on the distribitor is always the worst because of the extra heat and water hits it most when driveing in rain , if your getting voltage when you turn on the ign the ballest wire is good , which is inside the dash , hope this gets you running
rob289c
I dragged this beauty home three years ago.  It's been patiently waiting for it's turn in the shop.  I got it inside last weekend, cleaned and repaired some connections and I can get it to turn over.  Not in Park; only in Neutral.  Probably Neutral Safety Switch but I can mess with that later.  By last Sunday night I put my in-line spark tester on # 1 and had all kinds of spark.  I figured I could rig up a fuel hose and my auxiliary fuel cell and it should have started and run.  It didn't.  No spark.  I checked the coil, ok.  I installed a known, good ICM.  I performed a few of the Duraspark II tests from the factory service manual.  I got to the one where I tested the red female that the ICM plugs into to the red wire connector on the coil and it suggests bad ballast resister.  I also have some very poor condition wiring that you will see in the pic.  I ordered a new coil connector, a four female-connector that connects to the ICM, a ballast resister, and a coil because it was cheap.
Where is the ballast resister located and what are the two connection points?  Ign switch at one end?  Where does it connect at the other end?  It looks like it has male pins at each end.
An other suggestions other than repair my wiring?  It's a mess and not much room to work in down there.  It's odd that I had strong spark and now I don't.  I've never heard this thing run and would like it to run while in the car before I pull the motor.  Any help will be appreciated.
rob289c
