Date: 08/17/2022 06:27 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Date: 06/24/2020 06:12 am
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
74 hood
Date: 07/03/2017 03:46 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
78 pinto wagon
Date: 06/04/2020 12:42 pm
  • Online today: 306
  • Guests: 208
  • Total: 208
LongTimeFordMan
Actually i discovered the difference when I built my capri in 1980.. the shifter was a real piece of work..
I had a feeling that the flywheel was different as well..
I have a capri block that I am rebuilding... I assume that the blocks are the same and have rhe same bellhousing mounting holes, etc.
Everything on a 2.0 Capri behind the crankshaft back is different from what is used on a Pinto. The tranie / flywheel / clutch / shifter /starter / driveshaft / rear end / bellhousing. It all different because it came from over seas, not the USA. Most of our stock Pinto parts were made here or in Germany. Lucas made the Capri  starter and as such it will not work on a 2.0 Pinto. We already know the tranie and shifter is different. I had several friends who raced Capri's in SCCA and they all complained that they could not use Pinto parts when they had tranie problems.  Replacing the tranie was much more than unbolting the old and replacing it with a Pinto tranie. If your really interested, the Capri's have several really good web sites both here and over seas.
robertwwithee
Quote from: LongTimeFordMan on October 18, 2017, 03:01:45 PM
Pix of pinto rims
To each his own.  13x7 fake panasports, real ones are reserved for race car.
LongTimeFordMan
Pix of pinto rims
LongTimeFordMan
I forward Dick's post about the rear end ratio..  I guess I lucked out with my wagon, it has 3:40 and with 14" tires the ratio is ideal for highway 1900 at 40 mph, 3000 at 70.
I think i have a wide ratio 4 speed because its pretty spunky off the line wit a 4 degree cam advance..
I would still recomment a swap to 14 " tires and alloy rims... I also switched to a 17 tooth speedo gear and the speedo and odometer is right on
As far as appearance, I actually get a lot of positive comments on my rims and the car seems to handle better.
LongTimeFordMan
Hi..
Not sure if this will duplicate since i tried to post it previously..
Looks like Dick and I are both recommending the same place...
I got some parts for my 73 pinto 4 speed at
https://www.taylor-race.com
The fellow there builds a lot of 4 and 5 speed racing transmissions based on the german 4 and 5 speed top loaders with the integral shifters.
You might want to call Taylor and pick his brain.. when i was there I got the idea that he builds all sorts of gearboxes.. be may have a used box in good shape, or recommend a source for a good used box.
I also had a 72 capri and it did not have the integral shifter like the pinto 4 speed, it had a side mounted external shifter.
robertwwithee
Quote from: dick1172762 on October 18, 2017, 02:17:47 PM
   You would need a very strong 2.0 engine to pull overdrive with any rear end ratio ever put in a Pinto by the factory. 3:55 is the very lowest gear put into Pintos from the factory and was in station wagons. Most Pintos came with gears around 3:00 and an overdrive is the last thing you would be able to use. It would take about 175 hp to pull such a gear and we both know that hp with a 2.0 is ONLY in an all out race car. 140 hp with a 2.0 is reasonable but with a lot of work and $$$$.
And my 3.55 rear is stock in a 72 sedan.  The 3.4 gear car was a swapped 8".
robertwwithee
Well, my T5 conversion with 3.4 gears and 205 60 13 tires worked out great.  And im running the same tires 3.55 rear with a T9.  Both 2.0 maybe 110hp meaning relatively stock.  This isnt my first rodeo, itll be fine.
Quote from: robertwwithee on October 18, 2017, 11:11:59 AM
The T5 are out there.  Im on a 2.0 conversion now and it was removed, ready to go for $200.  I can make that up in gas savings for a year!
robertwwithee
Quote from: dick1172762 on October 18, 2017, 10:16:51 AM
Try  http://www.taylor-race.com or 1-800-922-4327
Just went to the Web site... $3795 for Sierra 5 speed .. Straight cut gears only though..
There is a speed shop / sports car shop / tranie shop in Plano, Texas by the name of Taylor Racing or something like that that builds the T9 type tranies for sport car racing. Their known all over the country for their work. I bought one of their close ratio Pinto tranies a long time ago. Worked like a charm.
Henrius
Quote from: pintosopher on October 16, 2017, 09:25:02 AM
Kim,
No E-mail in any part of the UK site. Once upon a time there was a Quaife USA distributor, Unable to find at this time. I'm sending you this attachment to use for a suitability exercise with a Stock Merkur  T-9 . I may have access to a used one thru a close friend that converted his Merkur to a T-5 that was really boosted in HP ( Later the car was rear ended and totaled) . In the meantime, I've left my email with Quaife UK to further this endeavor.. I'm intrigued with a T-9 and would like to price out a Iron case t-9 for my racer.  :)
Thanks for the info. I did find an e-mail address on the site, sent an e-mail, but nobody answered it.
If you are in the UK, could you call them for me, and see if they do orders shipped to the US? If not, I won't spend any more time on inquires.
Got it Joe! Thanks. It looks like some of the T9 parts would fit a 4 speed tranie too. I keep looking on the Merkur site but most of the T9's are gone and replaced by a T5 long ago.
Dick , Sent you an email with PDF file for the Mag shown here..
Help. All I get on the classic ford mag site is blank pages.
72DutchWagon
Quote from: Wittsend on October 16, 2017, 12:18:41 PM
You can't import a cast iron case into California. They weigh too much and would eat precious fuel resources. And as we all know Jerky Clown does like anything that might pollute the (smoke filled by massive fires) air.  ;D
Well, the Crown prince of Bovine logic will just have to eat Tofu..  ;D  I may have to default to an aluminum case( to save on Shipping) and we all know that european aluminum is made from old WW2 warbirds :o.  Helping the manufacturers of the Crown doesn't bother me, ( I spend a ton on Teutonic pieces for the Hare). My Pinto would spin its mainshafts happily on Needle bearings and the ratio choices would have me in hillclimb nirvana, even in a non sequential "H" pattern.
Pintosopher, a known extraction tool to clean up the "stables" , Honey wagon awaits filling ;D
...  I'm intrigued with a T-9 and would like to price out a Iron case t-9 for my racer.  :)
Kim,
Henrius
Quote from: pintosopher on October 14, 2017, 07:39:54 AM
The Quaife T-9 is available with a variety of Ratios 1st thru 5th Gears. It's called a Clubman box and has a all alloy gearcase and some improvements internally. But it does have a limit to HP for reliability (190) and it's over 2000 Pounds UK in price. The Rocket box is indeed a 4speed with other ratios available, but again , a expensive option.
My comments were related to Hillclimb racing and the effect of a single ratio (3:40) not being ideal for that usage. My car went down the road in 4th just fine with the 23 inch tires and that gear on regular roads and street usage. Fuel mileage was acceptable with dual DCOE 40's and the car regularly delivered 25 MPG if you kept a light foot on the highway.
If your application requires a 5th gear, then I would recommend the T-9 with its limitations
Pintosopher, It's in the Feed Mix that makes for happy horses ;D
Thanks for the info. It sound like Quaife is a one-stop-shop to get a superlative 5 speed built for the Pinto. But how the heck would they ship a transmission from England to the US and how much would it cost??? I am guessing by sea mail. If I could get it delivered for US $4000 or less I would be interested.
Hill climb racing is quite a bit different than daily driving. Not sure my requirements parallel yours. Also my engine is way under 190 horsepower so I don't think the HP limits of the T9 would be an issue.
If you happen to have an e-mail for someone at Quaife let me know. They didn't list any on their website and it is impractical for me to telephone during the day.
Most of the GM Camaro T-5's came with the standard GM trans to bellhousing bolt pattern. There was a point (late 80's/early 90's???) where they went to the Ford bolt pattern (likely a Chevy Guy day of mourning) but again you are dealing with the the input shaft length being different in addition to the points you made.  Also a lot of those GM T-5's aren't rated for a lot of torque. They never used them behind a 350, only 305's. They used the T-56 for the 350. At least the one thing some of the Camaro's had going for them (in a V-8 application) was the 2.95 first gear.  But frankly it seems to be a lot of mix/match to get ratios, input shafts, shift lever locations that each application needs.
I've spent an extensive amount of time looking into a T-5 (or any Ford 5 speed) for my 289 Tiger and can get frustrating as nothing is ideal, or even close. And I'm hampered with a 5 bolt block and a vertical pattern Toploader bellhousing.
This is a pretty good discussion link on the T-5.
http://www.ffcars.com/forums/17-factory-five-roadsters/244421-t5-tranny-recommendations.html
There is also the GM (Camaro?) T5 option that puts the shifter in the right place, but needs a custom crossmember/mount due to the goofy angled tailshaft foot. It also puts the speedometer cable on the wrong side.
Perhaps the better question we should be asking is what is your budget for this 5 speed swap?  The Merkur T-9 is likely a very hard find and from what I've heard not as stout as a T-5. The Quaife T-9 that Pintosopher mentioned is likely $3,000+ to your front door.  A self pulled, 2.3*, T-5 (if you can find one) from a self serve wrecking yard is likely about $150. That is quite a cost difference.
*You mentioned " Found PLENTY of World Class T-5s on E-Bay."  BE AWARE I just did an Ebay search of "T-5 Transmission" and of the first 200 hits that came up NONE were for the 2.3 Ford version of the T-5.  They were either the Mustang or the Camaro.  The Mustang trans has a different length input shaft and the Camaro like wise, plus in most years the Camaro had a different bolt pattern. S-10 T-5's are also different.  I then did a search for "T-5 Transmission 2.3" and ONE transmission came up.  I see 2.3 input shafts on Ebay in the $80-$100 range but I'm not sure that is all you need to convert the 5.0 trans. Plus for better or worse you get the 5.0 ratios.
I live in So. Cal. where cars linger longer and parts tend to be more readily available.  I went to two self serve yards nearly every month for the past 20 years.  I'm going to say in the past 8 years I've seen two T-5 Turbo Coupes and maybe one to none T-5 2.3 Mustangs. So, even 2.3 T-5's aren't just lying around on the ground.  Think this through before committing. Tire size, rear axle ratio, type of driving, budget, mechanical skills, expectations, alterations (driveshaft, speedometer, shift lever location, clutch disc etc.) - are just a few things that come to mind.
I was fortunate that my '88 Turbo Coupe was my daily driver for 10 years. An insurance pay out (other parties fault) basically made the car free. It just so happened that my C-4, 6-3/4" rear end driveshaft fit perfectly to my T-5, 8" swapped rear end without alteration. I still had to hunt up a 86 or older bellcrank bellhousing (87-88 were hydraulic), pedals, cable, make the trans crossmember modifications, create a new cable mount (elevate over the crossmember), shorten the shifter etc.. So it is not just out with the old and bolt in the new. I'm not trying to discourage, but I do feel a responsibility to present many of the aspects of the swap.
Update: I ran the tag number and it is an 87-88 Mustang/Capri 2.3 trans. So, it is WC.  1352-162 Ford 87-88 Mustang/Cap ri 2.3 240 3.97 2.34 1.46 1 0.79 3.7 7T Y(WC)  http://www.mongosgarage.com/tech/t5/T5Numbers.PDF
Here is the Ebay link:  http://www.ebay.com/itm/Mustang-t5-transmission-87-88-2-3-79-93-ford-/122625095872?hash=item1c8d0678c0:g:iHMAAOSwj85Zf0Pa&vxp=mtr
Quote from: Henrius on October 14, 2017, 05:39:31 AM
The Quaife Rocket Box seems to be a FOUR speed with close gears, so I don't see how they would slow down the engine revs on the highway.
Thos Merkur T-9s are sure rare. Found PLENTY of World Class T-5s on E-Bay. How easy is it to swap the bell housing from my original 4 speed to the T-5? I am starting to wonder if this is a worthwhile project.
Henrius
Quote from: robertwwithee on October 06, 2017, 08:01:28 PM
Your car had the T5, and you are converting to a T9? Just curious, why are you doing that? Was the T-5 conversion not satisfactory?
Henrius
Quote from: pintosopher on October 06, 2017, 10:19:35 AM
Henrius
But I thought early Capris had the same 4 speed that the 2.0 Pinto had. When did they have a 5-speed? Was it that same tranny as the Merkur T-9?
