Custom Pinto Project
Date: 06/12/2016 07:37 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
Date: 05/21/2019 11:50 am
Date: 08/16/2018 08:54 am
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 11/08/2020 02:10 pm
Date: 01/28/2021 03:49 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
  • Online today: 367
  • Guests: 104
  • Total: 104
Drive line vibration damper question
Started by jburt, May 08, 2014, 07:33:29 PM
As best I can tell, the major block changes, at least for the Ranger, occurred for the '95 model year. Smaller mains, no fuel pump provision, and the head got a different intakes and ports.
On a related off-topic note, what thread size are the bellhousing bolts? My guess is M10 or M12, but I'd like to have them in hand before I have to hang something on an engine stand.
The stepped dowels would be dead easy to make on a lathe....and I have free access to one.  ;D
jburt
Quote from: Pinto5.0 on May 20, 2014, 04:40:34 PM
As you can tell we have no idea how to stay on topic LOL
Not a problem for me. I got my orig question answered and even more info I will eventually use.
Great job... Don't stop now.
I color outside the lines...
74 Squire Wagon - needs a lot of work.
Looking at a Ford 1980 powertrain service manual today shows both the C3 and C4 listed with Pinto/Bobcat 2.3 C4 service procedures specifically mentioned in that section. Apparently C4 still an option that late.
Quote from: jburt on May 20, 2014, 03:54:52 PM
Thanks everyone for the information and discussion. It is more than I anticipated and valuable to me.
jburt
Yeah, I have several early blocks drilled for both bells. I'll have to look again but I don't remember any of my turbo blocks being drilled for the 2.0 bell.
The 2.0 engines and bellhousings (both manual and auto) use hollow locating dowels that measure about 0.5" in diameter.  The 2.3 engines and bellhousings (both manual and auto) use hollow locating dowels that measure about 0.6" in diameter.  So when using a 2.0 bellhousing on a 2.3 engine, a stepped hollow locating dowel can be used to allow it sit flush and aligned.  As an alternative, the 2.0 bellhousing locating dowel hole could be bored out to the 2.3's larger size but the machining needs to be precise for alignment.
On the two sets of 2.3 block upper mounting holes, I suspect we are not thinking of the same thing.  To rephrase, the early 2.3 blocks (70's & 80's) have 8 holes drilled and tapped for bolting down the bellhousings but only six of the holes are used.  The extra 2 holes are at the top of the block, see photos.  The early auto bellhousings use the lower of the 2 upper holes.  The late autos (~90's) and manuals ( early and late) use the upper of the 2 upper mounting holes.  This is the same for both NA and turbo blocks.  The above is based on the parts that I have.  I have the following early 2.3 blocks that have the two sets of upper holes (8 total holes): 79NA, 86T, 87T, 88T, and 89NA.  I have the following late 2.3 blocks with just the upper of the two set of upper holes (6 total holes): 93NA, 95NA, and 98NA.  Hope this did not confuse it further.
On a side note, the 2.0 bellhousings (both auto and manual) would use the lower of the two sets of upper holes on the 2.3 blocks.
Quote from: oldkayaker on May 19, 2014, 06:33:01 AM
Just a clarification to muddy up the waters. :)
The C3 was the most common auto used in the 2.3 Pinto's but a few came with the C4's.  Checked RockAuto and both the C3 and C4 are listed for the 1975 to 1980 Pinto 2.3's.  According to RockAuto, the 1974 Pinto 2.3 auto was the C4 only and no C3 which varies from the above posted id tag evidence, more mud.  A few years ago a person on craigslist was selling a 1979 Pinto engine with an auto and the photo was of a C4 (just an evidence point).
Bellhousings use 6 holes.  The 2.3 blocks up to about 1994 had two sets of upper mounting holes making a total of 8 mounting holes.  Of the 2.3's two sets of upper mounting holes, the auto used the lower two while the manual used the upper two.  The hollow locating dowels on the 2.0 block are smaller than the 2.3 block making the need for step dowels to use a 2.0 bellhousing on the 2.3 block without machining the 2.0 bellhousing.  The 2.3 C4 bellhousing holes match the 2.3 block standard straight larger dowels, so no step dowels needed.  If using a 2.0 bellhousing on a 2.3 block, the step dowels are easiest way to go.  A fellow over on TuboFord.org sells custom made step dowels (I believe they are not a Ford product).
http://forum.turboford.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=6;t=014626
I've always assumed the stepped dowels were for all the early C4 bells, not just the 2.0 version. I've never done the swap to know for sure.
Is it N/A 2.3's that are double drilled for both bells? My 83, 85, 86 & 87 turbo blocks are only drilled for the later 2.3 bellhousing.
Quote from: oldkayaker on May 19, 2014, 01:57:20 PM
Anyway people probably need to look to see what they have.
That's what I always do..
74 PintoWagon you are correct on the 1974, I was just looking at flex plates on RockAuto.  I just checked O'Reilly and they list both C3 and C4 flex plates for 74 thru 79 Pinto's (the 1980 listing was unclear).  Maybe these part store listings are not the best resource for determining what originally came in what.  Anyway people probably need to look to see what they have.  In addition to the factory shuffling parts, past owners tend to use whatever is available to keep their cars running.
but the c4 was available in the later 79=80 pintos and the door tag code for c4 is a w
RockAuto shows a pan gasket for both C-3 and C-4 for 74..
Just took another look, if you look at the C-4 applications Pinto isn't on the list only the C-3 74-80..
None of this is surprising, nobody but nobody simply stops using one part and goes to the other at year end and Ford is the worst about dilly-dallying around with leftover truckloads of parts. I used to love the mid-year main wiring harness changes they used to make that you could not find replacement harnesses for. I have a '98 Contour that to this day I have not found a TPS sensor for, a very rare one used. Luckily I was able to mod it slightly to use another type that almost fit.
Quote from: jeremysdad on May 18, 2014, 09:29:22 PM
So, Ford has a set of 2.0 to 2.3 stepped dowels that they're not telling about?
2.0=C4
2.3=C3
In 74. Cut and dried.
The 2.0 C4 bell wont bolt to the top 2 holes on later 2.3's so the 74 C4 bell is needed because it has the upper mounting holes. The stepped dowels are because the block holes for the dowels are a different size than later versions so you need a dowel with both sizes on it. One end to the block & the other to fit the bell.
jeremysdad
2.0=C4
2.3=C3
My guess is the late build 74 cars got the C-3 after the last C-4's were installed since Ford was making the C-3 the automatic of choice for the 75 run.
jeremysdad
Thanks for helping to keep the flame alive! :)
jburt
Quote from: Pinturbo75 on May 18, 2014, 08:52:12 AM
you wouldn't be willing to post a pic of the door tag would you?? I haven't run across this before and ive been over tons of pintos....
I'm more a Chevy and older Ford guy but I've learned there is always something new to discover.
A birth date of March 74 would be pretty far into the model year to be a holdover.
Here's my door tag:
Here ya go.... Oh btw, when I bought the pan gasket the guy got the part number out of a catalog, said 74 with C-3....
O'Reilly's offer a pan gasket for the C-3 and C-4 for 74.
http://www.oreillyauto.com/site/c/search/Transmission+Parts/C0073/C0338.oap?year=1974&make=Ford&model=Pinto&vi=1135156&cat=AT+Oil+Pan+Gasket
http://en.wikipedia.org/wiki/Ford_C3_transmission
Well, don't know about the Mustang but my Pinto is a 74 all original unmolested and it has a C-3, code on the plate says C-3 and I replaced the pan gasket and it has 13 bolts, but I guess I don't have a C-3.. ::)
I don't need to research..... its been talked and hashed out before you newer guys were on here..... the reason it was talked about so much is the 2.3 turbo guys look specifically for the c4 bell from this year so we don't have to get step dowels for the bell.... its a direct bolt on without modification....the earlier c4 bells require step dowels to bolt up right...you guys can continue to deny fact ....im just tryin to get you straight....
and by the way.... your m2 may have had a c3 in it but it did not come from the factory with it.... here is a spec sheet on the 74 mustang 2....
http://www.automobile-catalog.com/car/1974/856055/ford_mustang_ii_3-door_22__2_3l_cruise-o-matic.html
Funny, the heavier '74 M II came with C3, I had one, the trans now is in the Pinto.
Parts store catalogs or computers really mean nothing, I found one year errors by the hundreds, the later electronic ones are no better. When someone insisted on something like this commonly a quick look at the year before or after their known year would produce the part but sometimes it got deeper than that. Some parts lines are out to lunch when it comes to correct #s. Even more amazing is all the crossovers a part can have yet they don't list them. Seems like the manufacturer would at least research all vehicles his part fits to get maximum sales.
Midyear changes are the worst, many not listed at all.
The parts books for Focus through the years produced lots of incorrect parts, nobody but nobody can keep all the motors straight there. Common for MTX parts to be listed as fitting ATX as well. Contour/Mystique and all the different incarnations of early zetecs out there? Give it up, you'll be researching for a while..........
jeremysdad
Quote from: 74 PintoWagon on May 09, 2014, 09:21:48 PM
Right, but I thought the 2.0 was dropped in 74 for the 2.3 and he's got a 2.3???..
They dropped the 1.6 in the 74 model year for the 2.3, it was the last year the 2.0 was offered.
ill tell you what.... go to any parts store you want and pull up a 1974 pinto with auto trans and if you find any listing anything other than a c4 ill donate any 20 bucks to the site.....74  is c4 only.....
how many pan bolts are on the tranny pan....should be 11
