$300 Pinto for sale
Date: 04/19/2017 10:24 am
Date: 08/01/2018 01:17 pm
Radiator
Date: 05/27/2018 06:07 am
Date: 03/25/2019 09:02 pm
Date: 01/12/2019 10:19 am
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
  • Online today: 344
  • Guests: 173
  • Total: 173
Drive line vibration damper question
Started by jburt, May 08, 2014, 07:33:29 PM
I had understood that C4 was a HD option in '74, don't remember where I got it though. I'd bet the C3 is worth maybe some mpg with less weight flinging around in there.
jburt
It is definitely a 2.3L / C3. I got the pan back on the Trans and reinstalled the rear seal. Filled it with fluid and took it for a test drive. The trans sounds and feels okay. Apparently all the fluid had puked out when the rear seal came loose after the previous owner had changed the trans fluid and filter. He said it made a real racket, vibrations, and didn't want to go any where. He threw up his hands and decided to divest himself of his nightmare after he had done a complete tuneup, new vacuum lines, and some front suspension work.
Still a lot of work to do to the little beast but I'll take it one bite at a time.
I color outside the lines...
74 Squire Wagon - needs a lot of work.
Quote from: jeremysdad on May 09, 2014, 06:35:38 PM
74 was an odd transmission year. 2.3 was introduced with the C3, 2.0's only came with a C4. So it could be either or. Depends on the motor. ;)
Right, but I thought the 2.0 was dropped in 74 for the 2.3 and he's got a 2.3???..
jeremysdad
Quote from: 74 PintoWagon on May 09, 2014, 08:05:58 AM
Sorry, but 74 is the first year for the C-3, 73 still had the C-4.. ;)
jburt
Thanks for the responses. I've bought a CD of the 73/79 complete parts numbers, break downs, and illustrations. (eBay) I went back and checked the C3 - C4 exploded illustrations to compare and my case is a C3. Off to climb under the wagon and finish putting it back together. Thanks again for the info.
Mine are missing & I never even realized it until I ended up with a car that has one. I'm not putting any back on mine.
I've removed that vibration  damper on all of my Pintos that I have lowered, and I have never seen any difference. Don't worry, just enjoy.
Quote from: Pinturbo75 on May 08, 2014, 07:37:40 PM
I don't use one on either of mine..... and being a 74 unless someone changed the tranny it is a c4..... only auto available that year..
Not necessary, it is small enough a weight to not make much difference anyway. Probably only notice it missing on a brand new 'tight' car, one of those detail things Detroit did that can be easily defeated like so many other things. My Mustang 2.3 didn't have one but the Pinto did, Mustang trans now in Pinto and can't tell any difference. Both C3.
jburt
Thanks for the info.
C-4... that's what I get for continuing to read after my eyes start crossing. When I got the car up in the air, the rear trans seal was flopping around on the d/l yoke. After seeing the vibration damper in the parts list, I started wondering...
jburt
My first question of what will probably be many as I familiarize myself with my 74 Pinto Squire Wagon.
2.3L - C-3 Trans.
What is the purpose and how critical is the D/L vibration damper on the back of the trans hsng. The housing is broken through the bolt holes so I can't just bolt another damper on. I could probably make something up if it is that critical. But, do the drive lines vibrate that bad? Or is it harmonics from the engine/trans?
I'm looking forward to playing with this thing but it is not going to be a restore. I guess more like a resto-rod.
Thanks  people, I've already learned a lot just cruising through the forum.
