2 liter blocks and heads
Date: 03/28/2018 09:58 am
Date: 05/15/2022 11:36 am
postal pinto
Date: 06/03/2020 09:31 am
Date: 04/27/2018 10:28 pm
KYB shocks
Date: 02/08/2017 07:09 pm
Date: 01/30/2017 01:48 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
V8 rear end
Date: 04/12/2018 10:57 am
Great Cruise wagon
Date: 12/17/2016 03:39 pm
  • Online today: 548
  • Guests: 502
  • Total: 502
best balance of power, fuel economy and cost
Started by poomwah, March 30, 2014, 09:41:01 PM
Quote from: poomwah on April 13, 2014, 06:15:54 PM
can't afford a bigger engine. But since my power steering is leaking, I may as well ditch it
I don't have power steering on mine and as easy as it is I sure wouldn't add it, wife don't even complain about it,lol..
poomwah
Quote from: Rob3865 on April 13, 2014, 06:10:19 PM
I don't know. If you gotta start deletin nice stuff like power steering in the name of power......maybe a bigger engine is in order.
Rob3865
Quote from: 74 PintoWagon on March 31, 2014, 07:32:23 AM
Well, I got everything on hold right now to finish the shop(which is just about done)then I'll be getting back on mine, already have the intake and header just need the carb, plan is to squeeze all the mileage I can without digging into the motor, at least not for a while anyhow..
Where are the pictures?  Hmmmmmmmmmmmmm LOL  Let's see pics!
poomwah
the open air cleaners don't pull in too much heat from the engine compartment?
Seems like everyone is about cold air intakes, you don't see too many people running open ones anymore, even though they look great :]
I bought one of these 2 days ago for when I replace my wagon engine. Cheapest price I've ever found.
http://www.ebay.com/itm/171191023049?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
poomwah
Yes, at least in my view. The stocker is abysmal.
poomwah
ok, so , it looks like I'm keeping the automatic. I have had knee surgery on both knees in the past. and they are giving me a lot of trouble lately. At least they started acting up BEFORE I swapped to a manual. LOL.
so......
looks like I'm sticking with the stock intake and carb.  Deleting power steering and emisisons (leaking power steering and cleaner engine compartment without emissions stuff), Adjustable cam gear.
  With the only change being lack of emissions and adjustable cam gear... is changing to a ranger tubular exhaust manifold even worth the money?
poomwah
so its looking like Ranger exhaust manifold, stock intake and carb , deleting power steering and emissions, swapping to manual trans, adding adjustable cam gear.
undecided on what air cleaner I'm going to use.
probably going to keep ignition stock.
don't know if I'm going to change cams.
I'm going to worry less about power vs fuel economy, and I'm going to concentrate mostly on simplicity, dependability, and tidiness.
poomwah
thanks Amc, looks like I've got a lot of decision making to do, got to figure out what I can afford, and what work I can actually do myself. Block off plates and brackets and stuff like that I can do.  Making adapter plates, that's beyond my equipment capabilities
It'll work but kinda problem. The stock 2.3 manifold sucks but will work if you just relegate yourself to a 100 hp. motor. The EFI lower is better but has to have some work done to make it work right. I used  a 2.0 manifold with adapter plate; it worked really well but the plates not commonly available, I made mine.
Most try to use the EFI lower to get more power but the commonly used one inch thick adapter is too low and flow suffers in my view. They make a two inch one that in and of itself would flow much better but that one may not fit under the hood, jury still out with the verdict. I for one haven't tried it yet.
If one could find a stock Offenhauser 2 barrel intake that would probably work OK with a 5200. Hard to find though. And made for inline two barrel, not staged progressive like the stock carb is. Intake work on the 2.3 SOHC is not a cut and dry affair, you have to do work to get anything to work really well.
poomwah
what are your thoughts on using a properly tuned 5200 on a better manifold?
poomwah
wow, thank you VERY much for that information Amc.
really makes me wish I could put a v8 in it at this point
The 2100 should hurt mileage, at cruise you are feeding from two transfer slot sets instead of one like the 5200. And air going through two venturis which is less efficient than one with more flow. Most of them are off V-8 engines so the power valve channel restrictions will need to be custom made, as in smaller. Most people simply change jets and valves only and a big giveaway in total set-up there. And which bore 2100? Only like 50 of them in several bores, and different every one. The location of the airbleed holes on the main emulsion tubes can make or break you mileage wise there. Meaning you should try out more than one booster venturi there.  The later 5200s even changed in size looking for mileage in the later year models. The early ones were too big on primary side and lost mileage. Of course they made more power, important on a first year small engine car.
Yes, sometimes you can get both power and economy with the same setup but much more common on bigger engines, the smaller ones tend to do less of that. The load (power to weight ratio) on smaller engine exaggerates the giveaway between power and economy there. Basic physics. Going to electronic ignition is one that gives on both ends. A PROPER header can, like a 4-2-1. Mods for TORQUE, not horsepower, can. Any UPPER horsepower mod almost always will cost mileage. Head porting in the valve pocket alone with no increase in size of port runners AT ALL can help. Slightly increased compression will help both if you can get it to not ping.
Small engines drop off way more in mileage percentage wise when they get old than big ones do, they have less power to give away when ring seal starts to drop off. It takes a certain amount of power just to maintain say 70 mph steady state. Thinking like 35-40 hp. depending on how slippery car body is. I find I have trouble hitting like 27-28 mpg (32 advertised) on my two older Focus 16 valve engines since they crossed around 110-120K miles, they are getting looser and mileage then begins to drop. I too know carbs backwards and forwards so can work on them blindfolded and hundreds jetted but I feel there is no noticeable difference in absolute power in carb or EFI if carb is well set up. The big difference is in how long the tune lasts and the extra life the motor gets from no extra fuel mixing with the oil. PCM is the biggest reason for cars lasting 300K miles now.
ATX with no lockup and no OD was always advertised as about 20% mileage cost in lots of earlier studies. Of course, once you get a certain amount of lower gear under the car the low output engine will cost more in mileage anyway, they do not have enough torque to lug an overdrive gear once the engine gets older, resulting in more throttle used to maintain speed and lost mileage doing so. OD is a much cleaner idea when used on bigger engines with more torque. My Focus cars actually tend to shift back to 3rd now at any slight incline, the OD as provided by Ford is too much load for the older higher mileage engines. Yet it worked fine when the engines were new and fresh. The engines are rated at 130 hp. but I feel they drop to maybe 110 real world with more mileage. 110 gross is about 80 or so net at the wheels, that's not a lot extra to play with.
poomwah
ok, I've got the game plan mostly figured out, with a few possibilities later.
I'm going to change the auto over to a manual.  Mostly because I'd rather have a manual for driving fun, but also it may help mileage a little and it opens up my cam choices if I decided I want to change it.
I'm going to keep the original bottom and and PROBABLY the head.  Ranger header and either FI lower intake or offy.
PROBABLY a 2100 carb, possibly a different model. Undecided on air cleaner.
POSSIBLY a newer roller cam head.
  I'm pretty confident none of that will hurt my fuel mileage.  If I don't gain any, that's ok, as long as I don't lose any.
I'm sure that with those things done that the car will be a lot more fun to drive though :]
poomwah
Thanks Tom,
   That's really decent of you , but there's no need to apologize. I appreciate all the opinions you shared
Seth
Poomwah,
  My apology, I didn't know about your disability, remote location and other difficulties.  I hope everything works out however you decide.
Tom
Quote from: dick1172762 on April 02, 2014, 11:45:32 AM
   I've driven Pintos since 1972 and their miles per gallon sucks. I've owned 16 of them and none ever got over 20 mpg. This engine was created in the late 60's so what do you expect? Its a tractor motor compared to todays motors. Just drive it and enjoy it. That's what its for plain and simple.
Well we'll see, I'm not giving up that easy, LOL..
Oh and the HP in 87 with EFI was 90 HP/130# ft. of torque so no huge gains over a basic carbed 2.3L in a Pinto. I would think an EFI head, intake & computer would bolt right on a Pinto block since compression should be close & there are no extra block holes needed for sensors.
The question of EFI being worth much is debatable. I have an 87 Mustang LX, 2.3L 5-speed with 87K miles that I originally bought to swap the drivetrain into my wagon. I held off doing the swap because the engine smokes at startup but everything points to it just needing valve seals so I may yet try this since I need to swap my ill running 2.3 anyhow. It will depend on the complexity of the engine wiring which is supposed to be minimal.
Here's what I do know. The Mustang weighs 2800# & the wagon 2600# so that's a wash. Aerodynamics are probably a wash at 65 mph as well. The Mustang in a good state of tune could do low 20's city, high 20's highway with the 5 speed. I figure the swap will net me about 23-24 mpg average in my wagon assuming I use the same rear axle ratio as the Stang. I need to see what's in both but I'm not swapping a rear if it's close enough (say 3.00 in the wagon & 3.08 in the Stang)
Getting the Stang stripped & scrapped is a priority on my to-do list this year so I may be on this task in a couple of months. If getting it in the wagon can be done quickly(I need the car running, not a 4 month project) then I may have this done by the end of June & I'll have some real facts to report on mileage.
poomwah
I don't want to turn this into a financial debate, but yes 5 to 8 dollars a week add up. Especially when my disability check just barely covers rent. Living out in the middle of nowhere eliminates walking and catching a ride. Driving prudently is something I've definitely learned to develop.  So there are times that 5 to 8 dollars a week will determine whether or not I drive somewhere or not.
That being said, I realize that for the most part, you have to pick power or fuel economy, but I also know that's not always the case. I know there are things that can be done that will improve power AND fuel economy, even if they are VERY minimal gains, every little bit adds up. I also know there are things that can be done that improve performance without hurting fuel economy. Again, VERY small gains, but still they add up.
I just don't know what applies to pintos and what doesn't.
I have a car for sale, whatever I get out of that is going into the bobcat. My biggest priority is to make it dependable. My next is to make it clean, ie ANYTHING that doesn't need to be under the hood is GONE.  No emissions checks in Ohio, so anything that isn't going to hinder engine efficiency is going.  Fuel economy is a real issue and I would like to improve it if possible. At best I want to make sure I don't LOWER it at all.
  While I have VERY little experience with fuel injection, I will go that route if that's the best way to go. I have decades of experience with carbs, while I still don't like experimenting with jetting, I am no stranger to to rebuilding and adjusting carbs, from single barrels to 4 barrels, including multi carb set  ups. I'm comfortable with all of them.
So, it seems the consensus is that to get 25mpg out of a pinto wagon you need to change the engine?  Would the whole engine need to be swapped, or just a newer top end do the trick... ranger for instance?
Well, again my math says for Poomwah the difference is between $5-$8 a week. Being prudent in how one drives helps.  My old Mazda 323 averaged about 34 MPG.  If I drove like a "Hypermiler" I could get 37 MPG. 65 MPH in that car got high 30's MPG.  Going 55 MPH got 44-45 MPG and only took 20 minutes more on a 2 hour drive.  There was NOTHING I could have added/removed parts wise to that car to get those differences.
If that $5-$8 a week is really hurting him, walking, catching a ride with others and driving prudent can make up that cash difference - fast.
Quote from: poomwah on April 02, 2014, 11:20:13 AM
I know that 5 mpg isn't much to most people. But in my financial situation it's a huge difference
I parked my crew cab dually because 9 mpg was killing me. Driving the 15 mpg Pinto instead feels like I won the gas lottery. My Neon was getting 32 mpg before winter & lately it's getting 21 partly due to winter blend gas but also I think the head gasket needing changed may be causing the decrease. I have an external oil leak by the cam feed so if that part went maybe it's blown elsewhere. I definitely notice the extra gas that car is drinking at 21 versus 32 so it's a priority to fix ASAP.
On paper it doesn't sound like a lot but that extra $20 a week in my tank gets noticed even though I make more than enough to afford it. I don't like giving free money to the oil company if I can get better mpg's outta my cars.
Quote from: 74 PintoWagon on April 02, 2014, 09:33:31 AM
I'm getting just about 20 now and it's running like crap, once I change the intake and carb and put a header on and rework the ignition curve a bit should be able to get 25+ I would think..
poomwah
Your question revolved around the best POWER and ECONOMY.  As I stated above you generally can't get one without sacrificing the other.  There was the Pinto MPG that was rated at 34 highway (manual) 30 highway (automatic) http://www.pinterest.com/pin/155092780890759062/.
But that is likely not "real world" driving. The test might well have had a lightweight driver, just enough fuel for the test, tires inflated to 40 PSI, the maximum permissible tail wind and road slope with the car going 50 MPH on the highway.  For sure the car had the 2.76 gears and a professional driver skilled at extracting mileage out of the car.
You (possibly weighing more that the "test driver") get into your car with a full tank of gas, you start up a cold motor and drive 70 MPH over inclined roads into a head wind with 3.55 gears in the rear.  Throw in city driving and if you get 20-25 MPG you are doing pretty good.  Before I went Turbo/2.3/5 speed my 2.0/Auto wagon averaged about 22 MPG.  I was about 50/50 - city/highway and live in a somewhat hilly area.
For the record the difference between 20 MPG and 25 MPG is 100 gallons of fuel over the course of a 10,000 mile year.  Here in So. Cal. gas is currently $4.00 a gallon. The difference is $400 a year or $33 a month or $8.33 a week.  That is less than an hours work a week (based on $9.00 minimum wage).  Chances are most Pinto's are being driven far less than that.  So, I doubt the difference is more than five bucks a week.  Just drive the car and enjoy it for what it is.  I think you will be happier.
BTW, Plymouth had a "Feather Duster." A far bigger car with a 6 cylinder engine nearly double the size of the Pinto.  Their claim was that it got 36 MPG.
"The Feather Duster featured lightweight aluminum parts including the intake manifold, bumper brackets, hood and trunk bracing, and manual transmission housing, for a weight savings of about 187 lb (84.8 kg)—5% lighter than a standard Duster similarly equipped. It came with a 225 Slant Six with its distributor and single-barrel carburetor calibrated for economy, a low-restriction exhaust system, an extra-high rear axle ratio, and was offered with either the Torqueflite 3-speed automatic or A833 overdrive 4-speed manual transmission. It was the most fuel-efficient car in its size class, achieving up to 36 mpg highway and 24 in the city with the manual transmission option. (along with Dodge's version, the Dart Lite)."
Quote from: poomwah on April 02, 2014, 09:12:13 AM
Wow.  So i guess 25 mpg was an unrealistic goal :[
I sure haven't had any luck getting there, that's for sure.....
