2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 03/07/2017 07:03 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Date: 08/27/2018 11:11 am
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
  • Online today: 445
  • Guests: 353
  • Total: 353
best balance of power, fuel economy and cost
Started by poomwah, March 30, 2014, 09:41:01 PM
I'm getting just about 20 now and it's running like crap, once I change the intake and carb and put a header on and rework the ignition curve a bit should be able to get 25+ I would think..
poomwah
Wow.  So i guess 25 mpg was an unrealistic goal :[
I have a 76 wagon, 2.3 auto with 60K orig. miles that was getting 15 mpg. I replaced the entire cooling system including the radiator, new brass terminal cap & rotor, NGK Iridium plugs & MSD 8mm wires, new PCV valve, new vacuum lines, new EGR base gasket & carb gasket plus an NOS carb out of the box.
For about 2 tanks of gas I topped 20 mpg then the carb started to bobble at idle & I'm back to 15 mpg again. I also now have pre-ignition that wont go away even after backing the timing down, checking the belt 3 times, swapping to colder plugs & tearing into the carb 4 times.
The moral to this story is that I spent $400+ trying to up my mileage & I'm worse off now than when I started. This years plan is to drop in my freshened turbo longblock with another NOS carb & a T5 in place of the auto & hope I solve every problem at once.
Congratulations on getting your car.
  Regarding mileage, RPM's etc., I know I bang this "Gong" every time the subject comes up but USE ONE OF THE MANY ON LINE CALCULATORS!  The transmission ratios, the rear end ratio AND the tire size are all a system.  Combined together they determine the final RPM your engine will be turning at a certain speed. Ideally you want the RPM's in the desired portion of the torque curve.
Most everything is a trade-off.  You only get in one area where you loose in another.  That said, it is possible to simulate an overdrive fifth gear or a different numerical rear end.  My already slow '73/2.0/Auto/3.40 wagon was "Bogashious" when I switched from the 185/70/13" to 225/60/16" tires off the Turbo Coupe.  I never did "the math" because the tires were temporary but you could clock it with a calendar, it was that slow.   Did it drop the RPM's? Sure, but I doubt mileage improved because I had to be "so into the throttle" just to get and keep the car moving.  BTW, look at a lot of the Asian 4 cylinder cars.  Even with a 5th gear overdrive they are turning 3,000 RPM @ 65 MPH.
Basically what I'm saying is dropping the RPM's doesn't in and of itself automatically mean an increase in mileage.  If you want to "test" the theory, trying appropriately sized taller tires is far more cost effective than swapping rear gears and transmissions. Use the calculator and see what tire size effectively gets you to the RPM's the gear and trans swap would. Then borrow (or buy cheaply) that tire/wheel size and see if you are happy with the results.
Frankly I doubt you can improve mileage more that about 2 MPG maximum with whatever you wind up doing. If you drive 10,000 miles a year you are only saving 30 gallons of gas.  If you get half the improvement and drive half the distance your talking about all of $25 a year.
poomwah
hey guys!!! this isn't hypothetical anymore. Instead of "lets say a late 70s 2.3"  lets say a 78 bobcat with a 2.3 automatic.
I got a "Pinto"!!!!!!
so the goal is to get 25mpg or above.
Thanks, looks like I need an overdrive if I'm gonna do any traveling then.
the wagon is 380 gears with a t5 and its about 2700 ish  and the sedan is 355 gears and 24 to 2500 ish with a t5
What's the rpm at 75, you running an overdrive???, that's pretty good mileage..
i did my turbo swap in 2 weekends for less than 500 bucks....bought a complete parts car and went to town .... now the wagon is around 230 whp and gets 27 mpg at 75 ...... the 75 sedan is over around 400 whp and gets 25 mpg at 75.....if you look hard enough and want it bad enough you can do it.... on the cheap.....
Well, I got everything on hold right now to finish the shop(which is just about done)then I'll be getting back on mine, already have the intake and header just need the carb, plan is to squeeze all the mileage I can without digging into the motor, at least not for a while anyhow..
Any bigger than stock cam with a stock ATX converter will not be the hot setup. At least if bigger in duration. Would work fine on MTX but ATX and the heavier wagon will not like the cam. Would be fine if you can bump lift but no duration.
I've run a Hooker header and a better intake on a 2.3 using stock 2 bbl. carb and cam and round port head reworked in the bowl area to make a car that would slightly outrun my 2 Focus 130 hp. zetec cars. The motor made quite a bit more torque at say 60 mph freeway entry and the gas mileage was great.
A stock 2.3 carb intake just flat blows. I used a 2.0 intake with an adapter plate but most can't go there. They used to make the plate for sale but no longer.
poomwah
Quote from: Srt on March 31, 2014, 02:57:45 AM
there is really no reason why you can't run a turbo AND get mid to high 20's in fuel mileage
I wish I could run turbo. I just can't afford the parts and don't have an engine hoist to do an engine swap.  My budget is going to be really tight.
My goal is to try to get at least 25mph and enough grunt to get out of its own way.
of course I need to get the car first, LOL
poomwah
wow, 20 mpg and 160 HP.  That is impressive.
I'm going to shoot for a lower HP and hopefully higher MPG
kartracer28
I am doing kinda the same thing right now. I have a 74 with the 2.0 I just bought a 2.3 that I am going to swap (with help from friends) I am putting an EFI intake that has been reworked to run a small 4 barrel. I am having the head redone and putting a cam in it from esslinger. I am also putting a header with a 2 1/2 inch exhaust with a 40 series flow master. The guys at Esslinger say it should make about 160HP and still run on pump gas. and if a drive it "right" I should get about 20MPG.
poomwah
Ok, I know that speed costs, and I know that power usually has a negative effect on fuel economy.  But I also know, though, that some things can improve power and fuel economy.
So, lets figure on a late 70's wagon with a 2.3 auto. what would be some options to make it more efficient?
turbo is going to out of my budget.  I don't have an engine hoist, so I'm prefer to find options that don't require swapping the engine.
  So....what do you guys recommend?  exhaust, cam, and carb on stock block?
Fuel injection from a ranger?
What should I expect performance and economy wise?
Thanks everybody
