Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 04/10/2017 07:30 pm
Date: 03/25/2019 09:02 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 02/25/2017 08:45 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Date: 08/26/2018 06:35 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
  • Online today: 502
  • Guests: 433
  • Total: 433
2.0 Valve adjustment
Started by rramjet, August 28, 2013, 03:18:52 PM
jeremysdad
Good to hear you got it back together and all is well! :)
Good for another 200,000 miles. :D
rramjet
OK finally got enough time, cooperating weather as well as a friend to act as fire guard to start the engine today. All is well and the idle is so smooth and quiet now. Can't say I notice any more power but haven't taken it out on the freeway yet and the new cam is just a stock one so didn't expect much more.
So all in all it got a new timing belt and tensioner, hardened exhaust seats, valve job, new cam and followers and oil tube as well as all the normal gaskets associated with a head removal.
rramjet
Quote from: amc49 on September 28, 2013, 04:35:14 AM
When the exhausts recede in head it will definitely affect idle. BTDT. Several times. They do not simply keep a good sealing seat while dropping deeper, rather they dent and ding as pieces of seat glow molten and come loose. Never saw a head that you didn't freshen up and idle quality didn't improve dramatically. Seat leaks show much more effect at low rpm, they have time then to leak part of the squeeze out.
Good point and something I thought about after I wrote this. I remember looking at the seat area around the exhaust valves and seeing a slightly irregular looking surface so I'm hoping for a nice improvement.
rramjet
Well got my head back from the machine shop today. It had NO burned exhaust valves they were just receding into the head. They installed hardened exhaust seats, ground all the valves, put in new cam bearings, the new Burton Stock cam, followers and oil spray tube. Did a cleanup mill on the head all for $300. Seemed pretty fair to me. Also gave me some Comp Cam lube to put on before start-up. Will be changing oil to one with some zinc before start-up as well.
Since the head was actually in pretty good shape I'm beginning to think the surging I was getting around 60 mph and the intermittent crappy idle is probably all carb related. It is a 5200 and has a rebuild kit in it but I know nothing more about it so far. I do know that it has never been adjusted they way it should be and hopefully that will help idle.
jeremysdad
They don't know it as the EAO. It's the 'Pinto motor' on the other side of the pond. They didn't know what you were talking about. :) 'European Automotive Organization.' That doesn't make sense to them. It's 'The Pinto lump'. ;) lol They're also pissed cause the motor Ford gave them to work with is German. ;) So, it's 'the Pinto lump.' ;) In England, they start at 1.2 L and go up from there. Don't ask me how I know these things...
rramjet
Thanks. That's great information.
Everything I could find said the 2.0 EAO was the same engine over there but I guess they are being cautious.
jeremysdad
Quote from: rramjet on September 09, 2013, 12:20:10 PM
Hey jeremysdad have you or anyone you know ordered one of these sets? I e-mailed them asking if it would work in an EAO 2.0 and they said they thought the engine was different than "their Pintos" That's too bad if true cause it's a good deal even with shipping.
Sorry for the delay, our internet was out yesterday. Yes, I am running one right now, 40 miles a day to and from work, getting 24 mpg. It's a direct replacement, fitment-wise. Idk if it's a fuel injection spec'd cam, or what the actual specs are, but it runs like a scalded dog, for what it is. Works, as they would say, 'a treat'.
I'm stashing money for a hi-po upgrade from them. Eventually. One day... *dreams lol
rramjet
Quote from: jeremysdad on September 01, 2013, 09:14:17 AM
Go ahead and do this when you have your head redone. Once, and done.
http://www.burtonpower.com/parts-by-category/engine-components/camshaft-parts/std-camshaft-kit-sohc-pinto-2-0-cam-followers-pipe-camsohc20kit.html
Lucky deal finding a place like that.
rramjet
Funny, the thought that maybe the head had already been done crossed my mind but I'm going to pull it anyway just to be safe. Opportunity to replace the timing belt and tensioner while I'm at it.
Found a local machine shop who's owner used to race Pinto's so feel like I will be in good hands.
And they're still $50, just picked up a reman over the weekend. :D
jeremysdad
Glad just adjusting the valves sorted most of your issues. It is possible that somewhere in it's previous years/owners, your head may have already been machined with hardened seats, which would be cool for you. I don't know of any way to know for sure other than tearing it down to look.
Regarding the distributor, mine originally had the dual-advance distributor, but somewhere over the years, the spout for the advance had been broken off, so I had the retard spout running ported vacuum cause I didn't know any better. Of course, it ran funny, but this was done while I was chasing my tail diagnosing the condition caused by receding valve seats, so I doubt it really made much of a difference.
I got a reman single advance distributor from O'Reilly for something like 50 bucks.
rramjet
Well adjusting the valves made a vast improvement in idle and low speed operation but still had a surge at 60 mph and higher. It would go away if the engine was under load like climbing a hill. Finally figured out the vacuum advance is bad. It will move momentarily with about 5 lbs of vacuum but won't hold it, the vacuum bleeds off quickly. Disconnected and plugged the line from the carb and no more surge. Assuming it was a lean surge with the possibility that the advance was also moving back and forth.
So far it appears that a vacuum advance unit is unobtainium although I have located complete rebuilt distributors for a pretty reasonable price.
Anyone else run into this?
Aw com'on, put some carbs on that 'stang. I see what look like lowly 4224 660 centersquirters on there. Centersquirters zoop, they load up the back barrels too much. We ran a single 4 bbl. 1300 cfm Dominator on our AMC 401 street car, and twins on the race car.
Second gear burnout? You gotta be kidding. That motor lugged down when he did it. One of our AMCs would have broke tires loose and rpm skyrocketed past redline instead of lugging down. We could do an exact dupe of that 'stang burnout in FOURTH gear.
I had a 8.4/1 compression 304 (rated at 150 HP LOL) out of a station wagon that ran in the high elevens in an AMX, it could do second gear like that 'stang. Actually better, I used to irritate the GM boys next door to our shop by sidestepping the clutch at 6000 or so and then doing a 100 foot tire smoking burnout past their garage at around 7500 rpm the whole time in 2nd. Everybody would come out and laugh at the huge cloud of tiresmoke.
rramjet
"Stupid expensive, but very fast. DHL pWns UPS/FedEx/USPS.  lol If I recall correctly, shipping was almost the same as the part price. But worth it...once, and done. "
Well even with the shipping shown on their website it's still cheaper than just the cams I've found stateside. It does look like they don't keep them in stock with the wait they mention.
jeremysdad
jeremysdad
Stupid expensive, but very fast. DHL pWns UPS/FedEx/USPS. :) lol If I recall correctly, shipping was almost the same as the part price. But worth it...once, and done. :)
Here, listen to this, and Happy Labor Day!!! http://www.youtube.com/watch?v=mIQ8ds1eKfA
rramjet
Thanks. Was thinking about that. Pretty good price considering it includes the followers and oil pipe. Need to find out what the shipping runs.
jeremysdad
I have 90% of that book committed to memory.
Available online in .pdf form for free but copyright issue means you have to find it yourself. Found another one too in the two minutes I spent just now looking for links. 'How to Powertune Ford SOHC', completely different book.
I was referring earlier to simple stock valvetrains,  not custom one off race setups, which are totally different. Also, the process I mentioned has nothing whatever to do with rocker face alignment, per se. It is simply to prevent the motor running like crap when a deep valvejob is done on car, tips extend and then the hydro lash adjuster on 2.3s then limits out to hold the valve open. Then mechanic throws the whole ball of wax at car trying to find out why it won't run. I saw it happen several times back in the seventies, the old school guys simply thought the valvetrain would take care of itself. Many of them were not smart enough to pre-collapse the adjusters anyway, if still at the last running position they then hold valve open when re-used after the valvejob. I take a simple C-clamp and squish all of them down at rebuild time, that way they are at zero bottom and then can expand to fit in the first couple minutes the engine runs. May rattle a bit but in a minute it's gone, and then motor runs fine.
Any Change in the Valve seat depth or Rocker arm post/ adjuster base on the head will affect the contact patch of the rocker arm "slipper " and the engagement of the valve tip to the rocker arm. Camshaft base circle diameter can alter this too. In the end you have to have All of the head components carefully matched to assure correct relationship throughout the entire rotation of a cam lobe. Any machinist/ builder that doesn't recognize these factors on the Ford 2.0 and 2.3 , doesn't deserve your money. To grasp it all, get ahold of a Copy of Dave Vizard's Book "How to Hotrod the 2.0 litre  OHC Ford."  and you will see the limitations of the engine and where building one for maximum performance, helps with a understanding of the design. This book is out of Print from HP books, but you might score one if you dig deeply enough.
Good Hunting,
rramjet
"No need on 2.0 or engine with solid lifters."
So the need to ensure rocker face alignment with valve tip is not a concern with 2.0?
Sounds like I might as well plan on cam bearings while I'm having head work done as well as line boring the bearing towers.
I was thinking about shaving a little of the head for a little compression boost, maybe .020. I have seen the warnings about shortening the head bolts if I do this. Thinking about going the stud route. Heard there are no alignment pins for the head/gasket so these would help as well as making it easier to reinstall the head.
Anything else I need to consider?
When seats are cut the valve lengths can then vary, modded even more by any work refacing tips. If the guy is sharp, he keeps a chart of how much the valve had removed to clean up, at 45 degree angle he needs to take half that off tip to keep valve the same but still grinding seat effect on head must come in there too.
Used to be a number Ford gave to check that clearance on 2.3 with hydraulic lifters, collapse lifter and then fit valve in hole with a follower and that clearance then gets measured between cam lobe and follower. It guarantees the working assembly is in the middle of the hydraulic travel of lifter for very long life. If valve now ends up being too long after the machine work the lifter runs out of internal adjustment travel while shrinking in height and holds valve open.
Pintosopher is right, the middle cam bearing in 2.0 wears like lightning. The 2.3 went to four towers to fix it but they wear pretty quick too, even a stock cam will have a wear step in them at 40,000 miles.
Here we go, I found the number, called 'collapsed lifter gap' in '80 Ford service manual and on 2.3 with hydro lifters, .040"-.050". The clearance puts the lifter seat right about in the middle of its' travel or I'm thinking around .080" total travel there.
'Cam journals in an OHC head...what a bunch of bitches.'
LOL..............you should try some hot rod inline four bikes now, them heads are swiss cheese.................
jeremysdad
If you have your head 'shaved', also have the cam journals 'align honed'. ".006" doesn't sound horrible, til you slide the cam in. ;) Cam journals in an OHC head...what a bunch of bitches. :)
rramjet
Good info. Thanks.
At this point I don't plan on anything more than a reliable funky get around car so no high lift cams or other performance stuff.
If I feel the need for more performance some day I think I would look at shoving a 5.0 in it.
Since I have a 2.0 semi race motor in mine ,a word of caution. The center cam bearing is prone to wearing out , especially with a high lift cam or long duration setup . This makes the engine nearly impossible to hold a accurate adjustment for any length of time. Add worn valve guides and it's pointless to attempt a smooth idle adjustment. Unless you replace that setup with a Needle bearing roller cam ($$$) , or at least a higher quality bearing shell for that center tower, you will be adjusting those valves a bunch.  This is one of the reasons the 2.3 engines have 4 cam bearing towers, and even when you switch them to solid adjustable rocker arm posts, they will hold an adjustment longer, regardless of Camshaft profile.
My two Horseshoes of advice,
