Pinto drive train
Date: 06/29/2018 08:32 am
78 pinto wagon
Date: 03/03/2020 01:07 pm
Wheel cap
Date: 04/25/2022 11:21 pm
Windshield
Date: 01/15/2022 09:31 pm
Great Cruise wagon
Date: 12/17/2016 03:39 pm
Date: 12/24/2016 04:13 pm
Date: 04/10/2017 07:30 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
  • Online today: 535
  • Guests: 421
  • Total: 421
2.0 Valve adjustment
Started by rramjet, August 28, 2013, 03:18:52 PM
rramjet
OK I understand. Maybe replacing the rockers if new valves are needed is something I need to consider.
The car is not a daily driver but I have put about 1200 miles on it since getting it in late June and quite a bit has been freeway. I make an 80 mile roundtrip on the freeway every Friday for another hobbly I have and it's just fun to drive and see expressions on peoples faces.
It had a crappy idle when I bought it but the PO said it needed to be timed. It kept running worse so I finally put a vacuum gage and timing light on it and needed to put a ton of advance in it to get it to idle decent but then it started surging on the freeway. Thought initially the timing belt was off a tooth but set everything on TDC and it was good so checked the valve adjust next and wa la.
It is going to our Winter place in AZ and will stay there from then on as a 2nd car.
Thinking I will get head work done here before it goes down. I know more about places here that can do it.
While this goes back to my Datsun 510 days more than Pinto, I think he is referring to the geometry of the rocker arm and the valve tip.  If they get too far out from the intended design the contact point at the valve can be too far off center.
I know on the Datsun motor, in addition to adjusting lash, a cam change potentially required different thickness "lash pads."  The pads sat on top of the valve  stem (held in place by the retainer).  Dykum dye would be put on the rocker contact point and the lash pad.  The goal was to have the fulcrum action as close to the center of the tip as possible.  Again, just a guess, but I think it is what he meant.
Frankly, I'd just drive the car and enjoy it.  Is it a daily driver?  If not, the wear/tear will probably be minimal.  I have three (running) "collector cars" (albeit, cheap ones).  I doubt I get more than a few hundred miles on each every year.  Thankfully the "Rat Rod" has made concept over condition acceptable these days.  Otherwise I'd go broke.
Tom
rramjet
Now to find someone who can do a decent job on a 40 year old head.
I'm not sure I understand the valve tip check. Is it needed because the hardened seats don't necessarily all sit at the same depth or variations in valve stem lengths or???
Yep, I went to getting 12,000 miles max highway miles at the last with '74 model head. The exhausts just sink like a b-tch. Run them a bit loose to get a bit longer between settings, and once you set them if you take the engine out and run the crap out of it you will get a small amount of exhaust seal back. The semi-molten condition of exhaust run like that lets the seat material flow a bit to fill carbon dents and pits.
Ain't no way around it, if you want a 2.3 to last in today's fuel climate you have to have hardened exhaust seats. The valves sold now work fine if you can get seats in there and correct. And when done the whole thing needs to be put together long enough to check and adjust the valvetip height so that it stays right with hydraulic lifter guts, otherwise the valve can be held open on a new rebuild. People used to make that mistake all the time back when I was running them to make engines that wouldn't run right at initial startup. The mechanics of the day all pronounced the engine as 'funny' and hard to 'get right' for long life, the only trouble I had was after fuel started dropping lead out, the more they dropped the shorter the heads lasted. If not for that the heads would've been bulletproof.
jeremysdad
Quote from: rramjet on August 28, 2013, 06:09:45 PM
I visited Harbor Freight and got a set of Metric crows feet 3/8" drive. The 19mm worked fine to break the lock nut loose. In most cases I could actually turn the adjusting nut by hand but used a small crescent wrench, (adjustable metric), if I couldn't do them by hand.
I found the best way for me to tighten them was to find the exact clearance then back the adjuster off about an 1/8 turn, tighten the lock nut snug by hand while holding the adjusting nut then tighten the lock nut with the wrench. Usually the adjusting nut turned just the right amount but not always so there were many repeats. A PIA job!
I really didn't look carefully at wear on the cam lobes other than to see that they didn't appear flattened but it seemed that the only shinny part was the top of the lobe.
As I said the car runs so much better now but I'm holding my breath to see how long it lasts.
I can tell you from experience...save for a valve job. :) lol
rramjet
jeremysdad
"Also thinking tight exhaust valves might be a sign that the seats/valves are recessing into the head."
Yes.
"BTW, I found getting the nuts loose for the adjuster to be a real pain. Some were difficult to get a wrench on and rotation was limited.  Anyway, I hope your test drive provided good result."
Agree with all of the above. I bought stubby wrenches (from Lowe's, but any stubby should be fine), and haven't had to mess with vice-grips or adjustables again. ;) Best 15 bucks I think I've ever spent.
Also, Ford spec is, I believe, to adjust every 12k miles. I do mine every 2 oil changes and clean the oil bar (carb cleaner) for sanity's sake.
I set them like I set points on engines with 2 screw points: I.e., I set them just slightly loose, so that tightening the lock nut brings them to spec ( always verify with the feeler gauge, never assume). Personally, I have found trying to hold both wrenches to be damn near impossible, except for when I set them on the bench before reinstalling the head (no intake/carb in the way).
One final note: Chilton's is wrong, they're metric (15mm/19mm). However, they are correct in stating that slightly loose is better than slightly tight. I'll take noise over head-work any day. :)
OP: By chance did you note the condition of your cam lobes? On a mechanical valve train, they should not be shiney all the way around, there should always be some Parkerization near the base (round) of the lobe. Also, your motor should always sound (lightly) like an old Singer sewing machine. ;)
As always, ymmv, and feel free to correct. :)
rramjet
Adjustment made a dramatic improvement. Actually got the vacuum gage in the middle of the green now and the timing is no where near as advanced as it was. I actually timed it with the vacuum gage. Too lazy to pull out the timing light.
I really do believe the exhaust seats/valves are probably receding into the head and I'm guessing if I keep making freeway runs at 70+ they will continue to do so.
I'm contemplating a head rebuild but will see how long the adjustment lasts.
Before I went 2.3 Turbo I had a similar experience with my 2.0.  I got the car at 86,000 and after a valve adjustment my compression also improved.  I think some of my cylinders were well below 100 lbs and after the adjustment they were in the 125-140 lbs range.  Seat recession is about the only thing I can think that would cause lose of clearance.  My engine smoked faintly and I'm wondering if exhaust valves getting hot (or the constant blast of leaking exhaust) damaged the seals.
Tom
rramjet
Taking a break after adjusting the valves on my 73 with a 2.0 and 95K miles. Found all of the Exhaust valves were really tight. Probably explains the crappy idle and lousy performance. I've read elsewhere that the valves on these things need regular adjustment but not sure how often that should be. I have no idea when and if they were ever adjusted before. I'll probably be lucky if I don't have any burnt exhaust valves. Helps explain the low compression readings 130 lbs I was getting. I had thought it was because I did not block the throttle open before doing the check. Didn't do a leak down test yet.
Heading back out to reassemble everything and see what it runs like.
