Date: 12/24/2016 04:13 pm
Great Cruise wagon
Date: 12/17/2016 03:39 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
nos core support
Date: 01/03/2020 09:39 pm
Date: 02/21/2017 06:29 am
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
  • Online today: 452
  • Guests: 256
  • Total: 256
Holley 5200 idle jet size...curious.
Started by jeremysdad, August 21, 2013, 12:08:56 PM
Yep it makes sense and I know how it works just didn't word it right I guess, but basics are the same though just more adjustability with the Weber which makes them superior over most carbs.
jeremysdad
Quote from: 74 PintoWagon on September 03, 2013, 11:33:51 PM
Is the idle circuit lean also?, changing the idle jets only affect the idle mixture at idle, you only need to change those if you can't get an adjustment on the mixture screw, once the butterfly is past the transfer slot you're on the main and the idle jets have no effect.
My brain is too tired to process the thought it is trying to get out, but in a Weber-designed carb, the progression holes (first ones uncovered if you flip it over and look just above the mixture screw) is also fed by the idle jet. I had a page with an illustration, but forgot to bookmark it. Thus the "speed screw open no more than 1 to 1&1/2 turns, mixture screw no more than 2 turns out" rule. The speed screw too far in is fudging a too lean idle jet by uncovering the progression circuit (and causes a flat spot when you tip in because you are idling on your enrichment circuit).
Does that make sense?
Eta: What you said is spot on for a standard Holley-design carb (your typical Motorcraft/Autolite carb, etc).
Eta 2: Not exactly what I was looking for, but shows the circuit pretty well. Notice how the hole right above the throttle plates are fed from the channel that feeds the idle mixture screw. https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&docid=VFqNCfVDaDhFKM&tbnid=W3T5fTYa4xV2BM:&ved=0CAUQjRw&url=http%3A%2F%2Fwww.webercarburatori.com%2F%3Fp%3Dhandbook%26s%3D2&ei=25gnUrORB8rC4AO1kIDYDQ&bvm=bv.51495398,d.dmg&psig=AFQjCNFnNmr0FiMJQYyPBuuIo-XrNUgIWA&ust=1378413057600345
I'm not too bad at chasing jetting. I swapped all 4 jets because the NOS carb was running lean & all 4 jets were smaller than my stock carb. It's not AS lean now but it's still lean. Putting the smaller air corrector jets that came with the NOS carb back in & leaving the larger 36 year old fuel jets in place should richen the mixture. My plugs are white & ashy.
jeremysdad
So, I remembered why my brain said 'It needs more fuel.' All the gas around here that you can find anymore is E10. Now, as we all (should know), adding ethanol to your gas sounds good (in theory, but not really), but it decreases fuel mileage. Why? Less potential energy. Modern vehicles can compensate for it on the fly, but we have to adjust through tuning. Have you ever read the jetting specs for an alcohol powered drag car? They're HUGE!!!
That's all I wanted to say. Hope everybody's having a great Labor Day weekend!!! :D
Keep it between the ditches. :)
Quote from: Pinto5.0 on August 29, 2013, 09:06:58 PMOh OK, so if I install the smaller pair that came with the carb combined with the larger fuel jets I installed from the stock carb it should richen it up. I swapped all 4 assuming they were all fuel related. I forget the sizes but all 4 stock jets were larger than the jets in the NOS carb.
Probably time to go back to square one and start over, and only "one" change at a time, shouldn't really have to change the air bleeds unless you did extensive mods on the motor?. . Don't know if you seen this before but this explains how the different circuits work, it is pretty simple.
http://www.thesamba.com/vw/archives/manuals/holley_carburetor/Holley_5200_Carburetor.pdf
Believe me, unless you have STRONG reason to and are a tuning guru, you do not want to change any AIR jet on a carb. Not as simple as fuel changes, and much harder to understand the effect. Changing a fuel jet pretty much richens everywhere, change an airjet or emulsion tube and you change the entire CURVE of fuel, say low fuel at low rpm to high fuel at same rpm but the same fuel amount further up the range. The change is NOT equilateral across the whole spectrum of the jet use at all. Think of a steep ramp as versus a shallower one, but with same fuel at the top, or same fuel at the bottom. Now take that steep ramp and grab it in the middle and yank it one way or the other, what airjets and emulsion tubes can do. You can get lost there so fast it's not funny.
When you have a carb pretty much dialed in like stock ones are you are dollars to donuts miles ahead by changing fuel jets only.
Say I have car that runs too lean at less rpm and too rich at higher, all at WOT so mainjet only, how would you correct it? Think about it. Oh, and I took the power valve away from you too..............................
jeremysdad
It is a Weber. Define 'top', Good Sir. The two you can't see without removing the air cleaner are your 'air correctors'. The one you can see without removing your air cleaner is your Primary Idle jet. The one you have to crook your head around your valve cleaner...well...that's your secondary idle jet, and that doesn't come into play until over 2200 rpm.
The two under your 'air correctors' are your 'emulsion tubes', which everything I have read says should not be touched unless you are an air/fuel ratio meter. :D lol
If it doesn't fit this: Speed screw less than 1 & 1/2 turns from not touching, and mixture between 1 & 1/4 to 1 & 3/4 turns from bottomed, then your Weber isn't jetted correctly.
Quote from: 74 PintoWagon on August 29, 2013, 08:40:00 PM
The ones on the top are the air bleeds.
Great, so there's no way to put smaller air correctors in to richen it up? That means drilling my fuel jets
Yes they flow fuel for the idle circuit.
I can tune Weber IDF's with my eyes closed but my 5200 was a 1st time attempt. I know the fuel jets are the ones in the bowl submerged in gas but are the 2 upper jets for air or are they fuel as well?
Yep, points to electronic is like night and day..
Man I converted my points to electronic long ago, and a mistake not to. The engine just runs so much longer and smoother the whole way. As soon as I found junkyard parts it was done.
Hot ignition clears up a lot of perceived carb troubles. When you put a suddenly hot firing ignition on you can experience a need for slightly more fuel when the hotter spark burns all you have and asks for more. MANY erratic but perceived as incorrect jetting issues can be solved with electronic ignition.
Well, don't have no emissions here so I'm lucky there, distributor is crap so I'm gonna ditch the points and go HEI, may not even have to do anything to carb after that, lol..
jeremysdad
Quote from: 74 PintoWagon on August 27, 2013, 08:19:29 AM
Thanks, I just found that site last night.. Of course the ignition is crap so I probably should fix that before messing with the carb, LOL..
Definitely do replace your ignition first. That's what led me to my belief that I need slightly more richness. (Which, I had wondered, as Chiltons states that one of the emissions features for 72 is an 'Emissions-rated carb'. Then after my discovery that my random miss was distributor cap related, and general running condition was still yet improved by a fresh set of plugs and wires (both under 7000 miles/12 mos in age) this weekend, it's evidently lacking something.
My list of fresh ignition parts: distributor, points (new), condensor (new), rotor (new), coil, wires (new), plugs (new). All gapped and set according to spec, timing set to 8 degrees, verified no vac leaks, new cam, fresh head rebuild, etc. Also new within 7000 miles: thermostat, coolant system hoses, radiator flushed, battery (new, with fresh connections).
Beyond that, it needs more gas. :) Thoughts welcomed, but carb and tuning parts on the way, anyway. Cause shiney is good!!! :)
Quote from: amc49 on August 27, 2013, 08:09:31 AM
Should help.............go down just past halfway to 'Holley 5200 jets' section.
http://www.mazdatrucking.com/B2200/5200.html
Quote from: amc49 on August 26, 2013, 07:50:46 PM
Two listed there, 6655 and 6655-1, both show Ford Pinto 2.0L MTX and for 49 states not California. Both use pretty much same hard parts.
primary idle fuel jet 60
secondary idle fuel jet 80
primary main fuel 137
secondary main fuel 135
And yes, the number spread seems reversed from the last set given. I triple checked to be sure of what catalog says. I have found this in junkyard carbs before too. The fuel jet depends upon the airjet, you can have a smaller fuel jet and still flow more fuel. The airjet determines the draw on the main fuel jet and same exact main fuel jet can be made to supply more or less fuel.
There are some carbs where the idle fuel jet is blocked off and not installed either front or rear, for reasons of their own the OEM using that carb wanted to make sure it was harder for people to mess with emission settings. There will be an idle jet somewhere as you MUST have one, but pressed down inside a channel so hard to find and mod. Or they may be looking at costs savings of drilling, tapping more holes too. Them guys will throw a party over one hole saved on 50,000 cars, and someone will probably get a bonus for finding the cost saving.
Thanks much for the info, I looked at the idle jets and can't see any numbers on them, are those numbers hole sizes?, the main jets don't have anything on them either but the hole size was .050 and .055??, and the high speeds have 70P and 90S. I know the idle jets need to be changed since the idle mixture screw is barely a 1/4 turn out and still don't idle quite right.
Scott Hamilton
Excellent information AMC- Really good hard to find stuff!
Quote from: amc49 on August 24, 2013, 10:33:34 PM
That one shows original application was a '72 Pinto 2.0L ATX
Primary idle fuel jet 55, secondary 50.
Main fuel jet 132 primary, secondary 135.
Note: the catalog is messed up on the idle jet positions. It calls the key number out for primary but is indicating the secondary position in the carb breakdown picture. Vice versa for the other one. The actual numbers I gave you may be right anyway, if they were input into catalog from a simple list instead of that same mis-translation of the call out pic. They WILL be right for values, just may be mixed up as to the position. Five million numbers in a catalog, sooner or later somebody had to fudge up somewhere............
Thinking the primary slightly bigger to have reserve for the curb idle screw, two fuel circuits on the primary side, only one on the secondary. You also want the one with the adjustment screw slightly bigger so that you can go slightly rich with the screw as an indicator you've gone too far, it helps when setting the screw. I'd be going with the 55 in primary..............
From the 'Holley Carburetor Illustrated Parts and Specs Manual' dated 1975, I bought mine around '78 or so.
Would you happen to have the specs for R-6655?, I can't find anything on it, it was on the car and I'm sure it's not what came on there originally. Thanks..
jeremysdad
Your stuff, your choice as always Daddio...................
jeremysdad
I'm aware of 'Racetep', but they're not on eBay. I figure with a brand new 32/36, my current state of tune, and a tuning kit...we're walking in high cotton.
Five minutes of research on the web says I'm wrong. Appears Holley and Weber used same nomenclature for jets. Kit should work but I didn't find the main sizes supplied in it, only three may not help.
Kit a bit high to me, I wouldn't use half of it. Once the air jets are locked in, rare to need to change them. I like separate stuff, of course the shipping can kill you............
http://www.racetep.com/weberX.html#jets
Long shot there.................been a long time since I went looking for Pinto jets. I'd bet the numbering could be different, and changing to a Weber was a mistake in my day, they had no power valves and absolutely sucked for mileage as a result. Of course now that could be different. The lack of a PV will surely tilt the jet package. No PV means the main must get much bigger.
I know what the conventional wisdom says, but I carefully drilled by hand when I wanted bigger jets back in the day, and had no trouble at all. Had a Holley chart showing the absolute hole sizes of marked jets. A few overlapped by virtue of the finish being different on same hole size but the ones I drilled (using a modeler's pin vise) showed more fuel when used.
jeremysdad
jeremysdad
You, Kind Sir, have my sincerest thanks. That was spot-on what and where my jets are. Now I know what to shop for in a tuning kit, size-wise.
Kudos. Seriously, kudos.
Edit: Lol. Everybody's human. Mistakes happen. :)
