1976 Pinto
Date: 10/24/2017 02:00 pm
Date: 11/02/2019 10:25 am
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Date: 12/04/2018 07:40 pm
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 08/05/2018 01:58 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
  • Online today: 531
  • Guests: 168
  • Total: 168
Holley 5200 idle jet size...curious.
Started by jeremysdad, August 21, 2013, 12:08:56 PM
That one shows original application was a '72 Pinto 2.0L ATX
Primary idle fuel jet 55, secondary 50.
Main fuel jet 132 primary, secondary 135.
Note: the catalog is messed up on the idle jet positions. It calls the key number out for primary but is indicating the secondary position in the carb breakdown picture. Vice versa for the other one. The actual numbers I gave you may be right anyway, if they were input into catalog from a simple list instead of that same mis-translation of the call out pic. They WILL be right for values, just may be mixed up as to the position. Five million numbers in a catalog, sooner or later somebody had to fudge up somewhere............
Thinking the primary slightly bigger to have reserve for the curb idle screw, two fuel circuits on the primary side, only one on the secondary. You also want the one with the adjustment screw slightly bigger so that you can go slightly rich with the screw as an indicator you've gone too far, it helps when setting the screw. Of course there are carbs where that reverses so go figure..........
From the 'Holley Carburetor Illustrated Parts and Specs Manual' dated 1975, I bought mine around '78 or so.
jeremysdad
R- 6309 - 3 is the number on the baseplate.
jeremysdad
I'll go look in a sec, that would  be great!
On an unrelated side note, this is the first car I've ever had that actually still had the metal id tag on it. Lol.
To OP, if you can give the R-(XXXX) number off the bottom flange of the main body, I may well be able to supply factory Ford fuel and air jet sizes out of the Holley Spec catalog. The Ford carb tag not of any use here. The Holley book should spec every 5200 made by them. Any carb made by them starts with 'R'.
Because the main idle feed hole with adjustable needle is up front. The back only needs a small hole to feed the transfer only, no curb idle hole in back. The transfer need a little bit of feed so that it is active when the back barrel first cracks open, the transfer is the accelerator pump there. Like regular Holley 4 bbl., the back gets less idle flow.
It can get wonky sometimes though. When they start searching to lower emissions they do all sorts of crazy things. The fuel flow not set by the jet alone, all systems have an airjet that bleeds air into the fuel to make it lighter and react quicker. If they increase the airjet, they can increase the fuel jet too but it could still flow LESS fuel than before. One of those weird things. On pulling done ANY 5200 I ALWAYS mark all jet positions on a piece of paper for future reference. Some are backwards as compared to others. I'm talking known factory built carbs not torn into by anyone before.
Why you do NOT want to mix up the airjets either.
I remember once pulling apart the 5200 on my Mustang II long ago when car just totally spit its' guts out and stranded me. Pulled a long piece of looked like yarn out of the fuel bowl and wondering 'how on earth that got past the filter?'. Like a 4 inch long piece. Just crazy.
jeremysdad
I found my flat spot last night when I pulled the idle jets to check while installing my shiney new K&N breather assembly. There was a tendril of teflon tape covering the hole in the end of the primary idle jet. Who knows...cleaned the passage with carb cleaner, and voila, purring like a kitten. :) After researching, the larger idle jet goes in the primary side, which seems contrary from an American mindset, but it works when you consider that the main circuit doesn't come into play until 3000 rpm or so. Info sourced directly from Weber.
The flat spot can commonly be caused by less than adequate accelerator pump shot too. If you can turn idle set screw both in and out and motor runs rougher either way then you are big enough on the idle jet. Pay particular attention to when you screw it OUT, or CCW direction. The lean out, or CW shows up more obvious than the over-richen, lean out will die but too rich may just get rough and not die. If you get rough going rich with screw then you're right as far as idle jet size. The richness will show up less on later models since they started necking back on the hole to hit idle emission specs.
You can always drill the hole bigger but you can't go back after doing so. I used to pick up extra idle fuel and air jets out of the junkyard just to have tuning parts. Pump shooters too.
If the carb has been set up to where the throttle blades are deep in the transfer slots or holes then your flat spot too, they should be set so that the blade or butterfly just begins to expose hole or slot there. The slots/holes act as miniature accelerator pumps themselves, if already exposed then no more fuel addition possible when the throttle is cracked open, and again the flat spot.
jeremysdad
Reading about the Holley 5200 around the internet, I have come across info that the famous 5200 Pinto flat spot is quite likely a too-small primary idle jet.
I remember swapping mine from primary to secondary and vice-versa last year when I was trying to limp it on 2.5 cylinders, but can't remember if I swapped them back.
Can someone with an early 2.0 look at their primary idle jet and tell me what size it is? They're the large brass screws toward the top of the carb, one on the driver (primary) and one on the pass (secondary) side.
Thanks, guys and gals! :)
