Date: 03/17/2019 10:15 pm
Date: 09/22/2020 11:33 pm
Interior Parts
Date: 08/07/2017 03:59 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Rear Bumper
Date: 07/26/2021 01:08 pm
Date: 12/09/2018 11:35 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 12/10/2017 01:14 pm
  • Online today: 1,459
  • Guests: 1411
  • Total: 1411
5200 to Webber Conversion
Started by Scott Hamilton, August 18, 2013, 01:39:33 PM
jeremysdad
jeremysdad
My Google research says they do have a high speed enrichment circuit. :)
Carb is installed with the prior stated jettings. It smells just a touch rich, but I have yet to play with the ignition advance. ;) And it is really happy. :) And set at, I believe...appx 3/4 turn on the air screw and 1 & 3/4 on the mixture screw.
Electric choke is AWESOME!!!!!! :D lol I'll report back with the Gates part number pre-molded hose I used to do that (smartly circumvent the water choke) tomorrow. Also, this conversion needs a fuel pressure regulator. Anymore than 3.5 psi, and a Weber will puke gas into the fuel bowl.
A 5200 has a small orifice in the 5/16 inlet, a Weber doesn't. :)
No, not power or enrichment valve, not part of main jet circuit either. A separate very high speed only circuit that works only at high airflows. The discharge for the fuel is way up high around the choke plate. No screw in jet parts for it, part of casting and not shown in Holley pics. Intended to make up for the high speed lean out that four cylinders go through when they begin to show reversion at high rpm.
If you pull top cover/choke housing, there may be a brass dowel in one port there on bottom surface, thinking that was a restriction for it. The actual outlet is in the choke housing, thinking primary. IIRC, been a while, I seem to have misplaced my Mike Ulrich Holley 5200 book, that showed it. Outlet is high and in the bigger choke area to make sure it does not work until very high rpm. It pulls from a blank hole in fuel bowl, no jet there. There is a blank passage on both barrels IIRC but one does not get used?
jeremysdad
Quote from: amc49 on September 03, 2013, 02:30:16 AM
Does anyone know if the Weber has the high speed pullover enrichening circuit that the Holley 5200 does? The outlet for it is high in the carb, around the choke plates.
Power valve? If so, yes. If not, please clarify. :)
jeremysdad
Quote from: Srt on August 28, 2013, 09:39:33 PM
Never intimated that the 38/38 was an emissions rated carb.
The 38/38 would of course have dual squirters because both throttle plates open simutaneously not progressively
References to Holley and Weber were in relation to early 71 vehicles as stated.
All statements were made based on my experiences on my car many years ago in 1971 on my (stock from the factory Weber 32/36 equipped manual trans) Pinto.
Good luck sorting yours out. I know once you get there it will have been worth the 'trip'.
I was not insinuating that you were, I was referring to the 5200 vs DFEV, in particular.
The carb I received, after taking it apart, was jetted this way from the factory:
Idle jets: 55/50
Mains: 137/140
Air correctors: 165/160
Emulsion tubes: Unknown, not taking it back apart. (lol)
Tomorrow morning, it goes on with idle jets 65/70, mains 140/145. Air correctors unchanged. I'll report back.
Enjoy your 3 day weekend!!!
Quote from: Srt on August 26, 2013, 03:45:42 AM
Some early '71 cars were factory equipped with a Weber (32/36) progressive secondary carb.
Later the carbs were (are) the same. However they were manufactured by Holley with license from Weber. In my experience the early carbs , either design, were identical right down to primary and secondary main jet sizes; idle air jet and emulsion tube sizes and design,
Personal experience met with no difference on a reasonably stock motor with any idle airjet or emulsion tube changes (not sure about now, but back then an enormous combinations of idle air jet/emusion tube configurations was available). But a world of difference could be felt with no. Mileage decrease with a drill size bigger in both the primary & secondary main jets.
I never had any experience with flat spot incidents on any I used. That could very well have been due to the fact that all the cars I worked on were at the time essentially new cars. Take notice that the time period I am referring to is 1970-1973 (early.
The 32/36 IS, on the early cars, a Weber Carburetor.
If you want to wake it up (an early one that is) make sure you have a decent valve job (I used to do my own and some creative valve seat 'massaging will do wonders), a bit bigger on the main jets both primary & secondary (leave all the other ones alone) and a recurve of the distributer will work wonders without hurting mileage at all.
If you have a 'hotter' motor & still want more but wish to stay with a 2bbl carb then consider a 38/38 DGV which is darn near bolt on but has both barrels opening simultaneously .
Just my 2 cents.
I have installed the Weber 38 DGAS non Progressive on a stock 2.0L  with headers, OMG !!!!! now that's where the Torque and HP were hiding!  :P  Screw the Smog check , My 9 inches of tires went up in a smoking Blizzard!  It was soo good that I swapped complete intakes just for a Smog check for the day. I still have those goodies for when I build another street car!
Mine is double discharge too, thought about plugging the secondary side up and see what happens, can always drill it back out if it don't work but I can't see having fuel dumped on the secondary when it's closed.
jeremysdad
If you have a 'hotter' motor & still want more but wish to stay with a 2bbl carb then consider a 38/38 DGV which is darn near bolt on but has both barrels opening simultaneously.
Just my 2 cents.
Have not installed, but from visual observation, I can say: there is no drilled hole for the decel valve, the accelerator pump 'squirter' is dual-discharge vs single, and it comes (generically) jetted much richer. It may be a 'Holley, under license from Weber', but a 5200 does not a Weber make. :)
I say again: 'Emissions-rated carburetor'. :) Not the same thing.
Quote from: jeremysdad on August 27, 2013, 06:11:29 PM
Just outside of Nashville, TN. Probably should hold on to it for a week or two, though, cause this is my daily ride back and forth to work. A call of 'I'll be there in 45, I had to change my carb back out on the side of I40' is better than 'I won't be there today.' (Got to love a motorhead boss!) lol
Guess when I upgrade cams, I'll be offering the Weber up, too. lol. Do they make a 38/38 with the 'F' oval neck vs the 'G' square neck? Guess one way or the other, I can mod my K&N. :) lol
Wow quite a ways away probably be a killer on the ride, but let me know when you decide to part with it I may still get it from ya..
jeremysdad
Quote from: 74 PintoWagon on August 26, 2013, 08:02:51 AM
Where you at?, wouldn't mind having another one to experiment with.
Yeah they do seem pretty simple, not into drilling jets though it's not just the hole size it's the flow, I've seen it go both ways on that something I learned many moons ago. Friend of mine had a Falcon drag car with Tunnelport 427 with 2 4's on it, one day at the track he was running kinda lean so he decided he was gonna try drilling jets so we did and it worked, two passes and the car went faster each time, but third time 3/4 track it was a melt down and holed two pistons was that ever a surprise, (at the time I didn't know that he already talked to someone about that and he was told you don't drill jets) so he took the jets and had them flowed and they flowed less then than in their original state before the first drilling, big learning curve there,LOL. I also learned that with my injectors not to mix different brands of pills, I had the same number pill from two different brands and they both flowed different.
Yeah finding parts can be hard, but if you are willing to go the way of the drill then these are among the most tunable carbs on the planet.
If someone referring to me earlier the 2.0 I mentioned was the German 2.0 not the smaller 2.3. The one with 3 cam towers not 4.
Quote from: jeremysdad on August 25, 2013, 10:51:48 PM
Lol. Yep. Somebody should want it. I just h8 the water choke. Oh, and that whole 'not really tuneable for power' thing. You know, whatever. :) lol
Quote from: Srt on August 26, 2013, 03:45:42 AMLater the carbs were (are) the same. However they were manufactured by Holley with license from Weber. In my experience the early carbs , either design, were identical right down to primary and secondary main jet sizes; idle air jet and emulsion tube sizes and design,
Mine says that on the bottom of the float bowl.
By the way, another of my $00.02 worth; the 32/36 not being tuneable on the early cars is a bunch of crap.
Just my 2 cents.
jeremysdad
Quote from: 74 PintoWagon on August 25, 2013, 09:53:47 PM
Got a kit from a local Parts store here, if I get enough time tomorrow I should get it done. You're not selling yours are ya??..
jeremysdad
I rebuilt mine with a kit from AutoZone, but the listing has disappeared.
That being said...mine works splendidly, but it is original to my 72 auto...and it wants more gas. $20 plus shipping. :) I'm just tired of the water choke, more than anything. lol
Speaking of my 5200, not my Weber. Just so we're clear.
Got it all apart today and the two check balls were there, bowl had a bunch of crap in it so I'm sure it just needs a good cleaning.
jeremysdad
Quote from: 74 PintoWagon on August 25, 2013, 10:14:57 AM
Well, this one came with the car so I have no idea what's inside but it looks like a reman?, I'm thinking maybe the check ball in the shooter cavity is missing?..
Could be, they're there for a reason.
@Scott: I'm amazed. I ordered one last night (found it for $199 on eBay), and she hasn't said a word. I did let her ride in the car this evening...maybe it's a 'Well, it does get better every day!) man win? :) lol Also a jetting kit...I'm giving mine a little more gas. :)
jeremysdad
Mine did that when I first got it. You could look down the primary bore and there would be a 1/4" of gas sitting on the butterfly. Rebuilt it, hasn't done it since. Not sure what was wrong, but it was obviously something. lol
No flat spot on mine just drools after shut down, gonna dissect it today and see what's up and freshen er up.
jeremysdad
You need to define 2.0, Kind Sir. There are 2: The 2.0 EAO, and the 2.0 that is a Brazilian smaller brother of the 2.3. They are different, and for posterity's sake, should be defined to avoid confusion here, where we discuss the 2.0 'Pinto' and the 2.3. People get confused.
Otherwise, good info.
Wow, I drove those carbs for years and never had flat spot problems at all. But then I drilled holes a place or two in mine to change things up. Not for a flat spot though, rather to make car work well with a header.
With a Hooker header, 2.0 intake on a 2.3 motor, and some light head porting the basically otherwise stock engine made my guess maybe 130 HP and was a joy to drive with ATX in a Mustang II. Car ran right up until destroyed in a major hailstorm in '95. If you have to raise idle screw enough so that you get the throttle plate too high in the transfer slot you can easily get flat spot on sudden opening of throttle. The solution is to drop the plate back down to correct and drill a slight hole in the plate to let the extra air come in that would otherwise be going around the plate with the idle set higher to open plate further. That way you still have the full fuel supply of the transfer slot to stop the flat spot.
Older engines have slightly less vacuum and how you end up with throttle plate too far open to begin with. They need a bit more aircrack there.
