Date: 08/30/2018 12:59 am
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Date: 11/05/2020 06:32 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
Date: 07/04/2022 07:55 pm
New cam
Date: 01/23/2017 05:11 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
  • Online today: 1,972
  • Guests: 164
  • Total: 164
5200 to Webber Conversion
Started by Scott Hamilton, August 18, 2013, 01:39:33 PM
jeremysdad
Unfortunately, this would have to wait. I just dropped $80 on a K&N 56-1010 5 minutes ago (priorities, and all...the cheap Redline air cleaner I had was developing holes after 8000 miles :() Also, something about 'you work on your car all the time, but never mine' or something. :)
Any idea what they did to fix your flat spot? I'm good with my hands. :)
Scott Hamilton
Yup - flat just off idle -
You can re-engineer the 5200, I had a carb shop in Idaho do for me... It worked great and lasted until the Stampede. The Webber is even better.
Unfortunately, that classic carb shop is closed, they did great work!
jeremysdad
Funny, I just fixed a random miss (mainly at idle) that I've had for a while via replacing my distributor cap (rotor had contacted one of the terminals, causing the miss, I suspect...but I also replaced my points/condensor with NOS Ford parts at the same time, so who knows for sure), and in driving today, I noticed that while the car will get out of its own way again (and runs freaking sweet!!! :D), there is a flat spot just off idle. Is that the flat spot you refer to here?
I thank you for this info, but I assure you, my wife won't! :D lol
Scott Hamilton
Everything is exactly as the 5200 except the piece that actually touches the pinto linkage rod.
This piece pulls off your old carb and can be placed on the new. I have worked on 2300 engines when I was a teenager and 'believe' they are the same but would need someone to confirm.
cromcru
i was wondering about webber carb. having too many problems with my 5200 to wanna keep it anymore.do you think the 74 2.3 linkage will swap over easy.
DreamBean
Go Ford, Go Fast Or Go Home!
Scott Hamilton
Some of you may know I had a little trouble with my Stock Holley 5200 on the recent Pinto Stampede. Today I replaced it with a Webber I ordered online...
http://www.piercemanifolds.com/ProductDetails.asp?ProductCode=K453
- Had to change one linkage piece from the old carb and everything else was a direct replacement. If you car has water Choke or an idle solenoid, you will have a few more things to work but this was a very easy swap and the engine runs fantastic. You know that flat spot inherent to the 5200s? Just smooth acceleration with the Webber. @ $259.00 it might be cheaper than a shop rebuilding your carb and setting up.
http://youtu.be/GJIPOE1M2z4
Here is a quick video I took to send to my Brother- Running sweet!
