Date: 06/07/2021 08:14 pm
V8 rear end
Date: 04/12/2018 10:57 am
73 rear hatchback glass
Date: 07/06/2017 11:33 am
pro stock front end
Date: 06/28/2019 07:43 pm
Center armrest for 1979 pinto . Possible anyone who makes them of has one for sale
Date: 08/13/2017 02:01 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 09/09/2018 03:22 pm
  • Online today: 600
  • Guests: 273
  • Total: 273
Ugly Yellow 72 Pinto
Started by Reeves1, May 24, 2013, 06:14:52 AM
Quote from: Pinto5.0 on July 14, 2013, 04:12:27 PM
You do know what that sharp corner is going to do to the back of your hand every time you need to work back there don't you? LOL
No room back there to "work" anyway.
When I drop the V8 in, I do so without the back plate etc.
After the back of the engine clears the cross member, I bolt all the stuff on, then move it backwards into place.
Guess I'll find out......
I can feel it already. lol. :D
Primer is just to protect the metal from rust for now.
Engine compartment will be stripped/blasted in the future , after more metal work is done.
Next I'll be working on the inner fenders.....
I took into account a 351w has a higher deck (302w is 8.2" and 351 9.5").
Some of the mods will be for the next owner ?
Brake line mods will be in the future as well......
Note I raised the bottom rad hose opening up (about) 1 1/8" - in case of a 351w in the future.
Note the wire harness hole has been moved up & to the left (right in picture). It will now clear the engine head/valve cover.
V8 swaps can be made easy as well.
This yellow one had no fire wall mods.
No hood scoop .
No cut rad support.
But, I'm not one to leave well enough alone.
I wanted the engine back as far as possible, yet still have a heater (I'm in Canada - it was +5c yesterday).
I should be able (?) to mount the rad behind the support (where it normally goes).
I'll be using a short water pump & CVF pulleys.
Flygirl62
Fascinating. I think the 2000cc in my '73, which was recently rebuilt, might be the last go-round with a four cylinder.
I hate to say that, since the car runs well, and it'd be kind of sad to see all that stock-ness, which I've preserved for so long, go away.
But, on the other hand...
I've always wanted a 302 instead. Thing is, some of the street installations I've seen in the past seemed a bit severe, cutting out the entire front cross member for the radiator installation and removing the hood latch; solid motor mounts, etc.
I also thought the early Pintos weren't good candidates for the swap—clearly I'm mistaken. I didn't know a radiator would fit in front of the engine compartment on the early cars.
Top section welded in. I'll grind it after all welding is done.
Welding from the inside as well.
I'll get a better picture.
Found a picture of the heater motor alteration. I didn't do this....so no idea what internal mods had to be made ?
Quote from: OhSix9 on July 05, 2013, 10:51:21 PM
i found some blower motors at the local surplus store that are perfect for the job and less than an inch thick. pulled the metal mounting plate off the stocker and just tacked the new one in place with its mounting tabs. installs in heater box as normal.
this topic has been around for a while on various builds. if you can, some pics & part #'s would go a long way toward helping out the next guy/gal with a clean install
OhSix9
Virgil to Sid
With a 302w it clears. With my B2P the guy that originally built it cut the casing & welded a small piece back in (will see if I have a picture).
I had thought about putting a short fan motor in, & may well do that in the future due to the next engine I want. When it goes through the full resto in a few years ?
Since I'm cutting & welding, I may cut the inner fenders. The bulge where the battery is & under the brake master.
This will/should allow the room needed to run headers in a normal fashion ? I'll think on this more.
I know there is lots of room on the right.
hurm2006
when installing a 302 into my 77 i had to change to a blower motor that had a shorter motor section sticking out of the firewall to clear the valve cover. Just something to consider checking before your ready to drop the motor in
'77 Sedan:   fuel injected High Output 5.0, 5 speed, 26 MPG!!! daily driver
Quote from: Pinto5.0 on July 04, 2013, 10:11:02 AMI just wanna drive it  :'(
Well, ya know the saying about that dontcha, "if it works don't fix it"... :D :D
I am sooooo hoping my '71 doesn't snowball like that. I just wanna drive it  :'(
Funny how that works, eh !  ;D
A few simple things & it snow balls from there !
Going to move the brass brake distributor (?) up onto the inner fender, just in front of the master. Will also install a line lock. Also all new brake lines.......and all other brake parts.
New master was found & is on the way up from the USA.
So much for keeping it simple  :o
Some trim work to do yet. But it gives an "idea" on what to cut out to get the (V8) moved back as far as can be, without deleting the heater.
I will be able to move the engine back an inch farther than the B2P (BOSS 302 Pinto).
I already have the piece made for the top part. Pics later.
Picked up a tank of gas & a 10lb spool of wire for the mig.
Never welded like that before.....
Next I'll tackle the fire wall. (and that hole through the inner fender by battery)
Made some changes as well.
Moved the 2 1/2" hole for the wire harness up and to the left.
Going to move the bottom heater hose hole up & over as well.
I will also be installing a 90 degree fitting in the 2 heater hoses at the fire wall.
Hoses do not bend sharp enough.
I'll be running them sharp right, against the fire wall, along the inner fender, behind the battery (you can see where I trimmed out some of the welded on part for more clearance). Then back to the engines front right.
Weld, grind, sand blast & prime.
Battery tray in rough shape, but useable. Will be a trunk mount in the future re-build anyway. Blasted & painted.
Found & bought a set of re-built closed chamber heads for $150.00 each.
Had the rad cleaned & pressure tested : all OK.
Same for the heater core : toast.
Found a NOS one, with seals & it's on the way !
Taking the heater box (from the blue parts car) completely apart. Drilling the factory rivets out & will sand blast all the metal parts & paint. Then rivet back together.
Work is slowing things down.....
It can never be easy. There's always a problem that gums up the works.
jim72
National head service has stock iron heads all done for about $300.00/pr. Might be less money than having your local machine shop do them,  Just saying
Idea for now is to keep it as cheap as I can, but still have a "fun" car to thrash.
The engine will be for 2-3 summers. Then a complete change & scrap the 302w.
Also, I'm not sure I'd trust aluminum heads with these mounts ?
I'll be using these headers.
jim72
if you want to go iron I have a pair of 351 '69 big valve gt heads already done with manley stainless valves,135seat # springs,and manley keepers. They are set up for screw in studs. I also have a fresh pair of world products iron165cc intake runners that flow like crazy.They are 1.94" intake 1.60"exhaust  The shipping from the east coast might be steep,but I can use you right on the price.
OhSix9
I was thinking the same thing myself. Unless they are a late set of 60's or modern fuelie heads they wont flow worth a damn anyways. even something low end like the edelbrock e streets are a big bonus. modern chambers and aluminum for better ping suppression.   You're in my neck of the woods. If you are just gonna rebuild a set of iron heads i have some big plug c90e 351w heads in the shed that you can have for 80 bucks. they are cores that need doin.
Virgil to Sid
jim72
For the cost of getting your iron heads rebuilt,you could probably make a substantial down-payment on a modest set of aluminums.  Just a thought.
When I got the car home I pulled the spark plugs. #5 was so gummed up it wouldn't fire.
When I pulled the heads this cyl had a puddle of oil sitting on the piston (cleaned up before pic).
Looking at the valve seals, all were up on the valve stems. Soft yet, but wrong kind ?
Getting the heads re-built. Stronger springs. New cam etc.....
#5 is the clean one on the left. Oil & not firing made it clean.
Right side. #1 on the right.
