Hatch needed
Date: 09/10/2017 09:16 pm
Date: 09/19/2019 04:43 pm
Date: 12/09/2018 06:59 am
Date: 01/19/2020 09:06 am
Date: 02/18/2017 04:44 pm
77-78 front grill
Date: 04/07/2017 12:35 am
sport steering wheeel
Date: 10/01/2020 10:58 pm
Date: 11/08/2019 10:01 am
Interior Parts
Date: 08/07/2017 03:59 pm
  • Total Topics: 16,268
  • Online today: 162
  • Guests: 134
  • Total: 134
Ugly Yellow 72 Pinto
Started by Reeves1, May 24, 2013, 06:14:52 AM
I remember reading on this site that the AC/heater is difficult to remove.
They were right  :o
Original plan was to do as little as possible & use it as a driver till the white car is done.
When the white one is done, I'll do a ground up change to this yellow one. It will be a light weight car. I have fiberglass : fenders, air dam, bumper. I'll pick a hood up for it as well. Going to gut the car. Full color change to blue (thinking maybe like the new F-150s).
Sub frames & tubs. Narrowed 9".
The engine I've been looking at is the all aluminum 351w bored & stroked to 427 from Ford Racing. 600 HP.
Not sure on trans yet.
Engine bay as it was. Had an Autolight 2 bl carb. Had a plastic fan bolted to the water pump, ready to blow apart. Not using one after it goes back together. Just the electric one. I have no idea why, but the toggle switch to turn the electric fan on was next the battery ! I will hook it up to a 180 degree sensor.
It had motor mounts from a Mustang ll. The frame mounts had only one 3/8" bolt in each one ! No welds !
The original Pinto frame mounts were poorly taken out.
Plan is to weld an 1/8" plate from behind the damage , up to close to the rad support. This will give the frame rails strength all the way up for the new front engine mounts.
Sitting in my nice cool shop having a beverage, I got to thinking......I have all kinds of 302w parts.
Edelbrock Performer RPM intake & 600 cfm Edelbrock carb. MSD dizzy & 6AL. Short water pump. Aluminum alt brackets & pulleys. Front engine mounts & Headman Headers. Car has an auto. No more, because I have all needed to put my T-5 into it.
One wire alt.
So I kept tearing stuff out. Note it has an AC unit. This will get pulled out & replaced with the heater from my blue parts car. As will the clutch/brake pedal unit.
Replacing the heater will give more clearance for the hoses.
When I first started the car it ran badly. Would not stay running. I could hear #5 exhaust rocker making noise.
Get it home & took the left rocker cover off. #5 had an extra jamb nut on the stud.
I had (originally) wanted to do a simple tune up & check all other items on the car so it would pass the out of Province inspection.
So I pulled the heads to check them out. They also needed new valve seals.
I have another set of heads. I'll take both sets in & get the best set rebuilt.
Don't like yellow  ;D
Loaded up & ready to leave in the AM , near Orillia Ont.
70 KM shy of Wa Wa Ont. had a blow out on the trailer. Of course, no cell service. Had to jack the trailer & take the tire off. Then unhook the trailer & drive to Wa Wa & find a new tire. It shredded due to having to drive a couple KM to a safe place to pull over. Lost a half day due to this.
I left picking this car up till May to avoid winter driving conditions & salt. ::)
