Date: 10/31/2018 12:04 pm
Date: 09/02/2021 08:21 am
Date: 08/13/2021 10:39 am
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
v8 springs
Date: 05/07/2017 04:46 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
Date: 05/15/2022 11:36 am
  • Online today: 548
  • Guests: 505
  • Total: 505
Pinto will only stay running with pumpage or choke closed
Started by MitchiePinto, October 28, 2012, 02:47:41 PM
MitchiePinto
 :) I have the car running
Disconnected the amplifier from the solenoid
Took the battery from my truck and put it in
Without pumping it started and stayed running, idle was superior and strong
Now it backfires whenever you give it gas? condensation maybe or wires or is it just cold seeing its below zero here.
It runs great with the fresh battery so from what I learned here its a charging issue.
ToniJ1960
Quote from: r4pinto on January 12, 2013, 04:43:28 PM
True... It would have to be a power lead grounding out that would cause a short to ground
Right :)
ToniJ1960
Quote from: MitchiePinto on January 12, 2013, 12:50:26 PM
Intresting, I just checked and I do not have a ground wire from the alt.
Also found no ballast resister I know its in the form of a big wire unless its hidden undercarpet or in the dash
Also found that the sound amplifier thingy in the trunk was connected to the starter solenoid which also resides in the trunk
Here I took some pics, ok well, cannot figure out how to send them on here lol
block is grounded to fender, batt is grounded to trunk body
Is the ignition module the one reading "wells" and has an aluminum body suppose to be grounded to the body, and the second module the one right above it whats with that little canister thing coming out of it?
A ground couldnt cause a short to ground.
I took a look at the pics you sent me & the cylinder thing above the ignition module is a condenser to eliminate noise for the radio. Now you said the car was charging but what was the voltage when the car was running? Also the resister wire that earthquake is talking about is off of the big terminal on the left of the starter solenoid & on my 1980 it is yellow in color. There are two of them there & they have a rubber orange thingy about two inches from the terminal itself.
MitchiePinto
ToniJ1960
Quote from: r4pinto on January 11, 2013, 04:29:20 PM
yes. The spark should be bright blue in color. Sounds like you have an ignition problem. Bad or no spark =  unhappy engine
This is interesting to know. I googled blue or orange spark to see if its true and I found someone who said they had orange spark and it was due to a short to ground from an alternator line somewhere shorting to the block and heating the block. I wouldnt really think the block would get hot this way its a lot of metal. But who knows, didnt you say your block was getting hot quick? Have you checked the voltages on the alternator output or on the battery while it was running?
MitchiePinto
Ok like 30 seconds ago I check the spark, took plug #1 out and had someone crank while I holded the plug 1/2 away from grounded metal, and the spark was good really good even at an 1" away it shot.
The spark is orange in coulour any signifiance to that?
My timing belt has hair cracks, but it does move in sigrence to the fan belt
Could not check compresson as my antique tester was stuck, but it souded like enough air was rushing past the hole
Ticking sound when turning over, goes away when running, always did it
Bumping the key usually mens the solenoid is toast but it sounds like your entire wiring harness is hacked up.
MitchiePinto
Battery does go dead after a few secs of cranking, but it will hold a charge once the chargers on it.
Alternator might be junk but it did charge when it was running, maybe not enough charge.
Il try the battery out of my trusty chevrolet
I should also mention that in the summer time I had issues with contact, like I would have to play with the key on-off till the starter kick in, it would just bump till it finally got the juice
Changed the terminals and it stopped but would keep doing it every so often.
battery is grounded to the body where it meets the passenger seat.
Il try to find motivation today, but I have a guy that wants it for a 351 v8 and rollcage conversion
Quote from: MitchiePinto on January 08, 2013, 05:35:14 PM
Just put on the 2100 and no go.  :'(
If it helps any the previous owner re-located the battery to the trunk
The battery looses energy very fast you can't keep the ignition on for more than 7-9 mins
I noticed that most of the ignition wires had splits in them
( I quess the previous owner had the issue too)
That was something you should have mentioned before. Does the battery maintain a charge or does it go dead after a few seconds of cranking? If the battery is junk & the alternator isn't charging you may not have the voltage necessary to keep the ignition running. Most electronic ignitions wont fire the plugs if system voltage drops below 11 volts.
I would set a new battery on the cowl & connect the positive to the solenoid terminal & ground the negative. Then see what happens. I'm gonna smack myself in the head if you have had a lack of voltage this whole time.
MitchiePinto
ToniJ1960
 I think I was wrong doesnt the accelerator pump squirt into the throats or whatever? Maybe the mixture screw is in too far?
earthquake
the pinto uses a resistor wire instead of a ballast resistor.Also with the block getting really hot fast have you checked your timing belt to make sure you haven't skipped a tooth or 2.Just a thought.
Quote from: MitchiePinto on January 07, 2013, 07:30:20 PM
I have electronic ignition,
I have 6.8v going to the pos end of the coil when ignitions on
OK, this sounds low but I may be wrong where Fords are concerned. I know Chrysler ran a ballast resistor on electronic ignitions to reduce voltage at the coil(to 9 volts I think) but GM ran 12 volts direct to their HEI ignition. MSD's supply the coil voltage so I'm not sure what they are putting out. I'd really like to know what's correct on Fords. If my wagon was here I'd check my voltage but I wont be able to do that for a couple weeks.
ToniJ1960
 ok I might sound stupid but ill try this one. I would think pumping the gas would just add gas to the bowl from the accelerator pump. Heres an idea, have you pulled the top of the carb off and looked to see how full the bowl is?
MitchiePinto
I have 6.8v going to the pos end of the coil when ignitions on, starter silioud is new
I think its the carb a 1.21 2150, which might be sucking too much air for my stock block minus the headers, cam etc..
Im in the process of trying to re-bush a 2100 1.08 MC from the late 80's
Car falls flat on its face once you take the choke off or stop pumping
Points ignitions have a resistance wire that cuts voltage to the positive side of the coil to roughly 5 volts. This keeps the output of the coil below 30,000 volts to avoid burning up the points. Electronic ignition coils have a higher output(42,000 V & higher) & eliminate the resistance wire & will fry points rather quickly.
The resistance wire will cut electronic coils output voltage as well but if that wire to the positive side of the coil is failing & only putting 2 or 3 volts to the coil this would cause the intermittent run issues & the electronic coil is simply a band-aid until the wire fails completely.
A simple test to check this is to run a wire with an alligator clip on one end direct from the battery to the positive terminal on the coil after unhooking the stock wire & fire up the engine. See if this eliminates the problem & if it does you will need to replace the resistance wire to fix it. Don't leave the direct hookup connected for long or you will fry the points after about 30 minutes or so. Also, don't hook it direct untill you are ready to fire it up because this can fry the points after 5 or so minutes if the engine isn't running.
allendeloura
Just a thought.  You say the car has point ignition.  I would try replacing the coil with one from an electronic ignition system. This along with changing the points again...no need to do the condenser as if it had failed you would not be getting anything.
I have experienced the same type of events before.  Motor would idle fine for a short while then she would appear to be suffreing from fuel starvation-which made no sense.  Under load on the road the motor would fall off and or backfire.  Chased these symptoms for a few hours thinking possibly a fuel issue, timing or vacuum leak(s) to no avail.  Swapped in another regular points type coil and still the same symptoms.  Then tried a coil from one of my electronic ignition cars and never had a problem again.
MitchiePinto
After tons of research I'm wondering if its my ignition timing being too far retarded.
My vaccuum gauge reads 18" hg with choke open and a little over 20" hg with choke closed
Vaccuum was steady but when the car stalls out the vaccuum drops fast normal? or ?
Car sneezes but no backfire
Its like its not igniting the fuel, just blowing raw fuel though the pipe
Block get very hot within seconds but the rad and hoses stay cool
Unless some how the distruberator moved (witch I find impossible)
Also merry christmas everyone
Any info would be great as this would be my last try before I send the car in for repairs (which is a 2 1/2 hour drive/tow )
MitchiePinto
Today I put a line to a empty can and the pump is working well with a cheap presure gauge I bought and it read roughly 8 psi.
Last time I did the intake gasket I put the gasket on wet, I did not drain the coolant and just slapped on the intake with coolant rushing out.
So im going to redo my intake the right way.
Is there any good ignition diagrams for the 1980 pinto? I have one for a duraspark system but it only shows one ignition module?, I have two box type things on the drivers side?
ToniJ1960
 I would just take it off right at the carb and run a hose into a jar and check that whole system, is gas getting to the carb or not that one check is at the end of the line so to speak. I know a lot more about troubleshooting electronics but this seems to make sense to me at least.
It shouldn't have a ballast resistor. That would cut voltage below 12 volts.
MitchiePinto
Thanks guys, Il try feeding the pump with a gas jug, then Il take a punch and go though the carb fuel filter (if first method fails)
Il check the sock in the tank
I think the coil module failing would be very rare
I have a spare dist. module that Il change first
I also have no ballast resistor, looks like the previous owner hard wired it without one
thanks for the help
Tonij1960 may be onto something. I haven't had that happen for almost 20 years but in the early days of Ethanol blend fuels the socks would melt. If the tank hadn't been filled with gas for a long time it can get rusty & that comes loose & clogs the sock as well as the carb filter. Try running a fuel line from the pump into a jug of gas to see if it helps. Pinholes in the hard line are an issue in the rustbelt.
Also try bloking off all vacuum lines from the carb & intake, especially power brakes to eliminate a potential leak.  A bad brake booster is a massive vacuum leak.
You eliminated everything besides the Duraspark box & distributor module.
ToniJ1960
 How far did you drive it the night before it started?
I had a 1979 wagon it ran ok to bring it home the next day it wouldnt stay running. I had the carb replaced, we changed the fuel pump and ignition module,fuel filter. It would go a few miles and stall out. Wait a little while it went a few more miles. We tried everything or we thought we did. It turned out to be the fuel sock the filter on the line inside the gas tank. I would blow out the line with an old bicycle pump to see if I heard bubbles in the tank and it ran ok for a few days. You just have to narrow it down pull off the fuel filter and stick a hose in a jar to see if its pumping enough gas. I waited until mine would stall then I did that and there was just a trickle.
Otherwise check to see if you smell gas like its loading up maybe. Pumping the gas is either adding more air or else its the accelerator pump adding more gas that makes a difference. Did you try changing the ignition module? I think I have a spare :)
MitchiePinto
Wondering if this is a low spark voltage issue?
I changed the mechanical fuel pump, intake gasket and siliconed the 1" rubber spacer to the intake to insure no leaks
No change so maybe its electrical?
What are some voltages, ohms and resistance tests I should be doing around the ignition system?
Replaced coil, cap & rotor, plugs & wires
