  • Online today: 548
  • Guests: 474
  • Total: 474
Pinto will only stay running with pumpage or choke closed
Started by MitchiePinto, October 28, 2012, 02:47:41 PM
MitchiePinto
I have my PVC plugged at the moment so I could troubleshoot this issue, is the PVC mandatory for idling
I can't see it being the timing off a tooth because it did run the previous day, but if all else fails il check the timing
I found that my float rod that holds the float has a lot of play in it?
Beginning to think my pinto is possessed
Back in Blue
Did you check your PCV valve to see if it is sticking.??   My 2300 was running like crap, changed that and it was fine..  Just another idea..
7 pintos and counting...
Shouldn't be cam lobes. You said it ran fine one day then bad the next.
Before spending more money chasing it I would pop the timing cover off & verify that it didn't jump a tooth or 2 on the belt. It's free to check it.
Pressure in fuel line just means the bowl was full & needle was closed.
MitchiePinto
I took apart my 2150 and found allot of sand/dirt in the metering rod and venturi cluster, socked it over night, blew it and reassembled it
Float was about 1/2 from top, so I adjusted it to 7/16 from top. Also found a vaccum leak from the right side and epoxied it.
Still no luck, still the same.
One intresting thing I found was when I pulled the fuel line off, so much pressue got contained in there that it shot gas like 6ft.... so maybe the needle and seat are stuck or not moving freely?
Also would the PV cause my car not to stay running, like is it part of the idle circuit or just used at WOT and loads
I filled the bowl with fuel though the top vent.. so even if the needle is sticking wouldn't there be enough fuel to run until the bowl empties
Intake gasket is still good, tested by antifreeze pressure test and brake cleaner while running
Maybe some bad cam lopes?
There's nothing like having multiple problems all at once. Now that the ignition is sorted it should make trackin intake or carb leaks easier. Spraying starting fluid around the intake & base of the carb should narrow the leaks down.
MitchiePinto
So now I just finished replacing the cap and rotor, my old cap and rotor had a lot of wear and tear on the metal pegs and the rotor looked rusty like.
The car still has the same issue but I can now tell that the new cap and rotor really helped, engine now sounds great and no missfiring but still wont stay running
I had a guy put his hand over the carb as I kept it running and it did not stall the car, just kept running
I think its the intake gasket
Try hosing the cap & wires with WD-40 after you check the underside for moisture. These hot/cold temp swings will yield a lot of comdensation.
MitchiePinto
Quote from: Pinto5.0 on October 29, 2012, 05:09:00 PM
Oh yeah, forgot that possibility. Crappy plug wires(ESPECIALLY damp or wet) will misfire like crazy & refuse to stay running as well.
OMG maybe maybe my car has an aborted hood alignment maybe rain dampened the inside of my distriburator cap.
Wires are still good.
MitchiePinto
Ok guys I went to napa and bought a set of autolite copper core plugs and a coil, I just finished putting them in and no luck
I gapped the plugs at .034 as factory specs
My cap is not cracked
I think it is a vacuum leak coming from under the intake manifold, from a gasket failing. Since the last couple of weeks my car has been leaking antifreeze very slowly at stand still
but it might be the thermostat housing.
My block gets very hot but the rad hoses ,rad and intake stay cold like ice cold?.... Sign of intake gasket failure ?
Need this car to stay running so I can bring it to storage
Quote from: Pinturbo75 on October 29, 2012, 02:16:48 PM
cracked distributor cap? ??? it can have the same symptoms
cracked distributor cap???? it can have the same symptoms
Quote from: MitchiePinto on October 28, 2012, 02:47:41 PM
The gas was 1 1/2 years old when I bought the car but hey it still burned and ran, thought maybe it was the bad gas so I drained it and cleaned it out and ran high test though the lines till it was clear.
You should also replace the fuel filter if you have not already, I like the clear plastic ones because you can see when they're bad.
If you tried feeding the carb by hand & got nowhere it may be ignition related. A weak coil or one that's connected backwards will limit RPM & foul plugs. Try fresh plugs & swap on a spare coil if you have one.
MitchiePinto
Not sure if its the fuel pump 5.0 but I am having some of the same issues as you described like car not wanting to go over 3000 rpm in neutral (mine cant go over 4500rpm) etc..
I tried bottle feeding the carb but no differance but I also heard they need the 3-8 psi from pump to operate correctly
I really feel like its the plug gap or plugs itself, I took some steel whool to all the plugs and burned the crude with a torch and popped them back in and the car did run on its own for 30-50 secs.
My theroy is that the 2.3L is a high compression engine and having clean plugs and the right gap is critical
Thanks starsky il have a look at that link
When the pump in my '80 was failing I had the car floored & it was bucking like a bronco at 25 mph trying to limp it home. After I pulled in my drive it stalled & would only run with my foot to the floor & wouldn't go past 3.000 rpm in neutral.
He tried swapping carbs which is why I thought fuel pump. Not every pump fails the same way but it's a simple & cheap fix I'd try before digging too deep into other possibilities. 30 bucks & an hour to swap & at least you rule it out. The new pump will tolerate the ethanol blend fuel as well.
78_starsky
hey pinto 5,  not sure if that would be a prob for if the pump was shot wouldn't he be opposite with less gas than too much?
here is a pretty good breakdown of the 2150, that gives good descriptions and explains the set ups and the theory of how this carb works.
http://tekatlarge.net/Motorcraft-2150-2V-Carburetor-theory-and-operation.php
there is 6 pages that are written in plain english.  hope this can help you set up the carb.
MitchiePinto
I had the car running great took it for a drive and parked it, then the following morning it wouldn't stay running without pumpage and wouldn't idle.
But nope still will not stay running, I also replaced the carb with a 2150 that was rebuilt....still the same thing, tried a ranger 1bbl carb and still the same thing
The only thing I changed in the car where the spark plugs, it had the stock autolite plugs that were still good but I changed them for a set of NGK iridium plugs
Could it be the plugs,gap,coil or ?
When I ran the autolites they had a slight tan on them, now with the NGKs they are black and dusty coal looking
What is the proper gap for 2.3L plugs?
Also when I had the intake off I noticed a lot of carbon build up on the block ports
There where also no vacuum leaks I checked with propane
Should the block ventilation plug be plugged into the carb all the time because I plugged the port just for trialing the issue at the moment
