Date: 02/08/2018 02:26 pm
Date: 12/31/2017 09:03 pm
Interior Parts
Date: 08/07/2017 03:59 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 12/09/2016 08:34 am
72 pinto drag car
Date: 07/08/2017 08:25 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Date: 07/21/2017 11:49 am
  • Online today: 586
  • Guests: 527
  • Total: 527
New project... 1980 Runabout
sedandelivery
Hey Matt, with all the problems you have solved on your Pintos, you are becoming a Pinto Guru or Sage whatever fits. If you come to Carlisle next year you can have the chrome grille gratis.
I have thought of a name for the car & I think I will go with Fred. Harold III is a possibility but not certain since Harold & Harold II were both sedans & this is a runabout.
Quote from: Reeves1 on June 26, 2012, 09:25:36 AM
Well that sucks !
It sure does.. Well, I haven't gotten anything else done to the car the past couple days, especially since I had a problem with the latch on my 2008 Pontiac. It wasn't the cars fault, but the operators for backing into a pole with the door. Oops. Back to the Pinto now... The car stil stinks under the hood but I'm hoping that when I clean it up with oven cleaner the smell will go away. Yes, I said oven cleaner. I have had more luck using oven cleaner to degrease an engine than I ever did using engine degreaser. I am gonna use that to clean all the old oil off the engine & engine bay. Depending how motivated I am today I will be timing the engine before I install the distributor I had in the garage.
A fire is not the way I wanted to get to page two already  :( .
Anyways, I got the engine compartment torn down & it really did a number on it. The following were destroyed by the fire:
Distributor, power steering pump, alternator, all vacuum lines, all the wiring in that area, distributor cap & plug wires. The alternator & power steering pump did not get much of the fire but the reservoir on the power steering pump shows a lot of blistering & warping so I will be replacing that. The alternator has a lot of charring & it appears the bearing & diode area got a lot of flame exposure.
Thanks. I think it's gonna set me back a little more than I would like. Gotta fix more than I thought. Just looked at the distributor & the electrical harness is all melted & nasty. Alternator harness is all bug gone, PCV valve is a plastic glob... sigh....  :-[
Sorry to hear about the fire. Hope it doesn't set you back too far....
Back in Blue
Sorry to hear about the fire!  Pinto life has it's ups and downs. Sounds like you have it handled though.
7 pintos and counting...
A day after the fire things have calmed down some. When I get off work today I'm gonna be surveying the damage & start teardown. At this point I know I need to rebuild the carb, replace the plug wires, some vacuum lines, etc.. I am gonna remove the alternator and have it checked out since there was fire damage to the wiring on it, as well as degrease the whole engine to make sure all is in good shape. Gaskets are going to be inspected & replaced as needed. Five years ago I had an engine fire on an old 85 Dodge Omni & the goal was to have the car running in a week. I made the goal, although the car didn't run all that well as I needed to do other repairs. In the case of this car I will have a similar goal, but will aim for two weeks. I do have the old plug wires from the 77, as well as some vacuum lines in the garage that I can use to patch up the vacuum system. The fuel system will be gone over to insure nothing bad happens after it's all fixed. I was hoping to drive this car to the family reunion but after this the 77 Pinto will have to do.
That's really good of you Steve, Thanks for the offer!
PM sent.
Alpine615
Oh no!
Thank God you were able to get it under control! I have an extra wiring harness from an 80, automatic, non-A/C car you can have, just reimburse me for shipping.
PM me your address if you're interested.
-Steve
1980 Runabout
That's a setback for sure, but at least your Dad's quick thinking minimized the damage!  Here's hoping it won't be TOO bad.
Had myself a setback today. I replaced the accelerator pump diaphragm & was doing some other work to the car. Tried to start it but it didn't wanna go. Finally the carb backfired & next thing I knew the engine was on fire!!!  :o  I ran to the garage & grabbed the fire extinguisher but couldn't get it working! Dad  saw me freaking out so I yelled at him that my car was on fire & to call 911. He ran outside  & ran to the back yard & got the garden hose. He got the fire out & within 15 minutes we were looking over the damage.
I now need a set of plug wires, various vacuum lines, and parts of the wiring harness repaired. We'll see what happens now.
Thanks Kim! I think it will look okay once I get the paint buffed out. The paint won't be perfect but it will work out alright for now. At least for a couple years.
Congrats on the new Pinto Matt!! Looks like it is going to buff out to be a real gem!! :D
Decided to do some cleaning on the car today. Cleaned the door panels up & the dash, as well as the windows. When the mail arrived the NOS headlight switch arrived so I started to remove the instrument cluster so I could get to it. Couldn't get it out of the car! When I was trying to remove it I heard "CRACK". I pulled the cluster too far & cracked the front of the painted plastic. Oh well, I was gonna replace that anyways since someone put an LED in there. Think for an old alarm. Decided to remove the radio to see if I can access it. Got pissed off at the radio with extra wires that were chopped from some time ago. Went under the hood & found the vacuum leak. No more idle misfire. I also pulled the plugs & checked them. Good thing I did because I found a plug that had a cracked insulator. It broke. Grabbed a spare that was in my tool box & installed it. Also went ahead & replaced the LF tire & put on a wheel cover so it doesn't look too bad. Still haven't got the fuel leak fixed. Can't even get to the dang pump. Gotta figure out how to get to it. On top of that the accelerator pump is now leaking. I have one on a spare carb that is in good shape so I will be putting it on to stop at least one fuel leak.
Gotta fix the wipers on the car. They are intermittent. Only problem is they do not have intermittent wipers installed. I think it's a bad switch since it works for a little bit but then nothing. Not completely sure though & I don't have a spare switch... I think. Gonna check my parts collection to see if I do or not.
I also wanna get those 14s off the car. Makes it look like crap with them on. I will more than likely have steel wheels on the car with 77 Pinto wheel covers on it until I decide what to do about the alloy wheels. They need center caps & a lot of work to look good.
Today I plan on getting the 77s spare tire bolted on the car so I can get that bad tire off the left front. It isn't too hot so I will probably also take care of the fuel pump as well. I have my 1985 Dodge Omni turbo that will be going in storage for a few months so I have a place to work on the 1980, as well as tear down the 77 when I am ready to do so. Right now it gets better mileage compared to my Pontiac so I will prolly fix the brakes & drive that next week. It has more gas in it anyways.
Today I played musical Pintos. I did a little polishing on the paint & then decided to get the cars switched around so I could replace the LF tire on the new Pinto. I took a battery that I knew was junk & installed it in the 77 Pinto so I could get the car running. I jump started the battery with the charger and moved the 77 out of the driveway. I had already started the 80 so I walked over to it to find it is gushing gas. I finished moving the car into the driveway, where I did a quick diagnostic & determined the fuel pump went bad. I'm not completely sure but pretty sure that to be the case. I have a spare pump in the garage that was never installed on any engine so I'm gonna install it on the 80. I really do need to get another battery so I can at least drive the 77 as needed.  Didn't get the tire changed but I was bored & took one of the spare 77 wheel covers out of the garage & put it on the 80. Doesn't look too bad.
Quote from: pintoman1 on June 21, 2012, 06:45:34 PM
looks good matt can't wait to see it at carlisle!
Thanks  ;D It's gonna take a LOT of work to get the car there at this point, yet not so much that it will drive me nuts fixing it up.
PintoMan1
1973 pinto runabout
Quote from: sedandelivery on June 21, 2012, 05:30:51 AM
Looking really good, Matt. It's amazing how the paint shined up with a little work. Good Luck with it!
Thanks! I'm thinking about getting those springs installed on this car once it is time to part ways with the 77. Still having some enjoyment with it.
Alpine615
Boooo Norm...  :)
I understand. I will have to keep looking.
1980 Runabout
sedandelivery
Quote from: dave1987 on June 20, 2012, 10:31:00 PM
Nice car Matt! I look forward to seeing this one develop as Harrold II did.
Let me know if you need anything if Fred cant get it for you. I have a lot of spae parts for my 78 and a fair amount of 79 and 80 parts on hand. Now that I have everything at the house and not in storage, I can get it out and take pictures quickly.
Thanks Dave, I think this one will be a lot of fun like Harold II was for the most part.  I will be sure to let you know if I need anything for the 80.
Quote from: Alpine615 on June 20, 2012, 10:55:59 PM
Matt,
Something else I'd be looking for would be a pair of those deluxe door trim panels. I noticed Harold II has the same ones. Can you spare the extras? If so, name your price...
Oh, and wow! What a difference a little bit of polish makes! Looking good already...
Thanks Steve! Just gotta get me some more rags now lol. Sorry, but the door panels are already claimed. Norm had first dibs on them at Carlisle when he found out Harold II might not be around. Told him I would give them to him since I don't need them for this car.
Quote from: dga57 on June 21, 2012, 12:09:44 AM
Ain't it amazing what you can do with a little polish and a lot of elbow grease?  It's looking good, Matt!
LOL, you're right about that Dwayne. I was definitely using the elbow grease on that one there. That little bit took me about half hour. Now that I know there's still some life left in the paint I can get it all shiney & not worry about a repaint right away.
Quote from: r4pinto on June 20, 2012, 09:22:14 PM
I was a bit bored at home so I went ahead & started to polish the paint to see what it would look like. I've got a little bit of the hood & cowl done, as well as most the RF fender.
Alpine615
Matt,
1980 Runabout
