Date: 10/14/2019 08:24 pm
Date: 05/28/2017 03:20 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Date: 04/21/2017 02:03 pm
Date: 03/17/2019 03:57 am
Date: 11/12/2020 08:28 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 02/18/2017 05:52 pm
  • Online today: 586
  • Guests: 251
  • Total: 251
New project... 1980 Runabout
Started by r4pinto, June 18, 2012, 09:56:55 PM
What hath the week wrought at this day of the Hump? Progress report?  The boys in the Bunkhouse want to know ;)
The battery died on me the other day, then the used battery I bought from AutoZone yesterday failed as well. Had alternator tested and starter. Both tested perfectly but the battery was low on charge. It doesn't hold a charge very well so I went to Walmart and bought a brand new battery. Started perfectly this morning but then driving to work the car lost all power. I coasted to the side of the road and put it in neutral to restart and it was running. The engine apparently regained ignition and cranked back up with inertia from the transmission ( that's my guess but not 100% sure). Last night at the gym the car started and then died. When I jiggled the ignition module connectors the car refired so I'm guessing there is a short in the module. I will be installing the new module tonight after work. Next week I am on vacation so I will be putting the car on jack stands and rebuilding the entire front suspension. We're talking new shocks, ball joints, inner and outer tie rods, and coil springs. I will get the car realigned and the tires rotated since the front right tire is feathered on the inside edge from the worn inner tie rod. I will also flush the cooling system and  change the oil while it's in the air. Only about 2300 miles since it's last oil change but might as well do it all at once.
Whatever.... progress is progress!!!  Way to go!
Dwayne :)
Or the Squeal of an English Wheel on bent steel ::)
Quote from: pintosopher on October 06, 2017, 03:19:03 PM
Ahh,  the Elevating impact of Balloon Logic in Kinetic energies...  Kaboom goes the Sonic barrier again.. Or was that the sound of a Sledge on Hatch rim? ;D
Sledge on 2x4
Not onward, but upward as in up, up, and away.
Onward, forever onward, I say...  ;)
Well the repair to the hatch seemed to work for now. I used a 2x4 and a 4 lb sledge to knock it in to shape. Might do some body patch work on the car once I get a new car and if so I will take care of the paint as well by sanding, and doing a rattle can paint job for now. The paint is junk on the car and flakes off easily so it will need to be sanded to the original color anyway before professionals paint the car, with some patch panels welded in. At least the car would look better rattle canned if done right.
It seems a simple thing like replacing the somewhat transmission fluid fouled plug on #1 has helped drastically. Last night the car ran better although not perfect and no starting problems after the car sat. Although it isn't completely correct and doing some work on the carburetor should help with that. I will address the vacuum lines at that time as well. I did however find out today the hatch leak is smaller but still there. The left four inches of the seat were wet so I have a little more tweaking on the hatch to do to get it completely sealed. Might just cut my losses and swap hatches.
And yet that was how my 77 was connected when I bought it. I'm not saying it was or was not correct however when it ran fine I had no other reason to think otherwise.
Quote from: dick1172762 on October 04, 2017, 03:36:53 PM
Off the Holly web site. Manifold vacuum is high at idle and low at wide open throttle (WOT).Ported vacuum is weak at idle. strong at cruise and weak at WOT. I have never seen a Pinto Holly / Weber carb pulling vacuum off the intake manifold. It may be the easy way, but its not the right way.
Dick , absolutely correct,  the last Car I had with a manifold vacuum dist hookup was a '55 chevy 2 bbl 265. And it wasn't using a port fitting, just the carb base. That could've been wrong but it was easy.
Pintosopher,
I need more cerebral ports in my vacuum laden brain  ::)
Quote from: dick1172762 on October 04, 2017, 03:14:29 PM
     On a car with an automatic tranie it is very hard to hear one ping because as you slow down to climb a hill and put a load on the engine, the tranie will downshift. It would have to be so bad that the engine would most likely not start to hear it ping. BTW I have seen many post about never using manifold vacuum for the disturber advance. Also I know you should never have it hooked up when setting the timing.
The 77 I had was set up the exact same way as this car so I would have no reason to think it was not correct. As for setting the timing you ASSUMED I did not disconnect the line from the distributor when setting the timing before which I did. You know what they say about assuming.
Quote from: r4pinto on October 04, 2017, 01:01:58 PM
Also I want to add one thing I noticed is no sounds of any pinging whatsoever (that I could identify anyway)
Quote from: r4pinto on October 04, 2017, 02:06:59 PM
Ultimately I want it to be as close to correct as possible. I may try to see if I can get the original carburetor to spray fuel and use it instead of the frankencarb on the car now
Ok, In the meantime, verify using the diagram, all of the emissions components present on your car. If you find wiring or pieces missing, I'll do my best to decipher the mess. 1980 isn't that much different from a 1977 , unless it's a California car.  :P If you have that vacuum controlled exhaust heat riser valve in the exhaust, make sure it's not frozen partially closed or even open too! It must have a functioning diaphragm to not allow air into the system unnecessarily, In fact, all vacuum pots must be functioning with no bleed down while checked with vacuum pump tool.
Pintosopher, Life can be lived in a vaccum, but it never sux   :-X
Quote from: r4pinto on October 04, 2017, 01:00:49 PM
So with that info I have two questions. Will having the vacuum advance hooked to intake vacuum cause some of this as opposed to ported vacuum? Is it possible that 77s had them set up that way? And last but not least how does one adjust the fuel mix on the carburetor?
Unless there is a vacuum control valve, like the throttle angle vacuum switch, or the vacuum regulator solenoid shown in the diagram I sent, any connection to the intake manifold results in full manifold vacuum to the Advance mechanism on the Dist at Idle. Ported vacuum is a low vacuum port to prevent any influence on the advance mechanism until the Butterflies move off the seat, (idle seat screw), hence limited or no vacuum at idle to prevent the spark advance from causing (dieseling) run on and why the carb has a Throttle Positioning idle solenoid.
This is why many attempts to adjust the tune are challenged if the whole equation isn't factory pertaining to components on the car.
Let me know how far you are willing to go with this relative to OEM setup...
Pintosopher, the hard way, is the one that sticks with you,
Quote from: r4pinto on October 04, 2017, 11:51:55 AM
Thanks for shooting those. The 80 had the dual converters when the 77 did not. I think the 77 was federal emissions since its carb had nothing to it. Very oddballish. Will have to make do with what is available to make it work. As for the 80 plugs... so you're saying the plugs indicate both lean and rich at the same time? I ordered a new ignition box and will also more than likely replace the distributor to see if that helps. Chasing the problem but no choice. Will also pull the carburetor, new filter, and check the float to see if that does any good
From my earliest apprenticeship as a Mechanic with 2 & 4 stroke engines. A properly tuned mixture for a 2 stroke (oil Mix or injection) is the Coffee creamed color ( insulator)for the full throttle Plug check. Any heavy soot at the rim of the plug is idle circuit richness (2 or 4 stroke)  this is for Carbureted engines as a reference. The color of # 1 indicates recent oil presence in the fuel mix (ATF?) or intake valve guide seal leakage on #1. Modern Emission controlled 4 stroke engines usually run near white  or grey at the plug insulator for Mid to full throttle. Much of this is due to calibration of Fuel injection Pre-OBD or Most OBD emissions.
In the case of a unwanted air bleed into the intake, no soot at idle, and bone white insulator with risk  for detonations (pinging) and possible engine damage under load.
That would also explain any unusual gas mileage benefit too, but seldom is present without pinging.
More variables, but in the absence of proof of a mechanical issue..  (Google Leakdown You tube videos)  this is where we are ::)
Pintosopher  The answers are out there, I want to believe, therefore I must know :o
Quote from: r4pinto on October 04, 2017, 07:20:04 AM
Oh it's beyond frustration. I'm trying to drive this thing so I don't rack up miles on a car with broken heat so I can trade it in April and it keeps acting up. I've even tried to look for vacuum diagrams to see if they were never hooked up right on the 77 but can't get a straight answer.  So I will try to describe it. The EGR line is running to the bottom port on the carburetor, and the distributor is to the intake vacuum port on the front port of the intake. Is it possible the previous owners of the 77 had it hooked up wrong? Yep. But being as I have nothing to compare to I had to hook it up the same way since it's the 77 carb on the 80.
More stuff.. PiX!
Here is a image of the 77 and later emissions for the 2.3L
Quote from: r4pinto on October 04, 2017, 09:39:47 AM
Fuel to the fire. Plug check. Cylinder one looks worse than the others. Included is the number one plug and one from number four. 2-4 all look the same. I smelled number one and it was residual transmission fluid. Will buy a new plug for the number one cylinder
Strangely enough, Your # 1 insulator is the  right mixure color (beige) for a plug check at high RPM, But all plugs showing soot around the rim which is rich At idle to 1/8 -1/4 throttle. Plain white on the insulator is a lean condition for a carbureted engine.
I did smell them before and they were fine. The only one that wasn't was the one that is apparently still fouled with transmission fluid and will be replacing it. If it were that rich the mpgs would be in the toilet and oil in the gas. I have neither. As for the float it was fine before however I will be pulling the carburetor to see what may be wrong with it.
A very rich mixture can wash the plugs off and make you think their ok. Smelling them will tell all if you look and smell after driving the car. At times they will look brand new. Most of the time the rich condition will be because by the float or the power valve.
I will dig into my Books and look for the Vacuum diagrams for both 77 & 80 and get back to you. Rich mixtures could be a sinking float in the carb bowl, allowing the fuel to pour in..
Back by 10AM PST
